U10-B074-200T
U10-B074-200T
    ARDUINO
    CONN RECEPTACLE 8X24 RIGHT ANGLE
U10-B074-200T 数据手册
A B C D E G F H REVISIONS 23.50 REV DESCRIPTION, ECN, EAR NO. DATE APP'D A PROPOSAL DEC04/13 ZLJ N DESIGN CHANGE JUL06/16 JS 1 1 7.40 13.30 2 2 1.50 (SEE LATCH PIN LENGTH OPTIONS) 22.48 1.00 4.03 3 3 1.20 6.90 5.75 1.20 5.24 7.34 2.62 0.60 12.10 1.30±0.03 0.05 L A B 4 0.66 ±0.05 TYP. (PTH) 0.08 M A B 24.20 MIN (COMPONENT KEEP OUT) U10 - B074 - X X X X OPTIONS 0T = STANDARD CONSTRUCTION (24G) WITH TAPE & REEL PACKAGING 10.95 0.35±0.03 0.05 L A B 3.00 TYP. 0.60 #74(B1) 0.15 1T= NO RESONANCE DAMPING FEATURE (12G) WITH TAPE &REEL PACKAGING #38(B37) 3.55 LATCH PTH PIN LENGTH OPTIONS 0 = 1.50 4.15 1.30 ±0.05 (NPTH) 7 = 2.20 A 3.08 8 = 3.00 5.40 5 3.55 2.10 #1(A1) #37(A37) 0.60 0.50 2.50 0.25 13.00 9 = 4.20 8.30 MIN (COMPONENT KEEP OUT) 4.45 21.90 B NOTES: 3 = 15 MICROINCHES OF GOLD ON MATING END WITH 100 MICROINCHES MINIMUM OF MATTE TIN ON SOLDER TERMINATION. 50-75 MICROINCHES OF NICKEL UNDERPLATE ALL OVER HATCH DENOTE TRACE KEEP OUT AREA UNLESS SPECIFIED OTHERWISE 1) MATERIAL: PRIMARY UNITS DRAWN MILLIMETERS CHECKED INCHES M.E. APP'D HOUSING: SOLDER REFLOW PROCESS COMPATIBLE LCP, UL94V-0 CONTACTS AND LATCH: HIGH PERFORMANCE COPPER ALLOY RESONANCE DAMPENING FEATURE: SEMI-CONDUCTIVE POLYMER SECONDARY 2)RoHS COMPLIANT 1 DECIMAL PLACE 0.2 ENG. REL. NO. 2 DECIMAL PLACES 0.10 REF. 3 DECIMAL PLACES 0.050 ANGULAR DEGREES 1 THIRD ANGLE PROJECTION THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C 5 CONTACT PLATING OPTIONS 2 = 30 MICROINCHES OF GOLD ON MATING END WITH 100 MICROINCHES MINIMUM OF MATTE TIN ON SOLDER TERMINATION. 50-75 MICROINCHES OF NICKEL UNDERPLATE ALL OVER 1.30 ±0.05 (NPTH) 6 4 D REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. E A.ALIM DEC04/13 BA P JUN11/14 ZLJ DEC04/13 ECN TBD Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenolcanada.com ULTRAPORT SLIMSAS™ 8X VERTICAL RECEPTACLE WITH LATCH PIN INSIDE – 74 POSITION DWG. NO. REV N P-U10-B074-XXXX DO NOT SCALE DRAWING CODE ID NO. F 6 03554 DWG SIZE: C G SCALE: SHEET 1 OF 1 7 H
U10-B074-200T 价格&库存
很抱歉,暂时无法提供与“U10-B074-200T”相匹配的价格&库存,您可以联系我们找货
