3500 Series
Long-Life I/O Connectors
Nov.1.2016 Copyright 2016
Sep.1.2018
2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
■OVERVIEW
These miniature, shielded interface connectors were designed for use with portable terminal equipment. They are
suited to a wide range of applications including hand-held terminals and PDA equipment because of excellent
insertion/removal durability (20,000 times).
■FEATURES
(1) Long-life connectors have an insertion/removal life
of 20,000 cycles.
(2) The structure of the contacts is the highly reliable,
two-contact bellows type.
(3) The lock uses a snap-lock system which relieves
the stress that accompanies forceful removal,
making these connectors resistant to external
forces such as sudden pulls of the cable.
(4) Release of the lock is achieved with a simple
operation of the push buttons at the left and right
sides of the plug. A positive lock sensation is
provided by a click locking sound when the
connector engages.
(5) The miniature, lightweight design (i.e., about 2g for
a 16-conductor receptacle) makes these connectors
effective in reducing the overall size and weight of
terminal equipment.
(6) Use of a new box-bending structure for the metal
shell supports EMI protection and makes this a
tough connector.
(7) ESD protection is provided by the metal shell-not
the cover (unless it is metal plated).
(8) The board mounting system uses 0.8-mm spaced
single row SMT for easy mounting.
(9) Suitable boards can be from 0.8 to 1.6mm thick,
affording a wide selection of board thicknesses.
(10) There are two types of plug-side wiring systems,
the pressure welding type designed to save labor in
wiring, and the solder type which enables an
arbitrary selection of the type of cable.
■APPLICATIONS
Hand-held terminals, PDA equipment, notebook computers, mobile communications equipment, office automation
equipment, measuring instruments, etc.
257
04/2009
Major Specifications
Sep.1.2018
Item
Materials and Processing
Rated Value
Operating temperature
range
-40℃ to +85℃
Rated voltage
125VAC
Rated current
1A
Insulation resistance
1,000MΩ or greater/
250VDC
Withstand voltage
350VAC for 1 minute
Contact resistance
Insertion/removal life
Item
Material
Processing
Insulation
Synthetic resin
Black color UL94V-0
Contacts
Copper alloy
Selective gold plating
Shell
Stainless steel
Tin plating
Insulation
Synthetic resin
Black color UL94V-0
Contacts
Copper alloy
Shell
Stainless steel
40mΩ or less
Lock spring
Stainless steel
20,000 times
Cover
Synthetic resin
Receptacles
Plugs
Black color
Structure of the Product Number
Receptacle Connectors
35 60 − 16 S R (50)
(1) (2)
(4) (5) (7) (8)
Plug Connectors
35 30 A − 16 P − CV (50)
(1) (2) (3)
(4) (5)
(6)
(8)
(1) Series No.: 35
(2) Termination style
60: Right-angle SMT type
30: Discrete wire pressure welding type
40: Solder type
(3) Suitable wire
A: AWG 28
(4) Number of contacts
(5) Type of opening portion
P: Plug connector
S: Receptacle connector
(6) Cover form
CV: Standard type
(7) Engagement direction of the connector
No symbol: Forward engagement
R: Reverse engagement
(8) Specification contents
(50): Specifications support RoHS
Diagram of Connector When Engaged
(Please see information about the connector mounting method.)
Plug connector side
Set body side
258
04/2009
■ RECEPTACLE CONNECTORS
■ FORWARD ENGAGEMENT TYPE
Plug logo mark position
when engaged
Sep.1.2018
Logo mark side
(Note)CONTACT No. for 16pos
Engagement
key
(Both sides)
Forward engagement type
3560-16S(50)
Unit: mm
HRS No.
Number of
contact
CL235-0007-0-50
CL235-0001-3-50
10
16
Product No.
A
B
C
D
E
F
RoHS
3560-10S(50)
3560-16S(50)
16.2
21.0
07.2
12.0
19.0
23.8
23.2
28.0
20.8
25.6
20.5
25.3
YES
■ REVERSE ENGAGEMENT TYPE
when engaged
Logo mark side
※……Reverse contact number
arrangement
Engagement
key
(Both sides)
Reverse engagement type
3560-16SR(50)
Unit: mm
HRS No.
Number of
contact
CL235-0008-2-50
CL235-0002-6-50
10
16
Product No.
