U90-B305-4081-100
U90-B305-4081-100
    ARDUINO
    CONN QSFP+ RCPT W/CAGE 2X3 R/A
U90-B305-4081-100 数据手册
A B C D E G F AMPHENOL PART NUMBER CONFIGURATION U90-B305-XXX1-XX0 CAGE & CONNECTOR CONTACT PLATING 2 = 0.76 μm MIN. GOLD ON MATING AREA, 3.81-7.62 μm TIN/LEAD ON TERMINATION. Ni PLATING FOR CAGE 1 4 = 0.76 μm MIN. GOLD OVER 1.27-3.81 μm OF NICKEL ON MATING AREA 0.381-1.52 μm OF MATTE TIN OVER 1.27-3.81 μm OF NICKEL ON PRESS FIT TAIL AREA. Ni PLATING FOR CAGE (RoHS COMPLIANT PER RoHS DIRECTIVE 2011/65/EU; OPTION 4 ONLY) 2 REV DESCRIPTION, ECN, EAR NO. DATE APP'D E PROPOSAL DRAWING JUN 01/11 ZLJ VENT HOLES AND EMI COVER 0 = WITH LARGE VENT HOLES & WITH EMI COVER 1 = WITH LARGE VENT HOLES, NO EMI COVER 2 = WITH SMALL VENT HOLES, WITH EMI COVER 3 = WITH SMALL VENT HOLES, NO EMI COVER 4 = WITH RECTANGULAR VENT HOLES & WITH EMI COVER 5 = WITH RECTANGULAR VENT HOLES, NO EMI COVER 3 = 0.38 μm MIN. GOLD ON MATING AREA, 3.81-7.62 μm TIN/LEAD ON TERMINATION. Ni PLATING FOR CAGE EMI GASKET 1 = CHOMERICS 1273 CONDUCTIVE ELASTOMER 2= CHOMERICS S6305 CONDUCTIVE ELASTOMER OPTIONAL LIGHT PIPES 6 = WITH LIGHT PIPE (TRIANGULAR OUTLET) LEFT ARROW POINTING BOTTOM PORT & RIGHT ARROW POINTING TOP PORT 7 = WITHOUT LIGHT PIPE 8 = WITH LIGHT PIPE (REVERSED DIRECTION) LEFT ARROW POINTING TOP PORT & RIGHT ARROW POINTING BOTTOM PORT OPTIONAL DUST COVER 0 = WITHOUT DUST COVER D = WITH DUST COVER F UPDATED WITH NEW PART NUMBERING SYSTEM JUN 14/11 ZLJ G LEAD FREE CONTACT PLATING OPTION ADDED JUL 04/11 ZLJ H U90-B305-X071-X10 NOW SHOWN CORRECTLY OCT 07/11 J REVERSED LP CONFIGURATION ADDED NOV 11/11 ZLJ K OTHER CONFIGURATION ADDED JAN 24/12 ZLJ L HEAT SINK CONFIGURATION ADDED MAY 10/12 KH M AHSI DESIGNATION ADDED MAY 17/12 ZLJ N KEEP OUT AREA ADDED OCT 31/12 ZLJ P RoHS DIRECTIVE ADDED&HEAT SINK OPT REMOVED DEC 3/12 ZLJ REFERENCE VIEW FOR OPTION 6 ONLY 1 THIS IS A CAD DRAWING. DO NOT MANUALLY REVISE. REFERENCE VIEW FOR OPTION 8 ONLY 2 PART # U90-B305-X071-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITHOUT LIGHT PIPE) PART # U90-B305-X071-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITHOUT LIGHT PIPE) PART # U90-B305-XD71-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITH DUST COVER AND WITHOUT LIGHT PIPE) H REVISIONS 3 3 PART # U90-B305-X061-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B305-X061-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B305-X061-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) OPTIONAL DUST COVER P/N U90-1401-8000BP (SHIPPED LOOSE) 4 4 PART # U90-B305-X081-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B305-X081-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B305-X081-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) 5 5 NOTES: 1. MATERIAL CAGE-PRESS FIT: COPPER ALLOY, NICKEL PLATED CONNECTOR-PRESS FIT: PLASTIC HOUSING,FLAMMABILITY RATING UL94 V-0. 6 UNLESS SPECIFIED OTHERWISE CONTACTS : PHOSPHOR BRONZE PLATING OPTION: SEE AMPHENOL PART NO CONFIGURATION PRIMARY UNITS EMI GASKET: CONDUCTIVE ELASTOMER SECONDARY EMI FINGERS: PHOSPHOR BRONZE WITH NICKEL PLATING LIGHT PIPE: GE LEXAN, OPTICAL GRADE Q.A. APP'D DWG APPR. 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A REFERENCE IN PARENTHESES GENERAL TOLERANCES 1. DECIMAL PLACE 2. CONNECTOR AND CAGE ASSEMBLY IS RoHS COMPLIANT. B C D DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 3. ANGULAR DEGREES 4. ANGULAR DEGREES E K.Haider MAY12,11 Z. Ljubijankic JUN01,11 A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X3 STACKED COMBO 0.X 0.25 ENG. REL. NO. 0.XX 0.13 6 DWG. NO. REF. X 1 X.X 0.5 Amphenol High Speed Interconnects THIRD ANGLE PROJECTION F REV P P-U90-B305-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. 