UE86-3G6620-10361
UE86-3G6620-10361
    ARDUINO
    CAGE/CONN 2X6 4 NORML EMI FINGER
UE86-3G6620-10361 数据手册
1 2 3 AMPHENOL PART NUMBER CONFIGURATION UE86 - 3G 6 6 2 0 - X 0 X 6 1 LIGHT PIPE OPTION 0 - NO LIGHT PIPE 1 - 4 LP PER 2X1, NORMAL ORIENTATION 2 - 2 INNER LP PER 2X1, NORMAL ORIENTATION 3 - 2 OUTER LP PER 2X1, NORMAL ORIENTATION 4 - 4 LP PER 2X1, REVERSING ORIENTATION 5 - 2 INNER LP PER 2X1, REVERSING ORIENTATION 6 - 2 OUTER LP PER 2X1, REVERSING ORIENTATION 7 - 3 LP PER 2X1, 2 OUTER LP, NORMAL ORIENTATION 8 - 3 LP PER 2X1, 2 OUTER LP, REVERSING ORIENTATION A 4 REV. A B C PACKAGING 1 - TRAY PACKAGING (STACKED) 5 6 REVISIONS ECN DESCRIPTION INITIAL RELEASE UPDATE PLATING OPTIONS UPDATE NOTES PLATING OPTIONS FOR CONNECTOR 2 - 30µ" GOLD PLATING ON MATING AREA 15~100µ" MATTE TIN ON TERMINATION 3 - 30µ" GOLD PLATING ON MATING AREA 150~300µ" MATTE TIN ON TERMINATION 5 - 15µ" GOLD PLATING ON MATING AREA 15~100µ" MATTE TIN ON TERMINATION 6 - 15µ" GOLD PLATING ON MATING AREA 150~300µ" MATTE TIN ON TERMINATION DATE 02/12/2014 JUN 25/14 AUG 19/14 APPROVED J. SI J.SI J.SI A PART NUMBER (LAST DIGIT INDICATING PACKAGING TYPE, NOT PRINTED ON THE PART) DATE CODE 4 LIGHT PIPES UE86-3G6620-10361 NO LIGHT PIPES UE86-3G6620-00361 B B 2 INNER LIGHT PIPES UE86-3G6620-20361 2 OUTER LIGHT PIPES UE86-3G6620-30361 3 LIGHT PIPES UPSIDE DOWN UE86-3G6620-80361 C C MATERIAL: (RoHS COMPLIANT) 2 INNER LIGHT PIPES UPSIDE DOWN UE86-3G6620-50361 4 LIGHT PIPES UPSIDE DOWN UE86-3G6620-40361 1. CAGE - PRESS FIT: COPPER ALLOY (NICKEL SILVER) 2. CONNECTOR - PRESS FIT: - PLASTIC HOUSING: LCP, FLAMMABILITY RATING UL94-V0 - CONTACTS: PHOSPHOR BRONZE 3. LIGHT PIPE: CLEAR POLYCABONATE, FLAMMABILITY RATING UL94-V0 4. PACKAGING: TRAY PACKAGING 5. TEMPERATURE RANGE: -40°C TO +85°C 3 LIGHT PIPES UE86-3G6620-70361 2 OUTER LIGHT PIPES UPSIDE DOWN UE86-3G6620-60361 D UNLESS SPECIFIED OTHERWISE DIMENSIONS ARE IN MILLIMETERS DRAWN REFERENCE IN PARENTHESES M.E. APP'D GENERAL TOLERANCES Q.A. APP'D 1 DECIMAL PLACE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR  USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 1 2 3 2 DECIMAL PLACE 3 DECIMAL PLACE ANGULAR DEGREES ENG. REL. NO. CHECKED P. OU J. SI FEB10/14 J. SI FEB 12/14 0.25 DWG APP'D 0.15 MATERIAL AND FINISH N/A 1 REF. THIRD ANGLE PROJECTION FEB 12/14 SEE NOTES ECN Exxxxx Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenolcanada.com 2X6 SFP ULTRAPORT WITH LIGHT PIPE OPTIONS AND EMI SPRING FINGER DWG. NO. DO NOT SCALE DRAWING CODE ID