U95-Z205-4081-141
U95-Z205-4081-141
    ARDUINO
    CONN 2X2 CAGE GASKET LP REV
U95-Z205-4081-141 数据手册
A B C D E G F H REVISIONS AMPHENOL PART NUMBER CONFIGURATION REV U95-Z205-XXX1-XX1 J 1 DATE APP'D Drawing Updated NOV 24/14 JS Pin Position Corrected DEC 10/14 JS JAN 20/15 JS View Corrected for 8-Rec Holes With LP 1 VENT HOLES AND EMI COVER 0 = WITH LARGE VENT HOLES & WITH EMI COVER 2 = WITH SMALL VENT HOLES & WITH EMI COVER 4 = WITH RECTANGULAR VENT HOLES & WITH EMI COVER CAGE & CONNECTOR CONTACT PLATING 4 = 0.76 µm MIN. GOLD OVER 1.27-3.81 µm OF NICKEL ON MATING AREA 0.381-1.52 µm OF MATTE TIN OVER 1.27-3.81 µm OF NICKEL ON PRESS FIT TAIL AREA. Ni PLATING FOR CAGE (RoHS COMPLIANT PER RoHS DIRECTIVE 2011/65/EU) EMI GASKET 1 = CHOMERICS 1273 CONDUCTIVE ELASTOMER 2 = CHOMERICS S6305 CONDUCTIVE ELASTOMER OPTIONAL LIGHT PIPES 6 = WITH LIGHT PIPE (TRIANGULAR OUTLET) LEFT ARROW POINTING BOTTOM PORT & RIGHT ARROW POINTING TOP PORT 7 = WITHOUT LIGHT PIPE 8 = WITH LIGHT PIPE (REVERSED DIRECTION) LEFT ARROW POINTING TOP PORT & RIGHT ARROW POINTING BOTTOM PORT OPTIONAL DUST COVER 0 = WITHOUT DUST COVER D = WITH DUST COVER 2 DESCRIPTION, ECN, EAR NO. G H 2 3 3 4 5 VENT HOLE FOR PART NUMBER U95-Z205-XX71-X01 VENT HOLE FOR PART NUMBER U95-Z205-XX71-X21 VENT HOLE FOR PART NUMBER U95-Z205-XX71-X41 VENT HOLE FOR PART NUMBER U95-Z205-XX61-X01 VENT HOLE FOR PART NUMBER U95-Z205-XX61-X21 VENT HOLE FOR PART NUMBER U95-Z205-XX61-X41 VENT HOLE FOR PART NUMBER U95-Z205-XX81-X01 VENT HOLE FOR PART NUMBER U95-Z205-XX81-X21 VENT HOLE FOR PART NUMBER U95-Z205-XX81-X41 4 5 NOTES: 1. MATERIAL CAGE-PRESS FIT: COPPER ALLOY, NICKEL PLATED CONNECTOR-PRESS FIT: PLASTIC HOUSING, FLAMMABILITY RATING UL94 V-0. CONTACTS: PHOSPHOR BRONZE PLATING OPTION: SEE AMPHENOL PART ON CONFIGURATION UNLESS SPECIFIED OTHERWISE EMI GASKET: CONDUCTIVE ELASTOMER LIGHT PIPE: GE LEXAN, OPTICAL GRADE 6 PRIMARY UNITS SECONDARY DUST COVER (IF ORDERED) SHIPPED LOOSE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APP'D 1 DECIMAL PLACE 0.25 ENG. REL. NO. 2 DECIMAL PLACES 0.15 REF. 0.5 THIRD ANGLE PROJECTION ANGULAR DEGREES E Alvin C ZLJ DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D APR 18/13 APR 18/13 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com UltraPort QSFP+ 2X2 STACKED COMBO WITH EMI GASKET 4X25G 6 DWG. NO. REV F J P-U95-Z205-XXX1-XX1 DO NOT SCALE DRAWING CODE ID NO. 03554 DWG SIZE: C G SCALE: SHEET 1 OF 4 1:1 H A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE J SEE SHEET 1 JAN 20/15 APP'D JS PART NUMBER 1 1 DATE CODE 73.2 2 2 3 3 38.4 43.4 19.00 18.75 4 4 25.1 30.1 25.7 1.25 SIGNAL PINS ON CONNECTOR 2.50 LOCATING POST 56.25 2.00 PRESS FIT PINS ON CAGE 5 5 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APP'D 1 DECIMAL PLACE 0.25 ENG. REL. NO. 2 DECIMAL PLACES 0.15 REF. ANGULAR