FS1-R38-20A2-00
FS1-R38-20A2-00
    ARDUINO
    EXPRESSPORT QSFP+ CONN 10G 38POS
FS1-R38-20A2-00 数据手册
7 8 6 5 3 4 1 2 REVISIONS 18.20 1.14 MIN. (11.50) 16.60 REV. ECN B C D E10141 DESCRIPTION DATE PROPOSAL DRAWING HOLD DOWN TAB CONFIGURATION ADDED UPPER SHORTING BAR REMOVED APPROVED 15/APR/10 YK 15/APR/10 YK 29/APR/10 YK 5.80 F F 5.35 6.30 2.93 5.49±0.20 E 0.3 8.14±0.20 0.3 C D (16.80) 0.90±0.05 E 0.10 C D 1.45±0.050 D 1.45±0.05 PART NUMBER NOISE CANCELLATION FEATURE FS1-R38-20A2-10 YES FS1-R38-20A2-00 NO FS1-R38-30A2-10 YES FS1-R38-30A2-00 NO CONTACT PLATING PACKAGING D 30μ" GOLD OVER 50μ" NICKEL IN CONTACT AREAS 100μ" MATTE TIN OVER 50μ" NICKEL IN SOLDER AREAS TAPE AND REEL (8.60) 11.50 15μ" GOLD OVER 50μ" NICKEL IN CONTACT AREAS 100μ" MATTE TIN OVER 50μ" NICKEL IN SOLDER AREAS C C 17.37 REF. 1.14 REF. 0.80 1.27 REF. 0.29 REF. 0.35±0.030 0.05 L A B NOTES: 1) MATERIAL: HOUSING: SOLDER REFLOW PROCESS COMPATIBLE LCP, UL94V-0 CONTACTS: PHOSPHOR BRONZE 1.80±0.030 0.05 L A B B 8.15 REF. B 3) PERFORMANCE: 2.51 5.18 ELECTRICAL: 0.5 AMPS MAX. PER CONTACT A 0.40 1 MECHANICAL: 250 MATING CYCLES MINIMUM 2X 2.03 REF. ( 2) ROHS COMPLIANT 1.55±0.050 4) COMPLIES WITH SFF-8436 SPECIFICATION 2.11 REF. 1.55) B A KEEPOUT ZONE IN HATCHED AREAS NO TRACES OR INK MARKING ALLOWED 1.78 REF. DECIMALS 16.80±0.050 7 .X .XX DO NOT SCALE DRAWING 0.25 0.13 ANGLES 2 K.SOBEL DESIGNED YK DATE Amphenol Canada Corp. 15/APR/10 21/APR/06 TITLE CHECKED MATERIAL AND FINISH EXPRESS PORT, QSFP+ 38 POSITION CONNECTOR QA APP'D RECOMMENDED PCB LAYOUT FOR FS1-R38-X0A2-X0 8 APPROVALS UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILIMETERS TOLERANCES ARE: DRAWN 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. ENG.REL.NO. EAR 12923 CODE IDENT. NO. 5 4 3 03554 IE APP'D DWG APP'D 2 SIZE C SCALE DWG. NO. REV. D P-FS1-R38-X0A2-XX PROJECT SHEET 1 OF 2 FS1 NTS 1 A 7 8 6 5 3 4 1 2 REVISIONS REV. ECN D DATE SEE SHEET 1 29/APR/10 APPROVED YK (11.50) 18.20 1.14 MIN. DESCRIPTION 16.60 5.80 F F 5.30 5.35 6.30 0.05±0.05 2.93 2.64 14.39 E E 5.49±0.20 0.3 8.14±0.20 0.3 C D (16.80) 0.10 C D 1.45±0.050 0.90±0.05 D 1.45±0.05 PART NUMBER NOISE CANCELLATION FEATURE FS1-R38-20A2-11 YES FS1-R38-20A2-01 NO FS1-R38-30A2-11 YES FS1-R38-30A2-01 NO CONTACT PLATING PACKAGING D 30μ" GOLD OVER 50μ" NICKEL IN CONTACT AREAS 100μ" MATTE TIN OVER 50μ" NICKEL IN SOLDER AREAS TAPE AND REEL (8.60) 2 PCS. SOLDER TABS 11.50 15μ" GOLD OVER 50μ" NICKEL IN CONTACT AREAS 100μ" MATTE TIN OVER 50μ" NICKEL IN SOLDER AREAS C C 17.37 REF. 1.14 REF. 0.40 0.80 1.27 REF. 0.29 REF. 0.35±0.030 0.05 L A B NOTES: 1.80±0.030 0.05 L A B 1) MATERIAL: HOUSING: SOLDER REFLOW PROCESS COMPATIBLE LCP, UL94V-0 CONTACTS: PHOSPHOR BRONZE 1 B 8.15 REF. 1.22±0.05 2 PLC. 0.10 L A B 5.18 2.69 14.89 A 1.55±0.050 1.55±0.05 KEEPOUT ZONE IN HATCHED AREAS NO TRACES OR INK MARKING ALLOWED 1.78 REF. APPROVALS UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILIMETERS TOLERANCES ARE: DRAWN DECIMALS .X .XX DO NOT SCALE DRAWING 0.25 0.13 ANGLES 2 K.SOBEL DESIGNED YK DATE Amphenol Canada Corp. 15/APR/10 21/APR/06 TITLE CHECKED MATERIAL AND FINISH EXPRESS PORT, QSFP+ 38 POSITION CONNECTOR QA APP'D RECOMMENDED PCB LAYOUT FOR FS1-R38-X0A2-X1 7 ELECTRICAL: 0.5 AMPS MAX. PER CONTACT MECHANICAL: 250 MATING CYCLES MINIMUM 16.80±0.050 8 A B 4) COMPLIES WITH SFF-8436 SPECIFICATION 2X B B 3) PERFORMANCE: 2.11 REF. 1.55) A 2) ROHS COMPLIANT 0.96 2.03 REF. ( 1.72±0.05 2 PLC. 0.10 L 2.51 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. ENG.REL.NO. EAR 12923 CODE IDENT. NO. 5 4 3 03554 IE APP'D DWG APP'D 2 SIZE C SCALE DWG. NO. REV. P-FS1-R38-X0A2-XX D PROJECT SHEET 2 OF 2 FS1 NTS 1 A
FS1-R38-20A2-00 价格&库存
很抱歉,暂时无法提供与“FS1-R38-20A2-00”相匹配的价格&库存,您可以联系我们找货
