W79E226APG
W79E226APG
    NUVOTON(新唐)
    LCC44
    W79E226APG
W79E226APG 数据手册
PRELIMINARY W79E225A/226A/227A DATA SHEET 8-bit Microcontroller Table of Contents1. 2. 3. 4. 5. 6. GENERAL DESCRIPTION ......................................................................................................... 5 FEATURES ................................................................................................................................. 6 PARTS INFORMATION LIST ..................................................................................................... 7 3.1 Lead Free (RoHS) Parts information list......................................................................... 7 PIN CONFIGURATION ............................................................................................................... 8 PIN DESCRIPTION................................................................................................................... 10 5.1 Port 4 ............................................................................................................................ 12 MEMORY ORGANIZATION...................................................................................................... 13 6.1 Program Memory (on-chip Flash) ................................................................................. 13 6.2 Data Memory ................................................................................................................ 13 6.3 Auxiliary SRAM ............................................................................................................. 14 6.4 NVM Data Flash............................................................................................................ 14 6.4.1 7. 8. SPECIAL FUNCTION REGISTERS ......................................................................................... 21 INSTRUCTION SET.................................................................................................................. 74 8.1 Instruction Timing.......................................................................................................... 82 8.1.1 9. 10. External Reset ..............................................................................................................89 Power-On Reset (POR)................................................................................................89 Watchdog Timer Reset.................................................................................................89 10.2 Reset State ................................................................................................................... 90 INTERRUPTS ........................................................................................................................... 91 11.1 Interrupt Sources .......................................................................................................... 91 11.2 Priority Level Structure ................................................................................................. 91 11.2.1 12. External Data Memory Access Timing............................................................................84 POWER MANAGEMENT.......................................................................................................... 87 9.1 Idle Mode ...................................................................................................................... 87 9.2 Power Down Mode ....................................................................................................... 87 RESET CONDITIONS............................................................................................................... 89 10.1 Sources of reset............................................................................................................ 89 10.1.1 10.1.2 10.1.3 11. Operation........................................................................................................................19 Response Time ............................................................................................................95 PROGRAMMABLE TIMERS/COUNTERS ............................................................................... 96 12.1 Timer/Counters 0 & 1.................................................................................................... 96 12.1.1 12.1.2 12.1.3 12.1.4 12.1.5 Time-Base Selection ....................................................................................................96 Mode 0 .........................................................................................................................96 Mode 1 .........................................................................................................................97 Mode 2 .........................................................................................................................97 Mode 3 .........................................................................................................................98 -1- Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 12.2 Timer/Counter 2 ............................................................................................................ 98 12.2.1 12.2.2 12.2.3 12.2.4 13. 14. 15. WATCHDOG TIMER............................................................................................................... 102 PULSE-WIDTH-MODULATED (PWM) OUTPUTS ................................................................. 105 14.1 PWM Features ............................................................................................................ 105 14.2 PWM Control Registers .............................................................................................. 106 14.3 PWM Pin Structures ................................................................................................... 108 14.4 Complementary PWM with Dead-time and Override functions .................................. 111 14.5 Dead-Time Insertion ................................................................................................... 111 14.6 PWM Output Override ................................................................................................ 113 14.7 Edge Aligned PWM (up-counter) ................................................................................ 116 14.8 Center Aligned PWM (up/down counter) .................................................................... 118 14.9 Single Shot (Up-Counter) ........................................................................................... 121 14.10 Smart Fault Detector .............................................................................................. 124 14.11 PWM Power-down/Wakeup Procedures ................................................................ 126 MOTION FEEDBACK MODULE ............................................................................................. 128 15.1 Input Capture Module (IC) .......................................................................................... 128 15.1.1 15.1.2 15.2 17. Compare Mode...........................................................................................................135 Reload Mode ..............................................................................................................136 Quadrature Encoder Interface (QEI) .......................................................................... 136 15.2.1 15.2.2 15.2.3 15.2.4 15.2.5 15.2.6 16. Capture Mode...............................................................................................................99 Auto-reload Mode, Counting up....................................................................................99 Auto-reload Mode, Counting Up/Down .......................................................................100 Baud Rate Generator Mode .......................................................................................101 Free-counting mode ...................................................................................................138 Compare-counting mode ............................................................................................138 X2/X4 Counting modes...............................................................................................138 Direction of Count.......................................................................................................138 Up-Counting ...............................................................................................................140 Down-Counting...........................................................................................................140 SERIAL PORT ........................................................................................................................ 141 16.1 Mode 0 ........................................................................................................................ 141 16.2 Mode 1 ........................................................................................................................ 142 16.3 Mode 2 ........................................................................................................................ 143 16.4 Mode 3 ........................................................................................................................ 144 16.5 Framing Error Detection ............................................................................................. 144 16.6 Multiprocessor Communications................................................................................. 146 I2C SERIAL PORTS ............................................................................................................... 147 17.1 SIO Port ...................................................................................................................... 147 17.2 The I2C Control Registers .......................................................................................... 147 17.2.1 17.2.2 17.2.3 17.2.4 Slave Address Registers, I2ADDR .............................................................................148 Data Register, I2DAT .................................................................................................148 Control Register, I2CON.............................................................................................148 Status Register, I2STATUS........................................................................................149 -2- Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 17.2.5 17.2.6 17.2.7 17.3 Modes of Operation .................................................................................................... 150 17.3.1 17.3.2 17.3.3 17.3.4 17.4 20. 21. 22. 23. 24. Master/Transmitter Mode ...........................................................................................152 Figure 17-5: Master Transmitter ModeMaster/Receiver Mode ...................................153 Slave/Transmitter Mode .............................................................................................154 Slave/Receiver Mode .................................................................................................155 GC Mode ....................................................................................................................156 SERIAL PERIPHERAL INTERFACE (SPI)............................................................................. 157 18.1 General descriptions................................................................................................... 157 18.2 Block descriptions ....................................................................................................... 157 18.3 Functional descriptions ............................................................................................... 159 18.3.1 18.3.2 18.3.3 18.3.4 18.3.5 18.3.6 18.3.7 18.3.8 18.3.9 18.3.10 18.3.11 19. Master Transmitter Mode ...........................................................................................150 Master Receiver Mode ...............................................................................................150 Slave Receiver Mode .................................................................................................150 Slave Transmitter Mode .............................................................................................151 Data Transfer Flow in Five Operating Modes............................................................. 151 17.4.1 17.4.2 17.4.3 17.4.4 17.4.5 18. I2C Clock Baud Rate Control, I2CLK..........................................................................149 I2C Time-out Counter, I2Timer ...................................................................................149 I2C Maskable Slave Address .....................................................................................149 Master mode ..............................................................................................................159 Slave Mode ................................................................................................................162 Slave select ................................................................................................................166 /SS output...................................................................................................................166 SPI I/O pins mode ......................................................................................................167 Programmable serial clock’s phase and polarity ........................................................168 Receive double buffered data register........................................................................169 LSB first enable ..........................................................................................................170 Write Collision detection .............................................................................................170 Transfer complete interrupt ......................................................................................170 Mode Fault ...............................................................................................................171 ANALOG-TO-DIGITAL CONVERTER .................................................................................... 173 19.1 Operation of ADC ....................................................................................................... 173 19.2 ADC Resolution and Analog Supply ........................................................................... 174 TIMED ACCESS PROTECTION ............................................................................................ 175 PORT 4 STRUCTURE ............................................................................................................ 177 IN-SYSTEM PROGRAMMING................................................................................................ 180 22.1 The Loader Program Locates at LDFlash Memory .................................................... 180 22.2 The Loader Program Locates at APFlash Memory .................................................... 180 OPTION BITS ......................................................................................................................... 181 23.1 Config0........................................................................................................................ 181 23.2 Config1........................................................................................................................ 182 ELECTRICAL CHARACTERISTICS....................................................................................... 183 24.1 Absolute Maximum Ratings ........................................................................................ 183 24.2 DC Characteristics ...................................................................................................... 183 -3- Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 24.3 AC Characteristics ...................................................................................................... 186 24.3.1 24.3.2 24.3.3 25. 26. 27. 28. External Clock Characteristics....................................................................................186 AC Specification .........................................................................................................186 MOVX Characteristics Using Stretch Memory Cycle ..................................................187 24.4 The ADC Converter DC ELECTRICAL CHARACTERISTICS ................................... 189 24.5 I2C Bus Timing Characteristics .................................................................................. 189 24.6 Program Memory Read Cycle .................................................................................... 190 24.7 Data Memory Read Cycle........................................................................................... 191 24.8 Data Memory Write Cycle........................................................................................... 191 TYPICAL APPLICATION CIRCUITS ...................................................................................... 192 25.1 Expanded External Program Memory and Crystal ..................................................... 192 25.2 Expanded External Data Memory and Oscillator........................................................ 192 PACKAGE DIMENSION ......................................................................................................... 193 26.1 44L PLCC ................................................................................................................... 193 26.2 48L LQFP (7x7x1.4mm footprint 2.0mm) ................................................................... 194 APPLICATION NOTE ............................................................................................................. 195 REVISION HISTORY .............................................................................................................. 201 -4- Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 1. GENERAL DESCRIPTION The W79E22X SERIES is a fast, 8051/52-compatible microcontroller with a redesigned processor core that eliminates wasted clock and memory cycles. Typically, the W79E22X SERIES executes instructions 1.5 to 3 times faster than that of the traditional 8051/52, depending on the type of instruction, and the overall performance is about 2.5 times better at the same crystal speed. As a result, with the fully-static CMOS design, the W79E22X SERIES can accomplish the same throughput with a lower clock speed, reducing power consumption. The W79E22X SERIES provides 256 bytes of on-chip RAM; 1/2/2-KB of NVM Data Flash EPROM; 1/2/2-KB of auxiliary RAM; four 8-bit, bi-directional and bit-addressable I/O ports; an additional 4-bit port P4 and 2-bit port P5; three 16-bit timer/counters; Motion Feedback Module support; 2 UART serial ports; 1 channels of I2C with master/slave capability; 1 channels of Serial Peripheral Interface (SPI), 8 channels of 12 bit PWM with configurable dead time and 8 channels of 10-bit ADC. These peripherals are all supported by 20 interrupt sources with 4 levels of priority. The W79E22X SERIES also contains a 16/32/64-KB Flash EPROM whose contents may be updated in-system by a loader program stored in an auxiliary, 4-KB Flash EPROM. Once the contents are confirmed, it can be protected for security. -5- Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 2. FEATURES z z z z z z z z z z z z z Fully-static-design 8-bit 4T-8051 CMOS microcontroller up to 40MHz. 16/32/64-KB of in-system-programmable Flash EPROM (AP Flash EPROM). 4-KB of Auxiliary Flash EPROM for the loader program (LD Flash EPROM). User can optionally reboot from LD Flash EPROM by pull low at either P4.3 or P3.6 and P3.7, at external reset. 1/2/2-KB auxiliary RAM, software-selectable, accessed by MOVX instruction. 1/2/2-KB of NVM Data Flash EPROM for customer data storage used. 256 bytes of scratch-pad RAM. Four 8-bit bi-directional ports; Port 0 has internal pull-up resisters enabled by software. Multipurpose I/O port4 (4 bits for 48L LQFP; 2 bits for 44L PLCC) with Chips select (CS) and boot function. Two bits bi-directional port5. Three 16-bit timers. One 16-bit Timer 3 for Motion Feed-Back Module. Motion Feedback Module - QEI decoder and 3 Inputs Capture. Eight channels of 12-bit PWM:-   − Complementary paired output with programmable dead-time insertion.   − Three modes: Edge aligned, center aligned and single shot.   − Output override control for BLDC motor application. z 10-bit ADC with 8-channel inputs. Two enhanced full-duplex UART with framing-error detection and automatic address recognition. z z One channel of I2C with master/slave capability. z One channel of SPI with master/slave capability. Software programmable access cycle to external RAM/peripherals. z z 20 interrupt sources with four levels of priority. z Software reset function. Optional H/L state of ALE/PSEN during power down mode. z z Built-in power management. z Code protection. Package: z               − Lead Free (RoHS) PLCC 44: − Lead Free (RoHS) LQFP 48: − Lead Free (RoHS) PLCC 44: − Lead Free (RoHS) LQFP 48: − Lead Free (RoHS) PLCC 44: − Lead Free (RoHS) LQFP 48: W79E225APG W79E225ALG W79E226APG W79E226ALG W79E227APG W79E227ALG -6- Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 3. PARTS INFORMATION LIST 3.1 Lead Free (RoHS) Parts information list PART NO. W79E225APG W79E225ALG W79E226APG W79E226ALG W79E227APG W79E227ALG EPROM FLASH SIZE 16KB 16KB 32KB 32KB 64KB 64KB RAM OPERATING FREQUENCY OPERATING VOLTAGE NVM FLASH EPROM PACKAGE REMARK up to 40MHz 256B + up to 20MHz 1KB up to 24MHz 4.5V ~ 5.5V 2.7V[1] ~ 5.5V 4.5V ~ 5.5V External memory up to 40MHz 256B+ up to 20MHz 1KB up to 24MHz 4.5V ~ 5.5V 2.7V[1] ~ 5.5V Internal memory 4.5V ~ 5.5V External memory up to 40MHz 256B + up to 20MHz 2KB up to 24MHz 4.5V ~ 5.5V 2.7V[1] ~ 5.5V Internal memory 4.5V ~ 5.5V External memory up to 40MHz 256B + up to 20MHz 2KB up to 24MHz 4.5V ~ 5.5V 2.7V[1] ~ 5.5V Internal memory 4.5V ~ 5.5V External memory up to 40MHz 256B + up to 20MHz 2KB up to 24MHz 4.5V ~ 5.5V 2.7V[1] ~ 5.5V Internal memory 4.5V ~ 5.5V External memory up to 40MHz 256B + up to 20MHz 2KB up to 24MHz 4.5V ~ 5.5V 2.7V[1] ~ 5.5V Internal memory 4.5V ~ 5.5V 1KB 1KB 2KB 2KB 2KB 2KB PLCC-44 Pin LQFP-48 Pin PLCC-44 Pin LQFP-48 Pin PLCC-44 Pin LQFP-48 Pin Internal memory External memory Note: 1. Minimum of 3.0V operating voltage for NVM program and erase operations. -7- Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 4. PIN CONFIGURATION 48 47 46 45 44 43 42 41 40 39 38 37 MISO, AD0, P0.0 1 36 P3.0, RXD MOSI, AD1, P0.1 2 35 P3.1, TXD SPCLK, AD2, P0.2 3 34 P3.2, INT0 SS, AD3, P0.3 4 33 P3.3, INT1 32 P3.4, T0, IC0, QEA 31 P3.5, T1, IC1, QEB 30 P3.6, WR INT2, AD4, P0.4 5 INT3, AD5, P0.5 6 INT4, AD6, P0.6 7 INT5, AD7, P0.7 8 XTAL1 W79E225 W79E226 W79E227 (LQFP 48-Pin) 29 P3.7, RD 9 28 P4.2 XTAL2 10 27 P4.3 VSS 11 26 EA ALE 12 25 VDD 13 14 15 16 17 18 19 -8- 20 21 22 23 24 Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet T2, ADC0, P1.0 BRAKE, ADC1, P1.1 RXD1, ADC2, P1.2 TXD1, ADC3, P1.3 ADC4, P1.4 ADC5, P1.5 ADC6, P1.6 ADC7, P1.7 AVDD STADC, P4.0 AVSS 6 5 4 3 2 1 44 43 42 41 40 MISO, AD0, P0.0 7 39 P4.1, T2EX, IC2, INDX MOSI, AD1, P0.1 8 38 P3.0, RXD 9 37 P3.1, TXD SS, AD3, P0.3 10 36 P3.2, INT0 INT2, AD4, P0.4 11 35 P3.3, INT1 INT3, AD5, P0.5 12 34 P3.4, T0, IC0, QEA INT4, AD6, P0.6 13 33 P3.5, T1, IC1, QEB INT5, AD7, P0.7 14 32 P3.6, WR XTAL1 15 31 P3.7, RD XTAL2 16 30 EA VSS 17 29 VDD SPCLK, AD2, P0.2 W79E225 W79E226 W79E227 (PLCC 44-Pin) PSEN P2.7, A15, SDA P2.6, A14, SCL P2.5, A13, PWM5 24 25 26 27 -9- 28 RST ALE 23 P2.0, A8, PWM0 22 P2.1, A9, PWM1 21 P2.2, A10, PWM2 20 P2.3, A11, PWM3 19 P2.4, A12, PWM4 18 Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 5. PIN DESCRIPTION SYMBOL TYPE INITIAL STATE DESCRIPTIONS EA I - EXTERNAL ACCESS ENABLE: This pin forces the processor to execute from external ROM. The ROM address and data are not presented on the bus if the EA pin is high. Note: This pin has no internal pull-up or pull-down. The pin needs externally pull-up to execute from internal APROM. For executing from external APROM, the pin needs externally pull-down. The pin state is internally latched during all reset. User needs to take note that changes to /EA pin state after reset will not be effective. PSEN O H High PROGRAM STORE ENABLE: PSEN enables the external ROM data in the Port 0 address/data bus. When internal ROM access is performed, PSEN strobe signal will not be output from this pin. ALE O H High ADDRESS LATCH ENABLE: ALE enables the address latch that separates the address from the data on Port 0. RST I L - RESET: Set this pin high for two machine cycles while the oscillator is running to reset the device. XTAL1 I - CRYSTAL 1: Crystal oscillator input or external clock input. XTAL2 O - CRYSTAL 2: Crystal oscillator output. VSS I - GROUND: Ground potential. VDD I - POWER SUPPLY: Supply voltage for operation. AVDD I - Analog power supply. AVSS I - Analog ground potential. High-Z PORT 0: Port 0 is an open-drain bi-directional I/O port. This port also provides a multiplexed low byte address/data bus during accesses to external memory. There is an embedded weakly pullup resistor on each port 0 pin which can be enabled or disabled by setting or clearing of PUP0, bit0 in A2h. The ports have alternate functions which are described below: P0.0, AD0, MISO P0.1, AD1, MOSI P0.2, AD2, SPCLK P0.3, AD3, /SS P0.4, AD4, INT2 P0.5, AD5, INT3 P0.6, AD6, INT4 P0.7, AD7, INT5 P0.0−P0.7 I/O DSH - 10 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PIN DESCRIPTION, continued SYMBOL P1.0−P1.7 TYPE I/O S H P2.0-P2.5 I/O S P2.6-P2.7 I/O D S P3.0-P3.7 I/O S H INITIAL STATE High DESCRIPTIONS PORT 1: 8-bit, bi-directional I/O port with internal pull-ups. The ports have alternate functions which are described below: P1.0, ADC0, T2 P1.1, ADC1, BRAKE P1.2, ADC2, RXD1 P1.3, ADC3, TXD1 P1.4, ADC4 P1.5, ADC5 P1.6, ADC6 P1.7, ADC7 PORT 2: 8-bit, bi-directional I/O port. This port also provides the upper address bits for accesses to external memory. P2.6 to P2.7 can be software configured as I2C serial ports. P2.0 to P2.5 also provides PWM0 to PWM5 outputs. P2.0, A8, PWM0 Tri-state P2.1, A9, PWM1 P2.2, A10, PWM2 P2.3, A11, PWM3 P2.4, A12, PWM4 P2.5, A13, PWM5 P2.6, A14, SCL P2.7, A15, SDA Note: P2.6 and P2.7 are permanent open drain pins. When access to High-Z external memory beyond 16K region, user requires to add external pull-up registers (up to 2Kohm) on these pins. This will result in slight increase in current consumption. High PORT 3: 8-bit, bi-directional I/O port with internal pull-ups. The ports have alternate functions which are described below: P3.0, RXD P3.1, TXD P3.2, /INT0 P3.3, /INT1 P3.4, T0, IC0, QEA P3.5, T1, IC1, QEB P3.6, /WR P3.7, /RD - 11 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PIN DESCRIPTION, continued SYMBOL P4.0-P4.3 P5.0-P5.1 TYPE INITIAL STATE DESCRIPTIONS PORT 4: 4-bit multipurpose programmable I/O port with alternate functions. The Port 4 has four different operation modes. P4.0, STADC P4.1, T2EX, IC2 P4.2 P4.3 Note: P4.2 & P4.3 are not supported in PLCC44 pins package. I/O S H High I/O S PORT 5: 2-bit, bit-directional I/O port. This port is not bit addressable. The alternate functions are described below: Tri-state P5.0, PWM6 P5.1, PWM7 Note: P5.0 & P5.1 are not supported in PLCC44 pins package. Note :TYPE I: input, O: output, I/O: bi-directional, H: pull-high, L: pull-low, D: open drain S: Schmitt Trigger 5.1 Port 4 Port 4, SFR P4 at address A5H, is a 4-bit multipurpose programmable I/O port which functions are I/O and chip-select function. It has four different operation modes: z Mode 0 - P4.0 ~ P4.3 is 4-bit bi-directional I/O port which is the same as port 1. The default Port 4 is a general I/O function. z Mode1 - P4.0 ~ P4.3 are read data strobe signals which are synchronized with RD signal at specified addresses. These read data strobe signals can be used as chip-select signals for external peripherals. z Mode2 - P4.0 ~ P4.3 are write data strobe signals which are synchronized with WR signal at specified addresses. These write data strobe signals can be used as chip-select signals for external peripherals. Mode3 - P4.0 ~ P4.3 are read/write data strobe signals which are synchronized with RD or WR signal at specified addresses. These read/write data strobe signals can be used as chipselect signals for external peripherals. When Port 4 is configured with the feature of chip-select signals, the chip-select signal address range depends on the contents of the SFR P4xAH, P4xAL, P4CONA and P4CONB. P4xAH and P4xAL contain the 16-bit base address of P4.x. P4CONA and P4CONB contain the control bits to configure the Port 4 operation mode. z - 12 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 6. MEMORY ORGANIZATION The W79E22X SERIES separates the memory into two sections; Program Memory and Data Memory. Program Memory stores instruction op-codes, while Data Memory stores data or memory-mapped devices. 6.1 Program Memory (on-chip Flash) W79E22X SERIES includes one 16/32/64K bytes of main FLASH EPROM for application program (AP FLASH EPROM) and one 4K bytes of FLASH EPROM for loader program (LD FLASH EPROM) to operate the in-system programming (ISP) feature, and one 1/2/2K bytes of NVM Flash EPROM for data storage. The 16/32/64K bytes Flash EPROM is AP0 bank. The default active bank is AP0. In normal operation, the microcontroller will execute the code from main FLASH EPROM. By setting program registers, user can force the microcontroller to switch to programming mode which will cause it to execute the code (loader program) from the 4K bytes of auxiliary LD FLASH EPROM to update the contents of the 16/32/64K bytes of main FLASH EPROM. After reset, the microcontroller will executes the new application program in the main FLASH EPROM. This ISP feature makes the job easy and efficient in which the application needs to update firmware frequently without opening the chassis. 6.2 Data Memory W79E22X SERIES can access up to 64Kbytes of external Data Memory. This memory region is accessed by the MOVX instructions. Unlike the 8051 derivatives, W79E22X SERIES contains on-chip 1/2/2 Kbytes of Data Memory, which only can be accessed by MOVX instructions. These 1/2/2 Kbytes of SRAM is between address 0000h and 03FFH/07FFH. Access to the on-chip Data Memory is optional under software control. When enabled by DMEO bit of PMR register, a MOVX instruction that uses this area will go to the on-chip RAM. If MOVX instruction accesses the addresses greater than 03FFH/07FFH CPU will automatically access external memory through Port 0 and 2. When disabled, the 1/2/2 KB memory area is transparent to the system memory map. Any MOVX directed to the space between 0000h and FFFFH goes to the expanded bus on the Port 0 and 2. This is the default condition. In addition, the device has the standard 256 bytes of on-chip RAM. This can be accessed either by direct addressing or by indirect addressing. There are also some Special Function Registers (SFRs), which can only be accessed by direct addressing. - 13 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet FFFFH FFH Indirect Addressing RAM SFRs Direct Addressing Only 80H 7FH Direct & Indirect Addressing RAM 64K Bytes External Data memory 00H 07FFH 16/64K Bytes On Chip AP Flash 1/2K byte On Chip SRAM 03FFH 3FFFH 07FFH 0000H 0FFFH 1/2K Byte On Chip NVM Flash EPROM 03FFH MOVX Indirect Addressing 0000H 4K Bytes LD Flash 0000H 0000H Figure 6-1: W79E22X SERIESA Memory Map 6.3 Auxiliary SRAM W79E22X SERIES has a 1/2/2 KB of data space SRAM which is read/write accessible and is memory mapped. This on-chip SRAM is accessed by the MOVX instruction. There is no conflict or overlap among the 256 bytes scratch-pad memory and the 1/2/2 KB auxiliary sram as they use different addressing modes and instructions. Access to the on-chip Data Memory is optional under software control. Set DMEO bit of PMR SFR to 1 will enable the on-chip 1/2/2 KB MOVX SRAM and at the same time EnNVM bit must be cleared as NVM Data uses the same instruction of MOVX. Refer to. 6.4 NVM Data Flash W79E22X SERIES 1/2/2-KB NVM Data block shown in the diagram on Figure 6-1 shares the same address as AUX-RAM address. Due to overlapping of AUX-RAM, NVM data memory and external data memory physical address, the following table is defined. EnNVM bit (NVMCON.5) will enable read access to NVM data flash area. DME0 (PMR.0) will enable read access to AUX-RAM. ENNVM DME0 DATA MEMORY AREA 0 0 Enable External RAM read/write access by MOVX 0 1 Enable AUX-RAM read/write access by MOVX 1 X Enable NVM data Memory read access by MOVX only. If EER or EWR is set and NVM flash erase or write control is busy, to set this bit read NVM data is invalid. Table 6-1: Bits setting for MOVX access to Data Memory Area - 14 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet ENNVM = 1 INSTRUCTIONS NVM SIZE = SRAM (1K) ADDR ≤ 1K Read access Write access ADDR > 1K 1 MOVX A, @DPTR (Read) NVM Ext memory1 MOVX A, @R0 (Read) NVM2 NOP MOVX A, @R1 (Read) 2 NVM NOP MOVX @DPTR, A (Write) NOP Ext memory1 MOVX @R0, A (Write) NOP NOP MOVX @R1, A (Write) NOP NOP Table 6-2: W79E225 MOVX read/write access destination ENNVM = 1 INSTRUCTIONS NVM SIZE = SRAM (2K) ADDR ≤ 2K Read access Write access 1 ADDR > 2K MOVX A, @DPTR (Read) NVM Ext memory1 MOVX A, @R0 (Read) NVM2 NOP MOVX A, @R1 (Read) 2 NVM NOP MOVX @DPTR, A (Write) NOP Ext memory1 MOVX @R0, A (Write) NOP NOP MOVX @R1, A (Write) NOP NOP Table 6-3: W79E226/227 MOVX read/write access destination Note: 1. A15~A0=DPTR 2. A15~A8=XRAMAH - 15 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet It is partition into 16/32/32 pages area and each page has 64 bytes data as below figure. The page 0 is from 0000h ~ 003Fh, page 1 is from 0040h ~ 007Fh until page 31 address located at 07COh ~ 07FFh. Figure 6-2: W79E225 NVM Data Mapping - 16 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Page 31 64Bytes Page 30 64Bytes 07FFH 07C0H 07BFH 0780H 07FFH | | | | | | 2K Bytes Flash EPROM 0000H Page 03 64Bytes Page 02 64Bytes Page 01 64Bytes Page 00 64Bytes 00FFH 00C0H 00BFH 0080H 007FH 0040H 003FH 0000H Figure 6-3: W79E226/227 NVM Data Mapping - 17 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PAGE START ADDRESS END ADDRESS PAGE START ADDRESS END ADDRESS 0 0000h 003Fh 16 0400h 043Fh 1 0040h 007Fh 17 0440h 047Fh 2 0080h 00BFh 18 0480h 04BFh 3 00C0h 00FFh 19 04C0h 04FFh 4 0100h 013Fh 20 0500h 053Fh 5 0140h 017Fh 21 0540h 057Fh 6 0180h 01BFh 22 0580h 05BFh 7 01C0h 01FFh 23 05C0h 05FFh 8 0200h 023Fh 24 0600h 063Fh 9 0240h 027Fh 25 0640h 067Fh 10 0280h 02BFh 26 0680h 06BFh 11 02C0h 02FFh 27 06C0h 06FFh 12 0300h 033Fh 28 0700h 073Fh 13 0340h 037Fh 29 0740h 077Fh 14 0380h 03BFh 30 0780h 07BFh 15 03C0h 03FFh 31 07C0h 07FFh [Note: Page 16-31 is for W79E226/227 only] Table 6-4: W79E22X SERIES NVM page (n) area definition table It has a dedicated On-Chip RC Oscillator that is fixed at 6MHz +/- 50% frequency to support clock source for the 1/2/2K NVM data Flash. The on chip oscillator is enabled only during program or erase operation, through EWR or EER in NVMCON SFR. EWR or EER bits are cleared by hardware after program or erase operation completed. The program/erase time is automatically controlled by hardware. Figure 6-4: NVM control - 18 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 6.4.1 Operation User is required to enable EnNVM (NVMCON.5) bit for all NVM access (read/write/erase). Before write data to NVM Data, the page must be erased. A page is erased by setting page address which address will decode and enable page (n) on NVMADDRH and NVMADDRL, then set EER (NVMCON.7) and EnNVM (NVMCON.5). The device will then automatic execute page erase. When completed, NVMF will be set by hardware. NVMF should be cleared by software. Interrupt request will be generated if ENVM (EIE1.5) is enabled. EER bit will be cleared by hardware when erase is completed. The total erase time is about 5ms. For write, user must set address and data to NVMADDRH/L and NVMDAT, respectively. And then set EWR (NVMCON.6) and EnNVM (NVMCON.5) to enable data write. When completed, the device will set NVMF flag. NVMF flag should be cleared by software. Similarly, interrupt request will be generated if ENVM (EIE1.5) is enabled. The program time is about 50us. The following shows some examples of NVM operations (using W79E226/227): Read NVM data is by MOVX A,@DPTR/R0/R1 instruction: A read exceed 2k will read the external address Example1: DPTR=0x07FF, R0/R1 = 0xFF, XRAMAH=0x07, EnNVM=1 MOVX A,@DPTR Æ read NVM data at address 0x07FF MOVX A,@R0 Æ read NVM data at address 0x07FF MOVX A,@R1 Æ read NVM data at address 0x07FF Example2: DPTR = 0x2000, EnNVM=1, DME0=0 MOVX A,@DPTR Æ read external RAM data at address 0x2000, Erase NVM by SFR register: Example1: NVMADDRH = 0x07, NVMADDRL = 0xF0, page 31 will be enabled. After set EER, the page 31 will be erased. Example2: NVMADDRH = 0x10, NVMADDRL = 0x00, invalid NVM erase instruction (address exceed NVM boundary). Write NVM by SFR register: Example1: NVMADDRH = 0x07, NVMADDRL = 0xF0 After set EWR, data will be written to the NVM address = 0x07F0 location. Example2: NVMADDRH = 0x10, NVMADDRL = 0x00, after set EWR, invalid NVM write instruction (address exceed NVM boundary). During erase, write is invalid. Likewise, during write, erase is invalid. An erase or write is invalid if NVMF is not clear by software. A write to NVMADDRH and NVMADDRL is invalid during Erase or Write, and a write to NVMDAT is invalid only during NVM write access. - 19 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 6-5: NVM data memory control timing For security purposes, this NVM data flash provides an independent “Lock bit” located in Security bits. It is used to protect the customer’s 1/2/2K bytes of data code. It may be enabled after the external programmer finishes the programming and verifying sequence. Once this bit is set to logic 0, the 1/2/2K bytes of NVM Flash EPROM data can not be accessed again by external device. Note: 1. NVMF can be polled or by h/w interrupt to indicate NVM data memory erase or write operation has completed. 