U92-A110-1001-30
U92-A110-1001-30
    ARDUINO
    CONN MINI SAS RCPT W/CAGE R/A
U92-A110-1001-30 数据手册
8 7 6 5 4 1 2 3 REVISIONS U92 - A1X0 - 1X0X - XX F REV. DESCRIPTION DATE APPROVED F G H LEAD-FREE PLATING OPTION ADDED 8X 0.57 HOLE CHANGED TO 6X ADDED NOTES AND VIEW ADJUSTMENTS JUL 04/11 JUL 29/11 JUL 29/11 ZLJ ADRIAN G HEAT SINK OPTION 1 - NO HEAT SINK, NO CLIP 2 - FIN STYLE HEAT SINK (BLACK OXIDE) WITH CLIP 5 - ROUND PIN STYLE HEAT SINK (NICKEL PLATED) WITH CLIP A - FIN STYLE HEAT SINK (NICKEL PLATED) WITH CLIP D - SQUARE PIN STYLE HEAT SINK (BLACK OXIDE) WITH CLIP K - ROUND PIN STYLE HEAT SINK (CHROMATE PASSIVATION) WITH CLIP N - SQUARE PIN STYLE HEAT SINK (NICKEL PLATED) WITH CLIP MOUNTING SCREWS 0 - NO MOUNTING SCREWS SHIPPED J TOLERANCES ADDED TO PCB HOLES 1 - WITH MOUNTING SCREWS M2 X 04 - 4.3MM LONG K AHSI DESIGNATION ADDED SHIPPED BULK IN SAME TRAY WITH CAGE ASSEMBLIES CONTACT PLATING 1 - MATING AREA PLATING: 0.76 μm GOLD OVER 2.54 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.76 μm TIN LEAD OVER 2.54 μm OF NICKEL 2 - MATING AREA PLATING: 0.38 μm GOLD OVER 2.54 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.76 μm TIN LEAD OVER 2.54 μm OF NICKEL 3 - MATING AREA PLATING: 0.76 μm GOLD OVER 1.27 μm TO 3.81 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.381 μm TO 1.52 μm OF MATTE TIN OVER 1.27 μm TO 3.81μm OF NICKEL OPTIONAL DUST COVER 0 - NO DUST COVER D - WITH DUST COVER (SHIPPED BULK IN SAME BOX WITH CAGE & CONNECTOR ASSEMBLY) PACKAGING 1 - TRAY PACKAGING (HEAT SINKS ANC CLIPS , IF ORDERED, PACKED IN SEPARATE TRAYS FROM CAGES) A - TRAY PACKAGING (CAGE & CONNECTOR ASSEMBLY SHIPPED WITH HEAT SINK AND CLIP ATTACHED) OCT 20/11 MAY 15/12 ZLJ F E E D D PART # U92-A1N0-100A-10 SHOWN (CAGE & CONNECTOR ASSEMBLY WITH SQUARE PIN HEAT SINK ATTACHED, NO SCREWS AND NO DUST COVER) PART # U92-A120-100A-10 SHOWN (CAGE & CONNECTOR ASSEMBLY WITH FIN STYLE HEAT SINK ATTACHED, NO SCREWS AND NO DUST COVER) C C B B PART # U92-A110-1001-10 SHOWN (CAGE & CONNECTOR ASSEMBLY NO HEAT SINK, NO SCREWS AND NO DUST COVER SHIPPED) UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN CHECKED PART # U92-A150-1D0A-10 SHOWN (CAGE & CONNECTOR ASSEMBLY WITH ROUND PIN HEAT SINK ATTACHED, NO SCREWS AND WITH DUST COVER SHIPPED BULK) A DECIMALS ANGLES .X 0.2 X .XX 0.1 X.X 1° 0.5° 8 7 6 5 4 ZLJ SEP 22/09 ZLJ SEP 22/09 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com 4X MIN SAS HD CAGE AND CONNECTOR ASSEMBLY QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 SEP 22/09 SIZE DWG. NO. SCALE: 1:1 2 P-U92-A1X0-1X0X-XX PROJECT: HD REV K SHEET 1 OF 4 1 A 8 7 6 4 5 1 2 3 REVISIONS REV. K DESCRIPTION SEE SHEET ONE DATE APPROVED MAY 15/12 ZLJ F F D1 D9 C1 C9 E E B1 B9 A1 A9 11.25 12.4 DETAIL D SCALE 8 : 1 D C D AMPHENOL XXXX