U92-A410-1001-30
U92-A410-1001-30
    ARDUINO
    CONN MINI SAS RCPT W/CAGE 1X4
U92-A410-1001-30 数据手册
8 7 6 5 4 1 2 3 REVISIONS REV. U92 - A410 - 1X01 - XX F C D E F G H J K L MOUNTING SCREWS 0 - NO MOUNTING SCREWS SHIPPED 1 - WITH MOUNTING SCREWS M2 X 04 - 4.3 MM LONG SHIPPED BULK IN SAME TRAY WITH CAGE ASSEMBLIES OPTIONAL DUST COVER 0 - NO DUST COVER D - WITH DUST COVER (SHIPPED BULK IN SAME BOX WITH CAGE & CONNECTOR ASSEMBLY) DESCRIPTION DATE SCREW LENGTH REMOVED MODIFIED DIMENSION UPDATED DRAWING NUMBER LEAD FREE CONTACT PLATING OPTION ADDED 23X 0.57 HOLE CHANGED TO 18X NOTES ADDED AND VIEWS UPDATED TOLERANCES ADDED TO PCB HOLES DRAWING TITLES REVISED AHSI DESIGNATION ADDED CONTACT PLATING 1 - MATING AREA PLATING: 0.76 μm GOLD OVER 2.54 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.76 μm TIN LEAD OVER 2.54 μm OF NICKEL 2 - MATING AREA PLATING: 0.38 μm GOLD OVER 2.54 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.76 μm TIN LEAD OVER 2.54 μm OF NICKEL 3 - MATING AREA PLATING: 0.76 μm GOLD OVER 1.27 μm TO 3.81 μm OF NICKEL PRESS FIT TAIL AREA PLATING: 0.381 μm TO 1.52 μm OF MATTE TIN OVER 1.27 μm TO 3.81μm OF NICKEL APPROVED MAR 19/10 ZLJ SEPT 20/10 ZLJ OCT 28/10 ZLJ JUL 04/11 ZLJ JUL 29/11 ADRIAN G SEP 15/11 OCT 20/11 OCT 21/11 MAY 15/12 ZLJ F E E D D C C PART # U92-A410-1001-10 SHOWN (CAGE & CONNECTOR ASSEMBLY WITH NO SCREWS AND NO DUST COVER SHIPPED) B PART # U92-A410-1D01-10 SHOWN (CAGE & CONNECTOR ASSEMBLY WITH NO SCREWS AND DUST COVER SHIPPED BULK) UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN CHECKED A DECIMALS ANGLES .X 0.2 X .XX 0.1 X.X 1° 0.5° 8 7 6 5 4 K.SOBEL FEB 09/10 ZLJ FEB 09/10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com 16X MINI SAS HD CAGE AND CONNECTOR 4 PORT ASSEMBLY QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 B FEB 09/10 SIZE DWG. NO. SCALE: 1:1 2 P-U92-A410-1X01-XX PROJECT: HD REV L SHEET 1 OF 4 1 A 8 7 6 4 5 1 2 3 REVISIONS REV. L DESCRIPTION SEE SHEET ONE DATE APPROVED MAY 15/12 ZLJ F F E E 45.41 45.33 D D 5.63 11 C C AMPHENOL XXXX U92-A1X0-1X0X-1X 12.8 12.3 10.76 4.00 4.55 7.85 10.75 38 B B INK MARKING INFO: FOUR (4) DIGIT DATE CODE AND PART NUMBER UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN CHECKED A DECIMALS ANGLES .X 0.2 X .XX 0.1 X.X 1° 0.5° 8 7 6 5 4 K.SOBEL FEB 09/10 ZLJ FEB 09/10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com 16X MINI SAS HD CAGE AND CONNECTOR 4 PORT ASSEMBLY QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 FEB 09/10 SIZE DWG. NO. SCALE: 2:1 2 P-U92-A410-1X01-XX PROJECT: HD REV L SHEET 2 OF 4 1 A 8 7 6 4 5 1 2 3 REV. SEE SHEET ONE DATE APPROVED MAY 15/12 ZLJ 0 1 MIN. 13.31 3.7 0.7 0.7 3.1 4.5 3.8 8.3 7.6 6.9 DESCRIPTION