U95-Z105-4081-141
U95-Z105-4081-141
    ARDUINO
    CONN 2X1 CAGE GASKET LP REV
U95-Z105-4081-141 数据手册
A B C D E G F H REVISIONS AMPHENOL PART NUMBER CONFIGURATION REV DESCRIPTION, ECN, EAR NO. DATE APP'D D E Title Box Heading Modified Vent hole update for U95-Z105-XX71-X41 NOV 05/13 OCT 23/14 ZLJ JS U95-Z105-XXX1-XX1 1 1 VENT HOLES AND EMI COVER 0 = WITH LARGE VENT HOLES & WITH EMI COVER 2 = WITH SMALL VENT HOLES & WITH EMI COVER 4 = WITH RECTANGULAR VENT HOLES & WITH EMI COVER CAGE & CONNECTOR CONTACT PLATING 4 = 0.76 µm MIN. GOLD OVER 1.27-3.81 µm OF NICKEL ON MATING AREA 0.381-1.52 µm OF MATTE TIN OVER 1.27-3.81 µm OF NICKEL ON PRESS FIT TAIL AREA. Ni PLATING FOR CAGE (RoHS COMPLIANT PER RoHS DIRECTIVE 2011/65/EU) EMI GASKET 1 = CHOMERICS 1273 CONDUCTIVE ELASTOMER 2 = CHOMERICS S6305 CONDUCTIVE ELASTOMER OPTIONAL LIGHT PIPES 6 = WITH LIGHT PIPE (TRIANGULAR OUTLET) LEFT ARROW POINTING BOTTOM PORT & RIGHT ARROW POINTING TOP PORT 7 = WITHOUT LIGHT PIPE 8 = WITH LIGHT PIPE (REVERSED DIRECTION) LEFT ARROW POINTING TOP PORT & RIGHT ARROW POINTING BOTTOM PORT OPTIONAL DUST COVER 0 = WITHOUT DUST COVER D = WITH DUST COVER 2 3 2 VENT HOLE FOR PART NUMBER U95-Z105-XX71-X01 VENT HOLE FOR PART NUMBER U95-Z105-XX71-X21 VENT HOLE FOR PART NUMBER U95-Z105-XX71-X41 VENT HOLE FOR PART NUMBER U95-Z105-XX61-X01 VENT HOLE FOR PART NUMBER U95-Z105-XX61-X21 VENT HOLE FOR PART NUMBER U95-Z105-XX61-X41 3 4 4 VENT HOLE FOR PART NUMBER U95-Z105-XX81-X01 VENT HOLE FOR PART NUMBER U95-Z105-XX81-X21 VENT HOLE FOR PART NUMBER U95-Z105-XX81-X41 5 5 NOTES: 1. MATERIAL CAGE-PRESS FIT: COPPER ALLOY, NICKEL PLATED CONNECTOR-PRESS FIT: PLASTIC HOUSING, FLAMMABILITY RATING UL94 V-0. CONTACTS: PHOSPHOR BRONZE PLATING OPTION: SEE AMPHENOL PART ON CONFIGURATION 6 DRAWN UNLESS SPECIFIED OTHERWISE EMI GASKET: CONDUCTIVE ELASTOMER LIGHT PIPE: GE LEXAN, OPTICAL GRADE PRIMARY UNITS SECONDARY DUST COVER (IF ORDERED) SHIPPED LOOSE MILLIMETERS CHECKED MILLIMETERS M.E. APP'D REFERENCE IN PARENTHESES GENERAL TOLERANCES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D APR 18/13 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com UltraPort QSFP+ 2X1 STACKED COMBO WITH EMI GASKET 4X25G DWG APP'D 0.25 ENG. REL. NO. 2 DECIMAL PLACES 0.15 REF. E APR 18/13 ZLJ Q.A. APP'D 1 DECIMAL PLACE ANGULAR DEGREES Alvin C 0.5 6 DWG. NO. THIRD ANGLE PROJECTION DO NOT SCALE DRAWING F REV P-U95-Z105-XXX1-XX1 03554 DWG SIZE: CODE ID NO. G C SCALE: 1:1 E SHEET H 1 OF 4 A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE APP'D D E Title Box Heading Modified Vent hole update for U95-Z105-XX71-X41 NOV 05/13 OCT 23/14 ZLJ JS 1 1 PART NUMBER DATE CODE 73.2 2 2 19.4 3 3 24.4 4 4 30.1 25.1 25.7 1.25 SIGNAL PINS ON CONNECTOR 2.50 LOCATING POST 56.25 2.00 PRESS FIT PINS ON CAGE 5 DRAWN UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 MILLIMETERS CHECKED MILLIMETERS M.E. APP'D REFERENCE IN PARENTHESES GENERAL TOLERANCES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D APR 18/13 