2. While user program is erasing or writing to NVM data memory, the PC counter will continue to fetch for next instruction. 3. When uC is in idle mode and if NVM interrupt and global interrupt are enabled, the completion of either erasing or programming the NVM data memory will exit the idle condition. - 20 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 7. SPECIAL FUNCTION REGISTERS The W79E22X SERIES uses Special Function Registers (SFR) to control and monitor peripherals. The SFR reside in register locations 80-FFh and are only accessed by direct addressing. The W79E22X SERIES contains all the SFR present in the standard 8051/52, as well as some additional SFR, and, in some cases, unused bits in the standard 8051/52 have new functions. SFR whose addresses end in 0 or 8 (hex) are bit-addressable. The following table of SFR is condensed, with eight locations per row. Empty locations indicate that there are no registers at these addresses. CCL0 /PCNTL CCH0 /PCNTH CCL1 /PLSCNTL CCH1 /PLSCNTH INTCTRL SPCR SPSR SPDR I2CSADEN EIPH I2ADDR NVMADDRH I2DAT I2STATUS I2CLK I2TIMER ADCCON ADCH ADCL PDTC1 PDTC0 PWMCON4 WDCON PWMPL PWM0L NVMADDRL PWMCON1 PWM2L PWM6L PWMCON3 D0 PSW PWMPH PWM0H NVMDAT QEICON PWM2H PWM6H WDCON2 C8 T2CON T2MOD RCAP2L RCAP2H TL2 TH2 PWMCON2 PWM4L C0 SCON1 SBUF1 T3MOD T3CON PMR FSPLT ADCPS TA B8 IP SADEN SADEN1 POVM POVD PIO PWMEN PWM4H B0 P3 P5 RCAP3L RCAP3H EIP1H IPH A8 IE SADDR SADDR1 SFRAL SFRAH SFRFD SFRCN A0 P2 XRAMAH P4CSIN CAPCON0 CAPCON1 P4 CCL2 /MAXCNTL CCH2 /MAXCNTH 98 SCON SBUF P42AL P42AH P43AL P43AH NVMCON CHPCON 90 P1 EXIF P4CONA P4CONB P40AL P40AH P41AL P41AH 88 TCON TMOD TL0 TL1 TH0 TH1 CKCON CKCON1 80 P0 SP DPL DPH TL3 TH3 F8 EIP EIE1 F0 B E8 EIE I2CON E0 ACC D8 EIP1 PCON Table 7-1: Special Function Register Location Table - 21 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet SYMBOL DEFINITION INTCTRL INTERRUPT REGISTER ADD MSB RESS LSB CONTROL FFH - BIT_ADDRESS, - SYMBOL RESET INT5CT1 INT5CT0 INT4CT1 INT4CT0 INT3CT1 INT3CT0 xx00 0000B CCH1 CAPTURE COUNTER HIGH FEH /PLSCNTH 1 REGISTER CCH1.7 CCH1.6 CCH1.5 CCH1.4 CCH1.3 CCH1.2 CCH1.1 CCH1.0 /PLSCN /PLSCN /PLSCN /PLSCN /PLSCN /PLSCN /PLSCN /PLSCN 0000 0000B TH.7 TH.6 TH.5 TH.4 TH.3 TH.2 TH.1 TH.0 CCL1 CAPTURE COUNTER LOW 1 FDH /PLSCNTL REGISTER CCL1.7 CCL1.6 CCL1.5 CCL1.4 CCL1.3 CCL1.2 CCL1.1 CCL1.0 /PLSCN /PLSCN /PLSCN /PLSCN /PLSCN /PLSCN /PLSCN /PLSCN 0000 0000B TL.7 TL.6 TL.5 TL.4 TL.3 TL.2 TL.1 TL.0 CCH0 /PCNTH CAPTURE COUNTER HIGH FCH 0 REGISTER CCH0.7 CCH0.6 CCH0.5 CCH0.4 CCH0.3 CCH0.2 CCH0.1 CCH0.0 /PCNTH. /PCNTH. /PCNTH. /PCNTH. /PCNTH. /PCNTH. /PCNTH. /PCNTH. 0000 0000B 7 6 5 4 3 2 1 0 CCL0 /PCNTL CAPTURE COUNTER LOW 0 FBH REGISTER CCL0.7 CCL0.6 CCL0.5 CCL0.4 CCL0.3 CCL0.2 CCL0.1 CCL0.0 /PCNTL. /PCNTL. /PCNTL. /PCNTL. /PCNTL. /PCNTL. /PCNTL. /PCNTL. 0000 0000B 7 6 5 4 3 2 1 0 EIP1 EXTENDED PRIORITY 1 - EIE1 INTERRUPT ENABLE 1 EIP EXTENDED PRIORITY EIPH EXTENDED INTERRUPT F7H HIGH PRIORITY INTERRUPT INTERRUPT FAH - PNVMI PCPTF PT3 PBKF PPWMF PSPI xx00 0000B F9H - - ENVM ECPTF ET3 EBK EPWM ESPI xx00 0000B F8H (FF) PS1 (FE) PX5 (FD) PX4 (FC) PWDI (FB) PX3 (FA) PX2 (F9) - (F8) PI2C 0000 00x0B PS1H PX5H PX4H PWDIH PX3H PX2H - PI2CH 0000 00x0B I2CSADEN I2C SLAVE ADDRESS MASK F6H I2CSAD I2CSAD I2CSAD I2CSAD I2CSAD I2CSAD I2CSAD I2CSAD 1111 1110B EN.7 EN.6 EN.5 EN.4 EN.3 EN.2 EN.1 EN.0 SPDR SERIAL PERIPHERAL DATA F5H REGISTER SPD.7 SPD.6 SPD.5 SPD.4 SPD.3 SPD.2 SPD.1 SPD.0 xxxx xxxxB SPSR SERIAL PERIPHERAL F4H STATUS REGISTER SPIF WCOL SPIOVF MODF DRSS - - - 0000 0xxxB SPCR SERIAL PERIPHERAL F3H CONTROL REGISTER SSOE SPE LSBFE MSTR CPOL CPHA SPR1 SPR0 0000 0100B B B REGISTER F0H (F7) (F6) (F5) (F4) (F3) (F2) (F1) (F0) 0000 0000B I2TIMER I2C TIMER REGISTER EFH - - - - - ENTI DIV4 TIF xxxx x000B I2CLK I2C CLOCK RATE COUNTER EEH I2CLK.7 I2CLK.6 I2CLK.5 I2CLK.4 I2CLK.3 I2CLK.2 I2CLK.1 I2CLK.0 0000 0000B I2STATUS I2C STATUS REGISTER EDH 1111 1000B I2DAT ECH I2DAT.7 I2DAT.6 I2DAT.5 I2DAT.4 I2DAT.3 I2DAT.2 I2DAT.1 I2DAT.0 0000 0000B I2C DATA - I2ADDR I2C SLAVE ADDRESS EAH ADDR.7 ADDR.6 ADDR.5 ADDR.4 ADDR.3 ADDR.2 ADDR.1 GC 0000 0000B I2CON I2C CONTROL REGISTER E9H - ENS STA STO SI AA I2CIN - X000 000xB EIE EXTENDED ENABLE E8H (EF) ES1 (EE) EX5 (ED) EX4 (EC) EWDI (EB) EX3 (EA) EX2 (E9) (E8) EI2C 0000 00x0B PWMCON4 PWM CONTROL REGISTER E7H 4 PWMEO PWMOO PWM6O PWM7O M M M M - - BKF 0000 xxx0B PDTC0 DEAD TIME REGISTER 0 CONTROL E6H PDTC0.7 PDTC0.6 PDTC0.5 PDTC0.4 PDTC0.3 PDTC0.2 PDTC0.1 PDTC0.0 0000 0000B PDTC1 DEAD TIME REGISTER 1 CONTROL E5H PDTC1.7 PDTC1.6 PDTC1.5 PDTC1.4 PDTC1.3 PDTC1.2 PDTC1.1 PDTC1.0 0000 0000B ADCL ADC CONVERTER RESULT E3H LOW BYTE ADCLK1 ADCLK0 - - 22 - - - NVMAD NVMAD NVMAD xxxx x000B DRH.10 DRH.9 DRH.8 - INTERRUPT - - NVMADDRH NVM HIGH BYTE ADDRESS EBH - - ADC.1 ADC.0 00xx xxxxB Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued ADDR MSB ESS LSB BIT_ADDRESS, SYMBOL RESET SYMBOL DEFINITION ADCH ADC CONVERTER RESULT E2H HIGH BYTE ADC.9 ADC.8 ADC.7 ADC.6 ADC.5 ADC.4 ADCCON ADC CONTROL REGISTER E1H ADCEN - ADCEX ADCI ADCS AADR2 AADR1 AADR0 0x00 0000B ACC ACCUMULATOR (E7) (E6) (E5) (E4) (E3) (E2) (E1) (E0) 0000 0000B PWMCON3 PWM CONTROL REGISTER DFH 3 PWM7B PWM6B PWM5B PWM4B PWM3B PWM2B PWM1B PWM0B 0000 0000B PWM6L PWM 6 LOW BITS REGISTER DEH PWM6.7 PWM6.6 PWM6.5 PWM6.4 PWM6.3 PWM6.2 PWM6.1 PWM6.0 0000 0000B PWM2L PWM 2 LOW BITS REGISTER DDH PWM2.7 PWM2.6 PWM2.5 PWM2.4 PWM2.3 PWM2.2 PWM2.1 PWM2.0 0000 0000B PWMCON1 PWM CONTROL REGISTER DCH 1 E0H NVMADDRL NVM LOW BYTE ADDRESS DBH PWMRU Load N PWMF CLRPW PWM6I M PWM4I ADC.3 PWM2I ADC.2 PWM0I xxxx xxxxB 0000 0000B NVMAD NVMAD NVMAD NVMAD NVMAD NVMAD NVMAD NVMAD 0000 0000B DRH.7 DRH.6 DRH.5 DRH.4 DRH.3 DRH.2 DRH.1 DRH.8 PWM0L PWM 0 LOW BITS REGISTER DAH PWM0.7 PWM0.6 PWM0.5 PWM0.4 PWM0.3 PWM0.2 PWM0.1 PWM0.0 0000 0000B PWMPL PWM COUNTER LOW REGISTER D9H PWMP.7 PWMP.6 PWMP.5 PWMP.4 PWMP.3 PWMP.2 PWMP.1 PWMP.0 0000 0000B WDCON WATCH-DOG CONTROL D8H (DF) - (DE) POR (DD) - (DC) - WDCON2 WATCH-DOG CONTROL2 D7H - - - PWM6H PWM 6 HIGH BITS REGISTER D6H - - PWM2H PWM 2 HIGH BITS REGISTER D5H - QEICON QEI CONTROL REGISTER D4H - (DB) WDIF (DA) WTRF (D9) EWT (D8) RWT 0100 0000B - - - - STRLD 0000 0000B - - PWM6.1 PWM6.1 PWM6.9 PWM6.8 xxxx 0000B 1 0 - - - PWM2.1 PWM2.1 PWM2.9 PWM2.8 xxxx 0000B 1 0 - - DISIDX DIR QEIM1 QEIM0 QEIEN xxx0 0000B NVMDAT NVM DATA D3H NVMDA NVMDA NVMDA NVMDA NVMDA NVMDA NVMDA NVMDA 0000 0000B T.7 T.6 T.5 T.4 T.3 T.2 T.1 T.0 PWM0H PWM 0 HIGH BITS REGISTER D2H - - - - PWM0.1 PWM0.1 PWM0.9 PWM0.8 xxxx 0000B 1 0 PWMPH PWM COUNTER HIGH REGISTER D1H - - - - PWMP.1 PWMP.1 PWMP.9 PWMP.8 xxxx 0000B 1 0 PSW PROGRAM STATUS WORD D0H (D7) CY (D6) AC (D5) F0 (D4) RS1 (D3) RS0 PWM4L PWM 4 LOW BITS REGISTER PWM4.7 PWM4.6 PWM4.5 PWM4.4 PWM4.3 PWM4.2 PWM4.1 PWM4.0 0000 0000B PWMCON2 PWM CONTROL REGISTER CEH 2 BKCH BKPS BPEN BKEN TH2 T2 REG. HIGH CDH TH2.7 TH2.6 TH2.5 TH2.4 TH2.3 TH2.2 TH2.1 TH2.0 0000 0000B TL2 T2 REG. LOW CCH TL2.7 TL2.6 TL2.5 TL2.4 TL2.3 TL2.2 TL2.1 TL2.0 0000 0000B RCAP2H T2 CAPTURE LOW CBH RCAP2H RCAP2H RCAP2H RCAP2H RCAP2H RCAP2H RCAP2H RCAP2H 0000 0000B .7 .6 .5 .4 .3 .2 .1 .0 RCAP2L T2 CAPTURE HIGH CAH RCAP2L RCAP2L RCAP2L RCAP2L RCAP2L RCAP2L RCAP2L RCAP2L 0000 0000B .7 .6 .5 .4 .3 .2 .1 .0 T2MOD TIMER 2 MODE C9H HC5 HC4 HC3 HC2 T2CR - - DCEN (CE) EXF2 (CD) RCLK (CC) TCLK (CB) EXEN2 (CA) TR2 (C9) (C8) C8H (CF) TF2 C/ T CP/RL2 T2CON TIMER 2 CONTROL CFH FP1 (D2) OV FP0 (D1) F1 (D0) P 0000 0000B PMOD1 PMOD0 0000 0000B 0000 0xx0B 0000 0000B TA TIME ACCESS REGISTER C7H TA.7 TA.6 TA.5 TA.4 TA.3 TA.2 TA.1 TA.0 0000 0000B DDIO DISABLE DIGITAL I/O C6H DDIO.7 DDIO.6 DDIO.5 DDIO.4 DDIO.3 DDIO.2 DDIO.1 DDIO.0 0000 0000B - 23 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued SYMBOL DEFINITION ADDR MSB ESS LSB BIT_ADDRESS, FSPLT FAULT SAMPLING TIME REGISTER C5H SCMP1 SCMP0 SFP1 SFP0 SFCEN SFCST PMR POWER MANAGEMENT REGISTER C4H - - - - - ALEOFF - DME0 xxxx x0x0B T3CON TIMER 3 CONTROL C3H TF3 - - - - TR3 - CMP / RL3 0xxx x0x0B ICEN2 ICEN1 ICEN0 T3CR - - - 0000 0xxxB SYMBOL SFCDIR LSBD RESET 0000 0000B T3MOD TIMER 3 MODE CONTROL C2H ENLD SBUF1 SERIAL BUFFER 1 C1H SBUF1.7 SBUF1.6 SBUF1.5 SBUF1.4 SBUF1.3 SBUF1.2 SBUF1.1 SBUF1.0 xxxx xxxxB SCON1 SERIAL CONTROL 1 C0H (BF) (BE) SM0_1/F SM1_1 E_1 (BD) SM2_1 (BC) REN_1 (BB) TB8_1 PWM4H PWM 4 HIGH BITS REGISTER BFH - - - PWM4.11 PWM4.10 PWM4.9 PWM4.8 xxxx 0000B PWMEN PWM OUTPUT ENABLE REGISTER BEH PWM7E PWM6E PWM5E PWM4E PWM3E PWM2E PWM1E PWM0E 0000 0000B N N N N N N N N PIO PWM PIN OUTPUT SOURCE SELECT BDH PIO7 POVD PWM OUTPUT STATE REGISTERS BCH POVD.7 POVD.6 POVD.5 POVD.4 POVD.3 POVD.2 POVD.1 POVD.0 0000 0000B POVM PWM OUTPUT OVERRIDE CONTROL REGISTERS BBH POVM.7 POVM.6 POVM.5 POVM.4 POVM.3 POVM.2 POVM.1 POVM.0 0000 0000B SADEN1 SLAVE ADDRESS MASK 1 BAH SADEN1 SADEN1 SADEN1 SADEN1 SADEN1 SADEN1 SADEN1 SADEN1 0000 0000B .7 .6 .5 .4 .3 .2 .1 .0 SADEN SLAVE ADDRESS MASK B9H SADEN. SADEN. SADEN. SADEN. SADEN. SADEN. SADEN. SADEN. 0000 0000B 7 6 5 4 3 2 1 0 IP INTERRUPT PRIORITY B8H IPH INTERRUPT HIGH PRIORITY EIP1H EXTENDED INTERRUPT HIGH PRIORITY 1 RCAP3H RELOAD CAPTURE 3 HIGH B5H REGISTER RCAP3H RCAP3H RCAP3H RCAP3H RCAP3H RCAP3H RCAP3H RCAP3H 0000 0000B .7 .6 .5 .4 .3 .2 .1 .0 RCAP3L RELOAD CAPTURE 3 LOW REGISTER B4H RCAP3L RCAP3L RCAP3L RCAP3L RCAP3L RCAP3L RCAP3L RCAP3L 0000 0000B .7 .6 .5 .4 .3 .2 .1 .0 P5 PORT 5 B1H - - PIO6 PIO5 PIO4 PIO3 (BA) RB8_1 PIO2 (B9) TI_1 PIO1 (B8) RI_1 PIO0 0000 0000B 0000 0000B (BF) (BE) PADC (BD) PT2 (BC) PS (BB) PT1 (BA) PX1 (B9) PT0 (B8) PX0 0000 0000B B7H - PADCH PT2H PSH PT1H PX1H PT0H PX0H x000 0000B B6H - - PNVMIH PCPTFH PT3H PBKFH PPWMH PSPIH - - - (B6) WR (B4) (B5) T0/ T1/ ICO/QE IC1/QEB A xx00 0000B - - PWM7 PWM6 xxxx xx11B (B3) /INT1 (B2) /INT0 (B1) TXD (B0) RXD 1111 1111B PORT 3 B0H (B7) RD SFRCN F/W FLASH CONTROL AFH - WFWIN NOE NCE CTRL3 CTRL2 CTRL1 CTRL0 x011 1111B SFRFD F/W FLASH DATA AEH D7 D6 D5 D4 D3 D2 D1 D0 xxxx xxxxB SFRAH F/W FLASH HIGH ADDRESS ADH A15 A14 A13 A12 A11 A10 A9 A8 0000 0000B SFRAL F/W FLASH LOW ADDRESS ACH A7 A6 A5 A4 A3 A2 A1 A0 0000 0000B SADDR1 SLAVE ADDRESS 1 AAH SADDR1 SADDR1 SADDR1 SADDR1 SADDR1 SADDR1 SADDR1 SADDR1 0000 0000B .7 .6 .5 .4 .3 .2 .1 .0 SADDR SLAVE ADDRESS A9H SADDR. SADDR. SADDR. SADDR. SADDR. SADDR. SADDR. SADDR. 0000 0000B 7 6 5 4 3 2 1 0 IE INTERRUPT ENABLE A8H (AF) EA P3 (AE) EADC (AD) ET2 - 24 - (AC) ES (AB) ET1 (AA) EX1 (A9) ET0 (A8) EX0 0000 0000B Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued SYMBOL DEFINITION ADDR MSB ESS LSB BIT_ADDRESS, SYMBOL RESET INPUT CAPTURE 2 HIGH CCH2/MAX REGISTER/ MAXIMUM A7h CNTH COUNTER HIGH REGISTER CCH2.7 CCH2.6 CCH2.5 CCH2.4 CCH2.3 CCH2.2 CCH2.1 CCH2.0 /MAXCN MAXCN /MAXCN /MAXCN /MAXCN /MAXCN /MAXCN /MAXCN 0000 0000B TH.0 TH.2 TH.3 TH.6 TH.1 TH.5 TH.4 TH.7 INPUT CAPTURE 2 LOW CCL2/MAX REGISTER/ MAXIMUM A6h CNTL COUNTER LOW REGISTER CCL2.7 CCL2.6 CCL2.5 CCL2.4 CCL2.3 CCL2.2 CCL2.1 CCL2.0 /MAXCN /MAXCN /MAXCN /MAXCN /MAXCN /MAXCN /MAXCN /MAXCN 0000 0000B TL.2 TL.3 TL.4 TL.1 TL.0 TL.7 TL.6 TL.5 P4 - PORT 4 A5H - - - P4.3 P4.2 T2EX/IC2 STADC xxxx 1111B CPTF0/ QEIF xx00 0000B CCLD0 0000 0000B CAPCON1 CAPTURE CONTROL 1 REGISTER A4H - - ENF2 ENF1 ENF0 CPTF2 CPTF1/ DIRF CAPCON0 CAPTURE CONTROL 0 REGISTER A3H CCT2.1 CCT2.0 CCT1.1 CCT1.0 CCT0.1 CCT0.0 CCLD1 P4CSIN P4 CS SIGN A2H P43INV P42INV P41INV P40INV - PWDNH RMWFP P0UP 0000 x000B XRAMAH RAM HIGH BYTE ADDRESS A1H - - - - - A10 A9 A8 0000 0000B P2 PORT 2 A0H (A7) A15/ SDA (A6) A14/ SCL (A5) A13/ PWM5 (A4) A12/ PWM4 (A3) A11/ PWM3 (A2) A10/ PWM2 (A1) A9/ PWM1 (A0) A8/ PWM0 1111 1111B CHPCON ON CHIP PROGRAMMING CONTROL 9FH SWRST/ REBOOT LD/AP - - - LDSEL ENP 0000 0000B NVMCON NVM CONTROL 9EH EER EWR EnNVM NVMF 000x xxx0B P43AH HI ADDR. COMPARATOR OF P4.3 9DH A15 A14 A13 A12 A11 A10 A9 A8 0000 0000B P43AL LO ADDR. COMPARATOR OF P4.3 9CH A7 A6 A5 A4 A3 A2 A1 A0 0000 0000B P42AH HI ADDR. COMPARATOR OF P4.2 9BH A15 A14 A13 A12 A11 A10 A9 A8 0000 0000B P42AL LO ADDR. COMPARATOR OF P4.2 9AH A7 A6 A5 A4 A3 A2 A1 A0 0000 0000B SBUF SERIAL BUFFER 99H SBUF.7 SBUF.6 SBUF.5 SBUF.4 SBUF.3 SBUF.2 SBUF.1 SBUF.0 xxxx xxxxB (9D) SM2 (9C) REN (9B) TB8 (9A) RB8 (99) TI (98) RI 0000 0000B - - - - SCON SERIAL CONTROL 98H (9F) (9E) SM0/FE SM1 P41AH HI ADDR. COMPARATOR OF P4.1 97H A15 A14 A13 A12 A11 A10 A9 A8 0000 0000B P41AL LO ADDR. COMPARATOR OF P4.1 96H A7 A6 A5 A4 A3 A2 A1 A0 0000 0000B P40AH HI ADDR. COMPARATOR OF P4.0 95H A15 A14 A13 A12 A11 A10 A9 A8 0000 0000B P40AL LO ADDR. COMPARATOR OF P4.0 94H A7 A6 A5 A4 A3 A2 A1 A0 0000 0000B P4CONB P4 CONTROL REGISTER B 93H P43FUN P43FUN P43CMP P43CMP P42FUN P42FUN P42CMP P42CMP 0000 0000B 1 0 1 0 1 0 1 0 P4CONA P4 CONTROL REGISTER A 92H P41FUN P41FUN P41CMP P41CMP P40FUN P40FUN P40CMP P40CMP 0000 0000B 1 0 1 0 1 0 1 0 EXIF EXTERNAL INTERRUPT FLAG 91H IE5 IE4 IE3 IE2 - - - - 0000 xxxxB P1 PORT 1 90H (97) ADC7 (96) ADC6 (95) ADC5 (94) ADC4 (93) TXD1/ ADC3 (92) RXD1/ ADC2 (91) ADC1/ Brake (90) T2/ ADC0 1111 1111B CKCON1 CLOCK CONTROL 1 8FH - - - - - - CCDIV1 CCDIV0 0000 0000B CKCON CLOCK CONTROL 8EH WD1 WD0 T2M T1M T0M MD2 MD1 MD0 0000 0001B TH1 TIMER HIGH 1 8DH TH1.7 TH1.6 TH1.5 TH1.4 TH1.3 TH1.2 TH1.1 TH1.0 0000 0000B - 25 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued DEFINITION ADDR MSB ESS LSB TH0 TIMER HIGH 0 8CH TH0.7 TH0.6 TH0.5 TH0.4 TH0.3 TH0.2 TH0.1 TH0.0 0000 0000B TL1 TIMER LOW 1 8BH TL1.7 TL1.6 TL1.5 TL1.4 TL1.3 TL1.2 TL1.1 TL1.0 0000 0000B TL0 TIMER LOW 0 8AH TL0.7 TL0.6 TL0.5 TL0.4 TL0.3 TL0.2 TL0.1 TL0.0 0000 0000B TMOD TIMER MODE 89H GATE C /T M1 M0 GATE C /T M1 M0 0000 0000B 88H (8F) TF1 (8E) TR1 (8D) TF0 (8C) TR0 (8B) IE1 (8A) IT1 (89) IE0 (88) IT0 0000 0000B SYMBOL BIT_ADDRESS, SYMBOL RESET TCON TIMER CONTROL PCON POWER CONTROL 87H SMOD SMOD0 - - GF1 GF0 PD IDL 00xx 0000B TH3 TIMER HIGH 3 85H TH3.7 TH3.6 TH3.5 TH3.4 TH3.3 TH3.2 TH3.1 TH3.0 0000 0000B TL3 TIMER LOW 3 84H TL3.7 TL3.6 TL3.5 TL3.4 TL3.3 TL3.2 TL3.1 TL3.0 0000 0000B DPH DATA POINTER HIGH 83H DPH.7 DPH.6 DPH.5 DPH.4 DPH.3 DPH.2 DPH.1 DPH.0 0000 0000B DPL DATA POINTER LOW 82H DPL.7 DPL.6 DPL.5 DPL.4 DPL.3 DPL.2 DPL.1 DPL.0 0000 0000B SP STACK POINTER 81H SP.7 SP.6 SP.5 SP.4 SP.3 SP.2 SP.1 SP.0 0000 0111B P0 PORT 0 80H (87) INT5 (86) INT4 (85) INT3 (84) INT2 (83) /SS (82) SPCLK (81) MOSI (80) MISO 1111 1111B Table 7-2: Special Function Registers - 26 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PORT 0 Bit: 7 6 5 4 3 2 1 0 P0.7 P0.6 P0.5 P0.4 P0.3 P0.2 P0.1 P0.0 Mnemonic: P0 Address: 80h Port 0 is an open-drain 8-bit bi-directional I/O port. As an alternate function Port 0 can function as the multiplexed address/data bus to access off-chip memory. During the time when ALE is high, the LSB of a memory address is presented. When ALE is low, the port transits to a bi-directional data bus. This bus is used for reading external ROM and for reading or writing external RAM memory or peripherals. When used as a memory bus, the port provides active high drivers. The reset condition of Port 0 is tristate. Pull-up resistors are required when using Port 0 as an I/O port. BIT NAME FUNCTION 0 P0.0 MISO: SPI Master In Slave Out. 1 P0.1 MOSI: SPI Master Out Slave In. 2 P0.2 SPCLK: SPI Clock. 3 P0.3 /SS: Slave Select. 4 P0.4 INT2: External Interrupt 2. 5 P0.5 INT3: External Interrupt 3. 6 P0.6 INT4: External Interrupt 4. 7 P0.7 INT5: External Interrupt 5. STACK POINTER Bit: 7 6 5 4 3 2 1 0 SP.7 SP.6 SP.5 SP.4 SP.3 SP.2 SP.1 SP.0 Mnemonic: SP Address: 81h The Stack Pointer stores the Scratch-pad RAM address where the stack begins. In other words it always points to the top of the stack. DATA POINTER LOW Bit: 7 6 5 4 3 2 1 0 DPL.7 DPL.6 DPL.5 DPL.4 DPL.3 DPL.2 DPL.1 DPL.0 Mnemonic: DPL Address: 82h This is the low byte of the standard 8032 16-bit data pointer. - 27 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet DATA POINTER HIGH Bit: 7 6 5 4 3 2 1 0 DPH.7 DPH.6 DPH.5 DPH.4 DPH.3 DPH.2 DPH.1 DPH.0 Mnemonic: DPH Address: 83h This is the high byte of the standard 8032 16-bit data pointer. TIMER 3 LSB Bit: 7 6 5 4 3 2 1 0 TL3.7 TL3.6 TL3.5 TL3.4 TL3.3 TL3.2 TL3.1 TL3.0 Mnemonic: TL3 Address: 84h BIT NAME 7-0 FUNCTION Timer 3 LSB LSB of Timer3 TIMER 3 MSB Bit: 7 6 5 4 3 2 1 0 TH3.7 TH3.6 TH3.5 TH3.4 TH3.3 TH3.2 TH3.1 TH3.0 Mnemonic: TH3 BIT Address: 85h NAME 7-0 FUNCTION Timer 3 MSB MSB of Timer3 POWER CONTROL Bit: 7 6 5 4 3 2 1 0 SMOD SMOD0 - - GF1 GF0 PD IDL Mnemonic: PCON BIT Address: 87h NAME FUNCTION 7 SMOD This bit doubles the serial port baud rate in mode 1, 2, and 3 when set to 1. 6 SMOD0 Framing Error Detection Enable. When SMOD0 is set to 1, then SCON.7 (SCON1.7) now indicates a Frame Error and acts as the FE (FE_1) flag. When SMOD0 is 0, then SCON.7 (SCON1.7) acts as per the standard 8032 function. 5-4 - Reserved. 3-2 GF1-0 These two bits are general purpose user flags. 1 PD Setting this bit causes the device to go into the POWERDOWN mode. In this mode all the clocks are stopped and program execution is frozen. IDL Setting this bit causes the device to go into the IDLE mode. In this mode the clock to the CPU is stopped, so program execution is frozen, but the clock to the serial ports, timer, PWM, ADC, SPI and interrupt blocks is not stopped, and these blocks continue operating unhindered. 0 - 28 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet TIMER CONTROL Bit: 7 6 5 4 3 2 1 0 TF1 TR1 TF0 TR0 IE1 IT1 IE0 IT0 Mnemonic: TCON BIT Address: 88h NAME FUNCTION 7 TF1 Timer 1 Overflow Flag. This bit is set when Timer 1 overflows. It is cleared automatically when the program does a timer 1 interrupt service routine. Software can also set or clear this bit. 6 TR1 Timer 1 Run Control. This bit is set or cleared by software to turn timer/counter on or off. 5 TF0 Timer 0 Overflow Flag. This bit is set when Timer 0 overflows. It is cleared automatically when the program does a timer 0 interrupt service routine. Software can also set or clear this bit. 4 TR0 Timer 0 Run Control. This bit is set or cleared by software to turn timer/counter on or off. 3 IE1 Interrupt 1 Edge Detect Flag: Set by hardware when an edge/level is detected on INT1. This bit is cleared by hardware when the service routine is vectored to only if the interrupt was edge triggered. Otherwise it follows the inverse of the pin. 2 IT1 Interrupt 1 Type Control. Set/cleared by software to specify falling edge/ low level triggered external inputs. 1 IE0 Interrupt 0 Edge Detect Flag. Set by hardware when an edge/level is detected on INT0. This bit is cleared by hardware when the service routine is vectored to only if the interrupt was edge triggered. Otherwise it follows the inverse of the pin. 0 IT0 Interrupt 0 Type Control: Set/cleared by software to specify falling edge/ low level triggered external inputs. - 29 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet TIMER MODE CONTROL Bit: 7 6 5 4 3 2 1 0 GATE C/ T M1 M0 GATE C/ T M1 M0 TIMER1 TIMER0 Mnemonic: TMOD BIT NAME 7 GATE 6 C/ T 5 4 M1 M0 3 GATE 2 C/ T 1 0 M1 M0 Address: 89h FUNCTION Gating control: When this bit is set, Timer 1 is enabled only while the INT1 pin is high and the TR1 control bit is set. When cleared, the INT1 pin has no effect, and Timer 1 is enabled whenever TR1 is set. Timer or Counter Select: When clear, Timer 1 is incremented by the internal clock. When set, the timer counts falling edges on the T1 pin. Timer 1 mode select bit 1. See table below. Timer 1 mode select bit 0. See table below. Gating control: When this bit is set, Timer 0 is enabled only while the INT0 pin is high and the TR0 control bit is set. When cleared, the INT0 pin has no effect, and Timer 0 is enabled whenever TR0 is set. Timer or Counter Select: When clear, Timer 0 is incremented by the internal clock. When set, the timer counts falling edges on the T0 pin. Timer 0 mode select bit 1. See table below. Timer 0 mode select bit 0. See table below. M1, M0: Mode Select bits: M1 M0 Mode 0 0 Mode 0: 8-bit timer/counter TLx serves as 5-bit pre-scale. 0 1 Mode 1: 16-bit timer/counter, no pre-scale. 1 0 Mode 2: 8-bit timer/counter with auto-reload from THx 1 1 Mode 3: (Timer 0) TL0 is an 8-bit timer/counter controlled by the standard Timer-0 control bits. TH0 is an 8-bit timer only controlled by Timer-1 control bits. (Timer 1) Timer/Counter 1 is stopped. TIMER 0 LSB Bit: 7 6 5 4 3 2 1 0 TL0.7 TL0.6 TL0.5 TL0.4 TL0.3 TL0.2 TL0.1 TL0.0 Mnemonic: TL0 Address: 8Ah TL0.7-0 Timer 0 LSB TIMER 1 LSB Bit: 7 6 5 4 3 2 1 0 TL1.7 TL1.6 TL1.5 TL1.4 TL1.3 TL1.2 TL1.1 TL1.0 Mnemonic: TL1 TL1.7-0 Address: 8Bh Timer 1 LSB TIMER 0 MSB - 30 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Bit: 7 6 5 4 3 2 1 0 TH0.7 TH0.6 TH0.5 TH0.4 TH0.3 TH0.2 TH0.1 TH0.0 Mnemonic: TH0 Address: 8Ch TH0.7-0 Timer 0 MSB TIMER 1 MSB Bit: 7 6 5 4 3 2 1 0 TH1.7 TH1.6 TH1.5 TH1.4 TH1.3 TH1.2 TH1.1 TH1.0 Mnemonic: TH1 Address: 8Dh TH1.7-0 Timer 1 MSB CLOCK CONTROL Bit: 7 6 5 4 3 2 1 0 WD1 WD0 T2M T1M T0M MD2 MD1 MD0 Mnemonic: CKCON Address: 8Eh BIT NAME 7 WD1 Watchdog Timer mode select bit 1. See table below. 6 WD0 Watchdog Timer mode select bit 0. See table below. 5 T2M Timer 2 clock select: 1: divide-by-4 clock. 0: divide-by-12 clock. T1M Timer 1 clock select: 1: divide-by-4 clock. 0: divide-by-12 clock. T0M Timer 0 clock select: 1: divide-by-4 clock. 0: divide-by-12 clock. 4 3 FUNCTION Stretch MOVX select bit 2: MD2, MD1, and MD0 select the stretch value for the MOVX instruction. The RD or WR strobe is stretched by the selected interval, which enables the device to access faster or slower external memory devices or peripherals without the need for external circuits. By default, the stretch value is one. See table below. (Note: When accessing on-chip SRAM, these bits have no effect, and the MOVX instruction always takes two machine cycles.) 2 MD2 1 MD1 Stretch MOVX select bit 1. See MD2. 0 MD0 Stretch MOVX select bit 0. See MD2. - 31 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet WD1, WD0: Mode Select bits: These bits determine the time-out periods for the Watchdog Timer. The reset time-out period is 512 clocks more than the interrupt time-out period. WD1 WD0 0 INTERRUPT TIME-OUT 0 0 1 2 17 2 20 23 1 0 2 1 1 226 RESET TIME-OUT 2 2 2 2 17 20 23 26 + 512 + 512 + 512 + 512 MD2, MD1, MD0: Stretch MOVX select bits: MD2 MD1 MD0 STRETCH VALUE MOVX DURATION 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 0 1 2 3 4 5 6 7 2 machine cycles 3 machine cycles (Default) 4 machine cycles 5 machine cycles 6 machine cycles 7 machine cycles 8 machine cycles 9 machine cycles CLOCK CONTROL 1 Bit: 7 6 5 4 3 2 1 0 - - - - - - CCDIV1 CCDIV0 Mnemonic: CKCON1 BIT 7-2 Address: 8Fh NAME - FUNCTION Reserved. Timer 3 clock select. 1-0 CCDIV1 CCDIV0 Timer 3 clock 0 0 Fosc 0 1 Fosc/4 1 0 Fosc/16 1 1 Fosc/32 CCDIV PORT 1 Bit: 7 6 5 4 3 2 1 0 P1.7 P1.6 P1.5 P1.4 P1.3 P1.2 P1.1 P1.0 Mnemonic: P1 Address: 90h - 32 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT 7-0 NAME FUNCTION General purpose I/O port. Most instructions will read the port pins in case of a port read access, however in case of read-modify-write instructions, the port latch is read. Some pins also have alternate input or output functions. The alternate functions are described below. P1 ALTERNATE FUNCTION1 ALTERNATE FUNCTION2 P1.0 T2: External I/O for Timer/Counter 2 ADC0: Analog input0 P1.1 PWM Brake ADC1: Analog input1 P1.2 RXD1 ADC2: Analog input2 P1.3 TXD1 ADC3: Analog input3 P1.4 ADC4: Analog input4 P1.5 ADC5: Analog input5 P1.6 ADC6: Analog input6 P1.7 ADC7: Analog input7 EXTERNAL INTERRUPT FLAG Bit: 7 6 5 4 3 2 1 0 IE5 IE4 IE3 IE2 - - - - Mnemonic: EXIF BIT Address: 91h NAME FUNCTION 7 IE5 External Interrupt 5 flag. Set by hardware when a rising/falling/both edges is detected onINT5 pin. 6 IE4 External Interrupt 4 flag. Set by hardware when a rising/falling/both edges is detected on INT4 pin. 5 IE3 External Interrupt 3 flag. Set by hardware when a rising/falling/both edges is detected on INT3 pin. 4 IE2 External Interrupt 2 flag. Set by hardware when a rising edge is detected on INT2 pin. 3-0 - Reserved. PORT 4 CONTROL REGISTER A Bit: 7 6 5 4 P41FUN1 P41FUN0 P41CMP1 P41CMP0 Mnemonic: P4CONA 3 2 1 P40FUN1 P40FUN0 P40CMP1 0 P40CMP0 Address: 92h - 33 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PORT 4 CONTROL REGISTER B Bit: 7 6 5 4 3 2 P43FUN1 P43FUN0 P43CMP1 P43CMP0 P42FUN1 P42FUN0 P42CMP1 Mnemonic: P4CONB 1 0 P42CMP0 Address: 93h BIT NAME FUNCTION P4xFUN1, P4xFUN0 Port 4 alternate modes. =00: Mode 0. P4.x is a general purpose I/O port which is the same as Port 1. =01: Mode 1. P4.x is a Read Strobe signal for chip select purpose. The address range depends on the SFR P4xAH, P4xAL and bits P4xCMP1, P4xCMP0. =10: Mode 2. P4.x is a Write Strobe signal for chip select purpose. The address range depends on the SFR P4xAH, P4xAL and bits P4xCMP1, P4xCMP0. =11: Mode 3. P4.x is a Read/Write Strobe signal for chip select purpose. The address range depends on the SFR P4xAH, P4xAL and bits P4xCMP1, P4xCMP0. P4xCMP1, P4xCMP0 Port 4 Chip-select Mode address comparison: =00: Compare the full address (16 bits length) with the base address registers P4xAH and P4xAL. =01: Compare the 15 high bits (A15-A1) of address bus with the base address registers P4xAH and P4xAL. =10: Compare the 14 high bits (A15-A2) of address bus with the base address registers P4xAH and P4xAL. =11: Compare the 8 high bits (A15-A8) of address bus with the base address registers P4xAH and P4xAL. P4.0 BASE ADDRESS LOW BYTE REGISTER Bit: 7 6 5 4 3 2 1 0 A7 A6 A5 A4 A3 A2 A1 A0 Mnemonic: P40AL Address: 94h P4.0 BASE ADDRESS HIGH BYTE REGISTER Bit: 7 6 5 4 3 2 1 0 A15 A14 A13 A12 A11 A10 A9 A8 Mnemonic: P40AH Address: 95h P4.1 BASE ADDRESS LOW BYTE REGISTER Bit: 7 6 5 4 3 2 1 0 A7 A6 A5 A4 A3 A2 A1 A0 Mnemonic: P41AL Address: 96h - 34 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet P4.1 BASE ADDRESS HIGH BYTE REGISTER Bit: 7 6 5 4 3 2 1 0 A15 A14 A13 A12 A11 A10 A9 A8 Mnemonic: P41AH Address: 97h SERIAL PORT CONTROL Bit: 7 6 5 4 3 2 1 0 SM0/FE SM1 SM2 REN TB8 RB8 TI RI Mnemonic: SCON BIT Address: 98h NAME FUNCTION Serial Port mode select bit 0 or Framing Error Flag: This bit is controlled by the SMOD0 bit in the PCON register. SM0/FE (SM0) See table below. (FE) This bit indicates an invalid stop bit. It must be manually cleared by software. SM1 Serial Port mode select bit 1. See table below. Serial Port Clock or Multi-Processor Communication. (Mode 0) This bit controls the serial port clock. If set to zero, the serial port runs at a divide-by-12 clock of the oscillator. This is compatible with the standard 8051/52. If set to one, the serial clock is a divide-by-4 clock of the oscillator. SM2 (Mode 1) If SM2 is set to one, RI is not activated if a valid stop bit is not received. (Modes 2 / 3) This bit enables multi-processor communication. If SM2 is set to one, RI is not activated if RB8, the ninth data bit, is zero. Receive enable: REN 1: Enable serial reception. 0: Disable serial reception. TB8 (Modes 2 / 3) This is the 9th bit to transmit. This bit is set by software. (Mode 0) No function. RB8 (Mode 1) If SM2 = 0, RB8 is the stop bit that was received. (Modes 2 / 3) This is the 9th bit that was received. Transmit interrupt flag: This flag is set by the hardware at the end of the 8th bit in TI mode 0 or at the beginning of the stop bit in the other modes during serial transmission. This bit must be cleared by software. Receive interrupt flag: This flag is set by the hardware at the end of the 8th bit in RI mode 0 or halfway through the stop bits in the other modes during serial reception. However, SM2 can restrict this behavior. This bit can only be cleared by software. 7 6 5 4 3 2 1 0 SM1, SM0: Mode Select bits: SM0 SM1 MODE DESCRIPTION LENGTH 0 0 0 Synchronous 8 Tclk divided by 4 or 12 0 1 1 Asynchronous 10 Variable 1 0 2 Asynchronous 11 Tclk divided by 32 or 64 1 1 3 Asynchronous 11 Variable - 35 - BAUD RATE Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet ERIAL DATA BUFFER Bit: 7 6 5 4 3 2 1 0 SBUF.7 SBUF.6 SBUF.5 SBUF.4 SBUF.3 SBUF.2 SBUF.1 SBUF.0 Mnemonic: SBUF BIT 7-0 Address: 99h NAME FUNCTION Serial data is read from or written to this location. It consists of two separate 8 bit registers. One is the receive buffer, and the other is the transmit buffer. Any read access gets data from the receive data buffer, while write access is to the transmit data buffer. SBUF P4.2 BASE ADDRESS LOW BYTE REGISTER Bit: 7 6 5 4 3 2 1 0 A7 A6 A5 A4 A3 A2 A1 A0 Mnemonic: P42AL Address: 9Ah P4.2 BASE ADDRESS HIGH BYTE REGISTER Bit: 7 6 5 4 3 2 1 0 A15 A14 A13 A12 A11 A10 A9 A8 Mnemonic: P42AH Address: 9Bh P4.3 BASE ADDRESS LOW BYTE REGISTER Bit: 7 6 5 4 3 2 1 0 A7 A6 A5 A4 A3 A2 A1 A0 Mnemonic: P43AL Address: 9Ch P4.3 BASE ADDRESS HIGH BYTE REGISTER Bit: 7 6 5 4 3 2 1 0 A15 A14 A13 A12 A11 A10 A9 A8 Mnemonic: P43AH Address: 9Dh NVM CONTROL Bit: 7 6 5 4 3 2 1 0 EER EWR EnNVM - - - - NVMF Mnemonic: NVMCON BIT 7 Address: 9Eh NAME EER FUNCTION Set this bit to erase NVM data of page (n) to FFH. The NVM has 32 pages that each page has 64 bytes data memory. By select NVMADDRH and NVMADDRL of NVM address registers that will automatic enable page area. If set this bit, the page will be page erased, after finished, the NVMF flag will be set to “1”, then this bit will be cleared. If NVMF flag is set, the erase and write NVM data memory are invalid. - 36 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued BIT NAME 6 EWR 5 EnNVM 4~1 - 0 NVMF FUNCTION Set this bit is write data to NVM data memory by NVMADDRH and NVMADDRL to decode NVM data memory. If finished, NVMF flag will be set to “1”, and then this bit will be cleared. If NVMF flag is set, the erase and write NVM are invalid. To enable read NVM data memory area, refer as below table. 0: To disable the MOVX instruction to read NVM data memory. 1: To enable the MOVX instruction to read NVM data memory, the External RAM or AUX-RAM will be disabled. Reserved. NVM data memory erases or writes finished flag. If NVM data memory is finished by erase or write, it will be set to “1” by hardware and clear by software. And it will be interrupted when NVM erase/write interrupt is enabled. ISP CONTROL REGISTER Bit: 7 6 5 4 3 2 1 0 SWRST/ HWB - LD/AP - - - LDSEL ENP Mnemonic: CHPCON BIT 7 Address: 9Fh NAME W:SWRST R:HWB 6 LD/AP 5 (read-only) 4-2 - 1 LDSEL (write-only) 0 ENP FUNCTION Write access to this bit is different from read access. Write this bit to 1 to force the microcontroller to reset to the initial condition, just like power-on reset. This action re-boots the microcontroller and starts normal operation. This bit will be cleared during the reset. Read this bit to determine whether or not a hardware reboot is in progress. If CPU is rebooted by P3.6 & P3.7 or P4.3, this bit is set to 1 after the hardware reboot. Note: P4.3 pin is available in 48L LQFP package only. Reserved. 0: CPU is executing AP Flash EPROM 1: CPU is executing LD Flash EPROM Reserved. Loader Program Location Selection. This bit should be set before entering ISP mode. 0: The executing program is in the 64-KB AP Flash EPROM. The 4-KB LD Flash EPROM is the destination for re-programming. 1: The executing program is in the 4-KB memory bank. The 64-KB AP Flash EPROM is the destination for re-programming. FLASH EPROM Programming Enable. 1: Enable in-system programming mode. In this mode, erase, program and read operations are achieved. 0: Disable in-system programming mode. The on-chip flash memory is readonly. - 37 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet The way to enter ISP mode is to set ENP to 1 and write LDSEL properly then force CPU in IDLE mode, after IDLE mode is released CPU will restart from AP or LD ROM according the value of LDSEL. PORT 2 Bit: 7 6 5 4 3 2 1 0 P2.7 P2.6 P2.5 P2.4 P2.3 P2.2 P2.1 P2.0 Mnemonic: P2 BIT 7-0 Address: A0h NAME FUNCTION This port functions as an address bus during external memory access, and as a general-purpose I/O port on devices that incorporate internal program memory. When P2 functions a non-multiplexed address bus A15-A8 the port latch cannot be used for general I/O purposes but exists to support the MOVX instructions. Port 2 data will only be brought out on the P2.7-0 pins during indirect MOVX instructions. P2 ALTERNATE FUNCTION P2.0 P2.1 P2.2 P2.3 P2.4 P2.5 P2.6 P2.7 PWM0 output. PWM1 output. PWM2 output. PWM3 output. PWM4 output. PWM5 output. SCL, I2C serial clock. SDA, I2C serial data. XRAMAH Bit: 7 6 5 4 3 2 1 0 - - - - - A10 A9 A8 Mnemonic: XRAMAH BIT 7-3 2-0 Address: A1h NAME FUNCTION - Reserved. A10-8 XRAMAH is used for high byte address memory access through A15-8, when CPU executes MOVX with R0 (or R1) instructions. Depending EnNVM and DME0 setting, and address, the memory accessed may differs. Table below shows the memory access destination. This device has on-chip sram at 1/2/2K bytes. Note: User should take care when accessing the memory with this instruction. Access to invalid regions may cause undesirable results. - 38 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PORT 4 CHIP-SELECT POLARITY Bit: 7 6 5 4 3 2 1 0 P43INV P42INV P41INV P40INV - PWDNH RMWFP PUP0 Mnemonic: P4CSIN BIT Address: A2h NAME 7-4 P4xINV 3 - 2 PWDNH 1 RMWFP 0 PUP0 FUNCTION The Active Polarity of P4.x when it is set as a chip-select strobe output. High = Active High. Low = Active Low. Note: x = 3,2,1,0. Reserved. Set PWDNH to logic 1 then ALE and PSEN will keep high state, clear this bit to logic 0 then ALE and PSEN will output low during power down mode. Control Read Path of Instruction “Read-Modify-Write”. When this bit is set, the read path of executing “read-modify-write” instruction is from port pin otherwise from SFR. Enable Port 0 weak pull up. CAPTURE CONTROL 0 REGISTER Bit: 7 6 5 4 3 2 1 0 CCT2.1 CCT2.0 CCT1.1 CCT1.0 CCT0.1 CCT0.0 CCLD1 CCLD0 Mnemonic: CAPCON0 BIT 7-6 5-4 3-2 Address: A3h NAME FUNCTION CCT2.1-0 Capture 2 edge select. CCT2.1 CCT2.0 Description 0 0 Rising edge trigger 0 1 Falling edge trigger 1 0 Rising and falling edge trigger 1 1 Reserved. CCT1.1-0 Capture 1 edge select. CCT1.1 CCT1.0 Description 0 0 Rising edge trigger 0 1 Falling edge trigger 1 0 Rising and falling edge trigger 1 1 Reserved. CCT0.1-0 Capture 0 edge select. CCT0.1 CCT0.0 Description 0 0 Rising edge trigger 0 1 Falling edge trigger 1 0 Rising and falling edge trigger 1 1 Reserved. - 39 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued BIT 1-0 NAME CCLD.1-0 FUNCTION Reload trigger select. CCLD1 CCLD0 Description 0 0 Timer 3 overflow (default) 0 1 Reload by capture 0 block 1 0 Reload by capture 1 block 1 1 Reload by capture 2 block CAPTURE CONTROL 1 REGISTER Bit: 7 6 - - 5 4 ENF2 3 ENF1 2 ENF0 Mnemonic: CAPCON1 BIT 1 CPTF2 0 CPTF1/ CPTF0 Address: A4h NAME FUNCTION 7-6 5 4 3 2 ENF2 ENF1 ENF0 CPTF2 1 CPTF1/DIRF 0 CPTF0/QEIF Reserved. Enable filter for capture input 2. Enable filter for capture input 1. Enable filter for capture input 0. Input capture/reload 2 interrupt flag. Input Capture 2 flag share the same bit with DIRF flag. IC mode - Input capture/reload 1 interrupt flag. QEI mode - Direction changed interrupt flag. Bit is set by hardware when direction index (DIR) changes state and direction change interrupt is requested if it is enabled. DIRF is cleared by software. Input Capture 0 flag share the same bit with QEI flag. IC mode – Input capture/reload 0 interrupt flag. QEI mode - QEI interrupt flag. 1. In free-counting mode, if Pulse Counter overflows or underflows. 