NO. P-UE86-3G6620-X0X61 03554 DWG SIZE: A4 SCALE: 2:3 REV C SHEET 1 OF 5 1 2 3 4 REV. A B C 5 6 REVISIONS ECN DESCRIPTION INITIAL RELEASE UPDATE PLATING OPTIONS UPDATE NOTES DATE 02/12/2014 JUN 25/14 AUG 19/14 APPROVED J. SI J.SI J.SI A A 87.51 T20 T11 T1 T10 INNER LIGHT PIPE INNER LIGHT PIPE OUTER LIGHT PIPE OUTER LIGHT PIPE 86.25 +0.05 0.50 - 0.08 S T (TYP.) B10 B INNER LIGHT PIPE (OR MIDDLE LIGHT PIPE) B1 B11 OUTER LIGHT PIPE B B20 3.50(TYP.) MIDDLE PIN 3.50(TYP.) MIDDLE PIN 9.80(TYP.) 0.70 DETAIL A SCALE 2 : 1 2.01 2.60 3.00 10.29 3.50(TYP.) DETAIL B SCALE 2 : 1 14.00±0.10(TYP.) A C C 8.95±0.15(TYP.) 25.50 25.00 26.76 B 11.50 8.95±0.15(TYP.) 3.50(TYP.) REAR PIN 0.75(TYP.) 8.00(TYP.) 3.50(TYP.) REAR PIN 85.25 36.45 38.29 51.57 D UNLESS SPECIFIED OTHERWISE DIMENSIONS ARE IN MILLIMETERS DRAWN REFERENCE IN PARENTHESES M.E. APP'D GENERAL TOLERANCES Q.A. APP'D 1 DECIMAL PLACE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR  USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 1 2 3 2 DECIMAL PLACE 3 DECIMAL PLACE ANGULAR DEGREES ENG. REL. NO. CHECKED P. OU J. SI FEB10/14 J. SI FEB 12/14 0.25 DWG APP'D 0.15 MATERIAL AND FINISH N/A 1 REF. THIRD ANGLE PROJECTION FEB 12/14 SEE NOTES ECN Exxxxx Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenolcanada.com 2X6 SFP ULTRAPORT WITH LIGHT PIPE OPTIONS AND EMI SPRING FINGER DWG. NO. DO NOT SCALE DRAWING CODE ID NO. P-UE86-3G6620-X0X61 03554 DWG SIZE: A4 SCALE: 1:1 REV C SHEET 2 OF 5 1 2 3 5 REV. A B C 86.75±0.10 C A 4 6 REVISIONS ECN DESCRIPTION INITIAL RELEASE UPDATE PLATING OPTIONS UPDATE NOTES DATE 02/12/2014 JUN 25/14 AUG 19/14 APPROVED J. SI J.SI J.SI A 1.70±0.90 26.00±0.10 D 2.36 B B 3.50±0.30 C SECTION C-C 0.00±0.10 (BEZEL OPENING FLUSH WITH TOP SIDE OF PCB) 1.25 C C DETAIL D SCALE 2 : 1 88.00 MIN. D UNLESS SPECIFIED OTHERWISE DIMENSIONS ARE IN MILLIMETERS DRAWN REFERENCE IN PARENTHESES M.E. APP'D GENERAL TOLERANCES Q.A. APP'D 1 DECIMAL PLACE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR  USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 1 2 3 2 DECIMAL PLACE 3 DECIMAL PLACE ANGULAR DEGREES ENG. REL. NO. CHECKED P. OU J. SI FEB10/14 J. SI FEB 12/14 0.25 DWG APP'D 0.15 MATERIAL AND FINISH N/A 1 REF. THIRD ANGLE PROJECTION FEB 12/14 SEE NOTES ECN Exxxxx Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenolcanada.com 2X6 SFP ULTRAPORT WITH LIGHT PIPE OPTIONS AND EMI SPRING FINGER DWG. NO. DO NOT SCALE DRAWING CODE ID NO. P-UE86-3G6620-X0X61 03554 DWG SIZE: A4 SCALE: 1:1 REV C SHEET 3 OF 5 1 2 3 4 REV. A B C A 9.80 Y 12X 3.50 1.60±0.03 5 6 REVISIONS ECN DESCRIPTION INITIAL RELEASE UPDATE PLATING OPTIONS UPDATE NOTES APPROVED J. SI J.SI J.SI A X 3.50 NOTES: E 13.28 DATE 02/12/2014 JUN 25/14 AUG 19/14 1. 