U78-B1126-00221
U78-B1126-00221
    ARDUINO
    CONN RCPT SFP 20POS 2X1 S/CAGE
U78-B1126-00221 数据手册
8 7 5 6 4 3 2 1 REVISIONS REV. AMPHENOL PART NUMBER CONFIGURATION UE78 - B 1 1 2 6 - 0 0 X X 1 D C PRESS FIT CONNECTOR PLATING 2 = 30 μ" MIN. GOLD ON MATING AREA 15-100 μ" MATTE TIN ON TERMINATION 3 = 30 μ" MIN. GOLD ON MATING AREA 150-300 μ" MATTE TIN ON TERMINATION 5 = 15 μ" MIN. GOLD ON MATING AREA 15-100 μ" MATTE TIN ON TERMINATION 6 = 15 μ" MIN. GOLD ON MATING AREA 150-300 μ" MATTE TIN ON TERMINATION DESCRIPTION DATE APPROVED INITIAL RELEASE 2012/05/18 J.SI ECN A PART NUMBER (LAST DIGIT INDICATING PACKAGING TYPE, NOT PRINTED ON THE PART) PACKAGING 1 = TRAY PACKAGING D DATE CODE CAGE PLATING 2 = NICKEL PLATING 3 = MATTE TIN PLATING MATERIAL: CAGE: COPPER ALLOY C PLATING: SEE AMPHENOL PART NUMBER CONFIGURATION FOR OPTIONS. CONNECTOR: PLASTIC HOUSING: HIGH TEMPERATURE RESISTANT NYLON FLAMMABILITY RATING UL94V-0. B CONTACTS: PHOSPHOR BRONZE PLATING OPTION: SEE AMPHENOL PART NUMBER CONFIGURATION FOR OPTIONS. B DUST COVER THERMOPLASTIC,COLOR BLACK. PACKAGING: TRAY PACKAGING. OPTIONAL DUST COVER (SHIP LOOSE) P/N:U77-A1110-8000-P TEMPARATURE RANGE: -40°C TO +85°C UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: A DECIMALS 1 MATERIAL AND FINISH N/A DO NOT SCALE DRAWING 8 7 6 5 4 REF. X CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.25 X.XX 0.15 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. APPROVALS 03554 DATE Grace.L 2012/05/18 J.SI 2012/05/18 DESIGNED A Amphenol Canada Corp. TITLE SFP STACKED COMBO WITH PRESS FIT PINS (CONNECTOR AND CAGE) CHECKED QA APPD SIZE IE APP'D A3 DWG APP'D SCALE J.SI 2012/05/18 2 DWG. NO. 2:1 P-UE78-B1126-00XX1 SHEET PROJECT 1 REV. A 1 OF 4 8 7 4 5 6 3 2 1 REVISIONS REV. DESCRIPTION DATE APPROVED INITIAL RELEASE 2012/05/18 J.SI ECN A 14.00±0.10 D D 2.10 (TYP.) 8.95±0.15 12.40±0.10 6.80 25.50 25.20 8.95±0.15 6.68±0.10 C C 1.95 3.40 11.50 11.00 8.00 TYP. 7.50 25.68 14.25 0.10 M A B 42.10 51.63 T20 1.75 0.05 A M T11 -BB B T1 T10 B10 B1 15.00 B11 14.50 16.00 1.75 -A- B20 63.49 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: A DECIMALS N/A DO NOT SCALE DRAWING 8 7 1 MATERIAL AND FINISH THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. 