NKN100JR-73-3R3
NKN100JR-73-3R3
    YAGEO(国巨)
    插件,D4.5xL11.5mm
    插件电阻 - 3.3Ω ±5% 1W -
NKN100JR-73-3R3 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET WIREWOUND RESISTORS Flameproof, Non-Inductive NKN Series ±2%, ±5% 1/2W to 7W Product specification – August 13, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Wirewound Resistors Product Specification ORDERING INFORMATION Part number of the flameproof, non-inductive wirewound resistor are identified by the series, power rating, tolerance, packing, temperature coefficient, forming and resistance value. PART NUMBER NKN 200 J T - 73- 10R (1) (2) (3) (4) (5) (6) (7) (1) SERIES APPLICATIONS NKN Series  Power applications  Home appliance  Industry FEATURES  Higher power rating (2) POWER RATING -50 = 1/2W 300=3W 1WS = 1W 400=4W 100 = 1W 5WS=5W 2WS = 2W 500=5W 200 = 2W 7WS=7W 3WS = 3W  Non-inductive types  High stable performance and high reliability  Flameproof coating equivalent to UL-94V-0  RoHS compliant & halogen free (3) TOLERANCE G = ±2% J = ±5% (4) PACKAGING R = Reel Pack B = Bulk T = Box Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (6) FORMING 52- = 52.4mm F = F Type 73- = 73mm FK = FK Type 91-=91mm FFK = F-form Kink M = M-Type Forming FKK = FKK Type MB = M-form W/flat (7) RESISTANCE VALUE E24 Series Example: 0R1= 0.1Ω, 1R = 1Ω, 10R = 10Ω www.yageo.com Aug. 13, 2021 V.0 2 15 NKN Through Hole Resistors Product Specification Wirewound Resistors NKN DIMENSIONS Unit: mm Normal Miniature L ψD H ψd NKN-50 NKN1WS 9.0 ± 0.5 3.5 ± 0.3 26 ± 2.0 0.55 ± 0.05 NKN100 NKN2WS 11.5 ± 1.0 4.8 ± 0.5 35 ± 2.0 0.8 ± 0.05 NKN200 NKN3WS 15.5 ± 1.0 5.3± 0.5 33 ± 2.0 0.8 ± 0.05 NKN300 NKN400 NKN5WS 17.5 ± 1.0 6.5 ± 0.5 32 ± 2.0 0.8 ± 0.05 NKN500 NKN7WS 24.5 ± 1.0 8.5 ± 0.5 38 ± 2.0 0.8 ± 0.05 DERATING CURVE NKN1/2W~3WS Rated Power (%) 100 80 60 40 36 20 70 200 275 Ambient Temperature (°C) 200 275 Ambient Temperature (°C) NKN3W~7W Rated Power (%) 100 80 60 40 31 20 40 www.yageo.com Aug. 13, 2021 V.0 3 15 Through Hole Resistors Product Specification Wirewound Resistors NKN ELECTRICAL CHARACTERISTICS CHARACTERISTICS NKN-50 NKN100 NKN200 Power Rating at 40 °C NKN300 NKN400 NKN500 3W 4W 5W Power Rating at 70 °C 1/2W 1W 2W Resistance Range 0.08Ω~15Ω 0.05Ω~40Ω 0.03Ω~90Ω 0.1Ω~120Ω 0.1Ω~120Ω 0.18Ω~220Ω Voltage Proof on Insulation 250V 400V 400V 400V 400V 400V Maximum working voltage √(P X R) Maximum Inductance 0.15 μH Operating Temp. Range - 40°C to +200°C Temperature Coefficient ±300ppm/°C CHARACTERISTICS NKN1WS NKN2WS NKN3WS Power Rating at 40 °C NKN5WS NKN7WS 5W 7W Power Rating at 70 °C 1W 2W 3W Resistance Range 0.08Ω~15Ω 0.05Ω~40Ω 0.03Ω~90Ω 0.1Ω~120Ω 0.18Ω~220Ω Voltage Proof on Insulation 250V 400V 400V 400V 400V Maximum working voltage √(P X R) Maximum Inductance 0.15 μH Operating Temp. Range - 40°C to +200°C Temperature Coefficient ±300ppm/°C Note: For resistance value out of above range is by request. www.yageo.com Aug. 13, 2021 V.0 4 15 Through