U98-B121-1001
U98-B121-1001
    ARDUINO
    HOSTCONNCFP21PORTCAGE
U98-B121-1001 数据手册
CFP2 1xN Cage Assembly, Heat Sink, Heat Sink Clip, and Connector Cover Product Specification S6080C Rev 1.0 About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. CFP2 1x1 U98-B121-X00X CAGE ASSEMBLY WITH HEAT SINK AND CONNECTOR COVER CFP2 1x2 U98-B221-X00X CAGE ASSEMBLY WITH HEAT SINK AND CONNECTOR COVER Related Products QSFP+ 38 POSITION CONNECTOR CFP2 1x1 U98-B111-X0AX CAGE ASSEMBLY WITHOUT HEAT SINK OR CONNECTOR COVER THRU THE BEZEL CAGE ASSEMBLY WITH HEAT SINK CFP2 1x2 U98-B211-X0AX CAGE ASSEMBLY WITHOUT HEAT SINK OR CONNECTOR COVER Overview This short form Product Specification defines the general use and performance parameters for Amphenol’s CFP2 series 1xN cage assembly. Availability: 1x1 and 1x2 cages with heat sink and heat sink cage 1x3 BEHIND THE BEZEL CAGE ASSEMBLY WITH HEAT SINK AND LIGHT PIPES Usage The connector system is capable of data rates up to 10 Gbps per channel (up to 10 channels) or 25 Gbps per channel (up to 8 channels) and is intended for external connections (104 positions per port) using active cabling. CXP Applications CAGE AND CONNECTOR ASSEMBLY WITH ROUND PIN HEAT SINK AND ELASTOMER GASKET Revision Date: May 7, 2013 Intended for use in high speed serial interconnect applications such as:  Clusters  Servers  Storage devices Page 1 of 3 S6080C Rev 1.0 General Requirements About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. RoHS compliant Footprint compatible with other industry suppliers Press-fit cage and connector combo for minimum 3.00 mm (0.118in) PCB thickness in belly-tobelly application Cages are tray packed Dust cover for front face is available (bulk packed) Proper support for cage is required during insertion into PCB Extraction tool required for removing the combo from PCB (consult factory) Connector Electrical Characteristics Operating Voltage: 3.3V Operating Current: 1.875A Connector Mechanical Characteristics Related Products QSFP+ Insertion Force: 80 N Withdrawal Force: 50 N Durability: 200 mating cycles Material Requirements 38 POSITION CONNECTOR Unless otherwise specified, the materials for each component shall be:  Cage: Copper alloy, matte tin over nickel or nickel only plating  Heat Sink: Aluminum alloy, anodized or nickel plated  Heat Sink Clip: Steel alloy  Connector Cover: Zinc alloy, nickel plated Temperature rise: Meets the requirement of 30° C ΔT Operating and storage temperature: -40° to +85° C THRU THE BEZEL CAGE ASSEMBLY WITH HEAT SINK Process Characteristics Cage assembly is press-fit to customer PCB Connector cover is screw-mounted PCB Specifications 1x3 BEHIND THE BEZEL CAGE ASSEMBLY WITH HEAT SINK AND LIGHT PIPES Compliant Pin Holes must be drilled and plated through to specific dimensions to prevent damage during placement of cage assembly on the PCB. See table below. Recommended torque for connector cover mounting screws is 0.90±0.10 in·lb CXP CAGE AND CONNECTOR ASSEMBLY WITH ROUND PIN HEAT SINK AND ELASTOMER GASKET Amphenol Canada Corp. 605 Milner Avenue Toronto, Ontario, Canada, M1B 5X6 +1 416 291 4401 Page 2 of 3 Copyright © Amphenol Corporation 2013 • All rights reserved www.amphenolcanada.com THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. S6080C Rev 1.0 About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. Related Products QSFP+ 38 POSITION CONNECTOR THRU THE BEZEL CAGE ASSEMBLY WITH HEAT SINK Surface Finish Drilled Hole Diameter HASL SnPb Immersion Sn OSP 1.15±0.02 1.15±0.02 1.15±0.02 Finished Hole Diameter 1.05 Ref 1.05 Ref 1.05 Ref Immersion Au/Ni 1.15±0.02 1.05 Ref Surface Finish Thickness 0.004-0.010 0.0005 Min. 0.0002-0.0005 0.004-0.0076 (Ni) 0.0001-0.0005 (Au) Available Documents Drawing Numbers: 1x3 BEHIND THE BEZEL CAGE ASSEMBLY WITH HEAT SINK AND LIGHT PIPES P-U98-B1X1-X0XX CFP2 series 1x1 cage assembly P-U98-B2X1-X0XX CFP2 series 1x2 cage assembly Contact factory or Authorized Amphenol representative for alternate configurations CXP CAGE AND CONNECTOR ASSEMBLY WITH ROUND PIN HEAT SINK AND ELASTOMER GASKET Amphenol Canada Corp. 605 Milner Avenue Toronto, Ontario, Canada, M1B 5X6 +1 416 291 4401 Page 3 of 3 Copyright © Amphenol Corporation 2013 • All rights reserved www.amphenolcanada.com THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP.
U98-B121-1001 价格&库存
很抱歉,暂时无法提供与“U98-B121-1001”相匹配的价格&库存,您可以联系我们找货