DEGREES 0.5 E Alvin C ZLJ DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D APR 18/13 APR 18/13 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com UltraPort QSFP+ 2X2 STACKED COMBO WITH EMI GASKET 4X25G 6 DWG. NO. THIRD ANGLE PROJECTION REV F J P-U95-Z205-XXX1-XX1 DO NOT SCALE DRAWING CODE ID NO. 03554 DWG SIZE: C G SCALE: SHEET 2 OF 4 1:1 H A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE APP'D J SEE SHEET 1 JAN 20/15 JS CROSS HATCHED REPRESENTS TRACE KEEP OUT AREA (CAGE PRESS FIT PINS) 1 1 4.70 1.78 0.00 9.50 23.70 20.78 19.00 17.02 14.30 CROSS HATCHED REPRESENTS TRACE KEEP OUT AREA 28.50 38.00 36.02 33.30 0.37±0.05 (152) 0.10 M Z X Y 0.56±0.05 (15X) 0.10 M Z X Y A Y 0.80 TYP 1.60 TYP 2.00 (6X) 1.57 MIN 2.10 TYP 16.70 2 37 16.65 2.50±0.05(3X) TH 12.85 20 38 1 0.00 PIN 1 TOP PORT 6.60 3 X 11.20 13.70 66.07 CONNECTOR OUTLINE 19 3 1 26.30 5.92 5.22 1.92 1.22 0.52 19 3 3 4.52 21 2 49.10 MAX 8.52 20 38 17.30 9.22 18 37 PIN 1 BOTTOM PORT 12.52 9.92 2 4.85 13.22 21 8.85 1.05±0.05(15X) PTH 0.10 M Z X Y 2 13.92 18 0.00 29.55 32.05 2.35 (4X) 1.45 35.30 2.30 (4X) 44.30 4 CROSS HATCHED REPRESENTS LED SOLDER PAD SEATING AREA EXTENDING VERTICALLY 0.80 MM ABOVE THE TOP OF HOST PCB 0.00 0.81±0.05 (8X) PTH 0.10 M Z X Y 2.00 (8X) RECOMMENDED PCB BOARD LAYOUT COMPOENT SIDE SHOWN 5 1.73 0.33 4.13 7.63 11.13 CROSS HATCHED REPRESENTS COMPONENT KEEP OUT AREA (38.90)X(66.07) 14.63 z (38.90) CONNECTOR OUTLINE 17.27 CROSS HATCHED REPRESENTS TRACE KEEP OUT AREA 2.50 (15X) 1.68 0.34 18.67 0.34 1.68 4 5 DETAIL A SCALE 6 : 1 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APP'D 1 DECIMAL PLACE 0.25 ENG. REL. NO. 2 DECIMAL PLACES 0.15 REF. 0.5 THIRD ANGLE PROJECTION ANGULAR DEGREES E Alvin C ZLJ DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D APR 18/13 APR 18/13 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com UltraPort QSFP+ 2X2 STACKED COMBO WITH EMI GASKET 4X25G 6 DWG. NO. REV F J P-U95-Z205-XXX1-XX1 DO NOT SCALE DRAWING CODE ID NO. 03554 DWG SIZE: C G SCALE: SHEET 3 OF 4 2:1 H A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE APP'D J SEE SHEET 1 JAN 20/15 JS 1 1 2 2 0.20±0.10 PCB TOP SURFACE TO PANEL OPENING 6.00±0.30 54.95 3 3 38.85±0.10 R0.30 MAX (TYP) 4.65 4 4 25.51±0.10 43.50 5 5 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APP'D 1 DECIMAL PLACE 0.25 ENG. REL. NO. 2 DECIMAL PLACES 0.15 REF. 0.5 THIRD ANGLE PROJECTION ANGULAR DEGREES E Alvin C ZLJ DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D APR 18/13 APR 18/13 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com UltraPort QSFP+ 2X2 STACKED COMBO WITH EMI GASKET 4X25G DWG. NO. REV J P-U95-Z205-XXX1-XX1 DO NOT SCALE DRAWING CODE ID NO. F 6 03554 DWG SIZE: C G SCALE: SHEET 4 OF 4 1:1 H
U95-Z205-4081-141 价格&库存
很抱歉,暂时无法提供与“U95-Z205-4081-141”相匹配的价格&库存,您可以联系我们找货
