U95-T111-1001
U95-T111-1001
    ARDUINO
    CONN1X1CAGE
U95-T111-1001 数据手册
UltraPort QSFP 1xN cages Product Specification S6083C Rev 1.0 About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. 1x1 Cage with Fin heat sink 1x2 Cage with round pin heat sinks and single barrel light pipes Related Products QSFP+ QSFP+ 38 POSITION CONNECTOR 1x4 Cage with pin fin heat sinks and single barrel light pipes PCI Express 1x6 Cage with square pin heat sinks and quad barrel light pipes Overview SINGLE 1° CAGE This short form Product Specification defines the general use and performance parameters for Amphenol’s UltraPort QSFP 1xN cage series. It is designed to comply with the Quad Small Formfactor Pluggable (QSFP) SFF-8663 QSFP+ 28Gbps cage specification. MiniSAS Availability: 1x1, 1x2, 1x3, 1x4 and 1x6 versions are available in thru the bezel configurations. 1x1 One degree cage also available in thru the bezel configuration. Behind bezel and Hybrid versions shall become available soon. Usage 26 POSITION CONNECTOR WITH HOLD DOWN TABS The UltraPort QSFP single row cages are intended to be used with UltraPort QSFP SMT connector . (Refer to Product spec. S6082C) Applications FS1 SINGLE PORT CAGE WITH METAL GASKET Revision Date: January 20, 2015 Intended for use in high speed serial interconnect applications such as:  Cellular hubs  Switches  Servers  Storage devices Page 1 of 4 S6083C Rev 1.0 About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. Related Products QSFP+ General Requirements Cages are packaged in trays. Heat sinks/clips and light pipes are assembled to the cage and placed in the tray if available. Heat sinks and heat sink clips may be packaged seperately for 1x1 options only. Dust covers are packaged separately if ordered. “Belly-to-belly" version allows two cages to mount on opposite sides of the PCB. Cage Mechanical Characteristics Cages are available with and without Heat Sinks Cages are available with and without Light Pipes Cages are press-fit into PCBs Cages have error proof features according to QSFP MSA Material Requirements Unless otherwise specified, the materials for each component shall be: QSFP+ 38 POSITION CONNECTOR Cage   PCI Express Base material – Phosphor Bronze 100 µ” (2.54 µm)Minimum Nickel plated Heat Sink  Base material –Aluminum alloy with Nickel plating SINGLE 1° CAGE Heat Sink Clip  Base material – Stainless Steel MiniSAS Light Pipe  Base material – Clear Polycabonate, optical grade Dust Cover  Base material – Conductive Rubber 26 POSITION CONNECTOR WITH HOLD DOWN TABS EMI gasket  Base material – Conductive elastomer EMI flange  Base material – Dia cast zinc alloy with Nickel plating FS1 SINGLE PORT CAGE WITH METAL GASKET Operating temperature: -40° to +85° C Storage temperature: -40° to +85° C Amphenol Canada Corp. 605 Milner Avenue Toronto, Ontario, Canada, M1B 5X6 +1 416 291 4401 Page 2 of 4 Copyright © Amphenol Corporation 2015 • All rights reserved www.amphenolcanada.com THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. S6083C Rev 1.0 About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. Assembly Instructions Compliant Pin Holes must be drilled and plated through to specific dimensions to prevent damage during placement of cage assembly on the PCB. See table below. Related Products QSFP+ QSFP+ 38 POSITION CONNECTOR PCI Express SINGLE 1° CAGE MiniSAS 26 POSITION CONNECTOR WITH HOLD DOWN TABS Surface Finish Drilled Hole Diameter HASL SnPb Immersion Sn OSP 1.15±0.02 1.15±0.02 1.15±0.02 Finished Hole Diameter 1.05 Ref 1.05 Ref 1.05 Ref Immersion Au/Ni 1.15±0.02 1.05 Ref Surface Finish Thickness 0.004-0.010 0.0005 Min. 0.0002-0.0005 0.004-0.0076 (Ni) 0.0001-0.0005 (Au) FS1 SINGLE PORT CAGE WITH METAL GASKET Amphenol Canada Corp. 605 Milner Avenue Toronto, Ontario, Canada, M1B 5X6 +1 416 291 4401 Page 3 of 4 Copyright © Amphenol Corporation 2015 • All rights reserved www.amphenolcanada.com THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. S6083C Rev 1.0 About Amphenol Commercial Products Amphenol’s commercial connector products are used in a variety of end user applications including networking, telecom, server & computer, storage & HDD, consumer electronics and entertainment, professional audio & Industrial & Military/Aerospace. Available Documents Drawing Numbers: Related Products QSFP+ P-FS1-Z38-X0Z6-10 UltraPort QSFP SMT connector, with resonance dampening feature P-U95-T(A,L)1X1-1XXX P-U95-T(L)2X1-1XXX P-U95-T(L)3X1-1XXX P-U95-T(L)4X1-1XXX P-U95-T(L)6X1-1XXX P-U95-W1X1-1XXX UltraPort QSFP UltraPort QSFP UltraPort QSFP UltraPort QSFP UltraPort QSFP UltraPort QSFP P-U95-G(P)1X1-1XXX P-U95-G(P)2X1-1XXX P-U95-G(P)3X1-1XXX UltraPort QSFP 1x1 behind bezel, 0 deg., heat sink and light pipe options-Preliminary UltraPort QSFP 1x2 behind bezel, 0 deg., heat sink and light pipe options-Preliminary UltraPort QSFP 1x3 behind bezel, 0 deg., heat sink and light pipe options-Preliminary P-U95-D(V)1X1-1XXX P-U95-D(V)2X1-1XXX P-U95-D(V)3X1-1XXX P-U95-D(V)4X1-1XXX UltraPort QSFP UltraPort QSFP UltraPort QSFP UltraPort QSFP 1x1 thru the bezel cage, 0 deg. with heat sink and light pipe options 1x2 thru the bezel cage, 0 deg. with heat sink and light pipe options 1x3 thru the bezel cage, 0 deg. with heat sink and light pipe options 1x4 thru the bezel cage, 0 deg. with heat sink and light pipe options 1x6 thru the bezel cage, 0 deg. with heat sink and light pipe options 1x1 thru the bezel cage, 1 deg. with heat sink options 1x1 hybrid cage, 0 deg., heat sink and light pipe options-Preliminary 1x2 hybrid cage, 0 deg., heat sink and light pipe options-Preliminary 1x3 hybrid cage, 0 deg., heat sink and light pipe options-Preliminary 1x4 hybrid cage, 0 deg., heat sink and light pipe options-Preliminary Contact factory or Authorized Amphenol representative for alternate configurations QSFP+ 38 POSITION CONNECTOR PCI Express SINGLE 1° CAGE MiniSAS 26 POSITION CONNECTOR WITH HOLD DOWN TABS FS1 SINGLE PORT CAGE WITH METAL GASKET Amphenol Canada Corp. 605 Milner Avenue Toronto, Ontario, Canada, M1B 5X6 +1 416 291 4401 Page 4 of 4 Copyright © Amphenol Corporation 2015 • All rights reserved www.amphenolcanada.com THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP.
U95-T111-1001 价格&库存
很抱歉,暂时无法提供与“U95-T111-1001”相匹配的价格&库存,您可以联系我们找货