0.56 mm DIAMETER HOLES ARE CHASSIS GROUND (99HOLES). 3X 3.50 0.50 COMPONENT KEEP-OUT AREAS 1.72 B B 6.29 COMPONENT KEEP-OUT AREAS 58.00 4X 8.00 99X 0.56±0.05(TYP.) 0.10 M X Y C C 4.50 7.125 6X 14.25 87.50 2X6 PCB LAYOUT D UNLESS SPECIFIED OTHERWISE DIMENSIONS ARE IN MILLIMETERS DRAWN REFERENCE IN PARENTHESES M.E. APP'D GENERAL TOLERANCES Q.A. APP'D 1 DECIMAL PLACE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR  USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 1 2 3 2 DECIMAL PLACE 3 DECIMAL PLACE ANGULAR DEGREES ENG. REL. NO. CHECKED P. OU J. SI FEB10/14 J. SI FEB 12/14 0.25 DWG APP'D 0.15 MATERIAL AND FINISH N/A 1 REF. THIRD ANGLE PROJECTION FEB 12/14 SEE NOTES ECN Exxxxx Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenolcanada.com 2X6 SFP ULTRAPORT WITH LIGHT PIPE OPTIONS AND EMI SPRING FINGER DWG. NO. DO NOT SCALE DRAWING CODE ID NO. P-UE86-3G6620-X0X61 03554 DWG SIZE: A4 SCALE: 3:2 REV C SHEET 4 OF 5 1 2 3 4 REV. A B C A 40X 3.95 0.37±0.05 0.05 M 5 6 REVISIONS ECN DESCRIPTION INITIAL RELEASE UPDATE PLATING OPTIONS UPDATE NOTES DATE 02/12/2014 JUN 25/14 AUG 19/14 APPROVED J. SI J.SI J.SI A 3.95 X Y LED KEEP-IN ZONE (X4) G F OUTER LIGHT PIPE INNER LIGHT PIPE (OR MIDDLE LIGHT PIPE) B B DETAIL F SCALE 10 : 1 12.00 4.00 T19 3X 3.00 T16 T20 T11 T14 T18 0.70 T13 T17 T15 T12 0.70 T2 T5 T1 3.00 T7 T3 T9 B6 B10 T10 T6 B9 0.80 T8 T4 B3 B4 B7 B8 B1 B5 B2 C C 9X 0.80 1.60±0.03 B12 B11 1.30 Y B15 B18 B14 B13 B17 B16 B20 B19 0.50 X 9.80 DETAIL G SCALE 5 : 1 10.80 DETAIL E SCALE 5 : 1 D UNLESS SPECIFIED OTHERWISE DIMENSIONS ARE IN MILLIMETERS DRAWN REFERENCE IN PARENTHESES M.E. APP'D GENERAL TOLERANCES Q.A. APP'D 1 DECIMAL PLACE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR  USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 1 2 3 2 DECIMAL PLACE 3 DECIMAL PLACE ANGULAR DEGREES ENG. REL. NO. CHECKED P. OU J. SI FEB10/14 J. SI FEB 12/14 0.25 DWG APP'D 0.15 MATERIAL AND FINISH N/A 1 REF. THIRD ANGLE PROJECTION FEB 12/14 SEE NOTES ECN Exxxxx Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenolcanada.com 2X6 SFP ULTRAPORT WITH LIGHT PIPE OPTIONS AND EMI SPRING FINGER DWG. NO. DO NOT SCALE DRAWING CODE ID NO. P-UE86-3G6620-X0X61 03554 DWG SIZE: A4 SCALE: 2:1 REV C SHEET 5 OF 5
UE86-3G6620-10361 价格&库存
很抱歉,暂时无法提供与“UE86-3G6620-10361”相匹配的价格&库存,您可以联系我们找货