2. In compare-counting mode, if Pulse Counter overflows from Maximum Count to zero or underflows from zero to Maximum Count. PORT 4 Bit: 7 6 5 4 3 2 1 0 - - - - P4.3 P4.2 P4.1 P4.0 Mnemonic: P4 BIT Address: A5h NAME 7-4 3-2 P4 1 P4 0 P4 FUNCTION Reserved. GPIO. GPIO. Alternate function T2EX/IC2 for Timer 2 external trigger/Input Capture 2 respectively. GPIO. Alternate function STADC. External start ADC trigger input. - 40 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet INPUT CAPTURE 2/MAXIMUM COUNTER LOW REGISTER Bit: 7 6 5 4 3 2 1 0 CCL2.7/ MAXCNT L.7 CCL2.6/ MAXCNT L.6 CCL2.5/ MAXCNT L.5 CCL2.4/ MAXCNT L.4 CCL2.3/ MAXCNT L.3 CCL2.2/ MAXCNT L.2 CCL2.1/ MAXCNT L.1 CCL2.0/ MAXCNT L.0 Mnemonic: CCL2/MAXCNTL Address: A6h INPUT CAPTURE 2/MAXIMUM COUNTER HIGH REGISTER Bit: 7 6 5 4 3 2 1 0 CCH2.7/ MAXCNT H.7 CCH2.6/ MAXCNT H.6 CCH2.5/ MAXCNT H.5 CCH2.4/ MAXCNT H.4 CCH2.3/ MAXCNT H.3 CCH2.2/ MAXCNT H.2 CCH2.1/ MAXCNT H.1 CCH2.0/ MAXCNT H.0 Mnemonic: CCH2/MAXCNTH Address: A7h INTERRUPT ENABLE Bit: 7 6 5 4 3 2 1 0 EA EADC ET2 ES ET1 EX1 ET0 EX0 Mnemonic: IE BIT Address: A8h NAME FUNCTION 7 EA Global enable: Enable/disable all interrupts. 6 EADC Enable ADC interrupt. 5 ET2 Enable Timer 2 interrupt. 4 ES Enable Serial Port 0 interrupts. 3 ET1 Enable Timer 1 interrupt. 2 EX1 Enable external interrupt 1. 1 ET0 Enable Timer 0 interrupt. 0 EX0 Enable external interrupt 0. SLAVE ADDRESS Bit: 7 6 5 4 3 2 1 0 SADDR.7 SADDR.6 SADDR.5 SADDR.4 SADDR.3 SADDR.2 SADDR.1 SADDR.0 Mnemonic: SADDR BIT NAME 7-0 SADDR Address: A9h FUNCTION The SADDR should be programmed to the given or broadcast address for serial port to which the slave processor is designated. SLAVE ADDRESS 1 Bit: 7 6 5 4 3 2 1 0 SADDR1.7 SADDR1.6 SADDR1.5 SADDR1.4 SADDR1.3 SADDR1.2 SADDR1.1 SADDR1.0 Mnemonic: SADDR1 Address: AAh - 41 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME FUNCTION 7-0 SADDR1 The SADDR1 should be programmed to the given or broadcast address for serial port 1 to which the slave processor is designated. ISP ADDRESS LOW BYTE Bit: 7 6 5 4 3 2 1 0 A7 A6 A5 A4 A3 A2 A1 A0 Mnemonic: SFRAL Address: ACh Low byte destination address for In System Programming operations. ISP ADDRESS HIGH BYTE Bit: 7 6 5 4 3 2 1 0 A15 A14 A13 A12 A11 A10 A9 A8 Mnemonic: SFRAH Address: ADh Low byte destination address for In System Programming operations. (SFRAH, SFRAL) represents the address of the ROM byte that will be erased, programmed or read. ISP DATA BUFFER Bit: 7 6 5 4 3 2 1 0 D7 D6 D5 D4 D3 D2 D1 D0 Mnemonic: SFRFD Address: AEh In ISP mode, read/write a specific byte ROM content must go through SFRFD register. ISP OPERATION MODES Bit: 7 6 5 4 3 2 1 0 - WFWIN NOE NCE CTRL3 CTRL2 CTRL1 CTRL0 Mnemonic: SFRCN BIT Address: AFh NAME FUNCTION 7 - Reserved. 6 WFWIN On-chip FLASH EPROM bank select for in-system programming. 0= AP FLASH EPROM bank is selected as destination for re-programming. 1= LD FLASH EPROM bank is selected as destination for re-programming. 5 NOE Flash EPROM output enable. 4 NCE Flash EPROM chip enable. 3-0 CTRL The Flash Control Signals. - 42 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet WFWIN NOE NCE CTRL[3:0] SFRAH, SFRAL SFRFD Erase 4KB LD Flash 1 1 0 0010 X X Erase 16/32/64K AP Flash 0 1 0 0010 X X Program 4KB LD Flash 1 1 0 0001 Address in Data in Program 16/32/64KB AP Flash 0 1 0 0001 Address in Data in Read 4KB LD Flash 1 0 0 0000 Address in Data out Read 16/32/64KB AP Flash 0 0 0 0000 Address in Data out ISP MODE PORT 3 Bit: 7 6 5 4 3 2 1 0 P3.7 P3.6 P3.5 P3.4 P3.3 P3.2 P3.1 P3.0 Mnemonic: P3 BIT 7-0 Address: B0h NAME FUNCTION General purpose I/O port. Each pin also has an alternate input or output function that is controlled by other SFRs. The alternate function is enabled if the corresponding port latch bit is set to 1. P3 ALTERNATE FUNCTION P3.7 RD Strobe for read from external RAM. P3.6 WR Strobe for write to external RAM. P3.5 T1/IC1/QEB; Timer/counter 1 external count input/Input Capture 1/QEI input B. P3.4 T0/IC0/QEA; Timer/counter 0 external count input/Input Capture 0/QEI input A. P3.3 /INT0 External interrupt 1. P3.2 /INT1 External interrupt 0. P3.1 TxD Serial port output. P3.0 RxD Serial port input. PORT 5 Bit: 7 6 5 4 3 2 1 0 - - - - - - P5.1 P5.0 Mnemonic: P5 BIT Address: B1h NAME FUNCTION 7-2 - Reserved. 1-0 P5 General purpose I/O port. Each pin also has an alternate input or output function. This port can not support bit addressable. - 43 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet ALTERNATE FUNCTION P5.1 PWM7 output function P5.0 PWM6 output function TIMER 3 RELOAD LSB Bit: 7 6 5 4 3 2 1 0 RCAP3L.7 RCAP3L.6 RCAP3L.5 RCAP3L.4 RCAP3L.3 RCAP3L.2 RCAP3L.1 RCAP3L.0 Mnemonic: RCAP3L BIT NAME 7-0 RCAP3L Address: B4h FUNCTION Timer 3 Reload LSB: This register is LSB of a 16 bit reload value when timer 3 is configured in reload mode. It served also as a compare register when timer 3 is configured as compare mode (see CMP/RL3 bit). TIMER 3 RELOAD MSB Bit: 7 6 5 4 3 2 1 0 RCAP3H.7 RCAP3H.6 RCAP3H.5 RCAP3H.4 RCAP3H.3 RCAP3H.2 RCAP3H.1 RCAP3H.0 Mnemonic: RCAP3H Address: B5h BIT NAME FUNCTION 7-0 RCAP3H Timer 3 Reload MSB: This register is MSB of a 16 bit reload value when timer 3 is configured in reload mode. It served also as a compare register when timer 3 is configured as compare mode (see CMP/RL3 bit). EXTENDED INTERRUPT HIGH PRIORITY 1 Bit: 7 6 - - 5 4 3 PNVMIH PCPTFH 2 PT3H Mnemonic: EIP1 BIT NAME 7-6 5 PNVMIH 4 PCPTFH 3 2 1 0 PT3H PBKFH PPWMFH PSPIH PBKFH 1 0 PPWMFH PSPIH Address: B6h FUNCTION Reserved. NVM interrupt High priority. PNVMIH = 1 sets it to highest priority level. Capture/reload Interrupt High priority. PCPTFH = 1 sets it to highest priority level. Timer 3 Interrupt High priority. PT3H = 1 sets it to highest priority level. PWM Brake Interrupt High priority. PBKFH = 1 sets it to highest priority level. PWM period Interrupt High priority. PPWMFH = 1 sets it to highest priority level. SPI Interrupt High Priority. PSPIH = 1 sets it to highest priority level. INTERRUPT HIGH PRIORITY Bit: 7 6 5 4 3 2 1 0 - PADCH PT2H PSHH PT1H PX1H PT0H PX0H Mnemonic: IPH Address: B7h - 44 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME 7 - 6 PADCH 5 PT2H 4 PSH 3 PT1H 2 PX1H 1 PT0H 0 PX0H FUNCTION Reserved. This bit defines the ADC interrupt High priority. PADCH = 1 sets it to highest priority level. This bit defines the Timer 2 interrupt High priority. PT2H = 1 sets it to highest priority level. This bit defines the Serial port 0 interrupt High priority. PSH = 1 sets it to highest priority level. This bit defines the Timer 1 interrupt High priority. PT1H = 1 sets it to highest priority level. This bit defines the External interrupt 1 High priority. PX1H = 1 sets it to highest priority level. This bit defines the Timer 0 interrupt High priority. PT0H = 1 sets it to highest priority level. This bit defines the External interrupt 0 High priority. PX0H = 1 sets it to highest priority level. INTERRUPT PRIORITY Bit: 7 6 5 4 3 2 1 0 - PADC PT2 PS PT1 PX1 PT0 PX0 Mnemonic: IP BIT Address: B8h NAME 7 6 PADC 5 PT2 4 PS 3 PT1 2 PX1 1 PT0 0 PX0 FUNCTION Reserved. This bit defines the ADC interrupt priority. PADC = 1 sets it to higher priority level. This bit defines the Timer 2 interrupt priority. PT2 = 1 sets it to higher priority level. This bit defines the Serial port 0 interrupt priority. PS = 1 sets it to higher priority level. This bit defines the Timer 1 interrupt priority. PT1 = 1 sets it to higher priority level. This bit defines the External interrupt 1 priority. PX1 = 1 sets it to higher priority level. This bit defines the Timer 0 interrupt priority. PT0 = 1 sets it to higher priority level. This bit defines the External interrupt 0 priority. PX0 = 1 sets it to higher priority level. - 45 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet SLAVE ADDRESS MASK ENABLE Bit: 7 6 5 4 3 2 1 0 SADEN.7 SADEN.6 SADEN.5 SADEN.4 SADEN.3 SADEN.2 SADEN.1 SADEN.0 Mnemonic: SADEN BIT 7-0 Address: B9h NAME SADEN FUNCTION This register enables the Automatic Address Recognition feature of the Serial port. When a bit in the SADEN is set to 1, the same bit location in SADDR will be compared with the incoming serial port data. When SADEN.n is 0, then the bit becomes don't care in the comparison. This register enables the Automatic Address Recognition feature of the Serial port. When all the bits of SADEN are 0, interrupt will occur for any incoming address. SLAVE ADDRESS MASK ENABLE 1 Bit: 7 6 5 4 3 2 1 0 SADEN1.7 SADEN1.6 SADEN1.5 SADEN1.4 SADEN1.3 SADEN1.2 SADEN1.1 SADEN1.0 Mnemonic: SADEN1 BIT 7-0 Address: BAh NAME SADEN1 FUNCTION This register enables the Automatic Address Recognition feature of the Serial port 1. When a bit in the SADEN1 is set to 1, the same bit location in SADDR1 will be compared with the incoming serial port data. When SADEN1.n is 0, then the bit becomes don't care in the comparison. This register enables the Automatic Address Recognition feature of the Serial port. When all the bits of SADEN1 are 0, interrupt will occur for any incoming address. PWM OUTPUT OVERRIDE CONTROL REGISTERS Bit: 7 6 5 4 3 2 1 0 POVM.7 POVM.6 POVM.5 POVM.4 POVM.3 POVM.2 POVM.1 POVM.0 Mnemonic: POVM BIT 7-0 Address: BBh NAME POVM FUNCTION PWM Override Mode enable bits; 0: The PWM output follows the corresponding PWM generator. 1: The PWM output is equal to corresponding bit in POVD. PWM OUTPUT STATE REGISTERS Bit: 7 6 5 4 3 2 1 0 POVD.7 POVD.6 POVD.5 POVD.4 POVD.3 POVD.2 POVD.1 POVD.0 Mnemonic: POVD Address: BCh - 46 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT 7-0 NAME FUNCTION PWM Override Data represents the value of PWM[7:0] respectively in override mode. 1 = Output on PWM I/O pin is ACTIVE when the corresponding PWM output override bit is cleared. 0 = Output on PWM I/O pin is INACTIVE when the corresponding PWM output override bit is cleared. POVD PWM PIN OUTPUT SOURCE SELECT Bit: 7 6 5 4 3 2 1 PIO7 PIO6 PIO5 PIO4 PIO3 PIO2 PIO1 Mnemonic: PIO BIT 7-0 0 PIO0 Address: BDh NAME FUNCTION Select pin output source from PWM or I/O register; x=0~7; PIOn is effective only when option bit PWMOE/PWMEE/PWM6E/PWM7E is in enabled status. Reset value=0; 1 = Correspondent I/O pin with high source/sink current. 0 = PWMn output; n=0~7 with high source/sink current. PIO.x PWM OUTPUT ENABLE REGISTER Bit: 7 6 5 4 3 2 1 0 PWM7EN PWM6EN PWM5EN PWM4EN PWM3EN PWM2EN PWM1EN PWM0EN Mnemonic: PWMEN Address: BEh BIT NAME 6,4,2,0 PWMeEN Set high to enable even PWM output; e = 0,2,4,6; Reset value=0; 1 = Enable PWM output. 0 = Disable PWM output. PWMoEN Set high to enable odd PWM output; o = 1,3,5,7; Reset value=0; 1 = Enable PWM output. 0 = Disable PWM output. 7,5,3,1 FUNCTION PWM 4 HIGH BITS REGISTER Bit: 7 6 5 - - 4 - 3 - Mnemonic: PWM4H 2 PWM4.11 1 PWM4.10 0 PWM4.9 PWM4.8 Address: BFh BIT NAME 7~4 - 3~0 PWM4.11 ~PWM4.8 FUNCTION Reserved The PWM 4 Register bit 11~8. - 47 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet SERIAL PORT CONTROL 1 Bit: 7 6 SM0_1/FE_1 SM1_1 5 4 3 2 1 0 SM2_1 REN_1 TB8_1 RB8_1 TI_1 RI_1 Mnemonic: SCON1 BIT Address: C0h NAME FUNCTION 7 SM0_1/ FE_1 Serial Port 1 mode select bit 0 or Framing Error Flag: This bit is controlled by the SMOD0 bit in the PCON register. (SM0) See table below. (FE) This bit indicates an invalid stop bit. It must be manually cleared by software. 6 SM1_1 Serial Port 1 mode select bit 1. See table below. 5 SM2_1 Serial Port Clock or Multi-Processor Communication. (Mode 0) This bit controls the serial port clock. If set to zero, the serial port runs at a divide-by-12 clock of the oscillator. This is compatible with the standard 8051/52. If set to one, the serial clock is a divide-by-4 clock of the oscillator. (Mode 1) If SM2_1 is set to one, RI_1 is not activated if a valid stop bit is not received. (Modes 2 / 3) This bit enables multi-processor communication. If SM2_1 is set to one, RI_1 is not activated if RB8_1, the ninth data bit, is zero. 4 REN_1 Receive enable: 1: Enable serial reception. 0: Disable serial reception. 3 TB8_1 (Modes 2 / 3) This is the 9th bit to transmit. This bit is set by software. 2 RB8_1 (Mode 0) No function. (Mode 1) If SM2_1 = 0, RB8_1 is the stop bit that was received. (Modes 2 / 3) This is the 9th bit that was received. 1 TI_1 Transmit interrupt flag: This flag is set by the hardware at the end of the 8th bit in mode 0 or at the beginning of the stop bit in the other modes during serial transmission. This bit must be cleared by software. RI_1 Receive interrupt flag: This flag is set by the hardware at the end of the 8th bit in mode 0 or halfway through the stop bits in the other modes during serial reception. However, SM2_1 can restrict this behavior. This bit can only be cleared by software. 0 SM1_1, SM0_1: Mode Select bits: SM0_1 SM1_1 MODE DESCRIPTION LENGTH 0 0 0 Synchronous 8 Tclk divided by 4 or 12 0 1 1 Asynchronous 10 Variable 1 0 2 Asynchronous 11 Tclk divided by 32 or 64 1 1 3 Asynchronous 11 Variable - 48 - BAUD RATE Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet SERIAL DATA BUFFER 1 Bit: 7 6 5 4 3 2 SBUF_1.7 SBUF_1.6 SBUF_1.5 SBUF_1.4 SBUF_1.3 SBUF_1.2 SBUF_1.1 SBUF_1.0 Mnemonic: SBUF1 BIT 7-0 0 Address: C1h NAME SBUF_1 1 FUNCTION For Serial Port 1. Serial data is read from or written to this location. It actually consists of two separate 8 bit registers. One is the receive buffer, and the other is the transmit buffer. Any read access gets data from the receive data buffer, while write access is to the transmit data buffer. TIMER 3 MODE CONTROL Bit: 7 6 ENLD 5 ICEN2 4 ICEN1 3 ICEN0 2 T3CR Mnemonic: T3MOD BIT 7 1 - 0 - - Address: C2h NAME FUNCTION ENLD Enable reloads from RCAP3 registers to timer 3 counters. ICEN2 Capture 2 External Enable. This bit enables the capture/reload function on the IC2 pin. An edge trigger (programmable by CAPCON0.CCT2[1:0] bits) detected on the IC2 pin will result in capture from free running timer 3 counters to input capture 2 registers, or reload from RCAP3 registers to timer 3 counters. 1 = Enable. 0 = Disable. ICEN1 Capture 1 External Enable. This bit enables the capture/reload function on the IC1 pin. An edge trigger (programmable by CAPCON0.CCT1[1:0] bits) detected on the IC1 pin will result in capture from free running timer 3 counters to input capture 1 registers, or reload from RCAP3 registers to timer 3 counters. 1 = Enable. 0 = Disable. ICEN0 Capture 0 External Enable. This bit enables the capture/reload function on the IC0 pin. An edge trigger (programmable by CAPCON0.CCT0[1:0] bits) detected on the IC0 pin will result input capture from free running timer 3 counters to input capture 0 registers, or reload from RCAP3 registers to timer 3 counters. 1 = Enable. 0 = Disable. 3 T3CR Timer 3 Capture Reset. In the Timer 3 Capture Mode this bit enables/disables hardware automatically reset timer 3 while the value in TL3 and TH3 have been transferred into the input capture register (CCLx, CCHx). Priority is given to T3CR to reset counter after capture. 2-0 - Reserved. 6 5 4 - 49 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet TIMER 3 CONTROL Bit: 7 TF3 6 - 5 - 4 - 3 2 - TR3 Mnemonic: T3CON BIT 1 - 0 CMP / RL3 Address: C3h NAME FUNCTION 7 TF3 Timer 3 overflows flag. This bit is set when Timer 3 overflows. It is cleared only by software and set by hardware. 6-3 - Reserved. 2 TR3 Timer 3 Run Control. This bit enables/disables the operation of timer 3. Halting this will preserve the current count in TH3, TL3. 1 - Reserved. CMP / RL3 Compare/Reload Select. This bit determines whether the Timer 3 will be use for compare or reload function. 0 = Timer 3 as reload mode, TF3 indicates the overflow flag 1 = Timer 3 as compare mode, TF3 indicates the compare match flag. 0 POWER MANAGEMENT REGISTER Bit: 7 6 5 4 3 2 1 0 - - - - - ALEOFF - DME0 Mnemonic: PMR BIT 7-3 Address: C4h NAME FUNCTION - Reserved. 2 ALEOFF This bit disables the expression of the ALE signal on the device pin during all on board program and data memory accesses. External memory accesses will automatically enable ALE independent of ALEOFF. ALEOFF=0: ALE expression is enabled. ALEOFF=1: ALE expression is disabled. 1 - Reserved. 0 DME0 This bit determines the on chip MOVX SRAM to be enabled or disabled. Set this bit to 1 will enable the on chip 2 KB MOVX SRAM. FAULT SAMPLING TIME REGISTER Bit: 7 SCMP1 6 SCMP0 5 4 SFP1 3 SFP0 Mnemonic: FSPLT 2 SFCEN 1 SFCST SFCDIR 0 LSBD Address: C5h - 50 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT 7-6 5-4 3 2 1 0 NAME FUNCTION Smart fault compare value selector (read/write): 00 = 4 SCMP [1:0] 01 = 16 10 = 64 11 = 128 Smart fault sampling frequency selector (read/write): 00 = FOSC/4 SFP[1:0] 01 = FOSC/8 10 = FOSC/16 11 = FOSC/128 Smart fault/brake counter enable (read/write): SFCEN 0 = Disable, and clear internal smart fault counter. 1 = Enable smart fault detector. Smart fault/brake counter status (read only): SFCST 0 = Counter is non-active. 1 = Counter is active. Smart fault/brake counters direction status (read only): SFCDIR 0 = Down counting. 1 = Up counting. Low level smart brake detector: LSBD 0 = Disable low level smart brake detector. 1 = Enable low level smart brake detector. It will be cleared by software. ADC PIN SELECT Bit: 7 6 5 4 3 2 1 0 ADCPS.7 ADCPS.6 ADCPS.5 ADCPS.4 ADCPS.3 ADCPS.2 ADCPS.1 ADCPS.0 Mnemonic: ADCPS BIT 7-0 Address: C6h NAME ADCPS FUNCTION ADC input pin select. There are 8 ADC input pins shared with P1.0~P1.7. Its’ functions are controlled by the bit value in ADCPS. Set the bit to switch the corresponding pin to ADC input port; clear the bit to disable the pin to perform ADC input port. The reset value is 00H. BIT CORRESPONDING PIN BIT CORRESPONDING PIN ADCPS.0 ADCPS.1 ADCPS.2 ADCPS.3 P1.0 P1.1 P1.2 P1.3 ADCPS.4 ADCPS.5 ADCPS.6 ADCPS.7 P1.4 P1.5 P1.6 P1.7 TIMED ACCESS Bit: 7 6 5 4 3 2 1 0 TA.7 TA.6 TA.5 TA.4 TA.3 TA.2 TA.1 TA.0 Mnemonic: TA BIT Address: C7h NAME FUNCTION - 51 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 7-0 The Timed Access register controls the access to protected bits. To access protected bits, the user must first write AAh to TA. This must be immediately followed by a write of 55h to TA. Now a window is opened in the protected bits for three machine cycles, during which the user can write to these bits. For detail data, please refer "TIMED ACCESS PROTECTION" section. TA TIMER 2 CONTROL Bit: 7 6 5 4 3 2 1 0 TF2 EXF2 RCLK TCLK EXEN2 TR2 C / T2 CP/ RL2 Mnemonic: T2CON BIT Address: C8h NAME 7 TF2 6 EXF2 5 RCLK 4 TCLK 3 EXEN2 2 TR2 1 C/ T 0 CP/RL2 FUNCTION Timer 2 overflows flag. This bit is set when Timer 2 overflows. It is also set when the count is equal to the capture register in down count mode. It can be set only if RCLK and TCLK are both 0. It is cleared only by software. Software can also set this bit. Timer 2 External Flag. A negative transition on the T2EX pin (P4.1) or timer 2 underflow/overflow will cause this flag to set based on CP/ RL2 , EXEN2 and DCEN bits. If EXF2 is set by a negative transition, this flag must be cleared by software. Setting this bit in software or detection of a negative transition on T2EX pin will force a timer interrupt if enabled. Receive clock Flag. This bit determines the serial port time-base when receiving data in serial modes 1 or 3. If it is 0, then timer 1 overflow is used for baud rate generation, else timer 2 overflow is used. Setting this bit forces timer 2 in baud rate generator mode. Transmit clock Flag: This bit determines the serial port time-base when transmitting data in mode 1 and 3. If it is set to 0, the timer 1 overflow is used to generate the baud rate clock; else timer 2 overflow is used. Setting this bit forces timer 2 in baud rate generator mode. Timer 2 External Enable. This bit enables the capture/reload function on the T2EX pin if Timer 2 is not generating baud clocks for the serial port. If this bit is 0, then the T2EX pin will be ignored, else a negative transition detected on the T2EX pin will result in capture or reload. Timer 2 Run Control. This bit enables/disables the operation of timer 2. Halting this will preserve the current count in TH2, TL2. Counter/Timer select. This bit determines whether timer 2 will function as a timer or a counter. Independent of this bit, the timer will run at 2 clocks per tick when used in baud rate generator mode. If it is set to 0, then timer 2 operates as a timer at a speed depending on T2M bit (CKCON.5), else, it will count negative edges on T2 pin. Capture/Reload Select. This bit determines whether the capture or reload function will be used for timer 2. If either RCLK or TCLK is set, this bit will not function and the timer will function in an auto-reload mode following each overflow. If the bit is 0 then auto-reload will occur when timer 2 overflows or a falling edge is detected on T2EX if EXEN2 =1. If this bit is 1, then timer 2 captures will occur when a falling edge is detected on T2EX if EXEN2=1. TIMER 2 MODE CONTROL - 52 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Bit: 7 6 5 4 3 2 1 0 HC5 HC4 HC3 HC2 T2CR - - DCEN Mnemonic: T2MOD BIT Address: C9h NAME FUNCTION 7 HC5 Hardware clears INT5 flag. Setting this bit allows the flag of External Interrupt 5 to be automatically cleared by hardware while entering the interrupt service routine. 6 HC4 Hardware clears INT4 flag. Setting this bit allows the flag of External Interrupt 4 to be automatically cleared by hardware while entering the interrupt service routine. 5 HC3 Hardware clears INT3 flag. Setting this bit allows the flag of External Interrupt 3 to be automatically cleared by hardware while entering the interrupt service routine. 4 HC2 Hardware clears INT2 flag. Setting this bit allows the flag of External Interrupt 2 to be automatically cleared by hardware while entering the interrupt service routine. 3 T2CR Timer 2 Capture Reset. In the Timer 2 Capture Mode this bit enables/disables hardware automatically reset timer 2 while the value in TL2 and TH2 have been transferred into the capture register. 2-1 - Reserved. 0 DCEN Down Count Enable. This bit, in conjunction with the T2EX pin, controls the up/down direction that timer 2 counts in 16-bit auto-reload mode. TIMER 2 CAPTURE LSB Bit: 7 6 5 4 3 2 1 0 RCAP2L. 7 RCAP2L. 6 RCAP2L. 5 RCAP2L. 4 RCAP2L. 3 RCAP2L. 2 RCAP2L. 1 RCAP2L. 0 Mnemonic: RCAP2L BIT NAME 7-0 RCAP2L Address: CAh FUNCTION Timer 2 Capture LSB: This register is used to capture the TL2 value when a timer 2 is configured in capture mode. RCAP2L is also used as the LSB of a 16 bit reload value when timer 2 is configured in auto reload mode. TIMER 2 CAPTURE MSB Bit: 7 6 5 4 3 2 1 0 RCAP2H. 7 RCAP2H. 6 RCAP2H. 5 RCAP2H. 4 RCAP2H. 3 RCAP2H. 2 RCAP2H. 1 RCAP2H. 0 Mnemonic: RCAP2H Address: CBh - 53 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME FUNCTION 7-0 RCAP2H Timer 2 Capture HSB: This register is used to capture the TH2 value when a timer 2 is configured in capture mode. RCAP2H is also used as the HSB of a 16 bit reload value when timer 2 is configured in auto reload mode. TIMER 2 LSB Bit: 7 6 5 4 3 2 1 0 TL2.7 TL2.6 TL2.5 TL2.4 TL2.3 TL2.2 TL2.1 TL2.0 Mnemonic: TL2 Address: CCh TL2 Timer 2 LSB TIMER 2 MSB Bit: 7 6 5 4 3 2 1 0 TH2.7 TH2.6 TH2.5 TH2.4 TH2.3 TH2.2 TH2.1 TH2.0 Mnemonic: TH2 Address: CDh TH2 Timer 2 MSB PWM CONTROL REGISTER 2 Bit: 7 6 BKCH 5 BKPS 4 BPEN 3 BKEN 2 FP1 Mnemonic: PWMCON2 BIT 7 1 FP0 PMOD1 0 PMOD0 Address: CEh NAME FUNCTION BKCH See table below for BKCH settings. 6 BKPS Select which brake condition triggers brake flag. LSBD bit is described in SFR FSPLT. BKPS LSBD Description 0 0 0 = Brake is asserted if P1.1 is low. 1 0 1 = Brake is asserted if P1.1 is high x 1 Low level smart brake detector. 5 BPEN 4 BKEN BIT 3-2 See table below for BPEN settings. 0 = The Brake is never asserted. 1 = The Brake is enabled. NAME FP[1:0] FUNCTION Select PWM frequency prescaler select bits. The clock source of prescaler, Fpwm is in phase with Fosc if PWMRUN=1. FP[1:0] Fpwm 00 FOSC 01 FOSC /2 10 FOSC /4 11 FOSC /16 - 54 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued BIT 1-0 NAME FUNCTION PMOD[1:0] PWM Mode selects bits: PMOD[1:0] Description 00 Edge-aligned mode. (up counter) 01 Single-shot mode. (up counter) 10 Center aligned mode (up-down counter) 11 Reserved Brake Condition Table BPEN BKCH BRAKE CONDITION 0 Brake On, (Software brake and keeping brake). Software brake condition. When active (BPEN=BKCH=0, and BKEN=1), PWM output follows PWMnB setting. This brake has no effect on PWMRUN bit; therefore, internal PWM generator continues to run. When the brake is released, the state of PWM output depends on the current state of PWM generator output during the release. 1 Brake On, when PWM is not running (PWMRUN=0), the PWM output condition is follow PWMnB setting. When the brake is released (by disabling BKEN = 0), the PWM output resumes to the state when PWM generator stop running prior to enabling the brake. Brake Off, when PWM is running (PWMRUN=1). 1 0 Brake On, when Brake Pin asserted, PWM output follows PWMnB setting. The PWMRUN will be clear. External pin brake condition. When active (by external pin), PWM output follows PWMnB setting. PWMRUN will be cleared by hardware. BKF flag will be set. When the brake is released (by de-asserting the external pin + disabling BKEN = 0), the PWM output resumes to the state of the PWM generator output prior to the brake. 1 1 This brake condition (by Brake Pin) causes BKF to be set, but PWM generator continues to run. The PWM output does not follow PWMnB, instead it output continuously as per normal without affected by the brake. 0 0 PWM 4 LOW BITS REGISTER Bit: 7 6 5 4 3 2 1 0 PWM4.7 PWM4.6 PWM4.5 PWM4.4 PWM4.3 PWM4.2 PWM4.1 PWM4.0 Mnemonic: PWM4L PWM4.7-0 Address: CFh PWM4 Low Bits Register. PROGRAM STATUS WORD Bit: 7 6 5 4 3 2 1 0 CY AC F0 RS1 RS0 OV F1 P Mnemonic: PSW BIT Address: D0h NAME FUNCTION - 55 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 7 Carry flag. Set for an arithmetic operation which results in a carry being generated from the ALU. It is also used as the accumulator for the bit operations. Auxiliary carry: Set when the previous operation resulted in a carry (during addition) or a borrow (during subtraction) from the high order nibble. User flag 0. A general purpose flag that can be set or cleared by the by software. CY 6 AC 5 F0 4-3 RS.1-0 2 OV 1 F1 0 P Register bank selects bits: RS1 RS2 Register Bank 0 0 0 0 1 1 1 0 2 1 1 3 Address 00-07h 08-0Fh 10-17h 18-1Fh Overflow flag. Set when a carry was generated from the seventh bit but not from the 8th bit as a result of the previous operation or vice-versa. User Flag 1. General purpose flag that can be set or cleared by the user by software. Parity flag. Set/cleared by hardware to indicate odd/even number of 1's in the accumulator. PWMP COUNTER HIGH BITS REGISTER Bit: 7 6 5 4 3 2 1 0 - - - - PWMP.11 PWMP.10 PWMP.9 PWMP.8 Mnemonic: PWMPH Address: D1h BIT NAME FUNCTION 7-4 3-0 PWMP.11~PWMP.8 Reserved. PWM Counter Register bits 11~8. PWM 0 HIGH BITS REGISTER Bit: 7 6 - 5 - 4 3 - - 2 PWM0.11 PWM0.10 Mnemonic: PWM0H BIT 3~0 0 PWM0.9 PWM0.8 Address: D2h NAME 7~4 - 1 FUNCTION Reserved. PWM0.11 ~PWM0.8 The PWM 0 Register bit 11~8. NVM DATA Bit: 7 6 5 4 3 2 1 0 NVMDAT.7 NVMDAT.6 NVMDAT.5 NVMDAT.4 NVMDAT.3 NVMDAT.2 NVMDAT.1 NVMDAT.0 Mnemonic: NVMDAT Address: D3h - 56 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT 7~0 NAME FUNCTION NVMDAT.7~NVMDAT.0 The NVM data write register. The read NVM data is by MOVX instruction. QEI CONTROL REGISTER Bit: 7 6 5 4 3 2 1 0 - - - DISIDX DIR QEIM1 QEIM0 QEIEN Mnemonic: QEICON BIT 7-5 Address: D4h NAME FUNCTION - Reserved. DISIDX Disable Input Capture 2 edge detection function: 0 = Enable IC2 edge detection function (default). 1 = Disable IC2 edge detection function. This bit is effective when QEIEN=1. DIR Direction index of motion detection bit: 1 = Forward (Up-counting). 0 = Backward (Down-counting). This bit is writable and readable. 2-1 QEIM[1:0] QEI mode select bits: QEIM1 QEIM0 Descriptions 0 0 X4 free-counting mode 0 1 X2 free-counting mode 1 0 X4 compare-counting mode 1 1 X2 compare-counting mode 0 QEIEN Input module mode select bit: 0 = Input module performs Input Capture Functions. (Default value). 1 = Input module works as QEI. 4 3 PWM 2 HIGH BITS REGISTER Bit: 7 6 - 5 - 4 - 3 - 2 PWM2.11 PWM2.10 Mnemonic: PWM2H BIT 1 0 PWM2.9 PWM2.8 Address: D5h NAME FUNCTION 7~4 - Reserved 3~0 PWM2.11 ~PWM2.8 PWM 2 Register bit 11~8. PWM 6 HIGH BITS REGISTER Bit: 7 6 - 5 - 4 - 3 - Mnemonic: PWM6H BIT 2 PWM6.11 1 PWM6.10 0 PWM6.9 PWM6.8 Address: D6h NAME FUNCTION - 57 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 7~4 - Reserved 3~0 PWM6.11 ~PWM6.8 PWM 6 Register bit 11~8. WATCHDOG CONTROL 2 Bit: 7 6 5 4 3 2 1 0 - - - - - - - STRLD Mnemonic: WDCON2 BIT Address: D7h NAME FUNCTION 7-6 - Reserved. 0 STRLD Set this bit, CPU will restart from LD Flash EPROM after watchdog reset. Clear this bit, CPU will restart from AP Flash EPROM after watchdog reset. This register is protected by timer access (TA) register. WATCHDOG CONTROL Bit: 7 6 5 4 3 2 1 0 - POR - - WDIF WTRF EWT RWT Mnemonic: WDCON BIT Address: D8h NAME FUNCTION 7 - Reserved. 6 POR Power-on Reset Flag. Hardware will set this flag on a power up condition. This flag can be read or written by software. A write by software is the only way to clear this bit once it is set. 5-4 - Reserved. 3 WDIF Watchdog Timer Interrupt Flag. This bit is set by hardware to indicate that the time-out period has elapsed and invoke watch dog timer interrupt if enabled (EWDI=1). This bit must be clear by software. 2 WTRF Watchdog Timer Reset Flag. Hardware will set this bit when the watchdog timer causes a reset if EWT= 1. Software can read it but must clear it manually. A power-on reset will also clear the bit. This bit helps software in determining the cause of a reset 1 EWT Enable Watchdog timer Reset. Setting this bit will enable the Watchdog timer Reset function after 512 clocks delay from time out and setting WTRF flag. RWT Reset Watchdog Timer. This bit restarts the watchdog timer and helps in putting the watchdog timer into a know state. It also helps in resetting the watchdog timer before a time-out occurs. If EWDI (EIE.4) is set, an interrupt will occur when time-out. If EWT is set, 512 clocks after the time-out, a system reset will occur and CPU starts from 0000H. This bit is self-clearing. The WDCON SFR is set to a 0x0x0xx0b on an external reset. WTRF is set to a 1 on a Watchdog timer reset, but to a 0 on power on resets. WTRF is not altered by an external reset. POR is set to 1 by a power-on reset. EWT is cleared to 0 on a Power-on reset and unaffected by other resets. 0 The WDCON SFR is set to x0xx 0000b on an external reset. WTRF is set to a 1 on a Watchdog timer reset, but to a 0 on power on resets. POR is set to 1 by a power-on reset. EWT is cleared to 0 on a Power-on reset, reset pin reset, Watch Dog Timer reset and ISP reset. - 58 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet All the bits in this SFR have unrestricted read access. The bits of POR, WDIF, EWT and RWT require Timed Access (TA) procedure to write. The remaining bits have unrestricted write accesses. Please refer TA register description. PWMP COUNTER LOW BITS REGISTER Bit: 7 6 PWMP.7 5 PWMP.6 4 PWMP.5 3 PWMP.4 2 PWMP.3 PWMP.2 Mnemonic: PWMPL BIT 1 0 PWMP.1 PWMP.0 Address: D9h NAME FUNCTION 7~0 PWMP.7 ~PWMP.0 PWM Counter Low Bits Register. PWM0 LOW BITS REGISTER Bit: 7 6 PWM0.7 5 PWM0.6 4 PWM0.5 3 PWM0.4 2 PWM0.3 PWM0.2 Mnemonic: PWM0L BIT 1 0 PWM0.1 PWM0.0 Address: DAh NAME FUNCTION 7~0 PWM0.7 ~PWM0.0 PWM 0 Low Bits Register. NVM LOW BYTE ADDRESS Bit: 7 6 5 4 3 2 1 0 NVMADDR NVMADDR NVMADDR NVMADDR NVMADDR NVMADDR NVMADDR NVMADDR L.7 L.6 L.5 L.4 L.3 L.2 L.1 L.0 Mnemonic: NVMADDRL BIT 7~0 Address: DBh NAME FUNCTION NVMADDRL.7~ NVM low byte address. NVMADDRL.0 PWM CONTROL REGISTER 1 Bit: 7 PWMRUN 6 5 Load PWMF 4 3 CLRPWM PWM6I Mnemonic: PWMCON1 2 1 PWM4I 0 PWM2I PWM0I Address: DCh - 59 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME FUNCTION PWMRUN 0 = The PWM is not running. 1 = The PWM counter is running. Load This bit is auto cleared by hardware after the PWMP and PWMn are transferred to counter and compare register: 0 = The registers value of PWMP and PWMn is never loaded to counter and compare registers. 1 = The PWMP and PWMn registers load value to counter and compare registers at the counter underflow/match. 5 PWMF 12 bit counter overflow flag: 0 = The 12-bit counter is not underflow/match. 1 = The 12-bit counter is underflow/match. It will be set by hardware and cleared by software. 4 CLRPWM 1 = Clear 12-bit PWM counter to 000H. It will be automatically clear by hardware. 3-0 PWMxI 0 = PWM0 output is non-inverted. 1 = PWM0 output is inverted. Note: x = 0,2,4,6. 7 6 PWM 2 LOW BITS REGISTER Bit: 7 6 5 PWM2.7 PWM2.6 4 PWM2.5 3 PWM2.4 2 PWM2.3 1 PWM2.2 0 PWM2.1 Mnemonic: PWM2L BIT PWM2.0 Address: DDh NAME FUNCTION 7~0 PWM2.7 ~PWM2.0 PWM 2 Low Bits Register. PWM 6 LOW BITS REGISTER Bit: 7 6 5 PWM6.7 PWM6.6 4 PWM6.5 3 PWM6.4 2 PWM6.3 Mnemonic: PWM6L BIT 7~0 1 PWM6.2 0 PWM6.1 PWM6.0 Address: DEh NAME FUNCTION PWM6.7 ~PWM6.0 PWM 6 Low Bits Register. PWM CONTROL REGISTER 3 Bit: 7 PWM7B 6 PWM6B 5 PWM5B 4 3 PWM4B Mnemonic: PWMCON3 2 PWM3B 1 PWM2B PWM1B 0 PWM0B Address: DFh - 60 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME 7-0 PWMxB FUNCTION 0 = The PWM0 output is low, when Brake is asserted. 1 = The PWM0 output is high, when Brake is asserted. Note: x = 0~7 ACCUMULATOR Bit: 7 6 5 4 3 2 1 0 ACC.7 ACC.6 ACC.5 ACC.4 ACC.3 ACC.2 ACC.1 ACC.0 Mnemonic: ACC BIT 7-0 Address: E0h NAME ACC FUNCTION The A or ACC register is the standard 8032 accumulator ADC CONTROL REGISTER Bit: 7 6 5 4 3 2 1 0 ADCEN - ADCEX ADCI ADCS AADR.2 AADR.1 AADR.0 Mnemonic: ADCCON BIT NAME 7 6 ADCEN - 5 ADCEX 4 ADCI 3 Address: E1h ADCS FUNCTION Enable A/D Converter Function. Set ADCEN to logic high to enable ADC block. Reserved. Enable external start control of ADC conversion by a rising edge from P4.0. ADCEX=0: Disable external start. ADCEX=1: Enable external start control. A/D Converting Complete/Interrupt Flag. This flag is set when ADC conversion is completed. The ADC interrupt is requested if the interrupt is enabled. ADCI is set by hardware and cleared by software only. ADC Start and Status: Set this bit to start an A/D conversion. It may also be set by STADC if ADCEX is 1. This signal remains high while the ADC is busy and is reset right after ADCI is set. Notes: 1. It is recommended to clear ADCI before ADCS is set. However, if ADCI is cleared and ADCS is set at the same time, a new A/D conversion may start on the same channel. 