U90-T161-1D0A
U90-T161-1D0A
    ARDUINO
    CONN QSFP CAGE W/HEATSINK R/A
U90-T161-1D0A 数据手册
8 7 5 6 4 3 2 D 1 REVISIONS AMPHENOL PART NUMBER CONFIGURATION U90 - T 1 X 1 - 1 X X X PACKAGING HEAT SINK OPTION 5 = PIN STYLE HEAT SINK (NICKEL PLATED) AND CLIP (H=6.5mm; SAN HEIGHT) 1 = TRAY PACKAGING W/ HEAT SINK IN SEPARATE TRAY 6 = PIN STYLE HEAT SINK (NICKEL PLATED) AND CLIP (H=4.2mm; PCI HEIGHT) A = TRAY PACKAGING W/ HEAT SINK ASSEMBLED 7 = PIN STYLE HEAT SINK (NICKEL PLATED) AND CLIP (H=13.5mm; TALL) T = TAPE AND REEL PACKAGING W/ HEAT SINK IN SEPARATE TRAY D = PIN-FIN HEAT SINK (ANODIZED, BLACK)AND CLIP (H=6.5mm; SAN HEIGHT) LIGHT PIPE OPTION E = PIN-FIN HEAT SINK (ANODIZED, BLACK) AND CLIP (H=4.2mm; PCI HEIGHT) 0 = WITHOUT LIGHT PIPE F = PIN-FIN HEAT SINK (ANODIZED, BLACK) AND CLIP (H=13.5mm; TALL) 1 = WITH LIGHT PIPE N = PIN-FIN HEAT SINK (NICKEL PLATED) AND CLIP (H=6.5mm; SAN HEIGHT) P = PIN-FIN HEAT SINK (NICKEL PLATED) AND CLIP (H=4.2mm; PCI HEIGHT) OPTIONAL DUST COVER R = PIN-FIN HEAT SINK (NICKEL PLATED) AND CLIP (H=13.5mm; TALL) 0 = WITHOUT DUST COVER D = WITH DUST COVER SHIPPED AS LOOSE PIECE) NOTE: FOR DIMENSION "H" LOCATION SEE SHEET 2 DESCRIPTION DATE A NEW RELEASE AUG 14/09 ZLJ B DIMENSION ADDED FEB 22/12 ZLJ REV. ECN APPROVED D C C VIEW WITH PIN-FIN STYLE HEAT SINK, CLIP AND LIGHT PIPE ASSEMBLED (P/N U90-T1D1-101A) VIEW WITH PIN-FIN STYLE HEAT SINK AND CLIP ASSEMBLED (P/N U90-T1D1-100A) B B DUST COVER (SHIPPED LOOSE) P/N U79-111-9000-P VIEW WITH PIN STYLE HEAT SINK, CLIP AND LIGHT PIPE ASSEMBLED (P/N U90-T151-101A) VIEW WITH PIN STYLE HEAT SINK AND CLIP ASSEMBLED AND DUST COVER (SHIPPED LOOSE) (P/N U90-T151-1D0A) UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: A DECIMALS 0.5 MATERIAL AND FINISH SEE NOTE 1 DO NOT SCALE DRAWING 8 7 6 5 4 REF. CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.15 X.XX 0.10 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. APPROVALS 03554 DESIGNED CHECKED DATE J.HU FEB 22/12 ZLJ MAR 17/09 J.SI MAR 17/09 QA APPD A Amphenol Canada Corp. TITLE QSFP CAGE ASSEMBLY WITH OPTIONAL LIGHT PIPE (WITH LOW PROFILE HEAT SINK CLIP) SIZE IE APP'D A3 DWG APP'D SCALE A.GREEN MAR 17/09 2 DWG. NO. 2:1 REV. P-U90-T1X1-1XXX SHEET PROJECT 1 B 1 OF 5 8 7 6 5 4 3 2 1 REVISIONS REV. DESCRIPTION ECN B SEE SHEET 1 DATE APPROVED FEB 22/12 ZLJ D D 6.16 LIGHT PIPE CLIP K C C J 9.40 9.63 HEAT SINK CAGE 58.73 20.81 7.1 B B PART NUMBER DIM "J" DIM "H" U90-T151-1X0X U90-T161-1X0X U90-T171-1X0X U90-T1D1-1X0X U90-T1E1-1X0X U90-T1F1-1X0X U90-T1N1-1X0X U90-T1P1-1X0X U90-T1R1-1X0X 15.03 12.73 22.03 15.03 12.73 22.03 15.03 12.73 22.03 6.50 4.20 13.50 6.50 4.20 13.50 