03554 DWG SIZE: C G SCALE: SHEET 1 OF 4 4:1 H A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. P DATE SEE PAGE 1 DEC 3/12 APP'D ZLJ 1 1 57.75 PART NUMBER DATE CODE 73.27 2 2 15.60±0.30 (6X) 29.90±0.15 (12X) (1.0 ) (12X) 44.09±0.03 (6X) 3 3 57.41 62.35 PART # U90-B305-X061-X30 SHOWN 4 4 +0.15 18.60 - 0.05 (3X) 8.8±0.1(6X) (19.00) (2X) 2.00±0.05 TYP 15.45 5 24.95 30.05 15.45 9.37 3.75 2.74 62.35 15.45 25.60 10.70 6.25 12.21 44.30 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 1. DECIMAL PLACE 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 3. ANGULAR DEGREES 4. ANGULAR DEGREES E K.Haider MAY12,11 Z. Ljubijankic JUN01,11 0.8 TYP. Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X3 STACKED COMBO 0.X 0.25 ENG. REL. NO. 0.XX 0.13 6 DWG. NO. REF. X 1 X.X 0.5 1.25 2.06 2.00 9.00 (3X) 5 P-U90-B305-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. THIRD ANGLE PROJECTION F 03554 DWG SIZE: C G SCALE: 4:1 REV P SHEET 2 OF 4 H A B C D E G F H REVISIONS DESCRIPTION, ECN, EAR NO. REV P SEE PAGE 1 DATE APP'D DEC 3/12 ZLJ 1 2 A 2.30 1.88 (6X) CROSS HATCHED REPRESENTS TRACE KEEP OUT AREA (6X) 1.50 (6X) 1.60 TYP. 0 19.00 0.37±0.05 (228X) PTH 0.10 M X Y 0 1 Y 2 0.80 TYP. 1.57 MIN 37 21 38 2.50±0.05 (2X) TH PIN 1 TOP PORT (66.30) CONNECTOR OUTLINE 3 0 X 1.05±0.05 (10X) PTH 0.10 M X Y 2 6.60 9.45 19 38 3 8.25 21 37 11.20 13.70 12.25 18 3 1 16.42 (6X) 13.45 20 5.45 20 4.25 17.30 2 1 49.10 MAX 18 3 26.30 29.55 32.05 4 35.30 0.35 (6X) CROSS HATCHED REPRESENTS LED SOLDER PAD SEATING AREA 1.72 PIN 1 BOTTOM PORT 0.34 (2X) CROSS HATCHED REPRESENTS TRACE KEEP OUT AREA (4X) 1.34 (2X) 0.34 (2X) 1.25 TYP 1.20 3.37 TYP 2.50 (TYP.) 1.34 (2X) CROSS HATCHED REPRESENTS TRACE KEEP OUT AREA (CAGE PRESS FIT PINS) DETAIL A SCALE 6 : 1 RECOMMENDED PCB BOARD LAYOUT COMPONENT SIDE SHOWN 5 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. C D DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 1. DECIMAL PLACE B 1.03 TYP 0.90 TYP 0.25 (TYP.) CROSS HATCHED REPRESENTS COMPONENT KEEP OUT AREA (58.32)X(66.30) (58.32) CONNECTOR OUTLINE 4 3.30 TYP 44.30 A 1.45 0.25 0 19 3. ANGULAR DEGREES 4. ANGULAR DEGREES E K.Haider MAY12,11 Z. Ljubijankic JUN01,11 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X3 STACKED COMBO 0.X 0.25 ENG. REL. NO. 0.XX 0.13 6 DWG. NO. REF. X 1 X.X 0.5 5 P-U90-B305-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. THIRD ANGLE PROJECTION F 03554 DWG SIZE: C G SCALE: 4:1 REV P SHEET 3 OF 4 H A B C D E G F H REVISIONS DESCRIPTION, ECN, EAR NO. REV P DATE SEE PAGE 1 DEC 3/12 APP'D ZLJ PANEL CUTOUT BOTTOM LATCH 1 2 1 2 0.27±0.10 PCB FRONT PANEL (CUSTOMER SUPPLIED) CAGE ASSEMBLY PCB (CUSTOMER SUPPLIED) DETAIL B SCALE 8 : 1 3 3 LIGHT PIPE 57.85 4 4 71.88 ELASTOMER EMI GASKET 25.60 25.51 15.45 9.38 5 5 37.00 MAX. B 1.57 MIN 43.00±0.30 RECOMMENDED PANEL CUTOUT UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 1. DECIMAL PLACE 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D DRAWN MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 3. ANGULAR DEGREES 4. ANGULAR DEGREES E K.Haider MAY12,11 Z. Ljubijankic JUN01,11 A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X3 STACKED COMBO 0.X 0.25 ENG. REL. NO. 0.XX 0.13 6 DWG. NO. REF. X 1 X.X 0.5 Amphenol High Speed Interconnects P-U90-B305-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. THIRD ANGLE PROJECTION F 03554 DWG SIZE: C G SCALE: 4:1 REV P SHEET 4 OF 4 H
U90-B305-4081-100 价格&库存
很抱歉,暂时无法提供与“U90-B305-4081-100”相匹配的价格&库存,您可以联系我们找货
