U99-C056-200T
U99-C056-200T
    ARDUINO
    HOSTCONNCFP4RECEPTACLE56POS
U99-C056-200T 数据手册
CFP4 Series Connector Product Specification S6099C Rev 1.0 About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. Related Products QSFP+ U99-C056-XXXX 56 POSITION CFP4 SERIES CONNECTOR 38 POSITION CONNECTOR Overview This short form Product Specification defines the general use and performance parameters for Amphenol’s CFP4 series connector. THRU THE BEZEL CAGE ASSEMBLY WITH HEAT SINK The interconnect system comprises a 56 position 0.6 mm pitch connector designed to be compatible with the 100G Form factor Pluggable (CFP) Multi-source Agreement. Usage The connector system is capable of data rates up to 25 Gbps per channel (up to 4 channels) with resonance dampening for improved signal integrity (56 position connector). 1x3 BEHIND THE BEZEL CAGE ASSEMBLY WITH HEAT SINK AND LIGHT PIPES CXP Applications Intended for use in high speed serial interconnect applications such as:  Clusters  Servers  Storage devices General Requirements Connectors are tape and reel packaged for robotic pick-and-place. CAGE AND CONNECTOR ASSEMBLY WITH ROUND PIN HEAT SINK AND ELASTOMER GASKET Revision Date: January 12, 2015 Page 1 of 2 S6099C Rev 1.0 About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. Related Products QSFP+ 38 POSITION CONNECTOR Connector Electrical Characteristics Operating Voltage: 3.3V Operating Current: 1.87A Connector Mechanical Characteristics Maximum Insertion Force (without heat sink): 60 N Maximum Withdrawal Force (without heat sink): 50 N Durability: 200 mating cycles Material Requirements Unless otherwise specified, the materials for each component shall be:  Contacts o Base material – Phosphor Bronze o Contact Normal Force – 50g nominal o Plating  Mating area – 15 or 30 microinches (0.38 or 0.76 µm) min Gold over 50 µin (1.27 µm) min Nickel  Solder tails – 100 microinches (2.54 µm) min Matte Tin, over 50 µin (1.27 µm) min Nickel  Housings: Black color, glass-reinforced, lead-free solder reflow process compatible thermoplastic, UL94V-0 rated  Resonance dampening feature: Conductive polymer. Temperature rise: Meets the requirement of 30° C ΔT Operating and storage temperature: -40° to +85° C Process Characteristics THRU THE BEZEL CAGE ASSEMBLY WITH HEAT SINK Connectors are tape and reel packaged Cages offered in various options (refer to S6098C) Maximum process temperature during soldering is 260°C for 10 seconds Belly-to-belly placement possible, allowing for two cages to mount on opposite sides of PCB Resonance Dampening Features 1x3 BEHIND THE BEZEL CAGE ASSEMBLY WITH HEAT SINK AND LIGHT PIPES CXP This connector incorporates a ground commoning device to provide better common mode performance and reduced crosstalk at resonance frequencies. Available Documents Drawing Numbers: P-U99-C056-XXXX CFP4 Series Connector Contact factory or Authorized Amphenol representative for alternate configurations CAGE AND CONNECTOR ASSEMBLY WITH ROUND PIN HEAT SINK AND ELASTOMER GASKET Amphenol Canada Corp. 605 Milner Avenue Toronto, Ontario, Canada, M1B 5X6 +1 416 291 4401 Page 2 of 2 Copyright © Amphenol Corporation 2015 • All rights reserved www.amphenolcanada.com THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP.
U99-C056-200T 价格&库存
很抱歉,暂时无法提供与“U99-C056-200T”相匹配的价格&库存,您可以联系我们找货
