EM244808
EM244808
    EATON(伊顿)
    插件,P=5.08mm
    接线端子 间距P=5.08mm 16Pin(2x8) 直插
EM244808 数据手册
EM244808 EM244804 Dimensions - mm (in) 21.4+ _0.3 (0.843") L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 L+ _0.5 L+ _0.5 2.54+ _0.3 (0.100") 0.8+ _0.1 (0.031") 15.5+ _0.2 (0.610") 0.8+ _0.1 (0.031") 3.7+ _0.3 (0.146") Poles 13.8+ _0.3 (0.543") SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Material: Brass, Nickel-Plated Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified 25.1+ _0.3 (0.988") 5.08+ _0.1 (0.200") 0.8+ _0.1 (0.031") 2.54+ _0.2 (0.100") 2.54+ _0.3 (0.100") 4.6+ _0.3 (0.181") ø1.4~1.5 (ø0.055"~0.059") 5.08+ _0.1 (0.200") To convert to inches, divide by 25.4 PCB Hole Layout 21.4+ _0.3 (0.843") EuroMag Series EM2448 Series EuroMag Terminal Blocks Two Tier; 5.08 Centers; Modular Compliance References Edge Connectors, One-Sided Boards Two & Three Tier Terminal Blocks: Single Row EuroMag Series PCB Mount Terminal Blocks 2.54+ _0.2 (0.100") 15.5+ _0.2 (0.610") 4.6+ _0.3 (0.181") 5.08+ _0.1 (0.200") Part Numbering System En Mn 2n 4n 4n 8 nn n Series # of Poles 02 to 24 For additional product information, visit www.eaton.com/connectors 52
EM244808 价格&库存
很抱歉,暂时无法提供与“EM244808”相匹配的价格&库存,您可以联系我们找货
