GT17-2428SCF
GT17-2428SCF
    HRS(广濑)
    F CONN TERMINAL TIN 24-28 AWG
GT17-2428SCF 数据手册
GT13 GT5 For Network, High speed communication GT10 GT7 GT3 GT32 GT17 GT11 GT36 GT26 GT21 GT19 — Automotive Shielded Connector — (2mm Pitch) Features All surface shielded construction. Ideal for use as automotive USB connectors. GT18W GT25 GT8E GT9 GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. PO5G GT16 GT17 Series 120 Applications In-car data communications, etc. (For USB2.0, LVDS) GT17 Series ● For Network, High speed communication GT5 F Connectors GT13 Center Terminals (Used with 6, 8, and 10 pos. cable) GT16 GT19 GT21 1.45 2.1 GT26 Material Plating Copper alloy Tin plating Conductor Size (AWG) 20 to 22 AWG 24 to 28 AWG 30 AWG 24 to 28 AWG Outer Diameter φ1.1 to 1.3 φ0.7 to 1.0 φ1.1 to 1.3 φ0.5 to 0.7 Packaging RoHS 10,000 pcs/reel YES Packaging RoHS 10,000 pcs/reel YES GT17 M Connectors GT32 Center Terminals (Used with 6, and 10 pos. cable) GT3 GT7 18 GT10 GT18W 1.7 GT25 0.64 0.9 GT8E Material Plating Brass Tin plating Conductor Size (AWG) 20 to 22 AWG 24 to 28 AWG Outer Diameter φ1.1 to 1.3 φ0.7 to 1.0 φ1.1 to 1.3 GT15 HRS No. 767-0082-0 767-0076-8 767-0121-0 GT9 Part No. GT17-2022PCF GT17-2428PCF GT17A-2428PCF 121 For Network, High speed communication HRS No. 767- 0009 -0 767- 0010 -0 767- 0064 -9 767- 0122-3 GT11 Part No. GT17-2022SCF GT17-2428SCF GT17-30SCF GT17B-2428SCF GT36 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 14.35 21.1 PO5G 1.7 6 Pos. Straight Connectors Contact No.4 38.5 GT32 GT17 GT11 GT36 GT26 GT21 GT19 13.3 Contact No.6 6.6 16.6 PO5G Contact No.1 BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, retainer, and center terminal) ● Housing Part No. GT17VS- 6DS -HU GT17VSA-6DS-HU GT3 GT7 HRS No. 767- 0051-7 767- 0052-0 Material / Plating or Color PBT/Light Gray PBT/Black Packaging RoHS 1 YES HRS No. 767-0026-0 Material / Plating or Color PBT/Dark Gray Packaging 1 RoHS YES HRS No. 767- 0050-4 Material / Plating or Color Copper alloy / Tin plating HRS No. 767- 0049-5 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. 767- 0053-2 Material / Plating or Color PBT/Dark Gray Packaging 1 RoHS YES ● Insulator Part No. GT17V-6DS-2C ● Outer terminal Part No. GT17VS- 6DS -5CF Outer Diameter φ4.8 to 5.2 Packaging 1 ● Shield plate Part No. GT17VS- 6DS -SC GT10 GT18W ● Center terminal BMating Table GT9 GT8E Part No. GT17VS- 6DS -R GT25 ● Retainer GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. Contact No.3 14.7 BBy using two key codings for different purposes, incorrect insertion can be prevented. GT16 GT13 GT5 GT17 Series ● For Network, High speed communication 122 Used with 6,8, and 10 pos. cable Color Cable side connector Gray GT17VS- 6DS-HU Black GT17VSA- 6DS-HU Board connector GT17V- 6DP- DS(70) GT17VB - 6DP- DS(70) GT17VA - 6DP- DS(70) GT17VC - 6DP- DS(70) RoHS YES GT17 Series ● For Network, High speed communication GT5 6 Pos. Right-angle Connectors GT13 BBy using two key codings for different purposes, incorrect insertion can be prevented. Contact No.6 Contact No.4 GT19 Contact No.1 PO5G GT21 GT26 BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, retainer, and center terminal) GT36 Part No. GT17V-6DS-HU GT17VA-6DS-HU RoHS 1 YES HRS No. 767-0026-0 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES HRS No. 767-0027-2 767-0075-5 Material / Plating or Color HRS No. 767-0028-5 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. 