2. Software clearing of ADCS will abort conversion in progress. 3. ADC cannot start a new conversion while ADCS or ADCI is high. Select and enable analog input channel from ADC0 to ADC7. AADR[2:0] ADC selected input AADR[2:0] ADC selected input 2-0 AADR 000 001 010 011 ADCCH0 (P1.0) ADCCH1 (P1.1) ADCCH2 (P1.2) ADCCH3 (P1.3) - 61 - 100 101 110 111 ADCCH4 (P1.4) ADCCH5 (P1.5) ADCCH6 (P1.6) ADCCH7 (P1.7) Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet The ADCI and ADCS control the ADC conversion as below: ADCI ADCS ADC STATUS 0 0 ADC not busy; A conversion can be started. 0 1 ADC busy; Start of a new conversion is blocked. 1 0 Conversion completed; Start of a new conversion requires ADCI = 0. 1 1 This is an internal temporary state that user can ignore it. ADC CONVERTER RESULT HIGH REGISTER Bit: 7 6 5 4 3 2 1 0 ADC.9 ADC.8 ADC.7 ADC.6 ADC.5 ADC.4 ADC.3 ADC.2 Mnemonic: ADCH BIT NAME 7-0 ADC[9:2] Address: E2h FUNCTION 8 MSB of 10 bit A/D conversion result. ADCH is a read only register. ADC CONVERTER RESULT LOW REGISTER Bit: 7 6 5 4 3 2 1 0 ADCLK.1 ADCLK.0 - - - - ADC.1 ADC.0 Mnemonic: ADCL BIT Address: E3h NAME FUNCTION ADC Clock Frequency Select. The 10 bit ADC needs a clock to drive the converting that the clock frequency may not over 4MHz. ADCLK[1:0] controls the frequency of the clock to ADC block: ADCLK.1 7-6 1-0 ADCLK ADC ADCLK.0 ADC Clock Frequency 0 0 Crystal clock / 4 (Default) 0 1 Crystal clock / 8 1 0 Crystal clock / 16 1 1 Reserved 2 LSB of 10-bit A/D conversion result. Both bits are read only. PWM DEAD-TIME CONTROL REGISTER 1 Bit: 7 6 5 4 3 2 1 0 PDTC1.7 PDTC1.6 PDTC1.5 PDTC1.4 PDTC1.3 PDTC1.2 PDTC1.1 PDTC1.0 Mnemonic: PDTC1 Address: E5h - 62 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME FUNCTION Dead-time clock frequency (FDT) prescaler select bits. 7-6 5-0 PDTC1.7 PDTC1.6 FDT 0 0 FOSC/2 0 1 FOSC/4 1 0 FOSC/8 1 1 FOSC/16 PDTC1 PDTC1 Dead time counter. Unsigned 6 bit dead time value bits for Dead Time Unit. Dead-time = FDT * (PDTC1 [5:0]+1) PWM DEAD-TIME CONTROL REGISTER 0 Bit: 7 6 5 4 3 2 1 0 PDTC0.7 PDTC0.6 PDTC0.5 PDTC0.4 PDTC0.3 PDTC0.2 PDTC0.1 PDTC0.0 Mnemonic: PDTC0 BIT 7-4 3-0 Address: E6h NAME FUNCTION PDTC0 Control complementary PWM to delay a dead-time at every rising edge or falling edge. Reset value = 0. 1 = Dead-time is inserted at falling edge. 0 = Dead-time is inserted at rising edge. PDTC0.4 - controls the pair of (PWM0, PWM1). PDTC0.5 - controls the pair of (PWM2, PWM3). PDTC0.6 - controls the pair of (PWM4, PWM5). PDTC0.7 - controls the pair of (PWM6, PWM7). PDTC0 Enable dead-time insertion; Dead-time insertion is only active when the pair of complementary PWM is enabled. Reset value=0. If dead-time insertion is inactive, the outputs of pin pair are complementary without any delay. 1 = Programmable dead-time is inserted into the pair signals of comparator output to delay the pair signals change from low to high. 0 = Disable dead-time insertion. PDTC0.0 - enables the dead-time insertion on the pin pair (PWM0, PWM1). PDTC0.1 - enables the dead-time insertion on the pin pair (PWM2, PWM3). PDTC0.2 - enables the dead-time insertion on the pin pair (PWM4, PWM5). PDTC0.3 - enables the dead-time insertion on the pin pair (PWM6, PWM7). PWM CONTROL REGISTER 4 Bit: 7 6 5 4 3 PWMEOM PWMOOM PWM6OM PWM7OM Mnemonic: PWMCON4 2 - 1 - 0 - BKF Address: E7h - 63 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME FUNCTION PWMEOM PWM Channel 0, 2 and 4 Output Mode. 0 = Disable PWM channels 0, 2 and 4 to pwm output pins. 1 = Enable PWM channels 0, 2 and 4 to pwm output pins. 6 PWMOOM PWM Channel 1, 3 and 5 Output Mode. 0 = Disable PWM channels 1, 3 and 5 to pwm output pins. 1 = Enable PWM channels 1, 3 and 5 to pwm output pins. 5 PWM6OM PWM Channel 6 Output Mode. 0 = Disable PWM channel 6 to pwm output pin. 1 = Enable PWM channel 6 to pwm output pin. 4 PWM7OM PWM Channel 7 Output Mode. 0 = Disable PWM channel 7 to pwm output pin. 1 = Enable PWM channel 7 to pwm output pin. 3-1 - Reserved. BKF The External Brake Pin Flag. 0 = The PWM is not brake. 1 = The PWM is brake by external brake pin. It will be cleared by software. 7 0 Together with option bits (PWMEE and PWMOE), PWMEOM, PWMOOM, PWM6OM and PWM7OM control the PWM pin structure, as follow; PWMEE/PWMOE (OPTION BITS) PWMEOM/PWMOOM /PWM6OM/PWM7OM PIO.X (X = 0-7) PIN STRUCTURES X 0 X Tri-state 1 (Disable) 1 X Quasi (I/O output) 0 (Enable) 1 0 Push Pull (PWM output) 0 (Enable) 1 1 Push Pull (I/O output) Table 7-2: PWM pin structures (during internal rom execution) PWMEE/PWMOE (OPTION BITS) PWMEOM/PWMOOM /PWM6OM/PWM7OM PIO.X (X = 0-7) 1 (Disable) X X External access Push Pull 0 (Enable) X X External access Push Pull (strong) PIN OUTPUT PIN STRUCTURES Table 7-3: PWM pin structures (during external rom execution) Note: PWMEOM/PWMOOM/PWM6OM/PWM7OM are cleared to zero when CPU in reset state. Thus, the port pins that multi-function with PWM will be tristated on default. User is required to set the bits to 1 to enable GPIO/PWM outputs. - 64 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet EXTENDED INTERRUPT ENABLE Bit: 7 6 5 4 3 2 1 0 ES1 EX5 EX4 EWDI EX3 EX2 - EI2C Mnemonic: EIE BIT Address: E8h NAME FUNCTION 7 ES1 Enable Serial Port 1 interrupts. 6 EX5 Enable External Interrupt 5. 5 EX4 Enable External Interrupt 4. 4 EWDI Enable Watchdog timer interrupt. 3 EX3 Enable External Interrupt 3. 2 EX2 Enable External Interrupt 2. 1 - Reserved. 0 EI2C Enable I2C interrupt. I2C CONTROL REGISTER Bit: 7 6 5 4 3 2 1 0 - ENS STA STO SI AA I2CIN - Mnemonic: I2CON BIT Address: E9h NAME FUNCTION 7 - Reserved. 6 ENS I2C serial function block enable bit. When ENS=1 the I2C serial function enables. The port latches of SDA and SCL must be set to logic high. 5 STA I2C START Flag. Setting STA to logic 1 to enter master mode, the I2C hardware sends a START or repeat START condition to bus when the bus is free. 4 STO I2C STOP Flag. In master mode, setting STO to transmit a STOP condition to bus then I2C hardware will check the bus condition if a STOP condition is detected this flag will be cleared by hardware automatically. In a slave mode, setting STO resets I2C hardware to the defined “not addressed” slave mode. 3 SI I2C Interrupt Flag. When a new SIO state is present in the S1STA register, the SI flag is set by hardware, and if the EA and EI2C bits are both set, the I2C interrupt is requested. SI must be cleared by software. 2 AA Assert Acknowledge Flag. When AA=1 an acknowledged (low level to SDA) will be returned during the acknowledge clock pulse on the SCL line. When AA=0 an acknowledged (high level to SDA) will be returned during the acknowledge clock pulse on the SCL line. 1 I2CIN By default it is zero and input are allows to come in through SDA pin. As when it is 1 input is disallow and to prevent leakage current. During Power-Down mode input is disallow. 0 - Reserved. - 65 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet I2C ADDRESS REGISTER Bit: 7 I2ADDR.7 6 I2ADDR.6 5 I2ADDR.5 4 I2ADDR.4 3 I2ADDR.3 2 I2ADDR.2 Mnemonic: I2ADDR BIT 1 I2ADDR.1 0 GC Address: EAh NAME FUNCTION 7-1 I2ADDR I2C Slave Address. The contents of the register are irrelevant when I2C is in master mode. In the slave mode, the seven most significant bits must be loaded with the MCU’s own slave address. The I2C hardware will react if the contents of I2ADDR are matched with the received slave address. 0 GC Enable General Call Function. The GC bit is set the I2C port hardware will respond to General Call address (00H). Clear GC bit to disable general call function. NVM HIGH BYTE ADDRESS Bit: 7 6 5 4 3 2 1 0 - - - - - NVMADDR NVMADDR NVMADDR H.10 H.9 H.8 Mnemonic: NVMADDRH BIT 7-3 2-0 Address: EBh NAME NVMADDRH.10 ~ NVMADDRH.8 FUNCTION Reserved. NVM High byte address I2C DATA REGISTER Bit: 7 I2DAT.7 6 I2DAT.6 5 I2DAT.5 4 I2DAT.4 3 I2DAT.3 2 I2DAT.2 1 I2DAT.1 Mnemonic: I2DAT I2DAT.7-0 The data register of I2C channel. 0 I2DAT.0 Address: ECh I2C STATUS REGISTER Bit: 7 B7 6 B6 5 B5 4 B4 3 B3 2 0 Mnemonic: I2STATUS BIT 7-0 1 0 0 0 Address: EDh NAME FUNCTION I2STATUS The Status Register of I2C. The three least significant bits are always 0. The five most significant bits contain the status code. There are 23 possible status codes. When I2STATUS contains F8H, no serial interrupt is requested. All other I2STATUS values correspond to defined I2C states. When each of these states is entered, the I2C1 interrupt is requested (SI = 1). A valid status code is present in I2STATUS one machine cycle after SI is set by hardware and is still present one machine cycle after SI has been reset by software. In addition, states 00H stands for a Bus Error. A Bus Error occurs when a START or STOP condition is present at an illegal position in the formation frame. Example of illegal position are during the serial transfer of an address byte, a data byte or an acknowledge bit. - 66 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet I2C BAUD RATE CONTROL REGISTER Bit: 7 6 5 4 3 2 1 0 I2CLK.7 I2CLK.6 I2CLK.5 I2CLK.4 I2CLK.3 I2CLK.2 I2CLK.1 I2CLK.0 Mnemonic: I2CLK BIT 7-0 Address: EEh NAME I2CLK FUNCTION I2C clock rate control. I2C TIMER COUNTER REGISTER Bit: 7 6 5 4 3 2 1 0 - - - - - ENTI DIV4 TIF Mnemonic: I2TIMER BIT Address: EFh NAME FUNCTION 7-3 - Reserved. 2 ENTI Enable I2C 14-bits Time-out Counter. Setting ENTI to logic high will firstly reset the time-out counter and then start up counting. Clearing ENTI disables the 14bit time-out counter. ENTI can be set to logic high only when SI=0. 1 DIV4 I2C Time-out Counter Clock Frequency Selection. 0 = the clock frequency is coherent to the system clock Fosc. 1 = the clock frequency is Fosc/4. 0 TIF I2C Time-out Flag. When the time-out counter overflows hardware will set this flag and request the I2C interrupt if I2C interrupt is enabled (EI2C=1). This bit must be cleared by software. B REGISTER Bit: 7 6 5 4 3 2 1 0 B.7 B.6 B.5 B.4 B.3 B.2 B.1 B.0 Mnemonic: B BIT 7-0 Address: F0h NAME B FUNCTION The B register is the standard 8032 accumulator. SERIAL PERIPHERAL CONTROL REGISTER Bit: 7 6 5 4 3 2 1 0 SSOE SPE LSBFE MSTR CPOL CPHA SPR1 SPR0 Mnemonic: SPCR Address: - 67 - F3h Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME FUNCTION SSOE Slave Select Output Enable Bit. The SS output feature is enabled only in master mode by asserting the SSOE bit. In slave mode (/SS) input is not affected by SSOE bit. See table below. SPE Serial Peripheral System Enable Bit. When the SPE bit is set, SPI block functions is enable. When MODF is set, SPE always reads 0. 0 = SPI system disabled. 1 = SPI system enabled. LSBFE LSB - First Enable. This bit does not affect the position of the MSB and LSB in the data register. Reads and writes of the data register always have the MSB in bit 7. In master mode, a change of this bit will abort a transmission in progress and force the SPI system into idle state. 1 = Data is transferred least significant bit first. 0 = Data is transferred most significant bit first. 4 MSTR Master Mode Select Bit. It is customary to have an external pull-up resistor on lines that are driven by open drain devices. 0 = Slave mode. 1 = Master mode. 3 CPOL Clock Polarity Bit. When the clock polarity bit is cleared and data is not being transferred, the SPCLK pin of the master device has a steady state low value. When CPOL is set, SPCLK idles high. 2 CPHA Clock Phase Bit. The clock phase bit, in conjunction with the CPOL bit, controls the clock-data relationship between master and slave. The CPHA bit selects one of two different clocking protocols. 1-0 SPR SPI Baud Rate Selection Bits. These bits specify the SPI baud rates. 7 6 5 DRSS SSOE MASTER MODE SLAVE MODE 0 0 /SS input ( With Mode Fault ) /SS Input ( Not affected by SSOE ) 0 1 Reserved /SS Input ( Not affected by SSOE ) 1 0 /SS General purpose I/O ( No Mode Fault ) /SS Input ( Not affected by SSOE ) 1 1 /SS output ( No Mode Fault ) /SS Input ( Not affected by SSOE ) Note: In master mode, a change of LSBFE, MSTR, CPOL, CPHA and SPR [1:0] will abort a transmission in progress and force the SPI system into idle state. SERIAL PERIPHERAL STATUS REGISTER Bit: 7 6 SPIF WCOL 5 SPIOVF 4 3 MODF 2 DRSS Mnemonic: SPSR BIT 1 - 0 - - Address: F4h NAME FUNCTION - 68 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 7 SPIF 6 WCOL 5 SPIOVF 4 MODF 3 2-0 DRSS - SPI Interrupt Complete Flag. SPIF is set upon completion of data transfer between this device and external device or when new data has been received and copied to the SPDR. If SPIF goes high, and if ESPI is set, a serial peripheral interrupt is generated. When SPIF is set; it must be clear by software and attempts to write SPDR are inhibited if SPIF set. Write Collision Flag. If a writer collision occurs on SPI bus, WCOL is set to high by hardware. WCOL must be clear by software. SPI overrun flag. SPIOVF is set if a new character is received before a previously received character is read from SPDR. Once this bit is set it will prevent SPDR register form excepting new data and must be cleared first before any new data can be written. This flag is clear by software. 0 = No overrun. 1 = Overrun detected. SPI Mode Error Interrupt Status Flag. MODF is set when hardware detects mode fault. This bit is cleared by software. Data Register Slave Select. Refer to above table in SPCR register. Reserved. Note: Bits WCOL, MODF and SPIF are cleared by software writing “0” to them. SERIAL PERIPHERAL DATA I/O REGISTER Bit: 7 SPD.7 6 SPD.6 5 SPD.5 4 SPD.4 3 SPD.3 Mnemonic: SPDR BIT 7-0 2 SPD.2 1 SPD.1 0 SPD.0 Address: F5h NAME FUNCTION SPDR is used when transmitting or receiving data on serial bus. Only a write to this register initiates transmission or reception of a byte, and this only occurs in the master device. A read of the SPDR is actually a read of a buffer. To prevent an overrun and the loss of the byte that caused the overrun, the first SPIF must be cleared by the time a second transfer of data from the shift Register to the read buffer is initiated. SPD I2C SLAVE ADDRESS MASK ENABLE Bit: 7 I2CSADE N.7 6 I2CSADE N.6 5 I2CSADE N.5 4 I2CSADE N.4 3 I2CSADE N.3 Mnemonic: I2CSADEN BIT 7-0 2 I2CSADE N.2 1 I2CSADE N.1 0 I2CSADE N.0 Address: F6h NAME FUNCTION I2CSADEN This register enables the Automatic Address Recognition feature of the I2C. When a bit in the I2CSADEN is set to 1, the same bit location in I2CSADDR1 will be compared with the incoming serial port data. When I2CSADEN.n is 0, the bit becomes don't care in the comparison. This register enables the Automatic Address Recognition feature of the I2C. When all the bits of I2CSADEN are 0, interrupt will occur for any incoming address. The default value is 0xFE. - 69 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet EXTENDED INTERRUPT HIGH PRIORITY Bit: 7 6 5 4 3 2 1 0 PS1H PX5H PX4H PWDIH PX3H PX2H - PI2CH Mnemonic: EIPH BIT Address: F7h NAME FUNCTION 7 PS1H Serial Port 1 Interrupt High Priority. PS1H = 1 sets it to highest priority level. 6 PX5H External Interrupt 5 High Priority. PX5H = 1 sets it to highest priority level. 5 PX4H External Interrupt 4 High Priority. PX4H = 1 sets it to highest priority level. 4 PWDIH Watchdog Timer Interrupt High Priority. PWDIH = 1 sets it to highest priority level. 3 PX3H External Interrupt 3 High Priority. PX3H = 1 sets it to highest priority level. 2 PX2H External Interrupt 2 High Priority. PX2H = 1 sets it to highest priority level. 1 - Reserved. 0 PI2CH I2C Interrupt High Priority. PI2CH = 1 sets it to highest priority level. EXTENDED INTERRUPT PRIORITY Bit: 7 6 5 4 3 2 1 0 PS1 PX5 PX4 PWDI PX3 PX2 - PI2C Mnemonic: EIP BIT Address: F8h NAME FUNCTION 7 PS1 Serial Port 1 Interrupt Priority. 6 PX5 External Interrupt 5 Priority. 5 PX4 External Interrupt 4 Priority. 4 PWDI Watchdog Timer Interrupt Priority. 3 PX3 External Interrupt 3 Priority. 2 PX2 External Interrupt 2 Priority. 1 - Reserved. 0 PI2C I2C Interrupt Priority. EXTENDED INTERRUPT ENABLE 1 Bit: 7 6 - 5 - 4 ENVM 3 ECPTF Mnemonic: EIE1 2 ET3 1 EBK 0 EPWM ESPI Address: F9h - 70 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT NAME FUNCTION 7-6 - Reserved. 5 ENVM NVM Interrupt Enable Bit. 0 = Disable NVM interrupt. 1 = Enable NVM interrupt. 4 ECPTF Capture Interrupt Enable Bit. 0 = Disable External capture/reload interrupt. 1 = Enable External capture/reload interrupt. 3 ET3 Timer 3 Interrupt Enable Bit. 0 = Disable Timer 3 Interrupt. 1 = Enable Timer 3 Interrupt. 2 EBK Brake Interrupt Enable Bit. 0 = Brake interrupt disable. 1 = Brake interrupt enable. 1 EPWM PWM Period Interrupt Enable Bit. 0 = PWM period system interrupts disabled. 1 = PWM period system interrupts enabled. ESPI Serial Peripheral Interrupt Enable Bit. Set the ESPI bit to 1 to request a hardware interrupt sequence each time the SPIF/MODF status flag is set. 0 = SPI system interrupts disabled. 1 = SPI system interrupts enabled. 0 EXTENDED INTERRUPT PRIORITY 1 Bit: 7 6 5 4 3 2 1 0 - - PNVMI PCPTF PT3 PBKF PPWMF PSPI Mnemonic: EIP1 BIT Address: FAh NAME FUNCTION 7-6 - Reserved. 5 PNVMI NVM interrupt Priority 4 PCPTF Capture/reload Interrupt Priority. 3 PT3 Timer 3 Interrupt Priority. 2 PBKF PWM Brake Interrupt Priority. 1 PPWMF PWM period Interrupt Priority. 0 PSPI SPI Interrupt Priority. INPUT CAPTURE 0/PULSE READ COUNTER LOW REGISTER Bit: 7 6 5 4 3 2 1 0 CCL0.7/ PCNTL.7 CCL0.6/ PCNTL.6 CCL0.5/ PCNTL.5 CCL0.4/ PCNTL.4 CCL0.3/ PCNTL.3 CCL0.2/ PCNTL.2 CCL0.1/ PCNTL.1 CCL0.0/ PCNTL.0 Mnemonic: CCL0/PCNTL Address: FBh - 71 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PCNTL must be read first before reading at PCNTH as reading PCNTL will latch the PLSCNTH automatically into PCNTH; otherwise inaccurate result is read when reading PCNTH first as it will not latch the PLSCNTL data into PCNTL. INPUT CAPTURE 0/PULSE READ COUNTER HIGH REGISTER Bit: 7 6 5 4 3 2 1 0 CCH0.7/ PCNTH.7 CCH0.6/ PCNTH.6 CCH0.5/ PCNTH.5 CCH0.4/ PCNTH.4 CCH0.3/ PCNTH.3 CCH0.2/ PCNTH.2 CCH0.1/ PCNTH.1 CCH0.0/ PCNTH.0 Mnemonic: CCH0/PCNTH Address: FCh PCNTL must be read first before reading at PCNTH as reading PCNTL will latch the PLSCNTH automatically into PCNTH. INPUT CAPTURE 1/PULSE COUNTER LOW REGISTER Bit: 7 6 5 4 3 2 1 0 CCL1.7/ PLSCNT L.7 CCL1.6/ PLSCNT L.6 CCL1.5/ PLSCNT L.5 CCL1.4/ PLSCNT L.4 CCL1.3/ PLSCNT L.3 CCL1.2/ PLSCNT L.2 CCL1.1/ PLSCNT L.1 CCL1.0/ PLSCNT L.0 Mnemonic: CCL1/PLSCNTL Address: FDh INPUT CAPTURE 1/PULSE COUNTER HIGH REGISTER Bit: 7 6 5 4 3 2 1 0 CCH1.7/ CCH1.6/ CCH1.5/ CCH1.4/ CCH1.3/ CCH1.2/ CCH1.1/ PLSCNT H.7 PLSCNT H.6 PLSCNT H.5 PLSCNT H.4 PLSCNT H.3 PLSCNT H.2 PLSCNT H.1 CCH1.0/ PLSCNT H.0 Mnemonic: CCH1/PLSCNTH Address: FEh INTERRUPT CONTROL Bit: 7 6 5 4 3 2 1 0 - - INT5CT1 INT5CT0 INT4CT1 INT4CT0 INT3CT1 INT3CT0 Mnemonic: INTCTRL Address: FFh - 72 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet BIT 7-6 NAME - FUNCTION Reserved. Interrupt 5 edge select: 5-4 INT5CT INT5CT1 INT5CT0 Description 0 0 Rising edge trigger. 0 1 Falling edge trigger. 1 0 Rising and falling edge trigger. 1 1 Reserved. Interrupt 4 edge select: 3-2 INT4CT INT4CT1 INT4CT0 Description 0 0 Rising edge trigger. 0 1 Falling edge trigger. 1 0 Rising and falling edge trigger. 1 1 Reserved. Interrupt 3 edge select: 1-0 INT3CT INT3CT1 INT3CT0 Description 0 0 Rising edge trigger. 0 1 Falling edge trigger. 1 0 Rising and falling edge trigger. 1 1 Reserved. - 73 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 8. INSTRUCTION SET The W79E22X SERIES executes all the instructions of the standard 8051/52 family. The operations of these instructions, as well as their effects on flag and status bits, are exactly the same. However, the timing of these instructions is different in two ways. Firstly, the W79E22X SERIES machine cycle is four clock periods, while the standard-8051/52 machine cycle is twelve clock periods. Secondly, the W79E22X SERIES can fetch only once per machine cycle (i.e., four clocks per fetch), while the standard 8051/52 can fetch twice per machine cycle (i.e., six clocks per fetch). The timing differences create an advantage for the W79E22X SERIES. There is only one fetch per machine cycle, so the number of machine cycles is usually equal to the number of operands in the instruction. (Jumps and calls do require an additional cycle to calculate the new address.) As a result, the W79E22X SERIES reduces the number of dummy fetches and wasted cycles, and therefore improves overall efficiency, compared to the standard 8051/52. OP-CODE HEX CODE W79E22X SERIES MACHINE CYCLE BYTES W79E22X SERIES CLOCK CYCLES W79E22X SERIES VS. 8032 SPEED RATIO 8032 CLOCK CYCLES NOP 00 1 1 4 12 3 ADD A, R0 28 1 1 4 12 3 ADD A, R1 29 1 1 4 12 3 ADD A, R2 2A 1 1 4 12 3 ADD A, R3 2B 1 1 4 12 3 ADD A, R4 2C 1 1 4 12 3 ADD A, R5 2D 1 1 4 12 3 ADD A, R6 2E 1 1 4 12 3 ADD A, R7 2F 1 1 4 12 3 ADD A, @R0 26 1 1 4 12 3 ADD A, @R1 27 1 1 4 12 3 ADD A, direct 25 2 2 8 12 1.5 ADD A, #data 24 2 2 8 12 1.5 ADDC A, R0 38 1 1 4 12 3 ADDC A, R1 39 1 1 4 12 3 ADDC A, R2 3A 1 1 4 12 3 ADDC A, R3 3B 1 1 4 12 3 ADDC A, R4 3C 1 1 4 12 3 ADDC A, R5 3D 1 1 4 12 3 ADDC A, R6 3E 1 1 4 12 3 ADDC A, R7 3F 1 1 4 12 3 ADDC A, @R0 36 1 1 4 12 3 ADDC A, @R1 37 1 1 4 12 3 ADDC A, direct 35 2 2 8 12 1.5 - 74 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued OP-CODE HEX CODE W79E22X SERIES MACHINE CYCLE BYTES W79E22X SERIES CLOCK CYCLES W79E22X SERIES VS. 8032 SPEED RATIO 8032 CLOCK CYCLES ADDC A, #data 34 2 2 8 12 1.5 SUBB A, R0 98 1 1 4 12 3 SUBB A, R1 99 1 1 4 12 3 SUBB A, R2 9A 1 1 4 12 3 SUBB A, R3 9B 1 1 4 12 3 SUBB A, R4 9C 1 1 4 12 3 SUBB A, R5 9D 1 1 4 12 3 SUBB A, R6 9E 1 1 4 12 3 SUBB A, R7 9F 1 1 4 12 3 SUBB A, @R0 96 1 1 4 12 3 SUBB A, @R1 97 1 1 4 12 3 SUBB A, direct 95 2 2 8 12 1.5 SUBB A, #data 94 2 2 8 12 1.5 INC A 04 1 1 4 12 3 INC R0 08 1 1 4 12 3 INC R1 09 1 1 4 12 3 INC R2 0A 1 1 4 12 3 INC R3 0B 1 1 4 12 3 INC R4 0C 1 1 4 12 3 INC R5 0D 1 1 4 12 3 INC R6 0E 1 1 4 12 3 INC R7 0F 1 1 4 12 3 INC @R0 06 1 1 4 12 3 INC @R1 07 1 1 4 12 3 INC direct 05 2 2 8 12 1.5 INC DPTR A3 1 2 8 24 3 DEC A 14 1 1 4 12 3 DEC R0 18 1 1 4 12 3 DEC R1 19 1 1 4 12 3 DEC R2 1A 1 1 4 12 3 DEC R3 1B 1 1 4 12 3 DEC R4 1C 1 1 4 12 3 DEC R5 1D 1 1 4 12 3 - 75 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued OP-CODE HEX CODE W79E22X SERIES MACHINE CYCLE BYTES W79E22X SERIES CLOCK CYCLES W79E22X SERIES VS. 8032 SPEED RATIO 8032 CLOCK CYCLES DEC R6 1E 1 1 4 12 3 DEC R7 1F 1 1 4 12 3 DEC @R0 16 1 1 4 12 3 DEC @R1 17 1 1 4 12 3 DEC direct 15 2 2 8 12 1.5 MUL AB A4 1 5 20 48 2.4 DIV AB 84 1 5 20 48 2.4 DA A D4 1 1 4 12 3 ANL A, R0 58 1 1 4 12 3 ANL A, R1 59 1 1 4 12 3 ANL A, R2 5A 1 1 4 12 3 ANL A, R3 5B 1 1 4 12 3 ANL A, R4 5C 1 1 4 12 3 ANL A, R5 5D 1 1 4 12 3 ANL A, R6 5E 1 1 4 12 3 ANL A, R7 5F 1 1 4 12 3 ANL A, @R0 56 1 1 4 12 3 ANL A, @R1 57 1 1 4 12 3 ANL A, direct 55 2 2 8 12 1.5 ANL A, #data 54 2 2 8 12 1.5 ANL direct, A 52 2 2 8 12 1.5 ANL direct, #data 53 3 3 12 24 2 ORL A, R0 48 1 1 4 12 3 ORL A, R1 49 1 1 4 12 3 ORL A, R2 4A 1 1 4 12 3 ORL A, R3 4B 1 1 4 12 3 ORL A, R4 4C 1 1 4 12 3 ORL A, R5 4D 1 1 4 12 3 ORL A, R6 4E 1 1 4 12 3 ORL A, R7 4F 1 1 4 12 3 ORL A, @R0 46 1 1 4 12 3 ORL A, @R1 47 1 1 4 12 3 ORL A, direct 45 2 2 8 12 1.5 ORL A, #data 44 2 2 8 12 1.5 - 76 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued OP-CODE HEX CODE W79E22X SERIES MACHINE CYCLE BYTES W79E22X SERIES CLOCK CYCLES W79E22X SERIES VS. 8032 SPEED RATIO 8032 CLOCK CYCLES ORL direct, A 42 2 2 8 12 1.5 ORL direct, #data 43 3 3 12 24 2 XRL A, R0 68 1 1 4 12 3 XRL A, R1 69 1 1 4 12 3 XRL A, R2 6A 1 1 4 12 3 XRL A, R3 6B 1 1 4 12 3 XRL A, R4 6C 1 1 4 12 3 XRL A, R5 6D 1 1 4 12 3 XRL A, R6 6E 1 1 4 12 3 XRL A, R7 6F 1 1 4 12 3 XRL A, @R0 66 1 1 4 12 3 XRL A, @R1 67 1 1 4 12 3 XRL A, direct 65 2 2 8 12 1.5 XRL A, #data 64 2 2 8 12 1.5 XRL direct, A 62 2 2 8 12 1.5 XRL direct, #data 63 3 3 12 24 2 CLR A E4 1 1 4 12 3 CPL A F4 1 1 4 12 3 RL A 23 1 1 4 12 3 RLC A 33 1 1 4 12 3 RR A 03 1 1 4 12 3 RRC A 13 1 1 4 12 3 SWAP A C4 1 1 4 12 3 MOV A, R0 E8 1 1 4 12 3 MOV A, R1 E9 1 1 4 12 3 MOV A, R2 EA 1 1 4 12 3 MOV A, R3 EB 1 1 4 12 3 MOV A, R4 EC 1 1 4 12 3 MOV A, R5 ED 1 1 4 12 3 MOV A, R6 EE 1 1 4 12 3 MOV A, R7 EF 1 1 4 12 3 MOV A, @R0 E6 1 1 4 12 3 MOV A, @R1 E7 1 1 4 12 3 - 77 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued OP-CODE HEX CODE W79E22X SERIES MACHINE CYCLE BYTES W79E22X SERIES CLOCK CYCLES W79E22X SERIES VS. 8032 SPEED RATIO 8032 CLOCK CYCLES MOV A, direct E5 2 2 8 12 1.5 MOV A, #data 74 2 2 8 12 1.5 MOV R0, A F8 1 1 4 12 3 MOV R1, A F9 1 1 4 12 3 MOV R2, A FA 1 1 4 12 3 MOV R3, A FB 1 1 4 12 3 MOV R4, A FC 1 1 4 12 3 MOV R5, A FD 1 1 4 12 3 MOV R6, A FE 1 1 4 12 3 MOV R7, A FF 1 1 4 12 3 MOV R0, direct A8 2 2 8 12 1.5 MOV R1, direct A9 2 2 8 12 1.5 MOV R2, direct AA 2 2 8 12 1.5 MOV R3, direct AB 2 2 8 12 1.5 MOV R4, direct AC 2 2 8 12 1.5 MOV R5, direct AD 2 2 8 12 1.5 MOV R6, direct AE 2 2 8 12 1.5 MOV R7, direct AF 2 2 8 12 1.5 MOV R0, #data 78 2 2 8 12 1.5 MOV R1, #data 79 2 2 8 12 1.5 MOV R2, #data 7A 2 2 8 12 1.5 MOV R3, #data 7B 2 2 8 12 1.5 MOV R4, #data 7C 2 2 8 12 1.5 MOV R5, #data 7D 2 2 8 12 1.5 MOV R6, #data 7E 2 2 8 12 1.5 MOV R7, #data 7F 2 2 8 12 1.5 MOV @R0, A F6 1 1 4 12 3 MOV @R1, A F7 1 1 4 12 3 MOV @R0, direct A6 2 2 8 12 1.5 MOV @R1, direct A7 2 2 8 12 1.5 MOV @R0, #data 76 2 2 8 12 1.5 MOV @R1, #data 77 2 2 8 12 1.5 MOV direct, A F5 2 2 8 12 1.5 MOV direct, R0 88 2 2 8 12 1.5 - 78 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued W79E22X SERIES MACHINE CYCLE W79E22X SERIES CLOCK CYCLES W79E22X 8032 CLOCK SERIES VS. 8032 CYCLES SPEED RATIO HEX CODE BYTES MOV direct, R1 89 2 2 8 12 1.5 MOV direct, R2 8A 2 2 8 12 1.5 MOV direct, R3 8B 2 2 8 12 1.5 MOV direct, R4 8C 2 2 8 12 1.5 MOV direct, R5 8D 2 2 8 12 1.5 MOV direct, R6 8E 2 2 8 12 1.5 MOV direct, R7 8F 2 2 8 12 1.5 MOV direct, @R0 86 2 2 8 12 1.5 MOV direct, @R1 87 2 2 8 12 1.5 MOV direct, direct 85 3 3 12 24 2 MOV direct, #data 75 3 3 12 24 2 MOV DPTR, #data 16 90 3 3 12 24 2 MOVC A, @A+DPTR 93 1 2 8 24 3 MOVC A, @A+PC 83 1 2 8 24 3 MOVX A, @R0 E2 1 2-9 8 - 36 24 3 - 0.66 MOVX A, @R1 E3 1 2-9 8 - 36 24 3 - 0.66 MOVX A, @DPTR E0 1 2-9 8 - 36 24 3 - 0.66 MOVX @R0, A F2 1 2-9 8 - 36 24 3 - 0.66 MOVX @R1, A F3 1 2-9 8 - 36 24 3 - 0.66 OP-CODE MOVX @DPTR, A F0 1 2-9 8 - 36 24 3 - 0.66 PUSH direct C0 2 2 8 24 3 POP direct D0 2 2 8 24 3 XCH A, R0 C8 1 1 4 12 3 XCH A, R1 C9 1 1 4 12 3 XCH A, R2 CA 1 1 4 12 3 XCH A, R3 CB 1 1 4 12 3 XCH A, R4 CC 1 1 4 12 3 XCH A, R5 CD 1 1 4 12 3 XCH A, R6 CE 1 1 4 12 3 XCH A, R7 CF 1 1 4 12 3 XCH A, @R0 C6 1 1 4 12 3 - 79 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued OP-CODE HEX CODE W79E22X SERIES MACHINE CYCLE BYTES W79E22X SERIES CLOCK CYCLES W79E22X SERIES VS. 8032 SPEED RATIO 8032 CLOCK CYCLES XCH A, @R1 C7 1 1 4 12 3 XCHD A, @R0 D6 1 1 4 12 3 XCHD A, @R1 D7 1 1 4 12 3 XCH A, direct C5 2 2 8 12 1.5 CLR C C3 1 1 4 12 3 CLR bit C2 2 2 8 12 1.5 SETB C D3 1 1 4 12 3 SETB bit D2 2 2 8 12 1.5 CPL C B3 1 1 4 12 3 CPL bit B2 2 2 8 12 1.5 ANL C, bit 82 2 2 8 24 3 ANL C, /bit B0 2 2 6 24 3 ORL C, bit 72 2 2 8 24 3 ORL C, /bit A0 2 2 6 24 3 MOV C, bit A2 2 2 8 12 1.5 MOV bit, C 92 2 2 8 24 3 ACALL addr11 71, 91, B1, 11, 31, 51, D1, F1 2 3 12 24 2 LCALL addr16 12 3 4 16 24 1.5 RET 22 1 2 8 24 3 RETI 32 1 2 8 24 3 AJMP ADDR11 01, 21, 41, 61, 81, A1, C1, E1 2 3 12 24 2 LJMP addr16 02 3 4 16 24 1.5 JMP @A+DPTR 73 1 2 6 24 3 SJMP rel 80 2 3 12 24 2 JZ rel 60 2 3 12 24 2 JNZ rel 70 2 3 12 24 2 JC rel 40 2 3 12 24 2 JNC rel 50 2 3 12 24 2 JB bit, rel 20 3 4 16 24 1.5 JNB bit, rel 30 3 4 16 24 1.5 - 80 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Continued W79E22X SERIES MACHINE CYCLE W79E22X SERIES CLOCK CYCLES W79E22X SERIES VS. 8032 SPEED RATIO 8032 CLOCK CYCLES HEX CODE BYTES JBC bit, rel 10 3 4 16 24 1.5 CJNE A, direct, rel B5 3 4 16 24 1.5 CJNE A, #data, rel B4 3 4 16 24 1.5 CJNE @R0, #data, rel B6 3 4 16 24 1.5 CJNE @R1, #data, rel B7 3 4 16 24 1.5 CJNE R0, #data, rel B8 3 4 16 24 1.5 CJNE R1, #data, rel B9 3 4 16 24 1.5 CJNE R2, #data, rel BA 3 4 16 24 1.5 CJNE R3, #data, rel BB 3 4 16 24 1.5 CJNE R4, #data, rel BC 3 4 16 24 1.5 CJNE R5, #data, rel BD 3 4 16 24 1.5 CJNE R6, #data, rel BE 3 4 16 24 1.5 CJNE R7, #data, rel BF 3 4 16 24 1.5 DJNZ R0, rel D8 2 3 12 24 2 DJNZ R1, rel D9 2 3 12 24 2 DJNZ R5, rel DD 2 3 12 24 2 DJNZ R2, rel DA 2 3 12 24 2 DJNZ R3, rel DB 2 3 12 24 2 DJNZ R4, rel DC 2 3 12 24 2 DJNZ R6, rel DE 2 3 12 24 2 DJNZ R7, rel DF 2 3 12 24 2 DJNZ direct, rel D5 3 4 16 24 1.5 OP-CODE Table 8-1: Instruction Set for W79E22X SERIES - 81 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 8.1 Instruction Timing This section is important because some applications use software instructions to generate timing delays. It also provides more information about timing differences between the W79E22X SERIES and the standard 8051/52. In W79E22X SERIES, each machine cycle is four clock periods long. Each clock period is called a state, and each machine cycle consists of four states: C1, C2 C3 and C4, in order. Both clock edges are used for internal timing, so the duty cycle of the clock should be as close to 50% as possible. The W79E22X SERIES does one op-code fetch per machine cycle, so, in most instructions, the number of machine cycles required is equal to the number of bytes in the instruction. There are 256 available op-codes. 128 of them are single-cycle instructions, so many op-codes are executed in just four clock periods. Some of the other op-codes are two-cycle instructions, and most of these have two-byte op-codes. However, there are some instructions that have one-byte instructions yet take two cycles to execute. One important example is the MOVX instruction. In the standard 8051/52, the MOVX instruction is always two machine cycles long. However, in the W79E22X SERIES, the duration of this instruction is controlled by the software. It can vary from two to nine machine cycles long, and, RD and WR strobe lines are elongated proportionally. This is called stretching, and it gives a lot of flexibility when accessing fast and slow peripherals. It also reduces the amount of external circuitry and software overhead. The rest of the instructions are three-, four- or five-cycle instructions. At the end of this section, there are timing diagrams that provide an example of each type of instruction (single-cycle, two-cycle, …). In summary, there are five types of instructions in the W79E22X SERIES, based on the number of machine cycles, and each machine cycle is four clock periods long. The standard 8051/52 has only three types of instructions, based on the number of machine cycles, but each machine cycle is twelve clock periods long. As a result, even though the number of categories is higher, each instruction in the W79E22X SERIES runs 1.5 to 3 times faster, based on the number of clock periods, than it does in the standard 8051/52. Single Cycle C1 C2 C3 C4 CLK ALE PSEN AD7-0 A7-0 Data_ in D7-0 Address A15-8 PORT 2 Figure 8-1: Single Cycle Instruction Timing - 82 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Operand Fetch Instruction Fetch C1 C2 C3 C4 C1 C2 C3 C4 CLK ALE PSEN PC AD7-0 OP-CODE PC+1 Address A15-8 PORT 2 OPERAND Address A15-8 Figure 8-2: Two Cycles Instruction Timing Instruction Fetch C1 C2 C3 Operand Fetch C4 C1 C2 C3 Operand Fetch C4 C1 C2 C3 C4 CLK ALE PSEN AD7-0 PORT 2 A7-0 OP-CODE Address A15-8 A7-0 OPERAND Address A15-8 A7-0 OPERAND Address A15-8 Figure 8-3: Three Cycles Instruction Timing - 83 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Instruction Fetch C1 C2 C3 Operand Fetch C4 C1 C2 C3 Operand Fetch C4 C1 C2 C3 Operand Fetch C4 C1 C2 C3 C4 CLK ALE PSEN AD7-0 A7-0 OP-CODE A7-0 OPERAND A7-0 OPERAND A7-0 OPERAND Port 2 Address A15-8 Address A15-8 Address A15-8 Address A15-8 Figure 8-4: Four Cycles Instruction Timing Instruction Fetch C1 C2 C3 C4 Operand Fetch C1 C2 C3 C4 Operand Fetch C1 C2 C3 C4 Operand Fetch C1 C2 C3 C4 Operand Fetch C1 C2 C3 C4 CLK ALE PSEN AD7-0 A7-0 OP-CODE A7-0 OPERAND A7-0 OPERAND A7-0 OPERAND A7-0 OPERAND PORT 2 Address A15-8 Address A15-8 Address A15-8 Address A15-8 Address A15-8 Figure 8-5: Five Cycles Instruction Timing 8.1.1 External Data Memory Access Timing The timing for the MOVX instruction is another feature of the W79E22X SERIES. In the standard 8051/52, the MOVX instruction has a fixed execution time of 2 machine cycles. However, in W79E22X SERIES, the duration of the access can be controlled by the user. The instruction starts off as a normal op-code fetch that takes four clocks. In the next machine cycle, W79E22X SERIES puts out the external memory address, and the actual access occurs. The user can control the duration of this access by setting the stretch value in CKCON, bits 2 – 0. As shown in the table below, these three bits can range from zero to seven, resulting in MOVX instructions that take two to nine machine cycles. The default value is one, resulting in a MOVX instruction of three machine cycles. - 84 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Stretching only affects the MOVX instruction. There is no effect on any other instruction or its timing; it is as if the state of the CPU is held for the desired period. The timing waveforms when the stretch value is zero, one, and two are shown below. M2 M1 RD OR WR STROBE WIDTH @ 25 MHZ RD OR WR STROBE WIDTH IN CLOCKS MACHINE CYCLES M0 RD OR WR STROBE WIDTH @ 40 MHZ 0 0 0 2 2 80 nS 50 nS 0 0 1 3 (default) 4 160 nS 100 nS 0 1 0 4 8 320 nS 200 nS 0 1 1 5 12 480 nS 300 nS 1 0 0 6 16 640 nS 400 nS 1 0 1 7 20 800 nS 500 nS 1 1 0 8 24 960 nS 600 nS 1 1 1 9 28 1120 nS 700 nS Table 8-2: Data Memory Cycle Stretch Values First Second Machine cycle Machine cycle Last Cycle of Previous Instruction Next Instruction Machine Cycle MOVX instruction cycle C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 CLK ALE PSEN WR PORT 0 A0-A7 D0-D7 D0-D7 Next Inst. Address MOVX Inst. Address MOVX Inst. PORT 2 A0-A7 A15-A8 D0-D7 A0-A7 A0-A7 D0-D7 MOVX Data Address Next Inst. Read MOVX Data out A15-A8 A15-A8 A15-A8 Figure 8-6: Data Memory Write with Stretch Value = 0 - 85 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Last Cycle First of Previous Instruction Second Third Machine Cycle Machine Cycle Machine Cycle Next Instruction Machine Cycle MOVX instruction cycle C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 CLK ALE PSEN WR PORT 0 D0-D7 A0-A7 D0-D7 A0-A7 MOVX Inst. Address Next Inst. Address A15-A8 MOVX Data Address D0-D7 A0-A7 MOVX Data out Next Inst. Read MOVX Inst. PORT 2 D0-D7 A0-A7 A15-A8 A15-A8 A15-A8 Figure 8-7: Data Memory Write with Stretch Value = 1 Last Cycle First Second Third Fourth of Previous Instruction Machine Cycle Machine Cycle Machine Cycle Machine Cycle Next Instruction Machine Cycle MOVX instruction cycle C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 C1 C2 C3 C4 CLK ALE PSEN WR PORT 0 D0-D7 A0-A7 MOVX Inst. Address Next Inst. Address MOVX Inst. PORT 2 D0-D7 A0-A7 A15-A8 A0-A7 MOVX Data Address D0-D7 A0-A7 D0-D7 MOVX Data out Next Inst. Read A15-A8 A15-A8 A15-A8 Figure 8-8: Data Memory Write with Stretch Value = 2 - 86 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 9. POWER MANAGEMENT The W79E22X SERIES provides idle mode and power-down mode to control power consumption. These modes are discussed in the next two sections. 