EM293903
EM293903
    EATON(伊顿)
    插件,P=15mm
    接线端子 间距P=15.00mm 3Pin(1x3) 直插
EM293903 数据手册
EM2939 Series EuroMag Terminal Blocks Hi-Current, 15.00 Centers SPECIFICATIONS Rating: 115A, 600V with No Bottom Cover (NC) Option. Center Spacing: 0.591” (15.00mm) Wire Range: #2-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Copper Cage Material: Steel, Chromate-Plated Screw Size: M5 Stainless Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 15 lb-in. Recommended PCB Hole Diameters: 0.063" (1.60mm) Construction: Mold to length Agency Information: File E62622; CE Certified EM293908 Dimensions - mm Poles L (mm) 2 3 4 5 6 7 8 30.0 45.0 60.0 75.0 90.0 105.0 120.0 Test Points L 31.0 39.0 To convert to inches, divide by 25.4 1.3 15.0 3.8 1.2 12.5 4.5 0.5 High Current Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Terminal Blocks 3.0 Part Numbering System En Mn 2n 9n 3n 9 qq n Series # of Poles 02 to 08 For additional product information, visit www.eaton.com/connectors 62
EM293903 价格&库存
很抱歉,暂时无法提供与“EM293903”相匹配的价格&库存,您可以联系我们找货
EM293903
  • 20+47.96501
  • 50+47.05818
  • 100+44.38607
库存:1567