6 5 4 REF. X CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.25 X.XX 0.15 PIN ASSIGNMENT ON MATING AREA APPROVALS 03554 DATE Grace.L 2012/05/18 J.SI 2012/05/18 DESIGNED A Amphenol Canada Corp. TITLE SFP STACKED COMBO WITH PRESS FIT PINS (CONNECTOR AND CAGE) CHECKED QA APPD SIZE IE APP'D A3 DWG APP'D SCALE J.SI 2012/05/18 2 DWG. NO. 2:1 P-UE78-B1126-00XX1 SHEET PROJECT 1 REV. A 2 OF 4 8 7 5 6 4 3 2 1 REVISIONS REV. DESCRIPTION DATE APPROVED INITIAL RELEASE 2012/05/18 J.SI ECN A D D A 15.25±0.10 FRONT PANEL C C 25.80±0.10 +0.10 0.10 (TOP OF PCB ABOVE PANEL CUTOUT) - 0.08 3.50±0.30 A B 1.70±0.90 16.50±0.10 B SECTION A-A SCALE 2 : 1 RECOMMENDED BEZEL DESIGN UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: A DECIMALS 1 MATERIAL AND FINISH N/A DO NOT SCALE DRAWING 8 7 6 5 4 REF. X CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.25 X.XX 0.15 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. APPROVALS 03554 DATE Grace.L 2012/05/18 J.SI 2012/05/18 DESIGNED A Amphenol Canada Corp. TITLE SFP STACKED COMBO WITH PRESS FIT PINS (CONNECTOR AND CAGE) CHECKED QA APPD SIZE IE APP'D A3 DWG APP'D SCALE J.SI 2012/05/18 2 DWG. NO. 2:1 P-UE78-B1126-00XX1 SHEET PROJECT 1 REV. A 3 OF 4 8 7 4 5 6 3 2 1 REVISIONS REV. DESCRIPTION DATE APPROVED INITIAL RELEASE 2012/05/18 J.SI ECN A Y D D 42.10 BSC (SEE NOTE 1) 1.05 0.05 M X Y - Z - (SEE NOTE 2) 7.50 CROSS-HATCHED AREA DENOTES COMPONENT AND TRACE KEEP-OUT (EXCEPT CHASSIS GROUND) 11.00 1.90 1.85±0.05 0.05 M X Y Z - C - (THUR HOLE) 1.63 3.13 5.68 7.13 8.58 14.25 C 11.13 11.08 1.60 (TYP.) C B 0.05 M 1.05±0.05 X Y Z S 8.00 (TYP.) 4.50 0.60±0.05 0.05 M C S D S (40 PLCS PLATED THRU HOLES) 25.68 X (17 PLACES SEE NOTE 2) 1.85±0.05 0.05 M X Y C - D - (THUR HOLE) 51.63 RECOMMENDED SFP HOST BOARD LAYOUT (ONE SIDE CAGE MOUNTING) B B11 T1 B10 B12 B13 B14 B20 T16 T6 B5 T15 T7 T14 T8 B3 B1 NOTES: 1. DATUM AND BSC DIMS ESTABLISHED BY CUSTOMER. 2. HOLES ARE CHASSIS GROUND. 18 PLACES . T13 T9 B2 B19 T17 T5 B4 B18 T18 T4 B7 B16 B17 T19 T3 B6 B15 B T20 T2 B9 B8 THIS AREA DENOTES COMPONENT KEEP-OUT (TRACES ALLOWED) T12 T10 T11 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: A DECIMALS 1 MATERIAL AND FINISH N/A DO NOT SCALE DRAWING THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PUPOSES WITHOUT PERMISSION FROM AMPHENOL CANADA CORP. 8 7 6 5 4 REF. X CODE IDENT. NO. 3 DRAWN ANGLES X.X 0.25 X.XX 0.15 DETAIL B SCALE 6 : 1 APPROVALS 03554 DATE Grace.L 2012/05/18 J.SI 2012/05/18 DESIGNED A Amphenol Canada Corp. TITLE SFP STACKED COMBO WITH PRESS FIT PINS (CONNECTOR AND CAGE) CHECKED QA APPD SIZE IE APP'D A3 DWG APP'D SCALE J.SI 2012/05/18 2 DWG. NO. 2:1 P-UE78-B1126-00XX1 SHEET PROJECT 1 REV. A 4 OF 4
U78-B1126-00221 价格&库存
很抱歉,暂时无法提供与“U78-B1126-00221”相匹配的价格&库存,您可以联系我们找货