6.50 4.20 13.50 DIM "K" H 3.90 NOTES: 1. CAGE AND EMI SPRINGS MATERIAL: COPPER ALLOY CAGE PLATING: 3.81m [100"] MIN. NICKEL. HEAT SINK CLIP MATERIAL: STEEL ALLOY HEAT SINK MATERIAL: ALUMINUM LIGHT PIPE MATERIAL: GE LEXAN CLEAR OPTICAL GRADE 2. CAGE IS INTENDED TO BE COMPLIANT WITH THE QUAD SMALL FORMFACTOR PLUGGABLE (QSFP)TRANSCEIVER SPECIFICATION REVISION 1.0. UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: A DECIMALS 0.5 MATERIAL AND FINISH SEE NOTE 1 DO NOT SCALE DRAWING 8 7 6 5 4 REF. CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.15 X.XX 0.10 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. APPROVALS 03554 DESIGNED CHECKED DATE J.HU FEB 22/12 ZLJ MAR 17/09 J.SI MAR 17/09 QA APPD A Amphenol Canada Corp. TITLE QSFP CAGE ASSEMBLY WITH OPTIONAL LIGHT PIPE (WITH LOW PROFILE HEAT SINK CLIP) SIZE IE APP'D A3 DWG APP'D SCALE A.GREEN MAR 17/09 2 DWG. NO. 2:1 REV. P-U90-T1X1-1XXX SHEET PROJECT 1 B 2 OF 5 8 7 4 5 6 3 2 1 REVISIONS REV. 7.2 D SEE SHEET 1 APPROVED FEB 22/12 ZLJ A 1.1 3.4 D 16.20 MAX (SURFACE TRACES PERMITTED WITHIN THIS LENGTH) SOLDER PAD FOR LEDS (PAD SIZE DECIDED BY CUSTOMER) 6.16 DATE DESCRIPTION ECN B 16.8 5.40 A 15.80 0.40 38 11.30 MIN 1.05±0.05 (12 PLC.) (SEE NOTE 3) 0.1 M A K S L S 20 10.30 MAX 19 1 10.6 C 7.6 3.1 THIS AREA DENOTES COMPONENT KEEP-OUT (TRACES ALLOWED) C 9.00 MAX 0.35±0.03 (38 PLC.) 0.05 S K S L S 5.18 37.00 MAX (SEE NOTE 2) 9.00 (6 PLC.) BSC 1.80±0.03 (38 PLC.) 0.05 S K S L S 2.50 3.1 7.6 0.80 (36 PLC.) 3.50 MAX 1.69 MAX 0.1 L 1.55±0.05 A X K S 15.02 MAX L B 1.55±0.05 0.1 L A X Y 19.20 MAX B K DETAIL A SCALE 4 : 1 1.44 MIN 19.00 CROSS-HATCHED AREA DENOTES COMPONENT AND TRACE KEEPOUT (EXCEPT CHASSIS GROUND) 22.15 MIN X BSC (SEE NOTE 1) (SEE NOTE 1) RECOMMENDED PC BOARD LAYOUT (COMPONENT SIDE OF BOARD) Y A UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: NOTES: 1. DATUMS X AND Y ESTABLISHED BY CUSTOMER'S FUDUCIAL. 2. LOCATION OF EDGE OF PCB IS APPLICATION SPECIFIC. 3. DECIMALS 8 SEE NOTE 1 DO NOT SCALE DRAWING 7 0.5 MATERIAL AND FINISH THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. 6 5 4 REF. CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.15 X.XX 0.10 FINISHED HOLE SIZE. APPROVALS 03554 DESIGNED CHECKED DATE J.HU FEB 22/12 ZLJ MAR 17/09 J.SI MAR 17/09 QA APPD A Amphenol Canada Corp. TITLE QSFP CAGE ASSEMBLY WITH OPTIONAL LIGHT PIPE (WITH LOW PROFILE HEAT SINK CLIP) SIZE IE APP'D A3 DWG APP'D SCALE A.GREEN MAR 17/09 2 DWG. NO. 5:2 REV. P-U90-T1X1-1XXX SHEET PROJECT 1 B 3 OF 5 8 7 4 5 6 3 2 1 REVISIONS 13.40 D 6.20 1.10 3.40 5.40 38 10.60 1.05±0.05 (24 PLC.) (SEE NOTE 3) 0.1 M A K S L S 20 1 APPROVED FEB 22/12 ZLJ D 38 7.60 (2 PLC.) 19 SEE SHEET 1 A 6.16 3.10 (2 PLC) DATE DESCRIPTION ECN B (SEE PAGE 2) (SEE PAGE 2)A 11.30 MIN REV. A 10.60 20 19 1 3.10 (2 PLC.) C C THIS AREA DENOTES COMPONENT KEEP-OUT (TRACES ALLOWED) 4.50 (14 PLC.) THIS AREA DENOTES COMPONENT KEEP-OUT (TRACES ALLOWED) 37.00 MAX (SEE NOTE 2) BSC B B CROSS-HATCHED AREA DENOTES COMPONENT AND TRACE KEEPOUT (EXCEPT CHASSIS GROUND) 19.00 CROSS-HATCHED AREA DENOTES COMPONENT AND TRACE KEEPOUT (EXCEPT CHASSIS GROUND) 22.15 MIN 2.85 MIN BSC X (SEE NOTE 1) RECOMMENDED BELLY-TO-BELLY PC BOARD LAYOUT (COMPONENT SIDE OF BOARD) Y (SEE NOTE 1) A UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: NOTES: DECIMALS 1. DATUMS X AND Y ESTABLISHED BY CUSTOMER'S FUDUCIAL. 2. LOCATION OF EDGE OF PCB IS APPLICATION SPECIFIC. 3. 8 SEE NOTE 1 DO NOT SCALE DRAWING 7 0.5 MATERIAL AND FINISH THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. 6 5 4 REF. CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.15 X.XX 0.10 FINISHED HOLE SIZE. APPROVALS 03554 DESIGNED CHECKED DATE J.HU FEB 22/12 ZLJ MAR 17/09 J.SI MAR 17/09 QA APPD A Amphenol Canada Corp. TITLE QSFP CAGE ASSEMBLY WITH OPTIONAL LIGHT PIPE (WITH LOW PROFILE HEAT SINK CLIP) SIZE IE APP'D A3 DWG APP'D SCALE A.GREEN MAR 17/09 2 DWG. NO. 5:2 REV. P-U90-T1X1-1XXX SHEET PROJECT 1 B 4 OF 5 8 7 5 6 4 3 2 1 REVISIONS REV. DATE DESCRIPTION ECN B SEE SHEET 1 FEB 22/12 APPROVED ZLJ 20.00±0.10 6.16 D R0.30 MAX (TYP.) C 0.9 D CL OF PCB DATUMS K AND L 43.80 REF 13.43 BEZEL 10.15±0.10 (TYP.) C 2X 1.70 0.15±0.10 (BEZEL CUT-OUT TO PCB BOARD) (TYP.) 2.85 MIN THK HOST BOARD C HOST BOARD 4.36 (BEZEL CUT-OUT SPACING) RECOMMENDED BELLY-TO-BELLY MOUNTING DESIGN 21.00±0.10 SECTION C-C 0.9 D B 43.80 REF. BEZEL 13.43 CENTER LINE OF PCB DATUMS K AND L 6.16 10.15±0.10 TYP. D 20.00±0.10 C QSFP CONNECTOR P-FS1-R38-2000 SHOWN AS REFERENCE B 1.70 0.15 BEZEL CUT OUT TO PCB BOARD (TYP.) HOST BOARD SECTION D-D QSFP CONNECTOR P-FS1-R38-2000 SHOWN AS REFERENCE RECOMMENDED SINGLE SIDED MOUNTING DESIGN UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: A DECIMALS 0.5 MATERIAL AND FINISH SEE NOTE 1 DO NOT SCALE DRAWING 8 7 6 5 4 REF. CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.15 X.XX 0.10 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. APPROVALS 03554 DESIGNED CHECKED DATE J.HU FEB 22/12 ZLJ MAR 17/09 J.SI MAR 17/09 QA APPD A Amphenol Canada Corp. TITLE QSFP CAGE ASSEMBLY WITH OPTIONAL LIGHT PIPE (WITH LOW PROFILE HEAT SINK CLIP) SIZE IE APP'D A3 DWG APP'D SCALE A.GREEN MAR 17/09 2 DWG. NO. 2:1 P-U90-T1X1-1XXX SHEET PROJECT 1 REV. B 5 OF 5
U90-T161-1D0A 价格&库存
很抱歉,暂时无法提供与“U90-T161-1D0A”相匹配的价格&库存,您可以联系我们找货