9.1 Idle Mode The user can put the device into idle mode by writing 1 to the bit PCON.0. The instruction that sets the idle bit is the last instruction that will be executed before the device goes into Idle Mode. In the Idle mode, the clock to the CPU is halted, but not to the Interrupt, Timer, Watchdog timer, PWM, ADC and Serial ports blocks. This forces the CPU state to be frozen; the Program counter, the Stack Pointer, the Program Status Word, the Accumulator and the other registers hold their contents. The ALE and PSEN pins are held high during the Idle state. The port pins hold the logical states they had at the time Idle was activated. The Idle mode can be terminated in two ways. Since the interrupt controller is still active, the activation of any enabled interrupt can wake up the processor. This will automatically clear the Idle bit, terminate the Idle mode, and the Interrupt Service Routine (ISR) will be executed. After the ISR, execution of the program will continue from the instruction which put the device into Idle mode. The Idle mode can also be exited by activating the reset. The device can be put into reset either by applying a high on the external RST pin, a Power on reset condition or a Watchdog timer reset. The external reset pin has to be held high for at least two machine cycles i.e. 8 clock periods to be recognized as a valid reset. In the reset condition the program counter is reset to 0000h and all the SFRs are set to the reset condition. Since the clock is already running there is no delay and execution starts immediately. In the Idle mode, the Watchdog timer continues to run, and if enabled, a time-out will cause a watchdog timer interrupt which will wake up the device. The software must reset the Watchdog timer in order to preempt the reset which will occur after 512 clock periods of the time-out. When the device is exiting from an Idle mode with a reset, the instruction following the one which put the device into Idle mode is not executed. So there is no danger of unexpected writes. 9.2 Power Down Mode The device can be put into Power Down mode by writing 1 to bit PCON.1. The instruction that does this will be the last instruction to be executed before the device goes into Power Down mode. In the Power Down mode, all the clocks are stopped and the device comes to a halt. All activity is completely stopped and the power consumption is reduced to the lowest possible value. In this state the ALE and PSEN pins are pulled low (if PWDNH=0). The port pins output the values held by their respective SFRs. The device will exit the Power Down mode with a reset or by an external interrupt pin enabled (external interrupts 0 and 1). An external reset can be used to exit the Power down state. The high on RST pin terminates the Power Down mode, and restarts the clock. The program execution will restart from 0000h. In the Power down mode, the clock is stopped, so the Watchdog timer cannot be used to provide the reset to exit Power down mode. The device can be waken up from the Power Down mode by forcing an external interrupt pin activation, provided the corresponding interrupt is enabled, while the global enable (EA) bit is set. If these conditions are met, then either a low-level or a falling-edge at external interrupt pin will re-start the oscillator. The device will then execute the interrupt service routine for the corresponding external interrupt. After the interrupt service routine is completed, the program execution returns to the instruction after one which put the device into Power Down mode and continues from there. - 87 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet MODE PROGRAM MEMORY ALE PSEN PORT0 PORT1 PORT2 PORT3 PORT4 PORT5 Idle Internal 1 1 Data Data Data Data Data Data Idle External 1 1 Float Data Address Data Data Data [1] [1] Power Down Internal 0 1 [2] 0 1 [2] Data Data Data Data Data Data Power Down External 0 [1] 1 [2] 0 [1] 1 [2] Float Data Data Data Data Data Table 9-1: Status of external pins during Idle and Power Down Note: 1. When PWDNH=0. 2. When PWDNH=1. - 88 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 10. RESET CONDITIONS The user has several hardware related options for placing the W79E22X SERIES into reset condition. In general, most register bits go to their reset value irrespective of the reset condition, but there are a few flags whose state depends on the source of reset. The user can use these flags to determine the cause of reset using software. There are three ways of putting the device into reset state. They are External reset, Power-On Reset and Watchdog reset. In general, most registers return to their default values regardless of the source of the reset, but a couple flags depend on the source. As a result, the user can use these flags to determine the cause of the reset. The rest of this section discusses the three causes of reset and then elaborates on the reset state. 10.1 Sources of reset 10.1.1 External Reset The device samples the RST pin every machine cycle during state C4. The RST pin must be held high for at least two machine cycles before the reset circuitry applies an internal reset signal. Thus, this reset is a synchronous operation and requires the clock to be running. The device remains in the reset state as long as RST is one and remains there up to two machine cycles after RST is deactivated. Then, the device begins program execution at 0000h. There are no flags associated with the external reset, but, since the other two reset sources do have flags, the external reset is the cause if those flags are clear. 10.1.2 Power-On Reset (POR) If the power supply falls below Vrst, the device goes into the reset state. When the power supply returns to proper levels, the device performs a power-on reset and sets the POR flag. The software should clear the POR flag, or it will be difficult to determine the source of future resets. 10.1.3 Watchdog Timer Reset The Watchdog Timer is a free-running timer with programmable time-out intervals. The program must clear the Watchdog Timer before the time-out interval is reached to restart the count. If the time-out interval is reached, an interrupt flag is set. 512 clocks later, if the Watchdog Reset is enabled and the Watchdog Timer has not been cleared, the Watchdog Timer generates a reset. The reset condition is maintained by the hardware for two machine cycles, and the WTRF bit in WDCON is set. Afterwards, the device begins program execution at 0000h. - 89 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 10.2 Reset State When the device is reset, most registers return to their initial state. The Watchdog Timer is disabled if the reset source was a power-on reset. The port registers are set to FFh, which puts most of the port pins in a high state and makes Port 0 float (as it does not have on-chip pull-up resistors). The Program Counter is set to 0000h, and the stack pointer is reset to 07h. After this, the device remains in the reset state as long as the reset conditions are satisfied. Reset does not affect the on-chip RAM, however, so RAM is preserved as long as VDD remains above approximately 2 V, the minimum operating voltage for the RAM. If VDD falls below 2 V, the RAM contents are also lost. In either case, the stack pointer is always reset, so the stack contents are lost. The WDCON SFR bits are set/cleared in reset condition depends on the source of the reset. The WDCON SFR is set to a 0x0x0xx0b on an external reset. WTRF is set to a 1 on a Watchdog timer reset, but to a 0 on power on/down resets. WTRF is not altered by an external reset. POR is set to 1 by a power-on reset. EWT is cleared to 0 on a Power-on reset and unaffected by other resets. All the bits in this SFR have unrestricted read access. POR, WDIF, EWT and RWT bits require Timed Access (TA) procedure to write. The remaining bits have unrestricted write accesses. Please refer TA register description. Table below lists the different reset values for WDCON due to different sources of reset. WDCON Watch-Dog Control D8H (DF) - (DE) POR (DD) - (DC) - - 90 - (DB) WDIF (DA) WTRF (D9) EWT (D8) RWT x0xx 0000B External reset x0xx 0100B Watchdog reset x1xx 0000B Power on reset Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 11. INTERRUPTS The device has a four priority level interrupt structure with 20 interrupt sources. Each of the interrupt sources has an individual priority bit, flag, interrupt vector and enable bit. In addition, all the interrupts can be globally enabled or disabled. 11.1 Interrupt Sources The External Interrupts INT0 and INT1 can be either edge triggered or level triggered, depending on bits IT0 and IT1. The bits IE0 and IE1 in the TCON register are the flags which are checked to generate the interrupt. In the edge triggered mode, the INTx inputs are sampled in every machine cycle. If the sample is high in one cycle and low in the next, then a high to low transition is detected and the interrupts request flag IEx in TCON is set. The flag bit requests the interrupt. Since the external interrupts are sampled every machine cycle, they have to be held high or low for at least one complete machine cycle. The IEx flag is automatically cleared when the service routine is called. If the level triggered mode is selected, then the requesting source has to hold the pin low till the interrupt is serviced. The IEx flag will not be cleared by the hardware on entering the service routine. If the interrupt continues to be held low even after the service routine is completed, then the processor may acknowledge another interrupt request from the same source. Note that the external interrupts INT2 are edge trigger only. By default, the individual interrupt flag corresponding to external interrupt 2 to 5 must be cleared manually by software. It can be configured with hardware cleared by setting the corresponding bit HCx in T2MOD register. For instance, if HC2 is set hardware will clear IE2 flag after program enters the interrupt 2 service routine. While for INT3 to INT5 can detect the rising, falling or both edges which function are selectable by software located in INTCTRL [5:0] register. The Timer 0 and 1 Interrupts are generated by the TF0 and TF1 flags. These flags are set by the overflow in the Timer 0 and Timer 1. The TF0 and TF1 flags are automatically cleared by the hardware when the timer interrupt is serviced. The Timer 2 interrupt is generated by a logical OR of the TF2 and the EXF2 flags. These flags are set by overflow or capture/reload events in the timer 2 operation. The hardware does not clear these flags when a timer 2 interrupt is executed. Software has to resolve the cause of the interrupt between TF2 and EXF2 and clear the appropriate flag. When ADC conversion is completed hardware will set flag ADCI to logic high to request ADC interrupt if bit EADC (IE.6) is in high state. ADCI is cleared by software only. The I2C function can generate interrupt, if EI2C and EA bits are enabled, when SI Flag is set due to a new I2C status code is generated, SI flag is generated by hardware and must be cleared by software. The Watchdog timer can be used as a system monitor or a simple timer. In either case, when the timeout count is reached, the Watchdog timer interrupt flag WDIF (WDCON.3) is set. If the interrupt is enabled by the enable bit EIE.4, then an interrupt will occur. All the bits that generate interrupts can be set or reset by hardware, and thereby software initiated interrupts can be generated. Each of the individual interrupts can be enabled or disabled by setting or clearing a bit in the IE SFR. IE also has a global enable/disable bit EA, which can be cleared to disable all interrupts. 11.2 Priority Level Structure There are four priority levels for the interrupts; highest, high, low and lowest. The other interrupt source can be individually set to either high or low levels. Naturally, a higher priority interrupt cannot be interrupted by a lower priority interrupt. However there exists a predefined hierarchy amongst the interrupts themselves. This hierarchy comes into play when the interrupt controller has to resolve simultaneous requests having the same priority level. This hierarchy is defined as shown below; the interrupts are numbered starting from the highest priority to the lowest. - 91 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet SOURCE FLAG VECTOR ADDRESS FLAG CLEARED BY PRIORITY LEVEL External Interrupt 0 IE0 0003H Hardware, Follow the inverse of pin 1(highest) Timer 0 Overflow TF0 000BH Hardware, software 2 External Interrupt 1 IE1 0013H Hardware, Follow the inverse of pin 3 Timer 1 Overflow TF1 001BH Hardware, software 4 Serial Port RI + TI 0023H Software 5 Timer 2 Overflow TF2 + EXF2 002BH Software 6 A/D Converter ADCI 0033H Software 7 I2C Channel I2C1 SI 003BH Software 8 Serial Port 1 RI_1 + TI_1 007BH Software 9 SPI interrupt SPIF + MODF + SPIOVF 0083H Software 10 External Interrupt 2 IE2 0043H Hardware, software 11 External Interrupt 3 IE3 004BH Hardware, software 12 External Interrupt 4 IE4 0053H Hardware, software 13 External Interrupt 5 IE5 005BH Hardware, software 14 PWM Period PWMF 0073H Software 15 PWM Brake BKF 006BH Software 16 Timer 3 Overflow TF3 008BH Software 17 Capture Input/Direction Interrupt/QEI CPTF0/QEIF+ CPTF1/DIRF+ CPTF2 0093H Software 18 NVM Interrupt NVMF 009BH Software 19 Watchdog Timer WDIF 0063H Software 20 Table 11- 1: Priority structure of interrupts The interrupt flags are sampled every machine cycle. In the same machine cycle, the sampled interrupts are polled and their priority is resolved. If certain conditions are met, the hardware will execute an internally generated LCALL instruction which will vector the process to the appropriate interrupt vector address. The conditions for generating the LCALL are; 1. An interrupt of equal or higher priority is not currently being serviced. 2. The current polling cycle is the last machine cycle of the instruction currently being executed. 3. The current instruction does not involve a write to IE, EIE, EIE1, IP, EIP, EIP1, IPH, EIPH or EIP1H registers and is not a RETI. If any of these conditions are not met, then the LCALL will not be generated. The polling cycle is repeated every machine cycle, with the interrupts sampled in the same machine cycle. If an interrupt - 92 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet flag is active in one cycle but not responded to, and is not active when the above conditions are met, the denied interrupt will not be serviced. This means that active interrupts are not remembered; every polling cycle is new. The processor responds to a valid interrupt by executing an LCALL instruction to the appropriate service routine. This may or may not clear the flag which caused the interrupt. In case of Timer interrupts, the TF0 or TF1 flags are cleared by hardware whenever the processor vectors to the appropriate timer service routine. In case of external interrupt, INT0 and INT1, the flags are cleared only if they are edge triggered. In case of Serial interrupts, the flags are not cleared by hardware. In the case of Timer 2 interrupt, the flags are not cleared by hardware. The Watchdog timer interrupt flag WDIF has to be cleared by software. The hardware LCALL behaves exactly like the software LCALL instruction. This instruction saves the Program Counter contents onto the Stack, but does not save the Program Status Word PSW. The PC is reloaded with the vector address of that interrupt which caused the LCALL. These address of vector for the different sources are shown in Table 11- 1: Priority structure of interrupts. PRIORITY BITS INTERRUPT PRIORITY LEVEL IPH/EIPH/EIP1H IP/EIP/EIP1 0 0 Level 0 (lowest priority) 0 1 Level 1 1 0 Level 2 1 1 Level 3 (highest priority) Table 11- 2: Four-level interrupt priority Each interrupt source can be individually programmed to one of four priority levels by setting or clearing bits in the IP, IPH, EIP, EIPH, EIP1 and EIP1H registers. An interrupt service routine in progress can be interrupted by a higher priority interrupt, but not by another interrupt of the same or lower priority. The highest priority interrupt service cannot be interrupted by any other interrupt source. So, if two requests of different priority levels are received simultaneously, the request of higher priority level is serviced. If requests of the same priority level are received simultaneously, an internal polling sequence determines which request is serviced. This is called the arbitration ranking. Note that the arbitration ranking is only used to resolve simultaneous requests of the same priority level. As below Table summarizes the interrupt sources, flag bits, vector addresses, enable bits, priority bits, arbitration ranking, and whether each interrupt may wake up the CPU from Power Down mode. - 93 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet SOURCE FLAG VECTOR INTERRUPT ADDRESS ENABLE BITS INTERRUPT ARBITRATION PRIORITY RANKING CONTROL BITS POWER DOWN WAKEUP External Interrupt 0 IE0 0003H EX0 (IE.0) IPH.0,IP.0 1(highest) Yes Timer 0 Overflow TF0 000BH ET0 (IE.1) IPH.1,IP.1 2 No External Interrupt 1 IE1 0013H EX1 (IE.2) IPH.2,IP.2 3 Yes Timer 1 Overflow TF1 001BH ET1 (IE.3) IPH.3,IP.3 4 No Serial Port RI + TI 0023H ES (IE.4) IPH.4,IP.4 5 No Timer 2 Overflow TF2 + EXF2 002BH ET2 (IE.5) IPH.5,IP.5 6 No A/D Converter ADCI 0033H EADC (IE.6) IPH.6,IP.6 7 No I2C Channel I2C SI 003BH EI2C (EIE.0) EIPH.0, EIP.0 8 No Serial Port 1 RI_1 + TI_1 007BH ES1 (EIE.7) EIPH.7, EIP.7 9 No SPI interrupt SPIF/MODF/ SPIOVF 0083H ESPI (EIE1.0) EIP1H.0, EIP1.0 10 No External Interrupt 2 IE2 0043H EX2 (EIE.2) EIPH.2, EIP.2 11 No External Interrupt 3 IE3 004BH EX3 (EIE.3) EIPH.3, EIP.3 12 No External Interrupt 4 IE4 0053H EX4 (EIE.5) EIPH.5, EIP.5 13 No External Interrupt 5 IE5 005BH EX5 (EIE.6) EIPH.6, EIP.6 14 No PWM Period PWMF 0073H EPWM (EIE1.1) EIP1H.1, EIP1.1 15 No PWM Brake BKF 006BH EBK (EIE1.2) EIP1H.2, EIP1.2 16 No Timer 3 Overflow TF3 008BH ET3 (EIE1.3) EIP1H.3, EIP1.3 17 No Capture Input/Direction Interrupt/QEI CPTF0/QEIF + CPTF1/DIRF + CPTF2 0093H ECPTF (EIE1.4) EIP1H.4, EIP1.4 18 No NVM Interrupt NVMF 009BH ENVMI (EIE1.5) EIP1H.5, EIP1.5 19 No Watchdog Timer WDIF 0063H EWDI (EIE.4) EIPH.4, EIP.4 20 No Table 11- 3: Vector location for Interrupt sources and power down wakeup - 94 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 11.2.1 Response Time The response time for each interrupt source depends on several factors like nature of the interrupt and the instruction under progress. In the case of external interrupt INT0 to INT5, they are sampled at C3 of every machine cycle and then their corresponding interrupt flags IE0 and IE1 will be set or reset. Similarly, the Serial port flags RI/RI_1 and TI/TI_1 are set in C4 of last machine cycle. The Timer 0 and 1 overflow flags are set at C3 of the machine cycle in which overflow has occurred. These flag values are polled only in the next machine cycle. If a request is active and all three conditions are met, then the hardware generated LCALL is executed. This call itself takes four machine cycles to be completed. Thus there is a minimum time of five machine cycles between the interrupt flag being set and the interrupt service routine being executed. A longer response time should be anticipated if any of the three conditions are not met. If a higher or equal priority is being serviced, then the interrupt latency time obviously depends on the nature of the service routine currently being executed. If the polling cycle is not the last machine cycle of the instruction being executed, then an additional delay is introduced. The maximum response time (if no other interrupt is in service) occurs if the device is performing a write to IE, IP, IPH, EIE, EIP, EIPH, EIE1, EIP1 or EIP1H and then executes a MUL or DIV instruction. From the time an interrupt source is activated, the longest reaction time is 12 machine cycles. This includes 1 machine cycle to detect the interrupt, 2 machine cycles to complete the IE, IP, IPH, EIE, EIP, EIPH, EIE1, EIP1 or EIP1H access, 5 machine cycles to complete the MUL or DIV instruction and 4 machine cycles to complete the hardware LCALL to the interrupt vector location. Thus in a single-interrupt system the interrupt response time will always be more than 5 machine cycles and not more than 12 machine cycles. The maximum latency of 12 machine cycle is 48 clock cycles. Note that in the standard 8051 the maximum latency is 8 machine cycles which equals 96 machine cycles. This is a 50% reduction in terms of clock periods. - 95 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 12. PROGRAMMABLE TIMERS/COUNTERS The W79E22X SERIES has three 16-bit programmable timer/counters. 12.1 Timer/Counters 0 & 1 TM0 and TM1 are 16-bit Timer/Counters, and there are nearly identical. Each of these Timer/Counters has two 8 bit registers which form the 16 bits counting register. For Timer/Counter 0, it consists of TH0, the upper 8 bits register, and TL0, the lower 8 bit register. Similarly Timer/Counter 1 has two 8 bits registers; TH1 and TL1. The two timers can be configured to operate either as timers, counting machine cycles or as counters counting external inputs. When configured as a "Timer", the timer counts clock cycles. In "Counter" mode, the register is incremented on the falling edge of the corresponding external input pins, T0 for Timer 0 and T1 for Timer 1. The T0 and T1 inputs are sampled in every machine cycle at C4. If the sampled value is high in one machine cycle and low in the next, then a valid high to low transition on the pin is recognized and the count register is incremented. Since it takes two machine cycles to recognize a negative transition on the pin, therefore the maximum counting rate is 1/8 of the master clock frequency. In both "Timer" and "Counter" mode, the count register is updated at C3. Therefore, in the "Timer" mode, the recognized negative transition on pin T0 and T1 can cause the count register value to be updated only in the machine cycle following the one in which the negative edge was detected. The "Timer" or "Counter" function is selected by the " C/ T " bit in the TMOD Special Function Register. Each Timer/Counter has one selection bit for its own; bit 2 of TMOD selects the function for Timer/Counter 0 and bit 6 of TMOD selects the function for Timer/Counter 1. In addition each Timer/Counter can be set to operate in any one of four possible modes. The mode selection is done by bits M0 and M1 in the TMOD SFR. 12.1.1 Time-Base Selection The W79E22X SERIES can operate like the standard 8051/52 family, counting at the rate of 1/12 of the clock speed, or in turbo mode, counting at the rate of 1/4 clock speed. The speed is controlled by the T0M and T1M bits in CKCON, and the default value is zero, which uses the standard 8051/52 speed. 12.1.2 Mode 0 In Mode 0, the timer/counter is a 13-bit counter. The 13-bit counter consists of THx (8 MSB) and the five lower bits of TLx (5 LSB). The upper three bits of TLx are ignored. The timer/counter is enabled when TRx is set and either GATE is 0 or INTx is 1. When C/ T is 0, the timer/counter counts clock cycles; when C/ T is 1, it counts falling edges on T0 (P3.4 for Timer 0) or T1 (P3.5 for Timer 1). For clock cycles, the time base may be 1/12 or 1/4 clock speed, and the falling edge of the clock increments the counter. When the 13-bit value moves from 1FFFh to 0000h, the timer overflow flag TFx is set, and an interrupt occurs if enabled. This is illustrated in next figure below. - 96 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 12.1.3 Mode 1 Mode 1 is the same as Mode 0, except that the timer/counter is 16 bits, instead of 13 bits. Figure 12-1: Timer/Counters 0 & 1 in Mode 0 and Mode 1 12.1.4 Mode 2 In Mode 2, the timer/counter is in the Auto Reload Mode. In this mode, TLx acts as an 8 bits count register, while THx holds the reload value. When the TLx register overflows from FFh to 00h, the TFx bit in TCON is set and TLx is reloaded with the contents of THx, and the counting process continues. The reload operation leaves the contents of the THx register unchanged. Counting is enabled by the TRx bit and proper setting of GATE and INTx pins. As in the other two modes 0 and 1, mode 2 allows counting of either clock cycles (clock/12 or clock/4) or pulses on pin Tn. Figure 12-2: Timer/Counter 0 & 1 in Mode 2 - 97 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 12.1.5 Mode 3 Mode 3 is used when an extra 8-bit timer is needed. It has different effect on Timer 0 and Timer 1. TL0 and TH0 become two separate 8 bits counters. TL0 uses the Timer 0 control bits C/ T , GATE, TR0, INT0 and TF0, and it can be used to count clock cycles (clock/12 or clock/4) or falling edges on pin T0, as determined by C/ T (TMOD.2). TH0 becomes a clock-cycle counter (clock/12 or clock/4) and takes over the Timer 1 enable bit TR1 and overflow flag TF1. In contrast, mode 3 simply freezes Timer 1. If Timer 0 is in mode 3, Timer 1 can still be used in modes 0, 1 and 2, but it no longer has control over TR1 and TF1. Therefore when Timer 0 is in Mode 3, Timer 1 can only count oscillator cycles, and it does not have an interrupt or flag. With these limitations, baud rate generation is its most practical application, but other time-base functions may be achieved by reading the registers. Figure 12-3: Timer/Counter Mode 3 12.2 Timer/Counter 2 Timer/Counter 2 is a 16-bit up/down-counter equipped with a capture/reload capability. The clock source for Timer/Counter 2 may be the external T2 pin ( C/ T2 = 1) or the crystal oscillator ( C/ T2 = 0), divided by 12 or 4. The clock is enabled and disabled by TR2. Timer/Counter 2 runs in one of four operating modes, each of which is discussed below. - 98 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 12.2.1 Capture Mode Capture mode is enabled by setting CP/RL2 in T2CON to 1. In capture mode, Timer/Counter 2 is a 16-bit up-counter. When the counter rolls over from FFFFh to 0000h, the timer overflow flag TF2 is set, and an interrupt is generated, if enabled. If the EXEN2 bit is set, a negative transition on the T2EX pin captures the current value of TL2 and TH2 in the RCAP2L and RCAP2H registers. It also sets the EXF2 bit in T2CON, which generates an interrupt if enabled. In addition, if the T2CR bit in T2MOD is set, the W79E22X SERIES resets Timer 2 automatically after each capture. This is illustrated below. (RCLK,TCLK, CP/RL2 )= (0,0,1) Figure 12-4: Timer2 16-Bit Capture Mode 12.2.2 Auto-reload Mode, Counting up This mode is enabled by clearing CP/RL2 in T2CON register and DCEN in T2MOD. In this mode, Timer/Counter 2 is a 16-bit up-counter. When the counter rolls over from FFFFh to 0000h, the timer overflow flag TF2 is set, and TL2 and TH2 capture the contents of RCAP2L and RCAP2H, respectively. Alternatively, if EXEN2 is set, a negative transition on the T2EX pin causes a reload, which also sets the EXF2 bit in T2CON. - 99 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet (RCLK,TCLK, CP/RL2 )= (0,0,0) & DCEN= 0 Figure 12-5: 16-Bit Auto-reload Mode, Counting Up 12.2.3 Auto-reload Mode, Counting Up/Down This mode is enabled by clearing CP / RL2 in T2CON and setting DCEN in T2MOD. In this mode, Timer/Counter 2 is a 16-bit up/down-counter, whose direction is controlled by the T2EX pin (1 = up, 0 = down). If Timer/Counter 2 is counting up, an overflow reloads TL2 and TH2 with the contents of the capture registers RCAP2L and RCAP2H. If Timer/Counter 2 is counting down, TL2 and TH2 are loaded with FFFFh when the contents of Timer/Counter 2 equal the capture registers RCAP2L and RCAP2H. Regardless of direction, reloading sets the TF2 bit. It also toggles the EXF2 bit, but the EXF2 bit can not generate an interrupt in this mode. This is illustrated below. (RCLK,TCLK, CP/RL2 )= (0,0,0) & DCEN= 1 Figure 12-6: 16-Bit Auto-reload Up/Down Counter - 100 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 12.2.4 Baud Rate Generator Mode Baud rate generator mode is enabled by setting either RCLK or TCLK in T2CON. In baud rate generator mode, Timer/Counter 2 is a 16-bit counter with auto-reload when the count rolls over from FFFFh. However, rolling-over does not set TF2. If EXEN2 is set, then a negative transition on the T2EX pin sets EXF2 bit in the T2CON register and causes an interrupt request. RCLK+TCLK=1, CP/RL2 =0 Figure 12-7: Baud Rate Generator Mode - 101 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 13. WATCHDOG TIMER The Watchdog Timer is a free-running timer that can be programmed to serve as a system monitor, a time-base generator or an event timer. It is basically a set of dividers that divide the system clock to determine the time-out interval. When the time-out occurs, a flag is set, which can generate an interrupt or a system reset, if enabled. The interrupt will occur if its interrupt and global interrupt enables are set. The interrupt and reset functions are independent of each other and may be used separately or together. The main use of the Watchdog Timer is as a system monitor. In case of power glitches or electromagnetic interference, the processor may begin to execute errant code. The Watchdog Timer helps W79E22X SERIES recovers from these states. During development, the code is first written without the watchdog interrupt or reset. Then, the watchdog interrupt is enabled to identify code locations where the interrupt occurs, and instructions are inserted to reset the Watchdog Timer in these locations. In the final version, the watchdog interrupt is disabled, and the watchdog reset is enabled. If errant code is executed, the Watchdog Timer is not reset at the required times, so a Watchdog Timer reset occurs. When used as a simple timer, the reset and interrupt functions are disabled. The Watchdog Timer can be started by RWT and sets the WDIF flag after the selected time interval. Meanwhile, the program polls the WDIF flag to find out when the selected time interval has passed. Alternatively, the Watchdog Timer can also be used as a very long timer. In this case, the interrupt feature is enabled. Figure 13-1: Watchdog Timer The Watchdog Timer should be started by RWT because this ensures that the timer starts from a known state. The RWT bit is self-clearing; i.e., after writing a 1 to this bit, the bit is automatically cleared. After setting RWT, the Watchdog Timer begins counting clock cycles. The time-out interval is selected by WD1 and WD0 (CKCON.7 and CKCON.6). WD1 0 0 1 1 WD0 INTERRUPT TIME-OUT RESET TIME-OUT NUMBER OF CLOCKS 0 217 217 + 512 131072 13.11 mS 11.85 mS 5.24 mS 1 20 0 1 2 23 2 26 2 TIME @ 10 MHZ TIME @ 11.0592 MHZ TIME @ 25 MHZ 20 + 512 1048576 104.86 mS 94.81 mS 41.94 mS 23 + 512 8388608 838.86 mS 758.52 mS 335.54 mS 26 + 512 67108864 6710.89 mS 6068.15 mS 2684.35 mS 2 2 2 Table 13-1: Time-out values for the Watchdog Timer - 102 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet When the selected time-out occurs, the watchdog interrupt flag WDIF (WDCON.3) is set. After watchdog time-out, and if Watchdog Timer Reset EWT (WDCON.1) is enabled, the Watchdog Timer will cause a reset 512 clocks later. This reset lasts two machine cycles, and the Watchdog Timer reset flag WTRF (WDCON.2) is set, which indicates that the Watchdog Timer caused the reset. RWT can be used to clear Watchdog timer before a time-out occurs. The Watchdog Timer is disabled by a power-on/fail reset. The external reset and Watchdog Timer reset can not disable Watchdog Timer, instead it only restart the Timer. The control bits that support the Watchdog Timer are described as below: Watchdog Timer Control (WDCON) BIT NAME 7 - 6 POR 5-4 - FUNCTION Reserved. Power-on reset flag. The hardware sets this flag during power–up, and it can only be cleared by software. This flag can also be written by software. Reserved. WDIF Watchdog Timer Interrupt Flag. If the watchdog interrupt is enabled, the hardware sets this bit to indicate that the watchdog interrupt has occurred. If the interrupt is not enabled, this bit indicates that the time-out period has elapsed. This bit must be cleared by software. 2 WTRF Watchdog Timer Reset Flag. If EWT is 0, the Watchdog Timer has no affect on this bit. Otherwise, the hardware sets this bit when the Watchdog Timer causes a reset. It can be cleared by software or a power-fail reset. It can be also read by software, which helps determine the cause of a reset. 1 EWT Enable Watchdog-Timer Reset. Set this bit to enable the Watchdog Timer Reset function. 0 RWT Reset Watchdog Timer. Set this bit to reset the Watchdog Timer before a time-out occurs. This bit is automatically cleared by the hardware. 