767- 0031-0 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES ● Insulator Part No. GT17V-6DS-2C ● Outer terminal Part No. GT17V-6DS-5CF GT17V-6DS-3.8CF Copper alloy / Tin plating Outer Diameter φ4.8 to 5.2 φ3.6 to 4.0 Packaging RoHS 1 YES GT3 Packaging GT32 Material / Plating or Color PBT / Light Gray PBT / Black GT17 HRS No. 767-0029-8 767-0030-7 ● Shield plate GT7 Part No. GT17V-6DS-SC ● Retainer GT18W ● Center terminal Used with 6,8, and 10 pos. cable Cable side connector GT17V-6DS-HU Black GT17VA-6DS-HU Board connector GT17V- 6DP-DS(70)(Cable exit direction, up side from mounting side) GT17VB- 6DP-DS(70)(Cable exit direction, down side from mounting side) GT17VA- 6DP-DS(70)(Cable exit direction, up side from mounting side) GT17VC- 6DP-DS(70)(Cable exit direction, down side from mounting side) GT8E Gray GT25 BMating Table Color GT10 Part No. GT17V-6DS-R GT9 GT15 123 For Network, High speed communication ● Housing GT11 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16 Contact No.3 6 Pos. Printed Circuit Board Connectors BBy using two key codings for different purposes, incorrect insertion can be prevented. ● Cable extraction facing up In Combination with a Right-angle Connector (Facing Up) 16.5 15 13.1 2 GT17V-6DP-DS (70) 15.7 12.2 T=1.6 GT17V-6DS-HU PC BOARD PANEL GT26 In Combination with a Straight Connector 16.5 26.5 13.1 2 HRS No. 14.5 GT17VS-6DS-HU PC BOARD PANEL Material / Plating or Color Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Packaging RoHS 1 YES ● Cable extraction facing down In Combination with a Right-angle Connector (Facing Down) 16.5 PANEL GT10 13.1 T=1.6 GT17VB- 6DP-DS(70) GT17VB-6DP-DS(70) 12.2 GT18W GT17V-6DS-HU 22 GT7 GT3 GT17V-6DP-DS(70) 767-0024-4 70 GT25 12.2 T=1.6 Part No. 23.2 GT32 GT17 GT11 15.7 GT36 GT17VS-6DS-R GT17V-6DS-R GT9 GT8E 3 Part No. HRS No. GT17VB-6DP-DS(70) 767-0032-2 70 124 2 15 Material / Plating or Color Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Packaging RoHS 1 YES PC BOARD 15.7 GT19 GT21 GT17V-6DP-DS(70) GT17V-6DP-DS (70) GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. 22 PO5G GT17V-6DS-R 3 23.2 GT16 GT13 GT5 GT17 Series ● For Network, High speed communication GT17 Series ● For Network, High speed communication GT5 6 Pos. Printed Circuit Board Connectors GT13 BBy using two key codings for different purposes, incorrect insertion can be prevented. ● Cable extraction facing up 13.1 GT17VA-6DP-DS(70) 3 GT16 In Combination with a Right-angle Connector 16.5 15 (Facing Up) GT17V-6DS-R 2 22 12.2 15.7 T=1.6 GT17VA-6DS-HU PC BOARD PANEL 16.5 GT26 In Combination with a Straight Connector 26.5 13.1 GT17VA-6DP-DS 2 14.5 15.7 T=1.6 12.2 1 YES GT3 In Combination with a Right-angle Connector (Facing Down) 16.5 PANEL 13.1 HRS No. GT17VC-6DP-DS(70) 767- 0033-5 70 Packaging RoHS 1 YES GT15 Material / Plating or Color Housing: PBT/Black Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating PC BOARD GT9 Part No. 15.7 12.2 T=1.6 22 2 GT8E 3 15 GT25 GT17-6DS-R GT18W GT17VC- 6DP-DS(70) 