U90-B105-4071-110
U90-B105-4071-110
    ARDUINO
    CONN QSFP+ RCPT W/CAGE 2X1 R/A
U90-B105-4071-110 数据手册
A B C D E G F AMPHENOL PART NUMBER CONFIGURATION U90-B105-XXX1-XX0 1 CAGE & CONNECTOR CONTACT PLATING 2 = 0.76 μm MIN. GOLD ON MATING AREA, 3.81-7.62 μm TIN/LEAD ON TERMINATION. Ni PLATING FOR CAGE VENT HOLES AND EMI COVER 0 = WITH LAGE HOLES & WITH EMI COVER 1 = WITH LARGE VENT HOLES, NO EMI COVER 2 = WITH SMALL VENT HOLES & WITH EMI COVER 3 = WITH SMALL VENT HOLES, NO EMI COVER 4 = WITH RECTANGULAR VENT HOLES & WITH EMI COVER 5 = WITH RECTANGULAR VENT HOLES, NO EMI COVER 6 = WITH LARGE VENT HOLES & HEAT SINK 3 = 0.38 μm MIN. GOLD ON MATING AREA, 3.81-7.62 μm TIN/LEAD ON TERMINATION. Ni PLATING FOR CAGE 4 = 0.76 μm MIN. GOLD OVER 1.27-3.81 μm OF NICKEL ON MATING AREA 0.381-1.52 μm OF MATTE TIN OVER 1.27-3.81 μm OF NICKEL ON PRESS FIT TAIL AREA. Ni PLATING FOR CAGE PART # U90-B105-XD71-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITH DUST COVER AND WITHOUT LIGHT PIPE) PROPOSAL DRAWING DATE APP'D NOV 20,10 AG B PCB DIMENSION 6.60 IN D3,P3 WAS 6.0 MAR 11,11 AG C U90-B105-XD71 VIEW CORRECTED APR 29, 11 AG D UPDATED WITH NEW PART NUMBERING SYSTEM JUN 02, 11 ZL E LARGE VENT HOLE CONFIGURATION ADDED JUN 16, 11 ZL F RECTANGULAR VENT HOLE CONFIGURATION ADDED SEP 13, 11 ZL JAN 24, 12 ZL H NO GASKET NO GASKET SUPPORT CONFIGURATION ADDED OTHER CONFIGURATION ADDED FEB 09, 12 ZL 1 J HEAT SINK CONFIGURATION ADDED MAY 10/12 KH K AHSI DESIGNATION ADDED MAY 17/12 ZLJ L FLAMMABILITY RATING FOR LP & EMI GASKET 1273 ADDED MAY 28/12 ZLJ REFERENCE VIEW FOR OPTION 6 ONLY 2 REFERENCE VIEW FOR OPTION 8 ONLY PART # U90-B105-X061-030 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE, NO GASKET AND NO GASKET SUPPORT) PART # U90-B105-X071-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITHOUT LIGHT PIPE) PART # U90-B105-X071-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITHOUT LIGHT PIPE) DESCRIPTION, ECN, EAR NO. A THIS IS A CAD DRAWING. DO NOT MANUALLY REVISE. OPTIONAL LIGHT PIPES 6 = WITH LIGHT PIPE (TRIANGULAR OUTLET) LEFT ARROW POINTING BOTTOM PORT & RIGHT ARROW POINTING TOP PORT (UL RATED 94-V0) 7 = WITHOUT LIGHT PIPE 8 = WITH LIGHT PIPE (REVERSED DIRECTION) LEFT ARROW POINTING TOP PORT & RIGHT ARROW POINTING BOTTOM PORT ((UL RATED 94-V0) 2 REV G EMI GASKET 0 = NO GASKET, NO GASKET SUPPORT 1 = CHOMERICS 1273 CONDUCTIVE ELASTOMER; UL RATED 94-V0 2 = CHOMERICS S6305 CONDUCTIVE ELASTOMER OPTIONAL DUST COVER 0 = WITHOUT DUST COVER D = WITH DUST COVER H REVISIONS 3 3 OPTIONAL DUST COVER P/N U79-111-9000-P (SHIPPED LOOSE) PART # U90-B105-X061-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B105-X061-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B105-X061-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) 4 4 PART # U90-B105-X081-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B105-X081-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B105-X081-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) 5 5 NOTES: 1. MATERIAL CAGE-PRESS FIT: COPPER ALLOY, NICKEL PLATED CONNECTOR-PRESS FIT: PLASTIC HOUSING,FLAMMABILITY RATING UL94 V-0. CONTACTS : PHOSPHOR BRONZE PLATING OPTION: SEE AMPHENOL PART NO CONFIGURATION 6 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS EMI GASKET: CONDUCTIVE ELASTOMER; FOR FLAMMABILITY RATING SEE AMPHENOL PART NUMBER CONFIGURATION SECONDARY EMI FINGERS: PHOSPHOR BRONZE WITH NICKEL PLATING LIGHT PIPE: GE LEXAN, OPTICAL GRADE; UL RATED 94-V0 B Q.A. APP'D DWG APPR. 