U92-A1X0-1X0X-1X 16.5 NOT MATED WITH PLUG 12.24 C 4.00 10.76 12.8 D 4.55 38 7.85 10.75 B B INK MARKING INFO: FOUR (4) DIGIT DATE CODE AND PART NUMBER UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN CHECKED A DECIMALS ANGLES .X 0.2 X .XX 0.1 X.X 1° 0.5° 8 7 6 5 4 ZLJ SEP 22/09 ZLJ SEP 22/09 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com 4X MIN SAS HD CAGE AND CONNECTOR ASSEMBLY QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 SEP 22/09 SIZE DWG. NO. SCALE: 2:1 2 P-U92-A1X0-1X0X-XX PROJECT: HD REV K SHEET 2 OF 4 1 A 8 7 6 4 5 1 2 3 REVISIONS F DESCRIPTION SEE SHEET ONE ZLJ F 13.31 L 18.19±0.15 E E 7 5.5 3 D APPROVED A9 3.7 4.5 3.8 3.1 B9 0.7 0 0.7 C9 8.3 7.6 6.9 12.1 11.4 10.7 13.81 0 F D9 DATE JUN 04/11 1 MIN. REV. 3 2.25 1.5 0.75 K 0 0 D 0.75 1.5 2.25 3 1.5 5.5 5.5 7 J C D1 C1 B1 C A1 36X 0.37±0.05 0.05 L 6X 2.2 0.05 L K J 0.57±0.05 0.05 L K J RECOMMENDED SINGLE MOUNT PCB LAYOUT COMPONENT SIDE SHOWN B B UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN CHECKED A DECIMALS ANGLES .X 0.2 X .XX 0.1 X.X 1° 0.5° 8 7 6 5 4 ZLJ SEP 22/09 ZLJ SEP 22/09 A Division of Amphenol Corp. www.amphenol-highspeed.com 4X MIN SAS HD CAGE AND CONNECTOR ASSEMBLY QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. Amphenol High Speed Interconnects DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 SEP 22/09 SIZE DWG. NO. SCALE: 2:1 2 P-U92-A1X0-1X0X-XX PROJECT: HD REV K SHEET 3 OF 4 1 A 8 7 6 5 4 1 2 3 REVISIONS REV. K DESCRIPTION SEE SHEET ONE DATE APPROVED MAY 15/12 ZLJ HEAT SINK F F 11.9 HEAT SINK CLIP CAGE 12.07 E FRONT PANEL (CUSTOMER SUPPLIED) E PCB (CUSTOMER SUPPLIED) 0.38 PCB R0.75 MAX. 13.25 EMI FINGERS RECOMMENDED PANEL CUTOUT FOR SINGLE LEVEL MOUNTING D D CONNECTOR C C E 7.49 B 0.38 FROM TOP OF PCB TO BOTTOM EDGE OF PANEL OPENING PCB 3.7 NOTES: DETAIL E SCALE 16 : 1 19.2 B 1) MATERIAL BOTTOM EDGE OF PANEL OPENING MAIN CAGE: PHOSPHOR BRONZE WITH NICKEL PLATING HEAT SINK CLIP: STAINLESS STEEL HEAT SINK: ALUMINUM, FOR PLATING INFO. SEE SHEET ONE EMI FINGERS: PHOSPHOR BRONZE WITH NICKEL PLATING UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN MOUNTING SCREW: AISI 1010 STEEL CONNECTOR HOUSING: LCP CHECKED A CONTACTS: PHOSPHOR BRONZE, FOR PLATING INFO. SEE SHEET ONE 2) CONNECTOR AND CAGE ASSEMBLY ARE RoHS COMPLIANT DECIMALS ANGLES .X 0.2 X .XX 0.1 X.X 1° 0.5° 8 7 6 5 4 ZLJ SEP 22/09 ZLJ SEP 22/09 A Division of Amphenol Corp. www.amphenol-highspeed.com 4X MIN SAS HD CAGE AND CONNECTOR ASSEMBLY QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. Amphenol High Speed Interconnects DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 SEP 22/09 SIZE DWG. NO. SCALE: 1:1 2 P-U92-A1X0-1X0X-XX PROJECT: HD REV K SHEET 4 OF 4 1 A
U92-A110-1001-30 价格&库存
很抱歉,暂时无法提供与“U92-A110-1001-30”相匹配的价格&库存,您可以联系我们找货