Hole Resistors Wirewound Resistors Product Specification NKN TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 10 times rated power for 5 Sec. ±2%+0.05Ω Voltage Proof on IEC 60115-1 4.7 In V-Block for 60 sec. test voltage as No Breakdown Insulation PROCEDURE APPRAISE above table Temperature Coefficient IEC 60115-1 4.8 Between -40°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >100MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Damp Heat Steady State Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV(or Umax., whichever less) Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19 -40°C  Room Temp.   Resistance to Soldering IEC 60115-1 4.18 Heat +200°C ±1.0%+0.05Ω Room Temp.(5 cycles) 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body Accidental Overload Test IEC 60115-1 4.26 4 times RCWV for 1 Min. No evidence of flaming or arcing Note:. RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Aug. 13, 2021 V.0 5 15 Through Hole Resistors Wirewound Resistors Product Specification NKN AXIAL / REEL TAPE SPECIFICATION Unit: mm Normal Miniature a A B1-B2 (Max.) S (spacing) NKN-50 NKN1WS 6 ± 0.5 52.4 ± 1.5 1.2 5 73.0 ± 1.5 1.5 NKN100 NKN2WS 6 ± 0.5 52.4 ± 1.5 1.2 T (max. deviation of spacing) 5 1 mm per 10 spacing, 0.5 mm per 5 spacing NKN200 NKN300 NKN3WS NKN5WS 6 ± 0.5 73.0 ± 1.5 52.4± 1.5 1.5 1.2 10 NKN7WS 6 ± 0.5 91.0 ± 1.5 1.5 10 NKN400 NKN500 www.yageo.com Aug. 13, 2021 V.0 6 15 Through Hole Resistors Product Specification Wirewound Resistors NKN TAPE ON REEL PACKING TYPE Unit: mm/piece Normal Miniature Across Flange(A) B Quantity Per Reel NKN-50 NKN1WS 66.5 75.5 2,500 NKN100 NKN2WS 87 96 2,000 NKN200 NKN3WS 87 96 1,000 NKN300 NKN400 NKN5WS 87 96 1,000 www.yageo.com Aug. 13, 2021 V.0 7 15 Through Hole Resistors Wirewound Resistors Product Specification NKN TAPE ON BOX PACKING TYPE DIMENSIONS Unit: mm/piece Normal Miniature A B C Quantity Per Box NKN-50 NKN1WS 73 45 258 1,000 NKN100 NKN2WS 81 91 260 1,000 NKN100 NKN2WS 103 78 260 1,000 NKN200 NKN3WS 81 91 260 1,000 NKN200 NKN3WS 103 94 260 1,000 NKN300 NKN400 NKN5WS 81 91 260 500 NKN300 NKN400 NKN5WS 103 78 260 500 NKN500 NKN7WS 116 79 255 250 BULK PACKING Normal Miniature Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag NKN-50 NKN1WS 5,000 5 1,000 NKN100 NKN2WS 2,000 4 500 NKN200 NKN3WS 1,000 2 500 NKN300 NKN400 NKN5WS 1,000 2 500 NKN500 NKN7WS 500 10 50 www.yageo.com Aug. 13, 2021 V.0 8 15 Through Hole Resistors Wirewound Resistors Product Specification NKN FORMING M TYPE TYPE DIMENSIONS Unit: mm Normal Miniature L ψD ψd P H NKN-50 NKN1WS 9.0 ± 0.5 3.5± 0.3 0.55 ± 0.05 12.5 ± 1 10.0 ± 1 NKN100 NKN2WS 11.5 ± 1.0 4.8 ± 0.5 0.8 ± 0.05 15.0 ± 1 12.5 ± 1 NKN200 NKN3WS 15.5 ± 1.0 5.3 ± 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 NKN300 NKN400 NKN5WS 17.5 ± 1.0 6.5± 0.5 0.8 ± 0.05 25.0 ± 1 15.0 ± 1 NKN500 NKN7WS 24.5± 1.0 8.5± 0.5 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 MB TYPE MB TYPE TYPE DIMENSIONS Unit: mm Normal Miniature L ψD ψd P H1 H2 t NKN-50 - 9.0 ± 0.5 3.5± 0.3 0.55± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 - NKN1WS 9.0 ± 0.5 3.5± 0.3 0.8 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 NKN100 NKN2WS 11.5 ± 1.0 4.8 ± 0.5 0.8 ± 0.05 15.0 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 NKN200 NKN3WS 15.5 ± 1.0 5.3 ± 0.5 0.8 ± 0.05 20.