3 - 103 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet The POR, EWT, WDIF and RWT bits are protected by the Timed Access procedure. This procedure prevents software, especially errant code, from accidentally enabling or disabling the Watchdog Timer. An example is provided below. org mov mov clr jnb jmp bypass_reset: mov mov setb reti 63h TA,#AAH TA,#55H WDIF execute_reset_flag,bypass_reset $ ; Test if CPU need to reset. ; Wait to reset TA,#AAH TA,#55H RWT org 300h mov mov mov mov mov mov mov setb setb jmp ckcon,#01h ckcon,#61h ckcon,#81h ckcon,#c1h TA,#aah TA,#55h WDCON,#00000011B EWDI ea $ start: ; ; ; ; Select 2 ^ 17 timer ; Select 2 ^ 20 timer ; Select 2 ^ 23 timer ; Select 2 ^ 26 timer ; Wait time out Clock Control WD1, WD0: CKCON.7, CKCON.6 - Watchdog Timer Mode select bits. These two bits select the timeout interval for the Watchdog Timer. The reset interval is 512 clocks longer than the selected interval. The default time-out is 217 clocks, the shortest time-out period. - 104 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 14. PULSE-WIDTH-MODULATED (PWM) OUTPUTS 14.1 PWM Features The PWM block supports the following features; z Four 12-bit PWM channels or complementary pairs: „ 4 independent PWM outputs: PWM0, PWM2, PWM4 & PWM6. „ 4 complementary PWM pairs with insertion of programmable dead-time: (PWM0,PWM1), (PWM2,PWM3), (PWM4,PWM5), (PWM6,PWM7) z Three operation mode: Edge aligned mode, Center aligned mode and Single shot mode. z Programmable dead-time insertion between paired PWMs. z Output override control for Electrically Commutated Motor operation. z Hardware/software brake protection. z Support 2 independent interrupts: „ Interrupt request when up/down counter comparison matched or underflow. „ Interrupt request when external brake asserted. z Flexible operation in debug mode. z High Source/Sink current. The outputs for PWM0 to PWM7 are on P2[5:0] (PWM[5:0]) and P5[1:0] (PWM [7:6]) respectively. After CPU reset, the internal output of each PWM channel depends on the output controls and polarity settings. The interval between successive outputs is controlled by a 12–bit up/down counter which uses the oscillator frequency with configurable internal clock prescaler as its input. The PWM counter clock, has the frequency as the clock source FPWM = FOSC/Prescaler. The following Figure 14-1: PWM Block Diagram below is the block diagram for PWM. PWM0 Generator PWM0 & PWM1 Dead Time Generator Output Control PWM0 PWM2 Generator PWM2 & PWM3 Dead Time Generator Output Control PWM2 PWM Logic control PWM4 Generator PWM4 & PWM5 Dead Time Generator Output Control Brake Control PWM6 Generator PWM6 & PWM7 Dead Time Generator Output Control PWM Time Base Control PWM1 PWM I/O Pin Drive Block PWM3 PWM4 PWM5 PWM6 PWM7 Brake Condition Figure 14-1: PWM Block Diagram - 105 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 14.2 PWM Control Registers The overall functioning of the PWM module is controlled by the contents of the PWMCON1 register. The operation of most of the control bits is straightforward. For example PWM0I is an invert bit for each output which causes results in the output to have the opposite value compared to its noninverted output. The transfer of the data from the Counter and Compare registers to the control registers is controlled by the PWMCON1.6 (load) while PWMCON1.7 (PWMRUN) allows the PWM to be either in the run or idle state. If the Brake pin is not used to control the brake function, the “Brake when PWM is not running” function can be used to cause the outputs to have a given state when the PWM is halted. This approach should be used only in time critical situations when there is not sufficient time to use the approach outlined above, since going from the Brake state to run without causing an undefined state on the outputs is not straightforward. A discussion on this topic is included in the section on PWMCON2. The Brake function, which is controlled by the contents of the PWMCON2 register, is somewhat unique. In general, when Brake is asserted, the eight PWM outputs are forced to a user selected state, namely the state selected by PWMCON3. As shown in the description of the operation of the PWMCON2 register, if PWMCON2.4, BKEN, is a “1” brake is asserted under the control PWMCON2.7, BKCH, and PWMCON2.5, BPEN. As shown, if both are a “0”, brake is asserted. If PWMCON2.7 is a “1”, brake is asserted when the PWMRUN bit, PWMCON1.7, is a “0”. If PWMCON2.6, BKPS, is a “1”, brake is asserted when the Brake Pin, P1.1, has the same polarity as PWMCON2.6. When brake is asserted in response to this pin, the PWMRUN bit in PWMCON1.7 is automatically cleared, and BKF (PWMCON4.0) flag will be set. When both BKCH and BPEN are “1”, BKF will be set when Brake pin is asserted, but PWM generator continues to run. With this special condition, the PWM output does not follow PWMnB, instead it output continuously as per normal without affected by the brake. Since the Brake Pin being asserted will automatically clear the PWMRUN (PWMCON1.7) and BKF (PWMCON4.0) flag will be set, the user program can poll this bit or enable PWM’s brake interrupt to determine when the Brake Pin causes a brake to occur. The other method for detecting a brake caused by the Brake Pin would be to tie the Brake Pin to one of the external interrupt pins. This latter approach is needed if the Brake signal is of insufficient length to ensure that it can be captured by a polling routine. When, after being asserted, the condition causing the brake is removed, the PWM outputs go to whatever state that had immediately prior to the brake. This means that in order to go from brake being asserted to having the PWM run without going through an indeterminate state, care must be taken. If the Brake Pin causes brake to be asserted, the following prototype code will allow the PWM to go from brake to run smoothly by software polling BKF flag or enable PWM’s interrupt. • Rewrite PWMCON2 to change from Brake Pin enabled to S/W Brake. • Write PWM (0, 2, 4, 6) Compare register to always “1”, FFFh, or always “0”, 000h, to initialize PWM output to a High or Low, respectively. • Clear BKF flag. • Set PWMCON1 to enable PWMRUN and Load. • Poll Brake Pin until it is no longer active. • Poll PWMCON1 to find that Load Bit PWMCON1.6 is “0”. When “0”: • Write PWMP (0, 2, 4, and 6) Counter register for desired pulse widths and counter reload values. • Set PWMCON1 to Run and Transfer. - 106 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Note that if a narrow pulse on the Brake Pin causes brake to be asserted, it may not be possible to go through the above code before the end of the pulse. In this case, in addition to the code shown, an external latch on the Brake Pin may be required to ensure that there is a smooth transition in going from brake to run. A compare value greater than the counter reloaded value resulted in the PWM output being high. In addition there are two special cases. A compare value of all zeroes, 000H, causes the output to remain permanently Low. A compare value of all ones, FFFH, results in the PWM output remaining permanently High. Figure 14-2: PWM Time-base Generator and Brake Function The PWMP register fact that writes are not into the Counter register that controls the counter; rather they are into a holding register. As described below the transfer of data from this holding register, into - 107 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet the register which contains the actual reload value, is controlled by the user’s program. The width of each PWM output pulse is determined by the value in the appropriate compare register. Each PWM register pair of (PWMPH,PWMPL), (PWM0H,PWM0L), (PWM2H,PWM2L), (PWM4H,PWM4L) and (PWM6H,PWM6L),in the format of 12-bit width by combining 4 LSB of high byte and 8 MSB bits of low byte, decides the PWM period and each channel’s duty cycle. The following equations show the formula for period and duty for each pwm operation mode: Edge aligned: Period = (pwmp +1) * ioclock period * 1/prescaler Duty = duty * ioclock period Single shot: Period = (pwmp) * ioclock period /prescaler (no meaning since it is not periodic) Duty = (duty) * ioclock period/prescaler (for prescaler 1, 1/2/2, 1/4) (duty-1) * ioclock period /prescaler < Duty < (duty) * ioclock period/prescaler (for prescaler 1/16) Centre aligned: Period = (pwmp* 2) * ioclock period /prescaler Duty = (duty*2 - 1) * ioclock period /prescaler Note: “duty” refers to PWM0~3 register value. 14.3 PWM Pin Structures As show in the following diagrams, PWM pin structures are controllable through PWM options bits (PWMEE/PWMOE) and SFR PWMCON4 bits (PWMEOM/PWMOOM/PWM6OM/PWM7OM). PWMEE/PWMOE (OPTION BITS) PWMEOM/PWMOOM /PWM6OM/PWM7OM PIO.X (X = 0-7) X 0 X Tri-state 1 (Disable) 1 X Quasi (I/O output) 0 (Enable) 1 0 Push Pull (PWM output) 1 1 Push Pull (I/O output) 0 (Enable) PIN STRUCTURES Table 14-1: PWM pin structures (during internal rom execution) PWMEE/PWMOE (OPTION BITS) PWMEOM/PWMOOM /PWM6OM/PWM7OM PIO.X (X = 0-7) 1 (Disable) X X External access Push Pull 0 (Enable) X X External access Push Pull (strong) PIN OUTPUT PIN STRUCTURES Table 14-2: PWM pin structures (during external rom execution) Note: PWMEOM/PWMOOM/PWM6OM/PWM7OM are cleared to zero when CPU in reset state. - 108 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Thus, the port pins that multi-function with PWM will be tri-stated on default. User is required to set the bits to enable GPIO/PWM outputs. Figure 14-3: PWM0, 2 & 4 I/O pins Figure 14-4: PWM1, 3 & 5 I/O pins Figure 14-5: PWM6 I/O pin - 109 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-6: PWM7 I/O pin Figure 14-7: Even PWM Output OPOL (Option Bit) PWM Initial State Low High 0 PWMoEN 1 0 PWM Output (PWM1,3,5,7) 1 C PWMoB 0 1 In Brake Condition Note: o = 1,3,5,7 Figure 14-8: Odd PWM Output - 110 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 14.4 Complementary PWM with Dead-time and Override functions In this module there are four duty-cycle generators, from 0 through 3. The total of eight PWM output pins in this module, from 0 through 7. The eight PWM outputs are grouped into output pairs of even and odd numbered outputs. In complimentary modes, the odd PWM pins must always be the complement of the corresponding even PWM pin. For example, PWM1 will be the complement of PWM0. PWM3 will be the complement of PWM2, PWM5 will be the complement of PWM4 and PWM7 will be the complement of PWM6. Complementary mode is enabled only when both PWMeEN and the corresponding PWMoEN are set to high. The time base for the PWM module is provided by its own 12-bit timer, which also incorporates selectable prescaler options. Note: PWM pairs of (PWM2, 3), (PWM4, 5) and (PWM6, 7) are in the same structure as pair of (PWM0, 1). (Refer to Figure 14-9). Figure 14-9: Complementary PWM with Dead-time and Override functions 14.5 Dead-Time Insertion The dead time generator inserts an “off” period called “dead time” between the turnings off of one pin to the turning on of the complementary pin of the paired pins. This is to prevent damage to the power switching devices that will be connected to the PWM output pins. Each complementary output pair for the PWM module has 6-bits counter used to produce the dead time insertion. Each dead time unit has a rising and falling edge detector connected to the duty cycle comparison output. The dead time is loaded into the timer on the detected PWM edge event. Depending on whether the edge is rising or falling, one of the transitions on the complementary outputs is delayed until the timer counts down to zero. A timing diagram indicating the dead time insertion for one pair of PWM outputs is shown in Figure 14-10 and Figure 14-11. - 111 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PWM0 without Dead-Time PWM1 without Dead-Time PWM0 with Dead-Time PWM1 with Dead-Time Dead-Time Interval Note: PDTC0.4 selects insertion at rising edge Figure 14-10: Effect of Dead-Time for complementary pairs (rising edge) Figure 14-11: Effect of Dead-Time for complementary pairs (falling edge) Note: User need to take care that power switches should not be use when PWM pair is asserted (high) at the same time. PDTCO and PDTC1 have time access protection in writing access. In Power inverter application, a dead time insertion avoids the upper and lower switches of the half bridge from being active at the same time. Hence the dead time control is crucial to proper operation of a system. Some amount of time must be provided between turning off of one PWM output in a complementary pair and turning on the other transistor as the power output devices cannot switch instantaneously. - 112 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 14.6 PWM Output Override Figure 14-12: Override Flow Diagram Each of the PWM output channels can be manually overridden by using the appropriate bits in the POVD and POVM registers. This function allow user to drive the PWM I/O pins to specified logic states independent of the duty cycle comparison units. The PWM override bits are useful when controlling various types of Electrically Commutated Motor (ECM) like a BLDC motor. The POVD register contains eight bits, POVD[7:0]. It determines which PWM I/O pins will be overridden. On reset, POVD is 00H. The POVM register contains eight bits, POVM[7:0]. It determines the state of the PWM I/O pins when a particular output is overridden via the POVD bits. On reset, POVM is 00H. The POVM[7:0] bits are active-high. When the POVM[7:0] bits are set, the corresponding POVD[7:0] bit will have effect on the PWM output. When one of the POVM bits is set, the output on the corresponding PWM I/O pin will be determined by the state of corresponding POVD bit. When a POVM bit is clear, the PWM pin will be driven to its active state. The odd channel is always the complement of the even channel with dead time inserted.. Figure 14-13 demonstrates the override function in complementary mode. - 113 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-13: Override bit in complementary mode Assume rising edge dead time insertion; refer to Figure 14-12: Override Flow Diagram. Example: POVM0 = 1 and POVM1 = 0; PWM0EN and PWM1EN = 1; a. Odd override bits have no effect in complementary mode. b. Even override bit is activated, which causes the Odd PWM to deactivate. c. Dead-Time insertion. d. Even PWM activated after the dead-time. e. Even override bit is deactivated, which causes the Even PWM to deactivate. f. Dead-Time insertion. g. Odd PWM is activated after the dead time. Figure 14-14: Example 1 of Output Even & Odd Override - 114 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet STATE POVM PWMEEN = 1 PWMOEN = 1 POVD 1 2 3 4 5 6 1111 1111b 1111 1111b 1111 1111b 1111 1111b 1111 1111b 1111 1111b 0110 0100b 1010 0001b 0000 1001b 0001 1000b 1001 0010b 0100 0110b Table 14-3: Example 1 of Output Even & Odd Override Figure 14-15: Example 2 of Output Override #1: POVM #2: POVM (Odd not overridenot in (Odd not Override in State complementary) complementary) (PWMeEN = 1, (PWMeEN = 1, PWMoEN = 0) PWMoEN = 1) #3: POVM (Odd with Override not in complementary) (PWMeEN = 1, PWMoEN = 1) POVD 1 0001 0100b 0001 0100b 1011 1110 0000 0000b 2 0000 0101b 0000 0101b 1010 1111 0000 0000b 3 0100 0001b 0100 0001b 1110 1011 0000 0000b 4 0101 0000b 0101 0000b 1111 1010 0000 0000b Table 14-4: Example 2 of Output Override - 115 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 14.7 Edge Aligned PWM (up-counter) Figure 14-16: Edge-Aligned PWM In edge-aligned PWM Output mode, the 12 bits counter will starts counting from 0 to match with the value of the duty cycle PWM0 (old). When the match occurs, it will toggle the PWM0 output waveform to low. After CPU resets, the value of PWM0 waveform at starts of counter depend on the polarity setting located in the Option bits. At this point a new PWM0 (new) is written. The counter will continue counting to match with the value of the period register, PWMP (old) and toggle the PWM0 waveform to high. Please take note that PWM0 and PWMP is a double-buffered register used to set the duty cycle and counting period for the PWM time base respectively. For the 1st buffer it is accessible by user while the 2nd buffer holds the actual compare value used in the present period. Load bit must be set to 1 to enable the value to be loaded in to the 2nd buffer register when counter underflow/match. When the counter matches the PWMP (old) it will automatically update the new duty cycle register and the counter will again starts counting upwards to match the value PWM0 (new). At this point it will toggle the PWM0 waveform to low. New PWMP is written at this point. When the counter continues counting to match the PWMP (old), again the PWM0 waveform will be toggle to high. The counter starts counting from 0 again; at this point the value is PWM0 (new) and PWMP (new) to be match by the counter and once the counter matches these values it will be toggle at the PWM output. - 116 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-17: Edge-Aligned Flow Diagram - 117 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-18: Program Flow for Edge-Aligned mode PWMP (7FF) PWM0 (3FF) PWM0 Waveform PWM Period PWM Period PWM Period PWM Period PWM Period Figure 14-19: PWM0 Edge Aligned Waveform Output 14.8 Center Aligned PWM (up/down counter) - 118 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-20: Center-Aligned Mode Center-aligned PWM signals are produced by the module when the PWM time base is configured in an Up/Down Counting mode (see Figure 14-20). The counter will start counting-up from 0 to match the value of PWM0 (old); this will cause the toggling of the PWM0 output to low. The CPU reset states determine the starts value of PWM0 waveform at starts of counter lies on the polarity setting located in the Option bits. At this time the new PWM0 is written to the register. Counter continue to count and match with the PWMP (old). Upon reaching this states counter is configured automatically to down counting and toggle the PWM0 output when counter matches the PWM0 (old) value. Interrupt request when up/down counter underflow. Once the counter reaches 0 it will update the duty cycle register with Load = 1. Up-counting is continues with the matching at PWM0 (new) follow by a low toggle at the PWM0 output. By this time the PWMP buffer is still consist of the PWMP (old) value. A new PWMP is written. So the counter will still matches with this value and continues with down counting and matched the PWM0 (new) and toggle the PWM0 output. Again updates on the PWM period register is reflected on the 3rd cycle of the diagram by starts counting from 0 to match the PWM0 (new) and toggle at the PWM0 output to low. Counter is continuing up-counting, upon reaching the PWMP (new) it is matched. Then counter is down counting automatically to match at the PWM0 (new) to get a toggle high at PWM0 output. - 119 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-21: Center-aligned Flow Diagram - 120 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet PWMP (7FF) PWM0 (3FF) PWM0 Waveform PWM Period PWM Period PWM Period Figure 14-22: PWM0 Center Aligned Waveform Output 14.9 Single Shot (Up-Counter) Figure 14-23: Single Shot Mode The single shot mode PWM module will produce single pulse output. Single-pulse operation is configured when the PMOD1:PMOD0 bits are set to ‘01’ in PWMCON3 register. This mode of operation is useful for driving certain types of ECMs. In this mode, the PWM counter will start counting upwards when the PWMRUN is set to 1. When the counter value matches with the PWMP register, PWM interrupt will be generated if it is enable and PWMF is set and counter will reset to zero on the following input clock edge and PWMRUN will be cleared by hardware. Duty cycle of PWM channels are determined by the respective PWMx registers, where x = 0,2,4,6 - 121 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Example Steps of setting up Single Shot:1. Set initial state = 0 (controlled by EPOL option bit) 2. PWM0EN=0, POVM.0=0, PWM0I=0, PWM0=0000H(for keep comparator output in low state), PWMP=0001H(let the period as short as possible) 3. PWMRUN=1(Do a dummy PWMRUN for loading PWM0 to compare register0, which make comparator output LOW always. 4. PWM0EN=1, now the PWM0 pin should be still in 0 state. 5. PWMP=xxxxH(controls a period), PWM0=yyyyH(controls duty or pulse width) 6. PWMRUN=1(this time a real PWM single shot signal user wanted. The wave form should be the upper one. Note: In single shot mode, it’s important that user sets CLRPWM together with PWMRUN and LOAD in order to have PWMn and PWMP loaded into working registers immediately. - 122 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-24: Single-Shot Flow Diagram - 123 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 14.10 Smart Fault Detector This is a brake detection logic that is new to support external brake conditions that already exist. A dedicated SFR FSPLT is added for this function. The SFR consists of smart fault detector control and status bits. It basically consists of a clock divider, 8 bits counter, comparator and 4 selectable compare values. The following diagram show the general block diagram. Figure 14-25: Smart Fault Detector The smart fault detector is enabled when bit LSBD = 1 (FSPLT.0). This logic detects low level brake pin. The 8 bits counter is enabled by SFCEN bit located in SFR FSPLT.3. The counter is clock by Fosc divider selectable by SFP1-0 control bits (FSPLT.5-4). The comparator compares the 8 bits counter value with the compare value selectable with SCMP1-0 (FSPLT1-0). Upon initial detection of low level at brake pin, the 8 bits counter will be active. This will cause the counter to increment. While the counter is active and there is high level detected at brake pin, the counter will decrement. See next figure for timing diagram. When the counter value reaches compare value, BKF will be asserted. - 124 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-26: Smart Fault Detector timing diagram The smart fault detector consists of 2 status bits; SFCST and SFCDIR. A SFCST show status of 8 bits counter is active or in-active, while SFCDIR shows the counter’s counting direction. When SFCST = 0, SFCDIR keeps its’ state. The s/w can manually disable and clear the 8 bits counter, by clearing SFCEN to 0. The following tables show the tabulate accumulated low level Brake time with various Fosc/x dividers and compares value, at 40MHz and 20MHz. FOSC/X 1/4 1/8 1/16 1/128 SCMP[1:0] 4 16 64 128 10,000,000 0.40us 1.60us 6.40us 12.80us 5,000,000 0.80us 3.20us 12.80us 25.60us 2,500,000 1.60us 6.40us 25.60us 51.20us 312,500 12.80us 51.20us 204.80us 409.60us Table 14-5: Example the accumulated low level time at 40 MHz FOSC/X 1/4 1/8 1/16 1/128 SCMP[1:0] 4 16 64 128 5,000,000 0.80us 3.20us 12.80us 25.60us 2,500,000 1.60us 6.40us 25.60us 51.20us 1,250,000 3.20us 12.80us 51.20us 102.40us 156,250 25.60us 102.40us 409.60us 819.20us Table 14-6: Example the accumulated low level time at 20 MHz - 125 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 14.11 PWM Power-down/Wakeup Procedures The following flow diagrams describe the possible pwm procedures users require to take care prior to the product power-down/wake-up. The power-down procedure below will result in PWM output a low state after power-down. To output a high state, users may set PWMn to FFFh and initial state set to high through option bit (EPOL/OPOL). Figure 14-27: Example of PWM power-down procedure (pwm output low state) - 126 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 14-28: Example of PWM wake-up from power-down procedure - 127 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 15. MOTION FEEDBACK MODULE Motion feedback module is a peripheral module designed for motion feedback applications. This module includes two sub-modules: • Input Capture Module (IC). • Quadrature Encoder Interface (QEI). There are three 16-bit registers cascaded by two 8-bit SFR in motion feedback module, but with different definitions in each sub-module. Together with Timer 3, these modules provide a number of options for motion and control applications. Most of the features for the QEI and IC sub-modules are fully programmable thus making a flexible peripheral structure that can accommodate a wide range of uses. A simplified block diagram of the entire Motion Feedback module is shown in Figure 15-2. Note: The input pins are common to the IC and QEI sub-modules, only one of these two submodules may be used at any given time. IC sub-module is the default value upon reset. 15.1 Input Capture Module (IC) The capture modules are function to detect and measure pulse width and period of a square wave. It supports 3 capture inputs and digital noise rejection filter. The modules are configured by CAPCON0 and CAPCON1 SFR registers. Input Capture 0, 1 & 2 have their own edge detector but share with one timer i.e. Timer 3. The Input Capture pins structure are Schmitt trigger. For this operation it basically consists of; • 3 capture module function blocks. • Timer 3 block. Each capture module block consists of 2 bytes of capture registers, noise filter and programmable edge triggers. Noise Filter is used to filter the unwanted glitch or pulse on the trigger input pin. The noise filter can be enabled through bit ENFx (CAPCON1). If enabled, the capture logic required to sample 4 consecutive same capture input value in order to recognize an edge as a capture event. A possible implementation of digital noise filter is as follow; the interval between pulses requirement for input capture is 1 machine cycle width, which is the same as the pulse width required to guarantee a trigger for all trigger edge mode. For less than 3 system clocks, anything less than 3 clocks will not have any trigger and pulse width of 3 or more but less than 4 clocks will trigger but will not guarantee 100% because input sampling is at stage C3 of the machine cycle. Figure 15-1: Noise Filter The trigger option is programmable through CCTx [1:0] (CAPCON0). It supports positive edge, negative edge and both edge triggers. Each capture module consists of an enable, ICEN0~2. [Note: x=0, 1, 2 for capture 0, 1, 2 block]. - 128 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Capture blocks are triggered by external pins IC0, IC1 and IC2, respectively. If ICENx is enabled, each time the external pin triggers, the content of the free running 16 bits counter, TL3 & TH3 (from Timer 3 block) will be captured/transferred into the corresponding capture registers, CCLx and CCHx. This action also causes the corresponding CPTFx flag bit in CAPCON1 to be set, and generate an interrupt (if enabled by ECPTF bit in SFR, EIE1.4). The CPTF0-2 flags are logical “OR” to the interrupt module. Input Capture 0~2 share one interrupt named Capture Interrupt. Flag is set by hardware and cleared by software. Setting the T3CR bit (T3MOD.3), will allow hardware to reset timer 3 automatically after the value of TL3 and TH3 have been captured. Priority is given to T3CR to reset counter after capture the timer value into the capture register. When CMP/RL3 = 0 (reload mode, with T3CR=0 and ENLD=1), RCAP3 will be loaded into Timer 3 counter upon overflow. While the rest of the condition of combination of setting for T3CR and ENLD will reset the counter to 0000H. Capture 0 Block Capture 2 Block (Note) Capture 1 Block CCL0 CCH0 CCT0[1:0] CPTF0 With Schmitt Trigger IC0 (P3.4) [00] [1] ENF0 [01] Noise Filter ICEN0 IC2 (P4.1) IC1 (P3.5) [10] CPTF1 CMP/RL3 Reset Timer3 T3CR DIV by 1,4,16,32 Fosc CPTF2 CMP/RL3 TMF3 CPTF0 CPTF1 CPTF2 TL3 TH3 0 TF3 CCDIV[1:0] TR3 TOVF3 00 CPTF0 01 CPTF1 10 CPTF2 11 1 TR3 = TMF3 CMP/RL3 ENLD CMP/RL3 RCAP3L RCAP3H CCLD[1:0] Timer 3 Block Note:TOVF3 = Timer 3 overflow TMF3 = Internal Timer 3 Flag signal. Input Capture 2 block (refer to Figure 15-3). Figure 15-2: Timer3/Capture/Compare/Reload modules - 129 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 15-3: Input Capture 2 block diagram Note: When QEI enabled (QEIEN=1), input capture 2 (IC2) still can detect edge changes. . The following table shows the bits setting for enabling input capture 2 edge detection. QEIEN DISIDX 0 X(don’t care) 1 0 1 1 ICEN2 INPUT CAPTURE 2 EDGE DETECTION 0 Disabled. 1 Enabled. 0 Disabled. 1 Enabled. X Disabled, - 130 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 15-4: Timing diagram for Input Capture - 131 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 15-5: Program flow for measurement with IC0 between pulses with falling edge detection (ACC is incremented in interrupt service routine). - 132 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 15-6: Program flow for measurement with IC0 between pulses with rising edge detection (ACC is incremented in interrupt service routine). - 133 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 15-7: Program flow for measurement with IC0 pulse width with rising and falling edge detection (ACC is incremented in interrupt service routine). - 134 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 15-8: Compare/Reload Function Figure 15-9: Input Capture 0 Triggers 15.1.1 Compare Mode Timer 3 can be configured for compare mode. The compare mode is enabled by setting the CMP/RL3 bit to 1 in the T3CON register. RCAP3 will serves as a compare register. As Timer 3 counting up, - 135 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet upon matching with RCAP3 value, TF3 will be set (which will generate an interrupt request if enable Timer 3 interrupt ET3 is enabled) and the timer reload from 0 and starts counting again. 15.1.2 Reload Mode Timer 3 can be also be configured for reload mode. The reload mode is enabled by clearing the CMP/RL3 bit to 0 in the T3CON register. In this mode, RCAP serves as a reload register. When timer 3 overflows, a reload is generated that causes the contents of the RCAP3L and RCAP3H registers to be reloaded into the TL3 and TH3 registers, if ENLD is set. TF3 flag is set, and interrupt request is generated if enable Timer 3 interrupt ET3 is enabled. However, if ENLD = 0, timer 3 will be reload with 0, and count up again. Alternatively, other reload source is also possible by the input capture pins by configuring the CCLD [1:0] bit. If the ICENx bit is set, then a trigger of external IC0, IC1 or IC2 pin (respectively) will also cause a reload. This action also sets the CPTF0, CPTF1 or CPTF2 flag bit in SFR CAPCON1, respectively. 15.2 Quadrature Encoder Interface (QEI) The Quadrature Encoder Interface (QEI) decodes speed of rotation and motion sensor information. It can be used in any application that uses quadrature encoder for feedback. The QEI block supports the features as below: Two QEI phase inputs: QEA and QEB. 16-bit Up/Down Pulse Counter (PLSCNT) with 16-bit read access latched buffer (PCNT). Four pulse counter update modes: z z z         z − Mode0: x4 free-counting mode. − Mode1: x2 free-counting mode. − Mode2: x4 compare-counting mode. − Mode3: x2 compare-counting mode. Three interrupt sources:   − Pulse counter interrupt (CPTF0/QEIF).   − Direction index of motion detection with direction interrupt (CPTF1/DIRF).   − Input Capture 2 interrupt (CPTF2). z The three 16-bit SFRs in QEI share the same addresses with the capture counter registers. INPUT CAPTURE MODE QEI MODE Capture0 Counter Register (CCH0, CCL0) Pulse Read Counter Register (PCNTH, PCNTL) Capture1 Counter Register (CCH1, CCL1) Pulse Counter Register (PLSCNTH, PLSCNTL) Capture2 Counter Register (CCH2, CCL2) Maximum Counter Register (MAXCNTH, MAXCNTL) In QEI mode, IC1 and IC0 work as QEB and QEA inputs respectively. QEA and QEB accept the outputs from a quadrature encoded source, such as incremental optical shaft encoder. Two channels, A and B, nominally 90 degrees out of phase, are required. - 136 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 15-10: QEI Block Diagram The QEI control logic detects the relation of phase lead/lag between QEA and QEB to produce direction index (DIR) and clock to control pulse counter. The comparator/reload logic compares the pulse counter and maximum count and control the function of reloading pulse counter in comparecounting mode. In Free-counting mode, the pulse counter will counts until the 65535 value. In Compare-counting mode, the pulse counter will count to MAXCNT value. The value of the pulse counter is not affected during QEI mode changes, nor when the QEI is disabled altogether. In QEI mode, when IC2 edge (rising/falling edge is programmable through CAPCON0) has been detected, CPTF2 will be set (if QEIEN=ICEN2=1 and DISIDX=0), and the only way to clear it is by software. - 137 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet CHA*/CHB* - QEA/B after going through noise filter. See Figure 15-10. Figure 15-11: QEA/QEB/IC2 timing requirement. 15.2.1 Free-counting mode Pulse counter up or down counts according to direction index (DIR). When overflow or underflow occurs, it sets flag QEIF. 15.2.2 Compare-counting mode Pulse counter up or down counts according to direction index (DIR). On up counting, QEIF will be asserted when PLSCNT overflows from MAXCNT to zero on the next QEA edge for x2 counting mode, and on QEA/QEB edge for x4 counting mode. On down counting, QEIF will be asserted when PLSCNT underflows from zero to MAXCNT on the next QEA edge for x2 counting mode, and on QEA/QEB edge for x4 counting mode. This mode provides the position of a rotor to user. If a quadrature encoder output 1024 pulses to QEA per round, user can write MAXCNT with 4095 in x4 mode or 2047 in x2 mode and reset PLSCNT at initial before rotor runs. When the PLSCNT reaches MAXCNT, it means rotor runs one round on next QEA edge. 15.2.3 X2/X4 Counting modes In X2 counting mode, the pulse counter increases or decreases one on every QEA edge based on the phase relationship of QEA and QEB signals, however:In X4 counting mode, the pulse counter increases or decreases one on every QEA and QEB edge based on the phase relationship of QEA and QEB signals. 15.2.4 Direction of Count If QEA lead QEB, the pulse counter is increased by 1. If QEA lags QEB, the pulse counter is decreased by 1. The QEI control logic generates a signal that sets the DIR bit (QEICON.3); this in turn determines the direction of the count. When QEA leads QEB, DIR is set (= 1), and the position counter increments on every active edge. When QEA lags QEB, DIR is cleared, and the position counter decrements on every active edge. Refer to below table. - 138 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet CURRENT SIGNAL DETECTED PREVIOUS SIGNAL DETECTED RISING QEA QEA QEB 9 COUNTING CONTROL (DIR) INC (1) DEC (0) 9 QEA falling QEB falling QEB 9 QEA rising QEB rising FALLING 9 DEC (0) INC (1) 9 INC (1) 9 DEC (0) 9 INC (1) 9 DEC (0) Table 15-1: Direction of count Figure 15-12: X4 Counting Mode QEI x4 Counting mode provides for a finer resolution of the rotor position, since the counter increments or decrements more frequently for each QEA/QEB input pulse pair than in QEI x2 mode. This mode is selected by setting the QEI Mode Select bits to ‘00b’ or ‘10b’. In this mode, the QEI logic detects every edge on every QEA and QEB input edges. - 139 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 15-13: X2 Counting Mode QEI x2 Counting mode is selected by setting the QEI Mode Select bits (QEIM1:QEIM0) to ‘01b’ or ‘11b’. In this mode, the QEI logic detects every edge on the QEA input only. Every rising and falling edge on the QEA signal clocks the pulse counter. 15.2.5 Up-Counting Under the forward direction the DIR bit is 1 when up-counting. Software needs to clear the QEIF flag. For the free-counting mode counter will counts until it matches 65535 and next edges on the forward direction will set the QEIF high and reset the PLSCNT to zero. For compare-counting mode counter counts until the MAXCNT value and reload the counter to zero and starts counting up. Changes of direction trigger a down-count and PLSCNT decreasing in counter value. For X2 mode, only CHA edge will set QEIF while for X4 mode both CHA and CHB edges will set QEIF. 15.2.6 Down-Counting A change of direction will causes the counter to down-count for x2/x4 counting mode. It is indicated with the DIR bit as 0 and DIRF flag is set to 1. At this stage the PLSCNT will starts to down-count from the MAXCNT value for compare-counting mode and while in free-counting mode it will starts to down-count from 65535. The pulse counter will reload with MAXCNT when it down counts to zero in compare-counting mode and sets QEIF to high in the next edge. In free-counting mode the counter will count to 16 bits value before it reload the pulse counter with the value 65535 and set the QEIF high in the next edge. For X2 mode, only CHA edge will set QEIF while for X4 mode both CHA and CHB edges will set QEIF. - 140 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 16. SERIAL PORT The W79E22X SERIES has two enhanced serial ports that are functionally similar to the serial port of the original 8052 family. Both the serial ports are full-duplex ports, and the W79E22X SERIES provides additional features, such as Frame Error Detection and Automatic Address Recognition. The serial port 0 can use Timer 1 or 2 as baud rate generator, but the serial port 1 only uses Timer 1 as baud rate generator. However, note that if both serial ports are enabled the baud rate setting control of UART1 is also from the setting of UART0. The serial ports are capable of synchronous and asynchronous communication. In synchronous mode, the W79E22X SERIES generates the clock and operates in half-duplex mode. In asynchronous mode, the serial ports can simultaneously transmit and receive data. The transmit registers and the receive buffers are both addressed as SBUF (SBUF1 for the second serial port), but any write to SBUF/SBUF1 writes to the transmit register while any read from SBUF/SBUF1 reads from the receive buffer. Both serial ports can operate in four modes, as described below. The descriptions are for serial port 0, however, it also apply to the second serial port. 16.1 Mode 0 This mode provides half-duplex, synchronous communication with external devices. In this mode, serial data is transmitted and received on the RXD line, and the W79E22X SERIES provides the shift clock on TxD, whether the device is transmitting or receiving. Eight bits are transmitted or received per frame, LSB first. The baud rate is 1/12 or 1/4 of the oscillator frequency, as determined by the SM2 bit (SCON.5; 0 = 1/12; 1 = 1/4). This programmable baud rate is the only difference between the standard 8051/52 and the W79E22X SERIES in mode 0. Any write to SBUF starts transmission. The shift clock is activated, and data is shifted out on RxD until all eight bits are transmitted. If SM2 is 1, the data appears on RxD one clock period before the falling edge of the shift clock on TxD. Then, the clock remains low for two clock periods before going high again. If SM2 is 0, the data appears on RxD three clock periods before the falling edge of the shift clock on TxD, and the clock on TxD remains low for six clock periods before going high again. This ensures that, at the receiving end, the data on the RxD line can be clocked on the rising edge of the shift clock or latched when the clock is low. The TI flag is set high in C1 following the end of transmission. The functional block diagram is shown below. Write to SBUF Fosc Transmit Shift Register Internal Data Bus PARIN LOAD SOUT CLOCK 1/12 1/4 TX START TX SHIFT SM2 0 1 TX CLOCK TI RX CLOCK RI REN TX START Serial Interrupt RI TXD P3.1 Alternate Output Function SHIFT CLOCK LOAD SBUF RX SHIFT Serial Controllor RXD P3.0 Alternate Input Function RXD P3.0 Alternate Output Function Read SBUF CLOCK SIN PAROUT SBUF Internal Data Bus Receive Shift Register - 141 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 16-1 Serial Port Mode 0 The serial port receives data when REN is 1 and RI is zero. The shift clock (TxD) is activated, and the serial port latches data on the rising edge of the shift clock. The external device should, therefore, present data on the falling edge of the shift clock. This process continues until all eight bits have been received. The RI flag is set in C1 following the last rising edge of the shift clock, which stops reception until RI is cleared by the software. 