EM244506
EM244506
    EATON(伊顿)
    插件,P=5mm
    接线端子 间距P=5.00mm 12Pin(2x6) 直插
EM244506 数据手册
EuroMag Series PCB Mount Terminal Blocks Terminal Blocks: Single Row EM2445 Series EuroMag Terminal Blocks Two Tier; 5.00 Centers; Modular 12.5 17.5 22.5 27.5 32.5 37.5 42.5 47.5 52.5 57.5 62.5 13 14 15 16 17 18 19 20 21 22 23 24 Dimensions - in (mm) L (mm) 67.5 72.5 77.5 82.5 87.5 92.5 97.5 102.5 107.5 112.5 117.5 122.5 0.84 (21.40) L 0.10 (2.5) L 0.10 (2.5) 0.99 (25.1) 0.15 (3.7) 0.54 (13.8) 0.031 (0.79) 0.10 (2.5) 0.598 (15.20) 0.18 (4.6) 0.10 (2.5) 0.031 (0.79) 0.197 (5.00) To convert to inches, divide by 25.4 EM2445 Part Numbering System En Mn 2n 4n 4n 5 nn n Series EuroMag Series Poles EM244504 # of Poles 02 to 24 For additional product information, visit www.eaton.com/connectors 51 Compliance References 2 3 4 5 6 7 8 9 10 11 12 L (mm) EM244508 Edge Connectors, One-Sided Boards Poles Two & Three Tier SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin Plated Brass Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Rising Cage and Screw File E62622; CE Certified Agency Information:
EM244506 价格&库存
很抱歉,暂时无法提供与“EM244506”相匹配的价格&库存,您可以联系我们找货
EM244506
    • 1+9.42840
    • 200+3.76920
    • 500+3.63960
    • 1000+3.57480