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A REFERENCE IN PARENTHESES GENERAL TOLERANCES 1. DECIMAL PLACE 2. CONNECTOR AND CAGE ASSEMBLY IS RoHS COMPLIANT. C D DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 3. ANGULAR DEGREES 4. ANGULAR DEGREES E 0.X 0.25 ENG. REL. NO. 0.XX 0.13 NOV 18,10 S.M NOV 19,10 A.G NOV 20,10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X1 STACKED COMBO 6 DWG. NO. REF. X 1 X.X 0.5 Hisen.X THIRD ANGLE PROJECTION F REV L P-U90-B105-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. 03554 DWG SIZE: C G SCALE: SHEET 1 OF 4 4:1 H A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. L SEE PAGE 1 DATE MAY 28/12 APP'D ZLJ 19.75 1 1 PART NUMBER DATE CODE 2 2 72.97 (1.0) (4X) 3 3 PART # U90-B105-X061-X30 SHOWN 19.41 24.35 4 4 8.80±.1 (2X) 2.00±0.05 TYP +0.15 18.60 - 0.05 30.05 15.45 15.45 15.45 24.95 25.60 9.37 A 5 3.75 2.74 24.35 6.25 9.00 (3X) 2.00 10.70 5 1.25 2.06 0.8 TYP. 12.21 44.30 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 1. DECIMAL PLACE 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 3. ANGULAR DEGREES 4. ANGULAR DEGREES E 0.X 0.25 ENG. REL. NO. 0.XX 0.13 NOV 18,10 S.M NOV 19,10 A.G NOV 20,10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X1 STACKED COMBO 6 DWG. NO. REF. X 1 X.X 0.5 Hisen.X P-U90-B105-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. THIRD ANGLE PROJECTION F 03554 DWG SIZE: C G SCALE: 4:1 REV K SHEET 2 OF 4 H A B C D E G F H REV DESCRIPTION, ECN, EAR NO. DATE L SEE PAGE 1 MAY 28/12 APP'D ZLJ 0 Y 1 1.57 MIN 2.30 1 0.80 TYP. 0.37±0.05 (76X) PTH 0.10 M X Y 2 0 0.41 17.35 19.00 REVISIONS 2 1.60 TYP. 2.50±0.05 (2X) TH 21 37 38 0 13.45 20 12.25 X 3 PIN 1 TOP PORT 6.60 2 1 18 3 37 1.05±0.05 (10X) PTH 0.10 M X Y 8.25 21 38 5.45 20 4.25 17.30 2 4 1 18 1.45 0.25 0 19 3 3 9.45 19 4 26.30 PIN 1 BOTTOM PORT 1.72 3.30(2X) 35.30 1.20 CROSS HATCHED REPRESENTS LED SOLDER PAD SEATING AREA 5 44.30 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. C D DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 1. DECIMAL PLACE B 5 1.25(4X) DETAIL A SCALE 8 : 1 RECOMMENDED PCB BOARD LAYOUT COMPONENT SIDE SHOWN A 1.03 3.37 0.90(2X) 3. ANGULAR DEGREES 4. ANGULAR DEGREES E 0.X 0.25 ENG. REL. NO. 0.XX 0.13 NOV 18,10 S.M NOV 19,10 A.G NOV 20,10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X1 STACKED COMBO 6 DWG. NO. REF. X 1 X.X 0.5 Hisen.X P-U90-B105-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. THIRD ANGLE PROJECTION F 03554 DWG SIZE: C G SCALE: 4:1 REV K SHEET 3 OF 4 H A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. L DATE MAY 28/12 SEE PAGE 1 APP'D ZLJ 1 1 PANEL CUTOUT BOTTOM LATCH 0.27±0.10 2 2 PCB CAGE ASSEMBLY DETAIL B SCALE 6 : 1 FRONT PANEL (CUSTOMER SUPPLIED) PCB (CUSTOMER SUPPLIED) 3 3 LIGHT PIPE 19.85 ELASTOMER EMI GASKET 71.88 4 4 25.60 25.51 5 5 1.57 MIN 37.0 MAX. B 43.00±0.30 RECOMMENDED PANEL CUTOUT UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 1. DECIMAL PLACE 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 3. ANGULAR DEGREES 4. ANGULAR DEGREES E 0.X 0.25 ENG. REL. NO. 0.XX 0.13 NOV 18,10 S.M NOV 19,10 A.G NOV 20,10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X1 STACKED COMBO 6 DWG. NO. REF. X 1 X.X 0.5 Hisen.X P-U90-B105-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. THIRD ANGLE PROJECTION F 03554 DWG SIZE: C G SCALE: 4:1 REV K SHEET 4 OF 4 H
U90-B105-4071-110
PDF文档中包含的物料型号是ATMEGA16U2,它是一款基于AVR®增强型ATmega16U2单片机的USB2.0 AVR MCU。
器件简介指出ATMEGA16U2内置8KB SRAM和512KB的系统内可编程Flash,支持宽工作电压范围和高速的USB通信。
引脚分配描述了各引脚的功能,例如PCINT24/GND、PCINT25/UG磐、VCC、EVOUT、AREF等。
参数特性包括工作电压范围、时钟频率、I/O数、USB接口等。
功能详解说明了ATMEGA16U2的引脚功能、内部模块和外设功能。
应用信息提供了该芯片在电子设备中的使用场景,如USB通信接口、数据采集等。
封装信息显示了ATMEGA16U2的封装类型,如QFN44。
U90-B105-4071-110 价格&库存
很抱歉,暂时无法提供与“U90-B105-4071-110”相匹配的价格&库存,您可以联系我们找货