16.2 Mode 1 In Mode 1, full-duplex asynchronous communication is used. Frames consist of ten bits transmitted on TXD and received on RXD. The ten bits consist of a start bit (0), eight data bits (LSB first), and a stop bit (1). When receiving, the stop bit goes into RB8 in SCON. The baud rate in this mode is 1/16 or 1/32 of the Timer 1 overflow, and since Timer 1 can be set to a wide range of values, a wide variation of baud rates is possible. Transmission begins with a write to SBUF but is synchronized with the divide-by-16 counter, not the write to SBUF. The start bit is put on TxD at C1 following the first roll-over of the divide-by-16 counter, and the next bit is placed at C1 following the next rollover. After all eight bits are transmitted, the stop bit is transmitted. The TI flag is set in the next C1 state, or the tenth rollover of the divide-by-16 counter after the write to SBUF. Reception is enabled when REN is high, and the serial port starts receiving data when it detects a falling edge on RxD. The falling-edge detector monitors the RxD line at 16 times the selected baud rate. When a falling edge is detected, the divide-by-16 counter is reset to align the bit boundaries with the rollovers of the counter. The 16 states of the counter divide the bit time into 16 slices. Bit detection is done on a best-of-three basis using samples at the 8th, 9th and 10th counter states. If the first bit after the falling edge is not 0, the start bit is invalid, reception is aborted immediately, and the serial port resumes looking for a falling edge on RxD. If a valid start bit is detected, the rest of the bits are shifted into SBUF. After shifting in eight data bits, the stop bit is received. Then, if; 1. RI is 0, and 2. SM2 is 0 or the received stop bit is 1, the stop bit goes into RB8, the eight data bits go into SBUF, and RI is set. Otherwise, the received frame is lost. In the middle of the stop bit, the receiver resumes looking for a falling edge on RxD. Transmit Shift Register Timer 2 Overflow Timer 1 Overflow Write to SBUF 1/2 SMOD 0 TCLK RCLK Internal Data Bus 1 STOP 0 START LOAD PARIN SOUT TXD CLOCK 1 0 1 0 1 TX START 1/16 1/16 TX SHIFT TX CLOCK Serial Controllor RX CLOCK SAMPLE 1-To-0 DETECTOR TX START TI Serial Interrupt RI LOAD SBUF Read SBUF RX SHIFT CLOCK PAROUT RXD BIT DETECTOR SIN D8 SBUF Internal Data Bus RB8 Receive Shift Register Figure 16-2 Serial Port Mode 1 - 142 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 16.3 Mode 2 In Mode 2, full-duplex asynchronous communication is used. Frames consist of eleven bits: one start bit (0), eight data bits (LSB first), a programmable ninth bit (TB8) and a stop bit (0). When receiving, the ninth bit is put into RB8. The baud rate is 1/16 or 1/32 of the oscillator frequency, as determined by SMOD in PCON. Transmission begins with a write to SBUF but is synchronized with the divide-by-16 counter, not the write to SBUF. The start bit is put on TxD pin at C1 following the first roll-over of the divide-by-16 counter, and the next bit is placed on TxD at C1 following the next rollover. After all nine bits of data are transmitted, the stop bit is transmitted. The TI flag is set in the next C1 state, or the 11th rollover of the divide-by-16 counter after the write to SBUF. Reception is enabled when REN is high, and the serial port starts receiving data when it detects a falling edge on RxD. The falling-edge detector monitors the RxD line at 16 times the selected baud rate. When a falling edge is detected, the divide-by-16 counter is reset to align the bit boundaries with the rollovers of the counter. The 16 states of the counter divide the bit time into 16 slices. Bit detection is done on a best-of-three basis using samples at the 8th, 9th and 10th counter states. If the first bit after the falling edge is not 0, the start bit is invalid, reception is aborted, and the serial port resumes looking for a falling edge on RxD. If a valid start bit is detected, the rest of the bits are shifted into SBUF. After shifting in nine data bits, the stop bit is received. Then, if; 1. RI is 0, and 2. SM2 is 0 or the received stop bit is 1, the stop bit goes into RB8, the eight data bits go into SBUF, and RI is set. Otherwise, the received frame may be lost. In the middle of the stop bit, the receiver resumes looking for a falling edge on RxD. The functional description is shown in the figure below. Transmit Shift Register 1 TB8 Internal Data Bus 0 Fosc/2 Write to SBUF 1/2 STOP D8 PARIN START LOAD SOUT TXD CLOCK SMOD 0 TX START 1 1/16 1/16 TX SHIFT TX CLOCK Serial Controllor RX CLOCK SAMPLE 1-To-0 DETECTOR TX START TI Serial Interrupt RI LOAD SBUF Read SBUF RX SHIFT CLOCK PAROUT RXD BIT DETECTOR SIN D8 SBUF Internal Data Bus RB8 Receive Shift Register Figure 16-3 Serial Port Mode 2 - 143 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 16.4 Mode 3 This mode is the same as Mode 2, except that the baud rate is programmable. The program must select the mode and baud rate in SCON before any communication can take place. Timer 1 should be initialized if Mode 1 or Mode 3 will be used. Figure 16-4 Serial Port Mode 3 SM0 SM1 MODE TYPE BAUD CLOCK FRAME SIZE START BIT STOP BIT 9TH BIT FUNCTION 0 0 0 Synch. 4 or 12 OSC 8 bits No No None 0 1 1 Asynch. Timer 1 or 2 10 bits 1 1 None 1 0 2 Asynch. 32 or 64 OSC 11 bits 1 1 0, 1 1 1 3 Asynch. Timer 1 or 2 11 bits 1 1 0, 1 Table 16-1: Serial Ports Modes 16.5 Framing Error Detection A frame error occurs when a valid stop bit is not detected. This could indicate incorrect serial data communication. Typically, a frame error is due to noise or contention on the serial communication line. The W79E22X SERIES has the ability to detect framing errors and set a flag that can be checked by software. The frame error FE (FE_1) bit is located in SCON.7. This bit is SM0 in the standard 8051/52 family, but, in the W79E22X SERIES, it serves a dual function and is called SM0/FE. There are actually two separate flags, SM0 and FE. The flag that is actually accessed as SCON.7 is determined by SMOD0 (PCON.6). When SMOD0 is set to 1, the FE flag is accessed. When SMOD0 is set to 0, the SM0 flag is accessed. - 144 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet The FE bit is set to 1 by the hardware, but it must be cleared by the software. Once FE is set, any frames received afterwards, even those without errors, do not clear the FE flag. The flag has to be cleared by the software. Note that SMOD0 must be set to 1 while reading or writing FE. - 145 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 16.6 Multiprocessor Communications Multiprocessor communication is available in modes 1, 2 and 3 and makes use of the 9th data bit and the automatic address recognition feature. This approach eliminates the software overhead required to check every received address and greatly simplifies the program. In modes 2 and 3, address bytes are distinguished from data bytes by 9th bit set, which is set high in address bytes. When the master processor wants to transmit a block of data to one of the slaves, it first sends the address of the target slave(s). The slave processors have already set their SM2 bits high so that they are only interrupted by an address byte. The automatic address recognition feature then ensures that only the addressed slave is actually interrupted. This feature compares the received byte to the slave’s Given or Broadcast address and only sets the RI flag if the bytes match. This slave then clears the SM2 bit, clearing the way to receive the data bytes. The unaddressed slaves are not affected, as they are still waiting for their address. In mode 1, the 9th bit is the stop bit, which is 1 in valid frames. Therefore, if SM2 is 1, RI is only set if a valid frame is received and if the received byte matches the Given or Broadcast address. The master processor can selectively communicate with groups of slaves using the Given Address or all the slaves can be addressed together using the Broadcast Address. The addresses for each slave are defined by the SADDR and SADEN registers. The slave address is the 8-bit value specified in SADDR. SADEN is a mask for the value in SADDR. If a bit position in SADEN is 0, then the corresponding bit position in SADDR is a don't-care condition in the address comparison. Only those bit positions in SADDR whose corresponding bits in SADEN are 1 are used to obtain the Given Address. This provides flexibility to address multiple slaves without changing addresses in SADDR. The following example shows how to setup the Given Addresses to address different slaves. Slave 1: SADDR 1010 0100 SADEN 1111 1010 Given 1010 0x0x Slave 2: SADDR 1010 0111 SADEN 1111 1001 Given 1010 0xx1 The Given Address for slaves 1 and 2 differ in the LSB. In slave 1, it is a don't-care, while, in slave 2, it is 1. Thus, to communicate with only slave 1, the master must send an address with LSB = 0 (1010 0000). Similarly, bit 1 is 0 for slave 1 and don't-care for slave 2. Hence, to communicate only with slave 2, the master has to transmit an address with bit 1 = 1 (1010 0011). If the master wishes to communicate with both slaves simultaneously, then the address must have bit 0 = 1 and bit 1 = 0. Since bit 3 is don't-care for both slaves, two different addresses can address both slaves (1010 0001 and 1010 0101). The master can communicate with all the slaves simultaneously using the Broadcast Address. The Broadcast Address is formed from the logical OR of the SADDR and SADEN registers. The zeros in the result are don't–care values. In most cases, the Broadcast Address is FFh. In the previous case, the Broadcast Address is (1111111X) for slave 1 and (11111111) for slave 2. The SADDR and SADEN registers are located at addresses A9h and B9h, respectively. These two registers default to 00h, so the Given Address and Broadcast Address default to XXXX XXXX (i.e., all bits don't-care), which effectively removes the multiprocessor communications feature - 146 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 17. I2C SERIAL PORTS The I2C bus uses two wires (SCL and SDA) to transfer information between devices connected to the bus. The main features of the I2C bus are: – Bi-directional data transfer between masters and slaves. – Multi-master bus (no central master). – Arbitration between simultaneously transmitting masters without corruption of serial data on the bus. – Serial clock synchronization allows devices with different bit rates to communicate via one serial bus. – Serial clock synchronization can be used as a handshake mechanism to suspend and resume serial transfer. – The I2C bus may be used for test and diagnostic purposes. STOP Repeated START START STOP SDA tBUF tLOW tr SCL tHD;STA tf tHIGH tHD;DAT tSU;DAT tSU;STA tSU;STO Figure 17-1: I2C Bus Timing The device’s on-chip I2C logic provides the serial interface that meets the I2C bus standard mode specification. The I2C logic handles bytes transfer autonomously. It also keeps track of serial transfers, and a status register (I2STATUS) reflects the status of the I2C bus. The I2C port, SCL and SDA are at P2.6 and P2.7. When the I/O pins are used as I2C port, user must set the pins to logic high in advance. When I2C port is enabled by setting ENS to high, the internal states will be controlled by I2CON and I2C logic hardware. Once a new status code is generated and stored in I2STATUS, the I2C interrupt flag (SI) will be set automatically. If both EA and EI2C are also in logic high, the I2C interrupt is requested. The 5 most significant bits of I2STATUS stores the internal state code, the lowest 3 bits are always zero and the content keeps stable until SI is cleared by software. 17.1 SIO Port The SIO port is a serial I/O port, which supports all transfer modes from and to the I2C bus. The SIO port handles byte transfers autonomously. To enable this port, the bit ENS1 in I2CON should be set to '1'. The CPU interfaces to the SIO port through the seven special function registers. The detail description of these registers can be found in the I2C Control registers section. The SIO H/W interfaces to the I2C bus via two pins: SDA (P2.7, serial data line) and SCL (P2.6, serial clock line). Pull up resistor is needed for Pin P2.6 and P2.7 for I2C operation as these are 2 open drain pins. 17.2 The I2C Control Registers The I2C has 1 control register (I2CON) to control the transmit/receive flow, 1 data register (I2DAT) to buffer the Tx/Rx data, 1 status register (I2STATUS) to catch the state of Tx/Rx, recognizable slave address register for slave mode use and 1 clock rate control block for master mode to generate the variable baud rate. - 147 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet SYMBOL DEFINITION I2TIMER I2C Timer Counter Register I2CLK I2C Clock Rate I2STATUS I2C Status Register ADDRESS EFH MSB - - BIT_ADDRESS, SYMBOL - - - ENTI LSB DIV4 RESET TIF xxxx x000B EEH I2CLK.7 I2CLK.6 I2CLK.5 I2CLK.4 I2CLK.3 I2CLK.2 I2CLK.1 I2CLK.0 0000 0000B EDH I2STAT US.7 I2STAT US.6 I2STAT US.5 I2STAT US.4 I2STAT US.3 - - - 1111 1000B I2DAT I2C Data ECH I2DAT.7 I2DAT.6 I2DAT.5 I2DAT.4 I2DAT.3 I2DAT.2 I2DAT.1 I2DAT.0 0000 0000B I2ADDR I2C Slave Address EAH ADDR.7 ADDR.6 ADDR.5 ADDR.4 ADDR.3 ADDR.2 ADDR.1 GC 0000 0000B I2CON I2C Control Register E9H - x000 000xB I2CSADEN I2C Maskable Slave Address F6H I2CSAD I2CSAD I2CSAD I2CSAD I2CSAD I2CSAD I2CSAD I2CSAD 1111 1110B EN.7 EN.6 EN.5 EN.4 EN.3 EN.2 EN.1 EN.0 ENS STA STO SI AA I2CIN - Table 17-1: Control Registers of I2C Ports 17.2.1 Slave Address Registers, I2ADDR I2C port is equipped with one slave address register. The contents of the register are irrelevant when I2C is in master mode. In the slave mode, the seven most significant bits must be loaded with the MCU’s own slave address. The I2C hardware will react if the contents of I2ADDR are matched with the received slave address. The I2C ports support the “General Call” function. If the GC bit is set the I2C port1 hardware will respond to General Call address (00H). Clear GC bit to disable general call function. When GC bit is set, the device is in slave mode which can receive the General Call address(00H) sent by Master on the I2C bus. This special slave mode is referred to as GC mode. 17.2.2 Data Register, I2DAT This register contains a byte of serial data to be transmitted or a byte which has just been received. The CPU can read from or write to this 8-bit directly addressable SFR while it is not in the process of shifting a byte. Data in I2DAT remains stable as long as SI is set. The MSB is shifted out first.While data is being shifted out, data on the bus is simultaneously being shifted in; I2DAT always contains the last data byte present on the bus. Thus, in the event of arbitration lost, the transition from master transmitter to slave receiver is made with the correct data in I2DAT. I2DAT and the acknowledge bit form a 9-bit shift register which shifts in or out an 8-bit byte, followed by an acknowledge bit. The acknowledge bit is controlled by the hardware and cannot be accessed by the CPU. Serial data is shifted into I2DAT on the rising edges of serial clock pulses on the SCL line. When a byte has been shifted into I2DAT, the serial data is available in I2DAT, and the acknowledge bit (ACK or NACK) is returned by the control logic during the ninth clock pulse. Serial data is shifted out from I2DAT on the falling edges of SCL clock pulses, and is shifted into I2DAT on the rising edges of SCL clock pulses. I2C Data Register: I2DAT.7 I2DAT.6 I2DAT.5 I2DAT.4 I2DAT.3 I2DAT.2 I2DAT.1 I2DAT.0 shifting direction Figure 17-2: I2C Data Shift 17.2.3 Control Register, I2CON The CPU can read from and write to this 8-bit, directly addressable SFR. Two bits are affected by hardware: the SI bit is set when the I2C hardware requests a serial interrupt, and the STO bit is cleared when a STOP condition is present on the bus. The STO bit is also cleared when ENS = "0". ENS I2C serial function block enable bit. When ENS=1 the I2C serial function enables. The port latches of SDA1 and SCL1 must be set to logic high. - 148 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet STA STO SI AA I2CIN I2C START Flag. Setting STA to logic 1 to enter master mode, the I2C hardware sends a START or repeat START condition to bus when the bus is free. I2C STOP Flag. In master mode, setting STO to transmit a STOP condition to bus then I2C hardware will check the bus condition if a STOP condition is detected this flag will be cleared by hardware automatically. In a slave mode, setting STO resets I2C hardware to the “not addressed slave mode”. I2C Port 1 Interrupt Flag. When a new SIO state is present in the S1STA register, the SI flag is set by hardware, and if the EA and EI2C1 bits are both set, the I2C1 interrupt is requested. SI must be cleared by software. Assert Acknowledge control bit. When AA=1 prior to address or data received, an acknowledged (low level to SDA) will be returned during the acknowledge clock pulse on the SCL line when; 1.) A slave is acknowledging the address sent from master, 2.) The receiver devices are acknowledging the data sent by transmitter. When AA=0 prior to address or data received, a not acknowledged (high level to SDA) will be returned during the acknowledge clock pulse on the SCL line. By default it is zero and input are allows to come in through SDA pin. As when it is 1 input is disallow and to prevent leakage current. During Power-Down mode input is disallow. 17.2.4 Status Register, I2STATUS I2STATUS is an 8-bit read-only register. The three least significant bits are always 0. The five most significant bits contain the status code. There are 23 possible status codes. When I2STATUS contains F8H, no serial interrupt is requested. All other I2STATUS values correspond to defined I2C ports states. When each of these states is entered, a status interrupt is requested (SI = 1). A valid status code is present in I2STATUS one machine cycle after SI is set by hardware and is still present one machine cycle after SI has been reset by software. In addition, state 00H stands for a Bus Error. A Bus Error occurs when a START or STOP condition is present at an illegal position in the format frame. Examples of illegal positions are during the serial transfer of an address byte, a data byte or an acknowledge bit. 17.2.5 I2C Clock Baud Rate Control, I2CLK The data baud rate of I2C is determines by I2CLK register when I2C port is in a master mode. It is not important when I2C port is in a slave mode. In the slave modes, SIO will automatically synchronize with any clock frequency up to 400 KHz from master I2C device. The data baud rate of I2C setting conforms to the following equation. Data Baud Rate of I2C = FCPU / (I2CLK + 1), where FCPU = FOSC/4. For example, if FOSC=16MHz, the I2CLK=40(28H), the data baud rate of I2C = (16MHz/4)/(40+1) = 97.56K bits/sec. 17.2.6 I2C Time-out Counter, I2Timer In W79E22X SERIES, the I2C logic block provides a 14-bit timer-out counter that helps user to deal with bus pending problem. When SI is cleared user can set ENTI=1 to start the time-out counter. If I2C bus is pended too long to get any valid signal from devices on bus, the time-out counter overflows cause TIF=1 to request an I2C interrupt. The I2C interrupt is requested in the condition of either SI=1 or TIF=1. Flags SI and TIF must be cleared by software. 17.2.7 I2C Maskable Slave Address This register enables the Automatic Address Recognition feature of the I2C. When a bit in the I2CSADEN is set to 1, the same bit location in I2CSADDR1 will be compared with the incoming serial - 149 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet port data. When I2CSADEN.n is 0, then the bit becomes a don't-care in the comparison. This register enables the Automatic Address Recognition feature of the I2C. When all the bits of I2CSADEN are 0, interrupt will occur for any incoming address. Figure 17-3: I2C Time-out Block Diagram 17.3 Modes of Operation The on-chip I2C ports support five operation modes, Master transmitter, Master receiver, Slave transmitter, Slave receiver, and GC call. In a given application, I2C port may operate as a master or as a slave. In the slave mode, the I2C port hardware looks for its own slave address and the general call address. If one of these addresses is detected, and if the slave is willing to receive or transmit data from/to master(by setting the AA bit), acknowledge pulse will be transmitted out on the 9th clock, hence an interrupt is requested on both master and slave devices if interrupt is enabled. When the microcontroller wishes to become the bus master, the hardware waits until the bus is free before the master mode is entered so that a possible slave action is not interrupted. If bus arbitration is lost in the master mode, I2C port switches to the slave mode immediately and can detect its own slave address in the same serial transfer. 17.3.1 Master Transmitter Mode Serial data output through SDA while SCL outputs the serial clock. The first byte transmitted contains the slave address of the receiving device (7 bits) and the data direction bit. In this case the data direction bit (R/W) will be logic 0, and we say that a “W” is transmitted. Thus the first byte transmitted is SLA+W. Serial data is transmitted 8 bits at a time. After each byte is transmitted, an acknowledge bit is received. START and STOP conditions are output to indicate the beginning and the end of a serial transfer. 17.3.2 Master Receiver Mode In this case the data direction bit (R/W) will be logic 1, and we say that an “R” is transmitted. Thus the first byte transmitted is SLA+R. Serial data is received via SDA while SCL outputs the serial clock. Serial data is received 8 bits at a time. After each byte is received, an acknowledge bit is transmitted. START and STOP conditions are output to indicate the beginning and end of a serial transfer. 17.3.3 Slave Receiver Mode Serial data and the serial clock are received through SDA and SCL. After each byte is received, an acknowledge bit is transmitted. START and STOP conditions are recognized as the beginning and - 150 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet end of a serial transfer. Address recognition is performed by hardware after reception of the slave address and direction bit. 17.3.4 Slave Transmitter Mode The first byte is received and handled as in the slave receiver mode. However, in this mode, the direction bit will indicate that the transfer direction is reversed. Serial data is transmitted via SDA while the serial clock is input through SCL. START and STOP conditions are recognized as the beginning and end of a serial transfer. 17.4 Data Transfer Flow in Five Operating Modes The five operating modes are: Master/Transmitter, Master/Receiver, Slave/Transmitter, Slave/Receiver and GC Call. Bits STA, STO and AA in I2CON register will determine the next state of the SIO hardware after SI flag is cleared. Upon complexion of the new action, a new status code will be updated and the SI flag will be set. If the I2C interrupt control bits (EA and EI2) are enabled, appropriate action or software branch of the new status code can be performed in the Interrupt service routine. Data transfers in each mode are shown in the following figures. Figure 17-4: Legend for I2C flow charts - 151 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 17.4.1 Master/Transmitter Mode - 152 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 17.4.2 Figure 17-5: Master Transmitter ModeMaster/Receiver Mode Figure 17-6: Master Receiver Mode - 153 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 17.4.3 Slave/Transmitter Mode Figure 17-7: Slave Transmitter Mode - 154 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 17.4.4 Slave/Receiver Mode Figure 17-8: Slave Receiver Mode - 155 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 17.4.5 GC Mode Figure 17-9: General Call Address - 156 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 18. SERIAL PERIPHERAL INTERFACE (SPI) 18.1 General descriptions This device consists of SPI block to support high speed serial communication. It’s capable of supporting data transfer rates 5Mbit/s. This device’s SPI support the following features; • Master and slave mode. • Slave select output. • Programmable serial clock’s polarity and phase. • Receive double buffered data register. • LSB first enable. • Write collision detection. • Transfer complete interrupt. 18.2 Block descriptions The Figure 18-1 shows SPI block diagram. It provides an overview of SPI architecture in this device. The main blocks of SPI are the register blocks, control logics, baud rate control and pin control logics; a. Shift register and read data buffer. It is single buffered in the transmit direction and double buffered in the receive direction. Transmit data cannot be written to the shifter until the previous transfer is complete. Receive logics consist of parallel read data buffer so the shifter is free to accept a second data, as the first received data will be transferred to the read data buffer. b. SPI Control block. This provide control functions to configure the device for SPI enable, master or slave, clock phase and polarity, LSB access first selection, and Slave Select output enable. c. Baud rate control. These control logics divide CPU clock to 4 different selectable clocks 1/8, 1/32, 1/128 and 1/2/256. Its’ selection is controllable through SPR [1:0] bits. SPR1 SPR0 DIVIDER BAUD RATE 0 0 8 5MHz 0 1 32 1.25MHz 1 0 128 312.50kHz 1 1 256 156.25kHz Table 18-1 SPI Baud Rate Selection (FOSC @ 40MHz) d. SPI registers. There are three SPI registers to support its operations, they are; • SPI control registers (SPCR) • SPI status registers (SPSR) • SPI data register (SPDR) These registers provide control, status, data storage functions and baud rate selection control. Detail bits descriptions are found at SFR section. When using SPI pull-up must be apply at bit PUP0 = 1. e. Pin control logic. Controls behavior of SPI interface pins. - 157 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-1: SPI block diagram - 158 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 18.3 Functional descriptions 18.3.1 Master mode The device can configure the SPI to operate as a master or as a slave, through MSTR bit. When the MSTR bit is set, master mode is selected, when MSTR bit is cleared, slave mode is selected. During master mode, only master SPI device can initiate transmission. A transmission begins by writing to the master SPDR register. The bytes begin shifting out on MOSI pin under the control of SPCLK. The master places data on MOSI line a half-cycle before SPCLK edge that the slave device uses to latch the data bit. The SS must stay low before data transactions and stay low for the duration of the transactions. Figure 18-2: Master Mode Transmission (CPOL = 0, CPHA = 0) - 159 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 1 SPCLK Cycles 2 3 4 5 6 7 8 SPCLK (Output, CPOL=1) MOSI/MISO /SS (output to slave) 2 MSB 6 5 4 3 2 1 LSB 1 4 3 SPIF Master transfer in progress Master writes to SPDR: 1. /SS asserted. 2. During master transmit, data is shifting out through MOSI. During master receive, data is shifting in through MISO. 3. SPIF asserted at the end of transmission. 4. /SS negated. Note: When CPHA = 0, /SS output must go high between successive SPI characters. When CPOL = 1, SPCLK idle high. Figure 18-3: Master Mode Transmission (CPOL = 1, CPHA = 0) - 160 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-4: Master Mode Transmission (CPOL = 0, CPHA = 1) - 161 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-5: Master Mode Transmission (CPOL = 1, CPHA = 1) 18.3.2 Slave Mode When in slave mode, the SPCLK pin becomes input and it will be clock by another master SPI device. The SS pin also becomes input. Similarly, before data transmissions occurs, and remain low until the transmission completed. If SS goes high, the SPI is forced into idle state. If the SS is forced to high at the middle of transmission, the transmission will be aborted and the receiving shifter buffer will be high and goes into idle states. Data flows from master to slave on MOSI pin and flows from slave to master on MISO pin. The SPDR is used when transmitting or receiving data on the serial bus. Only a write to this register initiates transmission or reception of a byte, and this only occurs in the master device. At the completion of transferring a byte of data, the SPIF status bit is set in both the master and slave devices. A read of the SPDR is actually a read of a buffer. To prevent an overrun and the loss of the byte that caused the overrun, the first SPIF must be cleared by the time a second transfer of data from the shift register to the read buffer is initiated. - 162 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-6: Slave Mode Transmission (CPOL = 0, CPHA = 0) - 163 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-7: Slave Mode Transmission (CPOL = 1, CPHA = 0) - 164 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-8: Slave Mode Transmission (CPOL = 0, CPHA = 1) - 165 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-9: Slave Mode Transmission (CPOL = 1, CPHA = 1) 18.3.3 Slave select The slave select ( SS ) input of a slave device must be externally asserted before a master device can exchange data with the slave device. SS must be low before data transactions and must stay low for the duration of the transaction. The SS line of the master must be held high. The other three lines are dedicated to the SPI whenever the serial peripheral interface is on. The state of the master and slave CPHA bits affects the operation of SS . CPHA settings should be identical for master and slave. When CPHA = 0, the shift clock is the OR of SS with SPCLK. In this clock phase mode, SS must go high between successive characters in an SPI message. When CPHA = 1, SS can be left low between successive SPI characters. In cases where there is only one SPI slave MCU, its SS line can be tied to VSS as long as only CPHA = 1 clock mode is used. 18.3.4 /SS output Available in master mode only, SS output is enabled with the SSOE bit in the SPCR register and DRSS bit in the SPSR register. The SS output pin is connected to the SS input pin of the slave device. The SS output automatically goes low for each transmission when selecting external device and it goes high during each idling state to deselect external devices. - 166 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet DRSS SSOE MASTER MODE SLAVE MODE 0 0 SS input ( With Mode Fault ) SS Input ( Not affected by SSOE ) 0 1 Reserved SS Input ( Not affected by SSOE ) 1 0 SS General purpose I/O ( No Mode Fault ) SS Input ( Not affected by SSOE ) 1 1 SS output ( No Mode Fault ) SS Input ( Not affected by SSOE ) During master mode (with SSOE=DRSS= 0), mode fault will be set if SS pin is detected low. When mode fault is detected hardware will clear MSTR bit and SPE bit in the meantime it will also generated interrupt request, if ESPI is enabled. Figure 18-10: SPI interrupt request 18.3.5 SPI I/O pins mode When SPI is disabled (SPE = 0) the corresponding I/O is following the original setting and act as a normal I/O. In the case of SPI is enabled (SPE = 1) the SPI pins I/O mode follow the below table. For SS pin it is always at Quasi-bidirectional mode whether it is configured as master or slave. MISO MOSI CLK /SS Master Input Output Output Output*: DRSS=0,SSOE=0 Input: DRSS=1, SSOE=1 Slave Output** during /SS = Low Else Input mode Input Input Input Input = Quasi-bidirectional mode Output = Push-pull mode Output* = this output mode in /SS is Quasi-bidirectional output mode. Master needs to detect mode fault during master outputs /SS low. Output** = In SLAVE mode, MISO is in output mode only during the time of SS =Low, otherwise it must keep in input mode (Quasi-bidirectional). - 167 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 18.3.6 Programmable serial clock’s phase and polarity The clock polarity CPOL control bit selects active high or active low SPCLK clock, and has no significant effect on the transfer format. The clock phase CPHA control bit selects one of two different transfer protocols by sampling data on odd numbered SPCLK edges or on even numbered SPCLK edges. Thus, both these bits enable selection of four possible clock formats to be used by SPI system. The clock phase and polarity should be identical for the master SPI device and the communicating slave device. When CPHA equals 0, the SS line must be negated and reasserted between each successive serial byte. Also, if the slave writes data to the SPI data register (SPDR) while SS is low, a write collision error results. When CPHA equals 1, the SS line can remain low between successive transfers. The figures from Figure 18-2 to - 168 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-9 show the SPI transfer format, with different CPOL and CPHA. When CPHA = 0, data is sample on the first edge of SPCLK and when CPHA = 1 data is sample on the second edge of the SPCLK. Prior to changing CPOL setting, SPE must be disabled first. 18.3.7 Receive double buffered data register This device is single buffered in the transmit direction and double buffered in the receive direction. This means that new data for transmission cannot be written to the shifter until the previous transfer is complete; however, received data is transferred into a parallel read data buffer so the shifter is free to accept a second serial byte. As long as the first byte is read out of the read data buffer before the next byte is ready to be transferred, no overrun condition occurs. If overrun occur, SPIOVF is set. Second byte serial data cannot be transferred successfully into the data register during overrun condition and the data register will remains the value of the previous byte. The figure below shows the receive data timing waveform when overrun occur. - 169 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Data (N) Receiving SPI Shift Register Data (N+1) Receiving Data (N) Progressing Data (N+2) Receiveing Data (N+1) Progressing Data (N+2) Progressing SPIF SPI Data Register Data (N) Data (N) Data (N+2) SPIOVF When Data (N) is received, the SPIF will be set. If SPIF is not clear, the SPIOVF will be set, Data (N) will be kept. The Data (N+1) will be lost. To clear this bit by software. When Data (N+2) is received, the SPIF will be set. The SPI receive data timing waveform Figure 18-11: SPI Overrun Timing Waveform 18.3.8 LSB first enable By default, this device transfer the SPI data most significant bit first. This device provides a control bit SPCR.LSBFE to allow support of transfer of SPI data in least significant bit first. 18.3.9 Write Collision detection Write collision indicates that an attempt was made to write data to the SPDR while a transfer was in progress. SPDR is not double buffered in the transmit direction, any writes to SPDR cause data to be written directly into the SPI shift register. This write corrupts any transfer in progress, a write collision error is generated (WCOL will be set). The transfer continues undisturbed, and the write data that caused the error is not written to the shifter. A write collision is normally a slave error because a slave has no control over when a master initiates a transfer. A master knows when a transfer is in progress, so there is no reason for a master to generate a write-collision error, although the SPI logic can detect write collisions in both master and slave devices. WCOL flag is clear by software. 