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com UltraPort QSFP+ 2X1 STACKED COMBO WITH EMI GASKET 4X25G DWG APP'D 0.25 ENG. REL. NO. 2 DECIMAL PLACES 0.15 REF. E APR 18/13 ZLJ Q.A. APP'D 1 DECIMAL PLACE ANGULAR DEGREES Alvin C 0.5 5 6 DWG. NO. DO NOT SCALE DRAWING THIRD ANGLE PROJECTION F REV P-U95-Z105-XXX1-XX1 03554 DWG SIZE: CODE ID NO. G C SCALE: 1:1 E SHEET H 2 OF 4 A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE APP'D D E Title Box Heading Modified Vent hole update for U95-Z105-XX71-X41 NOV 05/13 OCT 23/14 ZLJ JS 1 CROSS HATCHED REPRESENTS TRACE KEEP OUT AREA Y 2.50±0.05(2X) TH 2 CROSS HATCHED REPRESENTS TRACE KEEP OUT AREA (CAGE PRESS FIT PINS) 0.00 4.70 9.50 14.30 19.00 1 0.37±0.05(76X) PTH 0.10 M Z X Y 1.57 MIN A 0.80 (TYP) 0.56±0.05(9X) PTH 0.10 M Z X Y 1.05±0.05(10X) PTH 0.10 M Z X Y 2.10 (TYP) 2 37 12.85 4.85 21 2 0.00 1 PIN 1 TOP PORT X (66.07) CONNECTOR OUTLINE 3 18 21 2 1 26.30 1.92 1.22 0.52 0.00 19 3 3 5.92 5.22 4.52 20 38 49.10 MAX 9.92 9.22 8.52 19 37 PIN 1 BOTTOM PORT 17.30 13.92 13.22 12.52 20 38 8.85 6.60 1.60 (TYP) 2.00(3X) 16.70 16.65 3 2.00(3X) 0.30(3X) 18 0.30(4X) 2.00(4X) 35.30 1.45 2.35 (2X) 2.30 (2X) 4 4 44.30 (19.90) CONNECTOR OUTLINE 2.50 (10X) 0.30(10X) CROSS HATCHED REPRESENTS LED SOLDER PAD SEATING AREA 5 0.33 0.00 1.73 4.13 7.63 11.13 14.63 RECOMMENDED PCB BOARD LAYOUT COMPONENT SIDE SHOWN 17.27 18.67 Z 0.81±0.05(4X) PTH 0.10 M Z X Y 2.00(4X) 5 DETAIL A SCALE 6 : 1 DRAWN UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 MILLIMETERS CHECKED MILLIMETERS M.E. APP'D REFERENCE IN PARENTHESES GENERAL TOLERANCES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D APR 18/13 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com UltraPort QSFP+ 2X1 STACKED COMBO WITH EMI GASKET 4X25G DWG APP'D 0.25 ENG. REL. NO. 2 DECIMAL PLACES 0.15 REF. E APR 18/13 ZLJ Q.A. APP'D 1 DECIMAL PLACE ANGULAR DEGREES Alvin C 0.5 6 DWG. NO. DO NOT SCALE DRAWING THIRD ANGLE PROJECTION F REV P-U95-Z105-XXX1-XX1 03554 DWG SIZE: CODE ID NO. G C SCALE: 2:1 E SHEET H 3 OF 4 A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE APP'D D E Title Box Heading Modified Vent hole update for U95-Z105-XX71-X41 NOV 05/13 OCT 23/14 ZLJ JS 1 1 2 2 0.20±0.10 PCB TOP SURFACE TO PANEL OPENING 6.00±0.30 54.95 3 3 19.85±0.10 4.65 R0.30MAX. (TYP) 4 4 25.51±0.10 5 5 24.50 DRAWN UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 MILLIMETERS CHECKED MILLIMETERS M.E. APP'D REFERENCE IN PARENTHESES GENERAL TOLERANCES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D APR 18/13 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com UltraPort QSFP+ 2X1 STACKED COMBO WITH EMI GASKET 4X25G DWG APP'D 0.25 ENG. REL. NO. 2 DECIMAL PLACES 0.15 REF. E APR 18/13 ZLJ Q.A. APP'D 1 DECIMAL PLACE ANGULAR DEGREES Alvin C 0.5 6 DWG. NO. DO NOT SCALE DRAWING THIRD ANGLE PROJECTION F REV P-U95-Z105-XXX1-XX1 03554 DWG SIZE: CODE ID NO. G C SCALE: 1:1 E SHEET H 4 OF 4
U95-Z105-4081-141 价格&库存
很抱歉,暂时无法提供与“U95-Z105-4081-141”相匹配的价格&库存,您可以联系我们找货