L N 12.1 11.4 10.7 13.81 0 REVISIONS F F 24 DETAIL F WITH PIN NUMBERS SHOWN SCALE 8 : 1 L 22 19.5 18.75 18 17.25 16.5 15.75 15 14.25 13.5 19.5 RELATIVE (MODULE) CL 15 E D9 C9 2.6 B9 A9 0.4 E 11 8.5 7.75 7 6.25 5.5 4.75 4 3.25 2.5 8.5 RELATIVE (MODULE) CL 4 D D1 2.5 3.25 4 4.75 5.5 6.25 7 7.75 8.5 7 C A1 CROSS-HATCHED AREA DENOTES COMPONENT AND TRACE KEEP-OUT 0 RELATIVE (MODULE) CL B1 D 0 ABSOLUTE (PART) CL 2.5 C1 M C 11 NOTES: 13.5 14.25 15 15.75 16.5 17.25 18 18.75 19.5 13.5 RELATIVE (MODULE) CL 18 B 1. ALL HOLES MUST FALL WITHIN POSITIONAL TOLERANCES RELATIVE TO INDIVIDUAL CONNECTOR ASSEMBLY AS WELL AS COMPLETED CAGE ASSEMBLY. 2. DATUM M AND N ESTABLISHED BY CUSTOMER'S FUDUCIAL. 3. ALL HOLE DIMENSIONS DENOTE FINISHED HOLE SIZES. B 22 24 144 X 0.37±0.05 0.05 L M 0.05 REL. CL (SEE NOTE 1) 4X 2.2 0.05 L M N UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN 18 X 0.57±0.05 0.05 L M N 0.05 REL. CL (SEE NOTE 1) CHECKED A RECOMMENDED 4 PORT MOUNT PCB LAYOUT COMPONENT SIDE SHOWN 7 6 ANGLES .X 0.2 X .XX 0.1 X.X 1° 0.5° 5 4 K.SOBEL FEB 09/10 ZLJ FEB 09/10 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com 16X MINI SAS HD CAGE AND CONNECTOR 4 PORT ASSEMBLY QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 8 DECIMALS DATE A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 FEB 09/10 SIZE DWG. NO. SCALE: 2:1 2 P-U92-A410-1X01-XX PROJECT: HD REV L SHEET 3 OF 4 1 A 8 7 6 4 5 1 2 3 REVISIONS REV. L DESCRIPTION SEE SHEET ONE DATE APPROVED MAY 15/12 ZLJ CAGE F F 75 44.9 12.5 E 25 12.07 E FRONT PANEL (CUSTOMER SUPPLIED) PCB (CUSTOMER SUPPLIED) 37.5 RECOMMENDED PANEL CUTOUT FOR SINGLE LEVEL MOUNTING D D CONNECTOR EMI FINGERS C C 0.38±0.05 PCB G EMI FINGERS 3.70 BOTTOM EDGE OF PANEL OPENING 7.56 19.22 DETAIL G SCALE 12 : 1 B NOTES: 1) MATERIAL MAIN CAGE: PHOSPHOR BRONZE WITH NICKEL PLATING D1 D9 C1 C9 B1 B9 UNLESS OTHERWISE SPECIFIED: APPROVAL DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE: DRAWN MOUNTING SCREW: AISI 1010 STEEL CONNECTOR HOUSING: LCP A A1 A9 CONTACTS: PHOSPHOR BRONZE, FOR PLATING INFO. SEE SHEET ONE DETAIL VIEW WITH PIN NUMBERS SHOWN SCALE 8 : 1 2) CONNECTOR AND CAGE ASSEMBLY ARE RoHS COMPLIANT 7 6 5 CHECKED DECIMALS ANGLES .X 0.2 X .XX 0.1 X.X 1° 0.5° 4 Amphenol High Speed Interconnects DATE K.SOBEL FEB 09/10 ZLJ FEB 09/10 A Division of Amphenol Corp. www.amphenol-highspeed.com 16X MINI SAS HD CAGE AND CONNECTOR 4 PORT ASSEMBLY QA APPR. ME APPR. DWG APPR. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 8 B A.G. ENG. REL. NO. DO NOT SCALE DRAWING NSCM: 3 FEB 09/10 SIZE DWG. NO. SCALE: 1:1 2 P-U92-A410-1X01-XX PROJECT: HD REV L SHEET 4 OF 4 1 A
U92-A410-1001-30 价格&库存
很抱歉,暂时无法提供与“U92-A410-1001-30”相匹配的价格&库存,您可以联系我们找货