18.3.10 Transfer complete interrupt This device consists of an interrupt flag at SPIF. This flag will be set upon completion of data transfer with external device, or when a new data have been received and copied to SPDR. If interrupt is enable (through ESPI), the SPI interrupt request will be generated, if global enable bit EA is also enabled. SPIF is software clear. - 170 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 18.3.11 Mode Fault Error arises in a multiple-master system when more than one SPI device simultaneously tries to be a master. This error is called a mode fault. When the SPI system is configured as a master and the /SS input line goes to active low, a mode fault error has occurred — usually because two devices have attempted to act as master at the same time. In cases where more than one device is concurrently configured as a master, there is a chance of contention between two pin drivers. For push-pull CMOS drivers, this contention can cause permanent damage. The mode fault mechanism attempts to protect the device by disabling the drivers. The MSTR and SPE control bits in the SPCR associated with the SPI are cleared by hardware and an interrupt is generated subject to masking by the ESPI control bit. Other precautions may need to be taken to prevent driver damage. If two devices are made masters at the same time, mode fault does not help protect either one unless one of them selects the other as slave. The amount of damage possible depends on the length of time both devices attempt to act as master. MODF bit is set automatically by SPI hardware, if the MSTR control bit is set and the slave select input pin becomes 0. This condition is not permitted in normal operation. In the case where /SS is set, it is an output pin rather than being dedicated as the /SS input for the SPI system. In this special case, the mode fault function is inhibited and MODF remains cleared. This flag is cleared by software. The following shows the sample hardware connection and s/w flow for multi-master/slave environment. It shows how s/w handles mode fault. Figure 18-12: SPI multi-master slave environment - 171 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 18-13: SPI multi-master slave s/w flow diagram - 172 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 19. ANALOG-TO-DIGITAL CONVERTER The ADC contains a digital-to-analog converter (DAC) that converts the contents of a successive approximation register to a voltage (VDAC), which is compared to the analog input voltage (Vin). The output of the comparator is then fed back to the successive approximation control logic that controls the successive approximation register. This is illustrated in the figure below. Figure 19-1: Successive Approximation ADC 19.1 Operation of ADC A conversion can be initiated by software only or by either hardware or software. The software only start mode is selected when control bit ADCCON.5 (ADCEX) =0. A conversion is then started by setting control bit ADCCON.3 (ADCS) to 1. The hardware or software start mode is selected when ADCCON.5 =1, and a conversion may be started by setting ADCCON.3 = 1 as above or by applying a rising edge to external pin STADC (P4.0). When a conversion is started by applying a rising edge, a low level must be applied to STADC for at least one machine cycle followed by a high level for at least one machine cycle. User sets ADCS to start converting then ADCS remains high while ADC is converting signal and will be automatically cleared by hardware when ADC conversion is completed. The end of the 10-bit conversion is flagged by control bit ADCCON.4 (ADCI). The upper 8 bits of the result are held in special function register ADCH, and the two remaining bits are held in ADCL.1 (ADC.1) and ADCL.0 (ADC.0). The user may ignore the two least significant bits in ADCL and use the ADC as an 8-bit converter (8 upper bits in ADCH). In any event, the total actual conversion time is 50 ADC clock input cycles. Control bits from ADCCON.0 to ADCCON.2 are used to control an analog multiplexer which selects one of eight analog channels. An ADC conversion in progress is unaffected by an external or software ADC start. The result of a completed conversion remains unaffected provided ADCI = logic 1. The result of a completed conversion (ADCI = logic 1) remains unaffected when entering the idle mode. The device supports maximum 8 analog input ports. 8 analog input ports share the I/O pins from P1.0 to P1.7. These I/O pins are switched to analog input ports by setting the bits of ADC Input Pin Select Register (DDIO) to logic 1. - 173 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Figure 19-2: ADC Block Diagram 19.2 ADC Resolution and Analog Supply The ADC circuit has its own supply pins (AVDD and AVSS) and one pins (Vref+) connected to each end of the DAC’s resistance-ladder that the AVDD and Vref+ are connected to VDD and AVSS is connected to VSS. The ladder has 1023 equally spaced taps, separated by a resistance of “R”. The first tap is located 0.5×R above AVSS, and the last tap is located 0.5×R below Vref+. This gives a total ladder resistance of 1024×R. This structure ensures that the DAC is monotonic and results in a symmetrical quantization error. For input voltages between AVSS and [(Vref+) + ½ LSB], the 10-bit result of an A/D conversion will be 0000000000B = 000H. For input voltages between [(Vref+) – 3/2 LSB] and Vref+, the result of a conversion will be 1111111111B = 3FFH. AVref+ and AVSS may be between AVDD + 0.2V and AVSS – 0.2 V. Avref+ should be positive with respect to AVSS, and the input voltage (Vin) should be between AVref+ and AVSS. The result can always be calculated from the following formula: Result = 1024 × Vin AVref + or Result = 1024 × V DD V SS - 174 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 20. TIMED ACCESS PROTECTION The W79E22X SERIES has features like the Watchdog Timer, wait-state control signal and poweron/fail reset flag that are crucial to the proper operation of the system. If these features are unprotected, errant code may write critical control bits, resulting in incorrect operation and loss of control. To prevent this, the W79E22X SERIES provides has a timed-access protection scheme that controls write access to critical bits. In this scheme, protected bits have a timed write-enable window. A write is successful only if this window is active; otherwise, the write is discarded. The write-enable window is opened in two steps. First, the software writes AAh to the Timed Access (TA) register. This starts a counter, which expires in three machine cycles. Then, if the software writes 55h to the TA register before the counter expires, the write-enable window is opened for three machine cycles. After three machine cycles, the window automatically closes, and the procedure must be repeated again to access protected bits. The suggested code for opening the write-enable window is; TA REG 0C7h ; Define new register TA, located at 0C7h MOV TA, #0AAh MOV TA, #055h Five examples, some correct and some incorrect, of using timed-access protection are shown below. Example 1: Valid access MOV TA, #0AAh MOV TA, #055h MOV WDCON, #00h ; 3 M/C ; Note: M/C = Machine Cycles ; 3 M/C ; 3 M/C Example 2: Valid access MOV TA, #0AAh MOV TA, #055h NOP SETB EWT ; 3 M/C ; 3 M/C ; 1 M/C ; 2 M/C Example 3: Valid access MOV TA, #0Aah ; 3 M/C MOV TA, #055h ; 3 M/C ORL WDCON, #00000010B ; 3M/C Example 4: Invalid access MOV TA, #0AAh MOV TA, #055h NOP NOP CLR POR ; 3 M/C ; 3 M/C ; 1 M/C ; 1 M/C ; 2 M/C - 175 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet Example 5: Invalid Access MOV TA, #0AAh NOP MOV TA, #055h SETB EWT 3 M/C 1 M/C 3 M/C 2 M/C In the first three examples, the protected bits are written before the window closes. In Example 4, however, the write occurs after the window has closed, so there is no change in the protected bit. In Example 5, the second write to TA occurs four machine cycles after the first write, so the timed access window in not opened at all, and the write to the protected bit fails. - 176 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 21. PORT 4 STRUCTURE Port 4 is a multi-function port that performs general purpose I/O port and chip-select strobe signals including read strobe, write strobe and read/write strobe signals. The 4 alternate modes are selected by P4xM1 and P4xM0. The function of chip-select strobe output provides that user can activate external devices by access to some specific address region. Port 4 Control Register A Bit: 7 6 5 4 3 2 1 0 P41M1 P41M0 P41C1 P41C0 P40M1 P40M0 P40C1 P40C0 Mnemonic: P4CONA Address: 92h Port 4 Control Register B Bit: 7 6 5 4 3 2 1 0 P43M1 P43M0 P43C1 P43C0 P42M1 P42M0 P42C1 P42C0 Mnemonic: P4CONB Address: 93h BIT NAME FUNCTION P4xM1, P4xM0 Port 4 alternate modes. =00: Mode 0. P4.x is a general purpose I/O port which is the same as Port 1. =01: Mode 1. P4.x is a Read Strobe signal for chip select purpose. The address range depends on the SFR P4xAH, P4xAL and bits P4xC1, P4xC0. =10: Mode 2. P4.x is a Write Strobe signal for chip select purpose. The address range depends on the SFR P4xAH, P4xAL and bits P4xC1, P4xC0. =11: Mode 3. P4.x is a Read/Write Strobe signal for chip select purpose. The address range depends on the SFR P4xAH, P4xAL and bits P4xC1, P4xC0 P4xC1, P4xC0 Port 4 Chip-select Mode address comparison: =00: Compare the full address (16 bits length) with the base address registers P4xAH and P4xAL. =01: Compare the 15 high bits (A15-A1) of address bus with the base address registers P4xAH and P4xAL. =10: Compare the 14 high bits (A15-A2) of address bus with the base address registers P4xAH and P4xAL. =11: Compare the 8 high bits (A15-A8) of address bus with the base address registers P4xAH and P4xAL. P40AH, P40AL: The Base address registers for comparator of P4.0. P40AH contains the high-order byte of address; P40AL contains the low-order byte of address. P41AH, P41AL: The Base address registers for comparator of P4.1. P41AH contains the high-order byte of address; P41AL contains the low-order byte of address. P42AH, P42AL: The Base address registers for comparator of P4.2. P42AH contains the high-order byte of address; P42AL contains the low-order byte of address. P43AH, P43AL: - 177 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet The Base address registers for comparator of P4.3. P43AH contains the high-order byte of address; P43AL contains the low-order byte of address. PORT 4 Bit: 7 6 5 4 3 2 1 0 - - - - P4.3 P4.2 P4.1 P4.0 Mnemonic: P4 P4.3-0 Address: A5h Port 4 is a bi-directional I/O port with internal pull-ups. PORT 4 CHIP-SELECT POLARITY Bit: 7 6 5 4 3 2 1 0 P43INV P42INV P42INV P40INV - PWDNH RMWFP PUP0 Mnemonic: P4CSIN Address: A2h P4xINV The active polarity of P4.x when it is set as a chip-select strobe output. High = Active High. Low = Active Low. PWDNH Set PWDNH to logic 1 then ALE and PSEN will keep high state, clear this bit to logic 0 then ALE and PSEN will output low during power down mode. RMWFP Control Read Path of Instruction “Read-Modify-Write”. When this bit is set, the read path of executing “read-modify-write” instruction is from port pin otherwise from SFR. PUP0 Enable Port 0 weak pull up. - 178 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet P4xCSINV P4 REGISTER DATA I/O P4.x RD_CS MUX 4->1 WR_CS READ WRITE RD/WR_CS PIN P4.x ADDRESS BUS P4xM0 P4xM1 EQUAL REGISTER P4xAL P4xAH Bit Length Selectable comparator P4.x INPUT DATA BUS REGISTER P4xC0 P4xC1 Figure 21-1 Port 4 Structure Diagram Here is an example to program the P4.0 as a write strobe signal at the I/O port address 1234H ~1237H and positive polarity, and P4.1 ~ P4.3 are used as general I/O ports. MOV P40AH, #12H MOV P40AL, #34H ;Define the base I/O address 1234H for P4.0 as an special function MOV P4CONA, #00001010B ;Define the P4.0 as a write strobe signal pin and the compared address is [A15:A2] MOV P4CONB, #00H ;P4.1~P4.3 as general I/O port which are the same as PORT1 MOV P4CSIN, #10H ;Write the P40CSINV =1 to inverse the P4.0 write strobe polarity Then any instruction writes data to address from 1234H to 1237H, for example MOVX @DPTR,A (with DPTR=1234H~1237H), will generate the positive polarity write strobe signal at pin P4.0. And the instruction of “MOV P4, #XX” will output the bit3 to bit1 of data #XX to pin P4.3~ P4.1. Note: P4.2 and P4.3 pins are available in 48L LQFP package only. - 179 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 22. IN-SYSTEM PROGRAMMING 22.1 The Loader Program Locates at LDFlash Memory CPU is Free Run at APFlash memory. CHPCON register had been set #03H value before CPU has entered idle state. CPU will switch to LDFlash memory and execute a reset action. H/W reboot mode will switch to LDFlash memory, too. Set SFRCN register where it locates at user's loader program to update APFlash bank 0 memory. Set a SWRESET (CHPCON=#83H) to switch back APFlash after CPU has updated APFlash program. CPU will restart to run program from reset state. 22.2 The Loader Program Locates at APFlash Memory CPU is Free Run at APFlash memory. CHPCON register had been set #01H value before CPU has entered idle state. Set SFRCN register to update LDFlash or another bank of APFlash program. CPU will continue to run user's APFlash program after CPU has updated program. Please refer demonstrative code to understand other detail description. - 180 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 23. OPTION BITS This device has two CONFIG bits (CONFIG0, CONFIG1) that must be define at power up and can not be set after the program start of execution. Those features are configured through the use of two flash EPROM bytes, and the flash EPROM can be programmed and verified repeatedly. Until the code inside the Flash EPROM is confirmed OK, the code can be protected. The protection of flash EPROM and those operations of the configuration bits are described below. 23.1 Config0 BIT DESCRIPTION B0 =0: Lock data out B1 =0: MOVC Inhibited B2 =0; 1/2/2K Data Flash EPROM lock bit B3 Reserved B4 =1: Disable H/W reboot by P3.6 and P3.7 =0: Enable H/W reboot by P3.6 and P3.7 B5 =1: Disable H/W reboot by P4.3 =0: Enable H/W reboot by P4.3 Note: Support in 48L LQFP package only. B6 Reserved B7 =1: Crystal > 24MHz =0: Crystal < 24MHz Table 23-1 Config0 Option Bits B0: Lock bit This bit is used to protect the customer's program code in the W79E22X SERIES. After the programmer finishes the programming and verifies sequence B0 can be cleared to logic 0 to protect code from reading by any access path. Once this bit is set to logic 0, both the Flash EPROM data and Special Setting Registers can not be accessed again. B1: MOVC Inhibit This bit is used to restrict the accessible region of the MOVC instruction. It can prevent the MOVC instruction in external program memory from reading the internal program code. When this bit is set to logic 0, a MOVC instruction in external program memory space will be able to access code only in the external memory, not in the internal memory. A MOVC instruction in internal program memory space will always be able to access the ROM data in both internal and external memory. If this bit is logic 1, there are no restrictions on the MOVC instruction. B4: H/W Reboot with P3.6 and P3.7 If this bit is set to logic 0, enable to reboot 4k LD Flash mode while RST =H, P3.6 = L and P3.7 = L state. CPU will start from LD Flash to update the user’s program. B5: H/W Reboot with P4.3 If this bit is set to logic 0, enable to reboot 4k LD Flash mode while RST =H and P4.3 = L state. CPU will start from LD Flash to update the user’s program - 181 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet B7: Select clock frequency. If clock frequency is over 24MHz, then set this bit is H. If clock frequency is less than 24MHz, then clear this bit. 23.2 Config1 BITS Bit 0 Bit 1 Bit 2 NAME FUNCTION PWMOE PWM Odd Channel 1, 3 and 5 Enable. 1: (Default). Disable odd PWM outputs to corresponding pins and the ports keep in Quasi bi-direction type. 0: Enable odd PWM outputs to corresponding pins and the ports are switched to push-pull type PWMEE PWM Even Channel 0, 2 and 4 Enable. 1: (Default). Disable even PWM outputs to corresponding pins and the ports keep in Quasi bi-direction type. 0: Enable even PWM outputs to corresponding pins and the ports are switched to push-pull type OPOL Define the polarity of PWM output after CPU reset, OPOL controls odd PWM outputs. 1: Initial output high 0: Initial output low Bit 3 EPOL Define the polarity of PWM output after CPU reset, EPOL control even PWM outputs. 1: Initial output high 0: Initial output low Bit 4-5 - Reserved. PWM6E PWM Channel 6 Output Enable. 1: (Default). Disable PWM6 outputs to corresponding pins and the ports keep in Quasi bi-direction type. 0: Enable PWM6 outputs to corresponding pins and the ports are switched to push-pull type PWM7E PWM Channel 7 Output Enable. 1: (Default). Disable PWM7 outputs to corresponding pins and the ports keep in Quasi bi-direction type. 0: Enable PWM7 outputs to corresponding pins and the ports are switched to push-pull type Bit 6 Bit 7 Table 23-2: Config 1 Option Bits - 182 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 24. ELECTRICAL CHARACTERISTICS 24.1 Absolute Maximum Ratings SYMBOL PARAMETER CONDITION RATING UNIT DC Power Supply VDD − VSS -0.3 +7.0 V Input Voltage VIN VSS -0.3 VDD +0.3 V Operating Temperature TA -40 +85 °C Storage Temperature Tst -55 +150 °C Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. 24.2 DC Characteristics (VDD − VSS = 5V ±10%, TA = 25°C, Fosc = 20 MHz, unless otherwise specified.) PARAMETER SYMBOL SPECIFICATION MIN TYP MAX UNIT VDD1 4.5 5.5 VDD2 2.7 5.5 VDD3 4.5 5.5 VDD4 3.0 IDD1 - 58 65 mA IDD2 - 37 45 mA IDD3 - 15 20 mA IDD4 - 12 16 mA IDD5 - 50 60 mA IDD6 - 33 38 mA IDD7 - 12 17 mA IDD8 - 10 15 mA V Operating Voltage Operating Current - 183 - TEST CONDITIONS VDD =4.5V ~ 5.5V @ 40MHz VDD =2.7V ~ 5.5V @ 20MHz VDD =4.5V ~ 5.5V @ 24MHz (external access) NVM program/erase operation. Run NOP VDD=5.5V at 40MHz Run NOP VDD=5.5V at 20MHz Run NOP VDD=3.0V at 20MHz Run NOP VDD=2.7V at 20MHz RST = VDD VDD=5.5V at 40MHz RST = VDD VDD=5.5V at 20MHz RST = VDD VDD=3.0V at 20MHz RST = VDD VDD=2.7V at 20MHz Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet DC Characteristics, continued PARAMETER SYMBOL SPECIFICATION MIN TYP MAX 35 42 UNIT mA IIDLE1 mA IIDLE2 Idle Current - 20 25 mA IIDLE3 - 9 14 mA IIDLE4 IPWDN - 8 - 11 10 mA uA Input Current P1, P2, P3, P4, P5 IIN1 -95 -55 10 uA Input Current RST IIN2 -10 50 300 uA Input Leakage Current P0, /EA ILK -10 0 10 uA -500 - -200 Power Down Current Logic 1 to 0 Transition Current P1, P2, P3, P4, P5 [*4] Input Low Voltage P1, P2, P3, P4, P5, (Schmitt input) Input High Voltage P1, P2, P3, P4, P5, (Schmitt input) Hysteresis Voltage ITL[*4] uA TEST CONDITIONS VDD=5.5V at 40MHz High) VDD=5.5V at 40MHz Low) VDD=5.5V at 20MHz High) VDD=5.5V at 20MHz Low) VDD=3.0V at 20MHz High) VDD=3.0V at 20MHz Low) VDD=2.7V at 20MHz VDD=2.7V~5.5V VDD=5.5V VIN=0V or VDD VDD=5.5V 00 ALE Low to Valid Data In tLLDV 2.5tCLCL - 5 tMCS + 2tCLCL 40 nS tMCS = 0 tMCS>0 Port 0 Address to Valid Data In tAVDV1 3.0tCLCL - 20 2.0tCLCL - 5 nS tMCS = 0 tMCS>0 ALE Low to RD or WR Low tLLWL 0.5tCLCL - 5 1.5tCLCL - 5 0.5tCLCL + 5 1.5tCLCL + 5 nS tMCS = 0 tMCS>0 tAVWL tCLCL - 5 2.0tCLCL - 5 nS tMCS = 0 tMCS>0 Port 0 Address to RD or WR Low 2.0tCLCL - 20 tMCS - 20 0 tMCS = 0 tMCS>0 nS - 187 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet MOVX Characteristics Using Stretch Memory Cycle, continud PARAMETER SYMBOL VARIABLE CLOCK MIN. VARIABLE CLOCK MAX. UNITS STRECH tAVWL2 1.5tCLCL - 5 2.5tCLCL - 5 nS tMCS = 0 tMCS>0 Data Valid to WR Transition tQVWX -5 1.0tCLCL - 5 nS tMCS = 0 tMCS>0 Data Hold after Write tWHQX tCLCL - 5 2.0tCLCL - 5 nS tMCS = 0 tMCS>0 RD Low to Address Float tRLAZ RD or WR high to ALE high tWHLH Port 2 Address to RD or WR Low 0 1.0tCLCL - 5 0.5tCLCL - 5 nS 10 1.0tCLCL + 5 nS tMCS = 0 tMCS>0 Note: tMCS is a time period related to the Stretch memory cycle selection. The following table shows the time period of tMCS for each selection of the Stretch value. M2 M1 M0 MOVX CYCLES TMCS 0 0 0 2 machine cycles 0 0 0 1 3 machine cycles 4 tCLCL 0 1 0 4 machine cycles 8 tCLCL 0 1 1 5 machine cycles 12 tCLCL 1 0 0 6 machine cycles 16 tCLCL 1 0 1 7 machine cycles 20 tCLCL 1 1 0 8 machine cycles 24 tCLCL 1 1 1 9 machine cycles 28 tCLCL Explanation of Logics Symbols In order to maintain compatibility with the original 8051 family, this device specifies the same parameter for each device, using the same symbols. The explanation of the symbols is as follows. t Time A Address C Clock D Input Data H Logic level high L Logic level low I Instruction P PSEN Q Output Data R RD signal V X Valid No longer a valid state W Z WR signal Tri-state - 188 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 24.4 The ADC Converter DC ELECTRICAL CHARACTERISTICS (VDD−VSS = 3.0~5V±10%, TA = -40~85°C, Fosc = 20MHz, unless otherwise specified.) PARAMETER Analog input ADC clock SPECIFICATION SYMBOL MIN. TYP. AVin VSS-0.2 ADCCLK 200KHz Conversion time - MAX. UNIT VDD+0.2 V 5MHz Hz 52tADC1 tC us Differential non-linearity DNL -1 - +1 LSB Integral non-linearity INL -2 - +2 LSB Offset error Ofe -1 - +1 LSB Gain error Ge -1 - +1 % Absolute voltage error Ae -3 - +3 LSB Notes:1. tADC: The period time of ADC input clock. 24.5 I2C Bus Timing Characteristics PARAMETER STANDARD MODE I2C BUS SYMBOL MIN. UNIT MAX. SCL clock frequency fSCL 0 100 kHz bus free time between a STOP and START condition tBUF 4.7 - uS Hold time (repeated) START condition. After this period, the first clock pulse is generated tHd;STA 4.0 - uS Low period of the SCL clock tLOW 4.7 - uS HIGH period of the SCL clock tHIGH 4.0 - uS Set-up time for a repeated START condition tSU;STA 4.7 - uS Data hold time tHD;DAT 5.0 - uS Data set-up time tSU;DAT 250 - nS Rise time of both SDA and SCL signals tr - 1000 nS Fall time of both SDA and SCL signals tf - 300 nS Set-up time for STOP condition tSU;STO 4.0 - uS Capacitive load for each bus line Cb - 400 pF - 189 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet STOP Repeated START START STOP SDA tBUF tLOW tr SCL tf tHIGH tHD;STA tHD;DAT tSU;DAT tSU;STA tSU;STO Figure 24-1: I2C Bus Timing 24.6 Program Memory Read Cycle tLHLL tLLIV ALE tAVLL tPLPH tPLIV PSEN tLLPL tPXIZ tPLAZ tLLAX1 PORT 0 ADDRESS A0-A7 tPXIX INSTRUCTION IN ADDRESS A0-A7 tAVIV1 tAVIV2 PORT 2 ADDRESS A8-A15 - 190 - ADDRESS A8-A15 Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 24.7 Data Memory Read Cycle tLLDV ALE tWHLH tLLWL PSEN tRLRH tLLAX1 tRLDV tAVLL RD PORT 0 INSTRUCTION IN tRHDZ tRLAZ tAVWL1 tRHDX ADDRESS A0-A7 DATA IN ADDRESS A0-A7 tAVDV1 tAVDV2 PORT 2 ADDRESS A8-A15 24.8 Data Memory Write Cycle ALE tWHLH tLLWL PSEN tWLWH tLLAX2 tAVLL WR tAVWL1 tWHQX tQVWX PORT 0 INSTRUCTION IN ADDRESS A0-A7 DATA OUT ADDRESS A0-A7 t AVDV2 PORT 2 ADDRESS A8-A15 - 191 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 25. TYPICAL APPLICATION CIRCUITS 25.1 Expanded External Program Memory and Crystal Vcc Vcc EA/VP 10u X1 CRY STAL R X2 8.2K P0.0 P0.1 P0.2 P0.3 P0.4 P0.5 P0.6 P0.7 RESET C1 INT0 INT1 T0 T1 C2 P1.0 P1.1 P1.2 P1.3 P1.4 P1.5 P1.6 P1.7 P2.0 P2.1 P2.2 P2.3 P2.4 P2.5 P2.6 P2.7 AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 AD8 AD9 AD10 AD11 AD12 AD13 AD14 AD15 AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 3 4 7 8 13 14 17 18 1 11 D0 D1 D2 D3 D4 D5 D6 D7 2 5 6 9 12 15 16 19 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 A0 A1 A2 A3 A4 A5 A6 A7 10 9 8 7 6 5 4 3 25 24 21 23 2 26 27 1 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 OC G 74F373 20 22 RD WR PSEN ALE/P TXD RXD A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 11 12 13 15 16 17 18 19 O0 O1 O2 O3 O4 O5 O6 O7 AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 CE OE 27512 Pin-diagram of standard 8051 Figure 25-1: Typical External Program Memory and Crystal connections CRYSTAL C1 C2 R 16 MHz 0P~20P 0P~20P - 24 MHz 0P~12P 0P~12P - 33 MHz 10P 10P 10K~1K 40 MHz 1P 1P 10K~1K The above table shows the reference values for crystal applications. Note: C1, C2, R components refer to Figure above. 25.2 Expanded External Data Memory and Oscillator Vcc Vcc EA/VP 10u OSCILLATOR X1 X2 8.2K P0.0 P0.1 P0.2 P0.3 P0.4 P0.5 P0.6 P0.7 RESET INT0 INT1 T0 T1 P1.0 P1.1 P1.2 P1.3 P1.4 P1.5 P1.6 P1.7 P2.0 P2.1 P2.2 P2.3 P2.4 P2.5 P2.6 P2.7 AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 AD8 AD9 AD10 AD11 AD12 AD13 AD14 AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 3 4 7 8 13 14 17 18 1 11 D0 D1 D2 D3 D4 D5 D6 D7 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 2 5 6 9 12 15 16 19 A0 A1 A2 A3 A4 A5 A6 A7 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 OC G 74F373 10 9 8 7 6 5 4 3 25 24 21 23 2 26 1 22 27 20 RD WR PSEN ALE/P TXD RXD Vcc 28 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 I/O0 I/O1 I/O2 I/O3 I/O4 I/O5 I/O6 I/O7 11 12 13 15 16 17 18 19 AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 OE WE CS VCC 20256 Pin-diagram of standard 8051 Figure 25-2: Typical External Data Memory and Oscillator connections - 192 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 26. PACKAGE DIMENSION 26.1 44L PLCC H D D 6 1 44 40 7 39 E 17 E E H G 29 18 28 c L 2 A e b b Seating Plane G Symbol A A1 A2 b 1 b c D E e GD GE HD HE L y A 1 A y 1 D Dimension in inch Min Dimension in mm Nom Max Nom Min Max 0.185 4.70 0.020 0.51 0.145 0.150 0.155 3.68 3.81 3.94 0.026 0.028 0.032 0.66 0.71 0.81 0.016 0.018 0.022 0.41 0.46 0.56 0.008 0.010 0.014 0.20 0.25 0.36 0.648 0.653 0.658 16.46 16.59 16.71 0.658 16.46 0.648 0.653 0.050 16.59 1.27 BSC 16.71 BSC 0.590 0.610 0.630 14.99 15.49 16.00 0.590 0.610 0.630 14.99 15.49 16.00 0.680 0.690 0.700 17.27 17.53 17.78 0.680 0.690 0.700 17.27 17.53 17.78 0.090 0.100 0.110 2.29 2.54 2.79 0.004 - 193 - 0.10 Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 26.2 48L LQFP (7x7x1.4mm footprint 2.0mm) - 194 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 27. APPLICATION NOTE In-system Programming Software Examples This application note illustrates the in-system programmability of the Winbond W79E22X SERIES Flash EPROM microcontroller. In this example, microcontroller will boot from APFlash bank and waiting for a key to enter in-system programming mode for re-programming the contents of 64 KB APFlash. While entering in-system programming mode, microcontroller executes the loader program in 4KB LDFlash bank. The loader program erases the 64 KB APFlash then reads the new code data from external SRAM buffer (or through other interfaces) to update the APFlash. If the customer uses the reboot mode to update his program, please enable this b3 or b4 of security bits from the writer. Please refer security bits for detail description. EXAMPLE 1: ;******************************************************************************************************************* ;* Example of APFlash program: Program will scan the P1.0. If P1.0 = 0, enters in-system ;* programming mode for updating the content of APFlash code else executes the current ROM code. ;* XTAL = 24 MHz ;******************************************************************************************************************* .chip 8052 .RAMCHK OFF .symbols CHPCON TA SFRAL SFRAH SFRFD SFRCN EQU EQU EQU EQU EQU EQU 9FH C7H ACH ADH AEH AFH ORG 0H LJMP 100H ; JUMP TO MAIN PROGRAM ;************************************************************************ ;* TIMER0 SERVICE VECTOR ORG = 000BH ;************************************************************************ ORG 00BH CLR TR0 ; TR0 = 0, STOP TIMER0 MOV TL0, R6 MOV TH0,R7 RETI ;************************************************************************ ;* APFlash MAIN PROGRAM ;************************************************************************ ORG 100H - 195 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet MAIN_APFlash: MOV A, P1 ANL A, #01H CJNE A, #01H, PROGRAM_APFlash JMP NORMAL_MODE ; SCAN P1.0 ; IF P1.0 = 0, ENTER IN-SYSTEM PROGRAMMING MODE PROGRAM_64: MOV TA, #AAH ; CHPCON register is written protect by TA register. MOV TA, #55H MOV CHPCON, #03H ; CHPCON = 03H, ENTER IN-SYSTEM PROGRAMMING MODE MOV SFRCN, #0H MOV TCON, #00H ; TR = 0 TIMER0 STOP MOV IP, #00H ; IP = 00H MOV IE, #82H ; TIMER0 INTERRUPT ENABLE FOR WAKE-UP FROM IDLE MODE MOV R6, #F0H ; TL0 = F0H MOV R7, #FFH ; TH0 = FFH MOV TL0, R6 MOV TH0, R7 MOV TMOD, #01H ; TMOD = 01H, SET TIMER0 A 16-BIT TIMER MOV TCON, #10H ; TCON = 10H, TR0 = 1, GO MOV PCON, #01H ; ENTER IDLE MODE FOR LAUNCHING THE IN-SYSTEM PROGRAMMING ;************** ****************************************************************** ;* Normal mode APFlashB APFlash program: depending user's application ;******************************************************************************** NORMAL_MODE: . ; User's application program . . . EXAMPLE 2: ;******************************************************************************************************************* ;* Example of 4KB LDFlash program: This loader program will erase the APFlashB APFlash first, then reads the new ;* code from external SRAM and program them into APFlashB APFlash bank. XTAL = 24 MHz ;******************************************************************************************************************* .chip 8052 .RAMCHK OFF .symbols CHPCON EQU 9FH - 196 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet TA SFRAL SFRAH SFRFD SFRCN EQU EQU EQU EQU EQU C7H ACH ADH AEH AFH ORG 000H LJMP 100H ; JUMP TO MAIN PROGRAM ;************************************************************************ ;* 1. TIMER0 SERVICE VECTOR ORG = 0BH ;************************************************************************ ORG 000B CLR TR0 ; TR0 = 0, STOP TIMER0 MOV TL0, R6 MOV TH0, R7 RETI ;************************************************************************ ;* 4KB LDFlash MAIN PROGRAM ;************************************************************************ ORG 100H MAIN_4K: MOV TA, #AAH MOV TA, #55H MOV CHPCON, #03H MOV SFRCN, #0H MOV TCON, #00H MOV TMOD, #01H MOV IP, #00H MOV IE, #82H MOV R6, #F0H MOV R7, #FFH MOV TL0, R6 MOV TH0, R7 MOV TCON, #10H MOV PCON, #01H UPDATE_APFlash: MOV TCON, #00H MOV IP, #00H MOV IE, #82H ; CHPCON = 03H, ENABLE IN-SYSTEM PROGRAMMING. ; TCON = 00H, TR = 0 TIMER0 STOP ; TMOD = 01H, SET TIMER0 A 16BIT TIMER ; IP = 00H ; IE = 82H, TIMER0 INTERRUPT ENABLED ; TCON = 10H, TR0 = 1, GO ; ENTER IDLE MODE ; TCON = 00H, TR = 0 TIM0 STOP ; IP = 00H ; IE = 82H, TIMER0 INTERRUPT ENABLED - 197 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet MOV TMOD, #01H ; TMOD = 01H, MODE1 MOV R6,#D0H ; SET WAKE-UP TIME FOR ERASE OPERATION, ABOUT 15 ms DEPENDING ON USER'S SYSTEM CLOCK RATE. MOV R7, #8AH MOV TL0, R6 MOV TH0, R7 ERASE_P_4K: MOV SFRCN, #22H MOV TCON, #10H MOV PCON, #01H ; SFRCN = 22H, ERASE APFlash APFlash0 ; SFRCN = A2H, ERASE APFlash1 ; TCON = 10H, TR0 = 1, GO ; ENTER IDLE MODE (FOR ERASE OPERATION) ;********************************************************************* ;* BLANK CHECK ;********************************************************************* MOV SFRCN, #0H ; SFRCN = 00H, READ APFlashB APFlash0 ; SFRCN = 80H, READ APFlashB APFlash1 MOV SFRAH, #0H ; START ADDRESS = 0H MOV SFRAL, #0H MOV R6, #FDH ; SET TIMER FOR READ OPERATION, ABOUT 1.5 μS. MOV R7, #FFH MOV TL0, R6 MOV TH0, R7 blank_check_loop: SETB TR0 MOV PCON, #01H MOV A, SFRFD CJNE A, #FFH, blank_check_error INC SFRAL MOV A, SFRAL JNZ blank_check_loop INC SFRAH MOV A, SFRAH CJNE A, #0H, blank_check_loop JMP PROGRAM_APFlashROM ; Enable TIMER 0 ; Enter idle mode ; Read one byte ; Next address ; End address = FFFFH blank_check_error: JMP $ ;******************************************************************************* ;* RE-PROGRAMMING APFlashB APFlash BANK - 198 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet ;******************************************************************************* PROGRAM_APFlashROM: MOV R2, #00H ; Target low byte address MOV R1, #00H ; TARGET HIGH BYTE ADDRESS MOV DPTR, #0H MOV SFRAH, R1 ; SFRAH, Target high address MOV SFRCN, #21H ; SFRCN = 21H, PROGRAM APFlash0 ; SFRCN = A1H, PROGRAM APFlash1 MOV R6, #9CH ; SET TIMER FOR PROGRAMMING, ABOUT 50 μS. MOV R7, #FFH MOV TL0, R6 MOV TH0, R7 PROG_D_APFlash: MOV SFRAL, R2 ; SFRAL = LOW BYTE ADDRESS CALL GET_BYTE_FROM_PC_TO_ACC ; THIS PROGRAM IS BASED ON USER’S CIRCUIT. MOVX @DPTR, A ; SAVE DATA INTO SRAM TO VERIFY CODE. MOV SFRFD, A ; SFRFD = data IN MOV TCON, #10H ; TCON = 10H, TR0 = 1,GO MOV PCON, #01H ; ENTER IDLE MODE (PRORGAMMING) INC DPTR INC R2 CJNE R2, #0H, PROG_D_APFlash INC R1 MOV SFRAH, R1 CJNE R1, #0H, PROG_D_APFlash ;***************************************************************************** ; * VERIFY APFlashB APFlash BANK ;***************************************************************************** MOV R4, #03H ; ERROR COUNTER MOV R6, #FDH ; SET TIMER FOR READ VERIFY, ABOUT 1.5 μS. MOV R7, #FFH MOV TL0, R6 MOV TH0, R7 MOV DPTR, #0H ; The start address of sample code MOV R2, #0H ; Target low byte address MOV R1, #0H ; Target high byte address MOV SFRAH, R1 ; SFRAH, Target high address MOV SFRCN, #00H ; SFRCN = 00H, Read APFlash0 ; SFRCN = 80H, Read APFlash1 - 199 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet READ_VERIFY_APFlash: MOV SFRAL,R2 ; SFRAL = LOW ADDRESS MOV TCON,#10H ; TCON = 10H, TR0 = 1,GO MOV PCON,#01H INC R2 MOVX A,@DPTR INC DPTR CJNE A,SFRFD,ERROR_APFlash CJNE R2,#0H,READ_VERIFY_APFlash INC R1 MOV SFRAH,R1 CJNE R1,#0H,READ_VERIFY_APFlash ;****************************************************************************** ;* PROGRAMMING COMPLETLY, SOFTWARE RESET CPU ;****************************************************************************** MOV TA, #AAH MOV TA, #55H MOV CHPCON, #83H ; SOFTWARE RESET. CPU will restart from APFlash0 ERROR_APFlash: DJNZ R4, UPDATE_APFlash . DEAL WITH IT. . . . ; IF ERROR OCCURS, REPEAT 3 TIMES. ; IN-SYST PROGRAMMING FAIL, USER'S PROCESS TO - 200 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet 28. REVISION HISTORY REVISION DATE PAGE A1.0 October 18, 2007 8,9 182 A1.1 November 17, 2007 7 111 A2.0 December 11, 2007 8, 137, 138 99, 100 111 182 35 DESCRIPTION Preliminary version initially issued Incorrect pin number format. Re-alignment. Operating voltage for NVM program/erase min at 3.0V. Added note for minimum NVM program/erase operating voltage. Updated Figure 14-8. Changed label “B” to “C”. Removed INDX descriptions. Updated diagram for T2EX at P4.1 pin. Updated diagram. Posc replaced with Fosc. Revise the Operating temperature to (-40, +85) °C Revise the content of UART mode select table. (SM0,SM1) is exchanged. A3.0 March 17, 2008 141 6, 7 1. Modified UART descriptions. 2. Add two parts of W79E226 series A4.0 April 15, 2008 68 Modified CPHA descriptions. A5.0 April 28, 2008 24 Revise the content of T3CON 6, 7 1. Revise part number W79E22XAFG to W79E22XALG 2. Revise On-Chip RC Oscillator 6MHz freq. accuracy to +/- 50% 3. Revise crystal application circuit’s R to 1K~10K ohm A6.0 August 29, 2008 18 192 A7.0 December 9, 2008 A8.0 March 13, 2009 129 1. Revise Figure 15-2: Timer3/Capture/Compare/Reload modules 184 1. Remove P0~P5 VIL1 typical 0.8V item. 2. Remove P0~P5 VIH1 typical 2.0V item Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Further more, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. - 201 - Publication Release Date: March 13, 2009 Revision A8.0 Preliminary W79E225A/226A/227A Data Sheet - 202 - Publication Release Date: March 13, 2009 Revision A8.0
W79E226APG 价格&库存
很抱歉,暂时无法提供与“W79E226APG”相匹配的价格&库存,您可以联系我们找货
