U10-C038-200T
U10-C038-200T
    ARDUINO
    CONN RECEPTACLE 4X24 RIGHT ANGLE
U10-C038-200T 数据手册
A B C D E G F H REVISIONS 12.70 REV DESCRIPTION, ECN, EAR NO. M UPDATE DESCRIPTION DATE APP'D JS APR06/16 1 1 15.80 3.00 RECOMMENDED PICK UP AREA 9.90 13.45 MIN (COMPONENT KEEP OUT) TRACE KEEP OUT AREA 2.15 12.45 5.70 0.66 TYP. (PTH) 0.08 M A B 2 3.00 1.78 5.55 5.15 6.60 16.20 MIN (COMPONENT KEEP OUT) 2 9.10 0.675 TYP 2.6 1.00 5.55 1.30±0.05 1.30 ±0.05(NPTH) B 0.15 A 3 3 #1(A1) 2.70 X (SEE PART NUMBER LATCH PIN OPTION) 0.60 #19(A19) 1.30±0.03 0.05 L A B 0.35±0.03 0.05 L A B 0.85 2.35 U10 - C038 - X X X X OPTIONS #20(B19) 0T = STANDARD CONSTRUCTION WITH TAPE & REEL PACKAGING 4 #38(B1) 15.30 MIN (PLUG) 4 1T= NO RESONANCE DAMPING WITH TAPE &REEL PARKAGING LATCH PIN OPTION 0 = 1.5mm LONG 5 4 = 2.2mm LONG NOTES: 5 = 3.0mm LONG 1) MATERIAL: 6 = 4.2mm LONG HOUSING: SOLDER REFLOW PROCESS COMPATIBLE LCP, UL94V-0 CONTACTS: HIGH PERFORMANCE COPPER ALLOY LATCH: PHOSPHOR BRONZE RESONANCE DAMPENING FEATURE: SEMI-CONDUCTIVE POLYMER CONTACT PLATING OPTION 2 = 30 MICROINCHES OF GOLD ON MATING END WITH 100 MICROINCHES MINIMUM OF MATTE TIN ON SOLDER TERMINATION. 50-75 MICROINCHES OF NICKEL UNDERPLATE ALL OVER 2)RoHS COMPLIANT 3 = 15 MICROINCHES OF GOLD ON MATING END WITH 100 MICROINCHES MINIMUM OF MATTE TIN ON SOLDER TERMINATION. 50-75 MICROINCHES OF NICKEL UNDERPLATE ALL OVER UNLESS SPECIFIED OTHERWISE PRIMARY UNITS DRAWN REFERENCE IN PARENTHESES A B C D NOV27/13 BA P SEP19/14 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenolcanada.com M.E. APP'D GENERAL TOLERANCES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. C.MICHLIK MILLIMETERS CHECKED SECONDARY 6 5 Q.A. APP'D DWG APP'D 1 DECIMAL PLACE 0.35 ENG. REL. NO. 2 DECIMAL PLACES 0.25 REF. 3 DECIMAL PLACES 0.15 ANGULAR DEGREES 2 E DWG. NO. THIRD ANGLE PROJECTION DO NOT SCALE DRAWING F 6 ULTRAPORT SLIMSAS™ 4X24 R/A RECEPTACLE WITH LATCH C.MICHLIK NOV27/13 ECN TBD REV P-U10-C038-XXXX 03554 DWG SIZE: CODE ID NO. G C SCALE: M 5:1 SHEET H 1 OF 1
U10-C038-200T 价格&库存
很抱歉,暂时无法提供与“U10-C038-200T”相匹配的价格&库存,您可以联系我们找货
