EM274214H
EM274214H
    EATON(伊顿)
    插件,P=2.54mm
    接线端子 间距:2.54mm 每排针脚数:14 排数:单排
EM274214H 数据手册
EuroMag Series PCB Mount Screwless Terminal Blocks 30.94 33.48 36.02 38.56 41.10 43.64 46.18 14 (0.551") 2.6 (0.102") 0.8 (0.032") Ø1.5 (Ø0.059") 0.5 (0.020") 5.08 (0.200") 2.54 (0.100") 2.54 (0.100") 5.5 (0.217") 10 11 12 13 14 15 16 5.08 (0.200") 8.08 10.62 13.16 15.70 18.24 33.48 30.94 28.40 L 10 (0.394") 2 3 4 5 6 7 8 9 3.5 (0.138") L (mm) VERTICAL Compliance References Poles Dimensions - mm (in) Edge Connectors, One-Sided Boards L (mm) EM274206V To convert to inches, divide by 25.4 PCB Hole Layout Ø1.2 (Ø0.04") 2.54 (0.100") HORIZONTAL # of Poles n 02 to 16 H - horizontal V - vertical Orientation 5.8 (0.200") 14 (0.55") 0.8 (0.03") 2.54 (0.100") 2.54 (0.100") 4.7 (0.85") En Mn 2n 7n 4n 2 nn n Series 0.5 (0.020") L PCB Hole Layout 5.08 (0.200") Part Numbering System Ø1.5 (Ø0.06") 2.6 (0.102") 3.5 (0.138") 10 (0.394") Ø1.2 (Ø0.047") For additional product information, visit www.eaton.com/connectors EuroMag Series Poles EM274210H Screwless SPECIFICATIONS Rating: 6A, 150V Center Spacing: 0.10” (2.54mm) Wire Range: #20-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Spring Material: Stainless Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single Row EM2742 Series EuroMag Terminal Blocks Screwless; 2.54 Centers 65
EM274214H 价格&库存
很抱歉,暂时无法提供与“EM274214H”相匹配的价格&库存,您可以联系我们找货
EM274214H
  • 100+44.61806100+5.77254