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 NKN500 NKN7WS 24.5 ± 1.0 8.5 ± 0.5 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 5.0 ± 1 1.4 ± 0.2 www.yageo.com Aug. 13, 2021 V.0 9 15 Through Hole Resistors Product Specification Wirewound Resistors 10 15 NKN MHA TYPE TYPE DIMENSIONS Normal Miniature NKN-50 NKN1WS Unit: mm L ψD ψd B H0 HI P P0 9.0±0.5 3.5±0.3 0.55±0.05 17.5Max 19.0±1.0 4.0±1.0 30.0±1.0 15.0±0.3 P1 P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.5 7.5±0.5 18.0±0.5 5.0Min 9.0±0.5 4.0±0.2 MHB TYPE TYPE Normal DIMENSIONS Miniature L 15.5±1.0 NKN200 NKN3WS P 30.0±1.0 Unit: mm ψD ψd B 5.3±0.5 0.8±0.05 P0 15.0±0.3 H H0 HI H2 H3 21.0Max. 30Max. 18.0±1.0 5.5(Ref.) 8.0±1.5 16Max. PI P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.8 7.5±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.3 www.yageo.com Aug. 13, 2021 V.0 Through Hole Resistors Product Specification Wirewound Resistors 15 NKN MHC TYPE TYPE DIMENSIONS Normal Miniature L NKN200 NKN3WS Unit: mm ψD ψd B H HI P P0 15.5±1.0 5.3±0.5 0.8±0.05 21.0Max. 19.0±1.0 5.25±1.0 30.0±1.0 15.0±0.3 F W W0 W1 ΨD0 10.0±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.2 FK TYPE F TYPE TYPE FFK TYPE FKK TYPE DIMENSIONS Unit: mm H Normal Miniature L ψD ψd P h NKN100 NKN2WS 11.5±1 4.8±0.5 0.8±0.05 6±1 8±1 24 NKN200 NKN3WS 15.5±1 5.3±0.5 0.8±0.05 8±1 8±1 28 Max. HI E Max. Max. 5±1 20 3.5 3.5±1 5± 1 25 3.5 3.5±1 hl e www.yageo.com Aug. 13, 2021 V.0 11 Through Hole Resistors Wirewound Resistors Product Specification 15 NKN PN TYPE ( Taping Pack ) AV TYPE ( Taping Pack ) TYPE DIMENSIONS Unit: mm TYPE DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. Normal Miniature H1 Max. H2 Max. H3 Max. NKN-50 NKN1WS 17 25.5 8.5 NKN-50 NKN1WS 14.5 23 8.5 NKN100 NKN2WS 19 27.5 8.5 NKN100 NKN2WS 17.5 26 8.5 FT TYPE ( Taping Pack ) TYPE DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. NKN-50 NKN1WS 13 21.5 8.5 NKN100 NKN2WS 16 24.5 8.5 www.yageo.com Aug. 13, 2021 V.0 12 Through Hole Resistors Product Specification Wirewound Resistors 15 NKN MARKING COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω TOLERANCE NKN Series ± 2% ( G ) ±5% (J) ±2%, ±5% 5-BAND-CODE www.yageo.com Aug. 13, 2021 V.0 13 Through Hole Resistors Wirewound Resistors Product Specification 15 NKN REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 13, 2021 V.0 14 Through Hole Resistors Wirewound Resistors Product Specification 15 NKN LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 13, 2021 V.0 15
NKN100JR-73-3R3 价格&库存
很抱歉,暂时无法提供与“NKN100JR-73-3R3”相匹配的价格&库存,您可以联系我们找货
