U92-A210-1001-30
U92-A210-1001-30
    ARDUINO
    CONN MINI SAS RCPT W/CAGE 1X2
U92-A210-1001-30 数据手册
8 7 6 5 4 1 2 3 REVISIONS REV. U92 - A2X0 - 1X0X - XX F HEAT SINK OPTION 1 - NO HEAT SINK, NO CLIP 2 - FIN STYLE HEAT SINK (BLACK OXIDE) WITH CLIP 3 - FIN STYLE HEAT SINK (NICKEL PLATED) WITH CLIP D E F G H J K DESCRIPTION DATE PART # CORRECTED IN ISO VIEWS ADDED PACKAGING NOTE LEAD FREE PLATING OPTION ADDED NOTES ADDED AND VIEW UPDATE TOLERANCES ADDED TO PCB HOLES DRAWING TITLES REVISED HEIGHT, LENGTH & WIDTH ADDED MOUNTING SCREWS 0 - NO MOUNTING SCREWS SHIPPED 1 - WITH MOUNTING SCREWS M2 X 04 - 4.3 MM LONG SHIPPED BULK IN SAME TRAY WITH CAGE ASSEMBLIES CONTACT PLATING L AHSI DESIGNATION ADDED 1 - MATING AREA PLATING: 0.76 μm GOLD OVER 2.54 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.76 μm TIN LEAD OVER 2.54 μm OF NICKEL 2 - MATING AREA PLATING: 0.38 μm GOLD OVER 2.54 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.76 μm TIN LEAD OVER 2.54 μm OF NICKEL 3 - MATING AREA PLATING: 0.76 μm GOLD OVER 1.27 μm TO 3.81 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.381 μm TO 1.52 μm OF MATTE TIN OVER 1.27 μm TO 3.81μm OF NICKEL OPTIONAL DUST COVER 0 - NO DUST COVER D - WITH DUST COVER (SHIPPED BULK IN SAME BOX WITH CAGE & CONNECTOR ASSEMBLY) APPROVED OCT 20/10 OCT 27/10 JUN 04/11 SEP 15/11 OCT 20/11 OCT 21/11 JAN 24/12 ZLJ MAY 15/12 ZLJ F PACKAGING 1 - TRAY PACKAGING (HEAT SINKS AND CLIPS, IF ORDERED, PACKED IN SEPARATE TRAYS FROM CAGES) A - TRAY PACKAGING (CAGE & CONNECTOR ASSEMBLY SHIPPED WITH HEAT SINK AND CLIP ATTACHED) E E D D C C PART # U92-A210-1D01-10 SHOWN (CAGE & CONNECTOR ASSEMBLY WITH NO SCREWS AND NO HEAT SINK, WITH DUST COVER SHIPPED BULK) PART # U92-A220-100A-10 SHOWN (CAGE & CONNECTOR ASSEMBLY WITH NO SCREWS, NO DUST COVER, WITH FIN-STYLE HEAT SINK) B B UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN CHECKED DECIMALS A .X 0.2 .XX 0.1 ANGLES X X.X 1° 0.5° 8 7 6 5 4 K.SOBEL APR 28/10 ZLJ FEB 09/10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com 8X MINI SAS HD CAGE AND CONNECTOR 2 PORT ASSEMBLY WITH HEAT SINK OPTION QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 FEB 09/10 SIZE DWG. NO. SCALE: 1:1 2 P-U92-A2X0-1X0X-XX PROJECT: HD REV L SHEET 1 OF 4 1 A 8 7 6 4 5 1 2 3 REVISIONS REV. L DESCRIPTION SEE SHEET ONE DATE APPROVED MAY 15/12 ZLJ F F D1 E D9 C1 C9 E 24.6±0.3 22.25 B1 B9 A1 A9 D 23.4 D DETAIL K SCALE 6 : 1 5.63 38.25 11 C C AMPHENOL XXXX U92-A2X0-1X01-1X 12.3 12.8 4 4.55 K 7.85 10.75 38 INK MARKING INFO: FOUR (4) DIGIT DATE CODE AND PART NUMBER B B UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN CHECKED DECIMALS A .X 0.2 .XX 0.1 ANGLES X X.X 1° 0.5° 8 7 6 5 4 K.SOBEL APR 28/10 ZLJ FEB 09/10 A Division of Amphenol Corp. www.amphenol-highspeed.com 8X MINI SAS HD CAGE AND CONNECTOR 2 PORT ASSEMBLY WITH HEAT SINK OPTION QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. Amphenol High Speed Interconnects DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 FEB 09/10 SIZE DWG. NO. SCALE: 2:1 2 P-U92-A2X0-1X0X-XX PROJECT: HD REV L SHEET 2 OF 4 1 A 8 7 6 4 5 1 2 3 REVISIONS REV. DESCRIPTION DATE SEE SHEET ONE APPROVED MAY 15/12 ZLJ 0 L F F 1 MIN. 0 13.31 3.7 0.7 0.7 3.1 3.8 4.5 6.9 7.6 8.3 10.7 11.4 12.1 13.81 N DETAIL F WITH PIN NUMBERS SHOWN SCALE 8 : 1 11 E C9 2.6 D9 B9 A9 E 8.5 8.5 0.4 7.75 7 6.25 RELATIVE (MODULE) CL 5.5 4.75 4 4 3.25 D D 2.5 0 ABSOLUTE (PART) CL 0 D1 B1 C1 2.5 3.25 CROSS-HATCHED AREA DENOTES COMPONENT AND TRACE KEEP-OUT 4 4.75 RELATIVE (MODULE) CL C A1 2.5 5.5 6.25 7 C 7 7.75 8.5 NOTES: 11 1. ALL HOLES MUST FALL WITHIN POSITIONAL TOLERANCES RELATIVE TO INDIVIDUAL CONNECTOR ASSEMBLY AS WELL AS COMPLETED CAGE ASSEMBLY. 2. DATUM M AND N ESTABLISHED BY CUSTOMER'S FUDUCIAL. 3. ALL HOLE DIMENSIONS DENOTE FINISHED HOLE SIZES. B B 72 X 0.37±0.05 0.05 L M 0.05 REL. CL (SEE NOTE 1) 10 X 0.57±0.05 0.05 L M N 0.05 REL. CL (SEE NOTE 1) 2 X 2.2 0.05 L M N UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN CHECKED DECIMALS A .X 0.2 RECOMMENDED 2 PORT MOUNT PCB LAYOUT COMPONENT SIDE SHOWN .XX 0.1 7 6 X X.X 1° 0.5° 5 4 K.SOBEL APR 28/10 ZLJ FEB 09/10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com 8X MINI SAS HD CAGE AND CONNECTOR 2 PORT ASSEMBLY WITH HEAT SINK OPTION QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 8 ANGLES DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 FEB 09/10 SIZE DWG. NO. SCALE: 2:1 2 P-U92-A2X0-1X0X-XX PROJECT: HD REV L SHEET 3 OF 4 1 A 8 7 6 4 5 1 2 3 REVISIONS REV. L DESCRIPTION SEE SHEET ONE DATE APPROVED MAY 15/12 ZLJ 50 F HEAT SINKS 22.9 F FRONT PANEL (CUSTOMER SUPPLIED) 12.5 25 12.07 CAGE E E PCB (CUSTOMER SUPPLIED) 25 DUST COVERS HEAT SINK CLIPS RECOMMENDED PANEL CUTOUT FOR SINGLE LEVEL MOUNTING EMI FINGERS D D CONNECTOR 16.54 REF. NOT MATED C C 0.38±0.05 L PCB EMI FINGERS 3.7 BOTTOM EDGE OF PANEL OPENING 7.57 19.22 DETAIL L SCALE 12 : 1 B D1 B D9 NOTES: C1 1) MATERIAL C9 MAIN CAGE: PHOSPHOR BRONZE WITH NICKEL PLATING MOUNTING SCREW: AISI 1010 STEEL CONNECTOR HOUSING: LCP B1 B9 CONTACTS: PHOSPHOR BRONZE, FOR PLATING INFO. SEE SHEET ONE LIGHT PIPE: GE LEXAN, OPTICAL GRADE A CHECKED A1 HEAT SINK: ALUMINIUM A9 DETAIL VIEW WITH PIN NUMBERS SHOWN SCALE 8 : 1 2) CONNECTOR AND CAGE ASSEMBLY ARE RoHS COMPLIANT 7 6 5 DECIMALS .X 0.2 .XX 0.1 ANGLES X X.X 1° 0.5° 4 DATE K.SOBEL APR 28/10 ZLJ FEB 09/10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com 8X MINI SAS HD CAGE AND CONNECTOR 2 PORT ASSEMBLY WITH HEAT SINK OPTION QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 8 UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 FEB 09/10 SIZE DWG. NO. SCALE: 1:1 2 P-U92-A2X0-1X0X-XX PROJECT: HD REV L SHEET 4 OF 4 1 A
U92-A210-1001-30 价格&库存
很抱歉,暂时无法提供与“U92-A210-1001-30”相匹配的价格&库存,您可以联系我们找货
