QSFP8-038-01-L-D-RA1
    SAMTEC(申泰)
    SMD,P=0.8mm(交错脚)
QSFP8-038-01-L-D-RA1 数据手册
REVISION L DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] QSFP8-XXX-01-X-D-RA1-XX "A" REF "B" REF C C 0.800 .0315 (TYP) (TOL. NON-ACCUM.) C "C" "D" "E" PIN 38 DO NOT SCALE FROM THIS PRINT C CL PIN 20 "A" "B" ROW SPECIFICATION -D: DOUBLE ROW (* = NOT TOOLED) PIN 19 "B" 0.400 .0157 (TYP) 0.95 .037 REF "A" "F" REF 0.400 .0157 (TYP) CL C 0.40±0.10 .016±.004 (MEASURED CONTACT TO CONTACT) 3.22 .127 REF 1.40 .055 REF C-342-02-X 1.40 .055 REF QSFP-XXX 3.50 .138 REF C 0.10 [.004] 8.60 .339 REF 0.30 .012 REF C C "G" "H" C 11.50±0.05 .453±.002 C FIG 1 SECTION "A"-"A" SCALE 5 : 1 QSFP8-038-01-X-D-RA1 SHOWN "J" UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 1.11N[0.25 LB]. 3. NOTE DELETED. 4. TUBES ARE STANDARD PACKAGING. 5. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM 6. ATTACH LABEL TO EACH REEL C 1.69 .066 REF 0.20 .008 (TYP) REF C 0.05±0.13 .002±.005 1.42 .056 REF 1.00 .039 REF 0.80 .031 (TYP) (TOL. NON-ACCUM.) PACKAGING BLANK: TUBES (SEE NOTE 4) -TR: TAPE & REEL (SEE NOTE 5 & 6) -FR: FULL REEL QTY TAPE & REEL (SEE NOTE 5 & 6) SMT TYPE -RA1: RIGHT ANGLE PLATING SPECIFICATION -L: 10u" MIN Au/50u"Ni IN CONTACT, TIN ON TAIL 5.35 .211 REF PIN 01 1.10 .043 REF LEAD STYLE -01 1.30 .051 REF 3.70 .146 REF POSITION 1 INDICATOR No OF POSITIONS *-020, -038, *-100 (TOTAL NUMBER OF POSITIONS) ANGLES X.X: 0.3 [.01] 2 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, COLOR: BLACK CONTACT: PHOS BRONZE F:\DWG\MISC\MKTG\QSFP8-XXX-01-X-D-RA1-XX-MKT.SLDDRW SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: QSFP8 ASM DWG. NO. QSFP8-XXX-01-X-D-RA1-XX BY: ROY LUO 7/20/2010 SHEET 1 OF 2 REVISION L C-342-01-X C-342-01-X QSFP-XXX-C 3.30±0.51 .130±.020 C 0.05±0.13 .002±.005 C 9.15±0.08 .360±.003 1.67 .066 REF C 1.17 .046 REF IN-PROCESS 1 (FILL QSFP-XXX-C) SECTION "B"-"B" SCALE 5 : 1 (SAME AS SECTION "A"-"A", EXCEPT AS SHOWN) QSFP-XXX-C C 0.30±0.05 .012±.002 TP-03 11.44±0.08 .450±.003 C PACKAGING VEIW IN-PROCESS 2 (FILL QSFP-XXX-C) PT-1-24-02-44 FILL QSFP-XXX-C VOIDS FACING OUT * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 F:\DWG\MISC\MKTG\QSFP8-XXX-01-X-D-RA1-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: QSFP8 ASM DWG. NO. QSFP8-XXX-01-X-D-RA1-XX BY: ROY LUO 7/20/2010 SHEET 2 OF 2
QSFP8-038-01-L-D-RA1 价格&库存
很抱歉,暂时无法提供与“QSFP8-038-01-L-D-RA1”相匹配的价格&库存,您可以联系我们找货
    • 1+54.10800
    • 10+52.80120
    • 31+51.92640
    库存:6
    • 1+77.824311+10.04558
    • 10+66.1324510+8.53640
    • 25+61.9877525+8.00140
    • 50+59.0260550+7.61910
    • 100+56.20932100+7.25552
    • 250+52.69126250+6.80140
    • 500+50.22197500+6.48267
    库存:631