A
B
C
D
E
F
RoHS
3560-10SR(50)
3560-16SR(50)
16.2
21.0
07.2
12.0
19.0
23.8
23.2
28.0
20.8
25.6
20.5
25.3
YES
259
04/2009
Sep.1.2018
■ PLUG CONNECTORS
Logo mark side
3530A-16P-CV(50)
Unit: mm
Item
HRS No.
Number of
contact
Pressure welding
wiring type
CL235-0009-5-50
10
CL235-0003-9-50
CL235-0010-4-50
CL235-0004-1-50
16
10
16
Solder wiring type
Product No.
A
B
C
3530A-10P-CV(50) 21.8
20.8
24.0
3530A-16P-CV(50) 26.6
3540-10P-CV(50) 21.8
3540-16P-CV(50) 26.6
25.6
20.8
25.6
28.8
24.0
28.8
RoHS
YES
B Internal Structure Diagram (Pressure welding wiring type)
Cable clamp
Frame
Shell
Cover A
Cover B
Pressure
plate(A)
Pressure
plate(B)
Logo mark
side
※ This look spring forms a
single body structure
with the frame and
cable clamp.
Insulation
※Lock spring
Suitable cable
Contacts
Specification
Number of contact
Cable outside diameter
AWG28(7/0.127)
UL20276
Conductor outside diameter :φ0.58
10
φ5.0
16
φ5.9
B Harness tool
Item
Wire forming palette
Number of
contact
common
Tools required for the harness
Product No.
HRS No.
3530/CA-MD
CL902-0345-9
10
3530-10/SP-MP
CL902-2060-0
16
3530-16/SP-MP
CL902-2009-2
Set palette
Solder wiring
Remaining length cutting jig
common
3530/CU-MP
CL902-0346-1
Pressure welding jig
common
3530/ID-MP
CL902-0347-4
10
3530-10/CA-MP(01)
CL902-2061-2(01)
16
3530-16/CA-MP(01)
CL902-0348-7(01)
Cable caulking jig
260
04/2009
B Board Mounting Dimensions Diagram
(Note)CONTACT No. for 16pos.
No.16(Note)…(16S)
No.1 …(16SR)
2.2
1d
ia(
. t
hr
ou
gh
ho
le)
No.1 …(16S)
No.16(Note)…(16SR)
or
. f
a(
di
g)
in
nt
ou
m
Edge of board
1.8
h
ug
ro
th
a(
di
Front of connector
le
ho
Sep.1.2018
w
re
sc
Pattern pad
Pattern prohibited area
Board mounting dimensions diagram(2 : 1)
Suitable board thickness t = 0.8∼1.6
(mm)
Product No.
A
B
C
D
E
F
3560-10S(50)
3560-10SR(50)
17.6
16.2
07.2
09.3
11.6
20.5
3560-16S(50)
3560-16SR(50)
22.4
21.0
12.0
11.4
16.4
25.3
B Technical DocumentⅠ
Ⅰ (Reference)
Number of Insertion / Removal Cycles and Contact Resistance
(mΩ)
60
40
Start
1000
10000
20000
(Times)
261
04/2009
B Technical DocumentⅡ
Ⅱ
Connector Mounting Method
1. Soldering Method
This connector and board mounting method uses soldering at the four dip locations marked A at the left and
right sides as well as the two surface mounting locations marked B at the left and right sides for a total of six
locations.
Sep.1.2018
Location A represents board through holes of 1.8mm diameter and 1mm diameter, whereas
location B represents pads of 2.8 × 1.85mm width. (See the board mounting diagram.)
Powered by TCPDF (www.tcpdf.org)
As illustrated in the diagram below, the opening portion of the connector is either inserted into the body of
the set or inserted into a rectangular hole of the set.
Connector opening portion
Board
Connector
2. Soldering and Screw Fastening Method
When there is not sufficient strength with the connector opening portion at the set, the mounting holes C (as
in Figure 1) at the left and right sides of the connector are used after the solder mounting to further fix the
connector with M2 screws.
The connector can be fixed to just the board with this method (as in Figure 2); however, in consideration of
connector twisting, the most effective mounting method is to fix the connector to both the body and the
board with screws as illustrated in Figures 3 and 4.
(Figure 1)
Board
Body of the set
Nut anchoring
(Figure 2)
262
(Figure 3)
Tapping screw anchoring
(Figure 4)
04/2009
很抱歉,暂时无法提供与“3560-16SR1(50)”相匹配的价格&库存,您可以联系我们找货