23.2 GT17VC-6DP-DS(70) GT10 GT17VA-6DS-HU GT7 ● Cable extraction facing down 125 For Network, High speed communication RoHS GT32 Packaging GT17VSA-6DS-HU PANEL GT17 GT17VA-6DP-DS(70) 767-0025-7 70 Material / Plating or Color Housing: PBT/Black Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating PC BOARD GT11 HRS No. GT36 GT17VS-6DS-R Part No. GT21 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 23.2 PO5G GT17VA- 6DP-DS(70) 6 Pos. In-line Connectors GT16 GT13 GT5 GT17 Series ● For Network, High speed communication PO5G GT19 Contact No.4 GT17 GT11 GT36 GT26 GT21 Contact No.1 BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, retainer, and center terminal) ● Housing Part No. GT17VSN-6DP-HU GT17VSV-6DP-HU GT17VSNA-6DP-HU Packaging RoHS 1 YES Packaging 1 RoHS YES HRS No. 767-0077-0 767-0128-0 767-0326-3 Material / Plating or Color HRS No. 767-0078-3 Material / Plating or Color PBT / Dark Gray HRS No. 767-0080-5 Material / Plating or Color Copper alloy / Tin plating HRS No. 767-0079-6 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. 767-0081-8 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES PBT / Light Gray PBT / Black GT32 ● Insulator Part No. GT17V-6DP-2C GT3 ● Outer terminal Part No. GT17VS-6DP-5CF Outer Diameter φ4.8 to 5.0 Packaging 1 RoHS YES GT25 GT18W GT10 GT7 ● Shield plate Part No. GT17VS-6DP-SC ● Retainer Part No. GT17VS-6DP-R ● Center terminal Used with 6, and 10 Pos. cable BMating Table GT9 GT8E Color GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. Contact No.6 Contact No.3 126 Gray Black In-line Connector GT17VSN-6DP-HU GT17VSV-6DP-HU GT17VSNA-6DP-HU BMated Condition Cable side Connector GT17V-6DS-HU GT17VS-6DS-HU GT17VA-6DS-HU GT17VSA-6DS-HU 62.6 GT17 Series ● For Network, High speed communication GT5 8 Pos. Right-angle Connectors GT13 BBy using two key codings for different purposes, incorrect insertion can be prevented. 18 7.3 15.6 Contact No.1 22 13.3 GT21 Contact No.8 GT19 Contact No.5 GT26 BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, retainer, and center terminal) Material / Plating or Color PBT / Light Gray PBT / Black Packaging RoHS 1 YES HRS No. 767-0005-0 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES GT17 HRS No. 767-0003-4 767-0004-7 ● Insulator Part No. GT17-8DS-2C GT32 ● Outer terminal HRS No. 767-0006-2 70 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. 767-0008-8 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES RoHS YES GT7 ● Shield plate Part No. GT17-8DS-SC(70) Packaging 1 GT3 Part No. HRS No. Material / Plating or Color Outer Diameter GT17-8DS-7CF(70) 767-0007-5 70 Phosphor bronze / Tin plating φ6.8 to 7.2 ● Retainer GT10 Part No. GT17-8DS-R ● Center terminal GT18W Used with 6,8, and 10 pos. cable BMating Table Cable side connector GT17- 8DS-HU Black GT17A- 8DS-HU GT8E Gray Board connector GT17V- 8DP-DS(Cable exit direction, up side from mounting side) GT17VB- 8DP-DS(Cable exit direction, down side from mounting side) GT17VB - 8DP- DS-SB(Cable exit direction, down side from mounting side) GT17VA- 8DP-DS(Cable exit direction, up side from mounting side) GT17VC- 8DP-DS(Cable exit direction, down side from mounting side) GT17VC - 8DP- DS-SB(Cable exit direction, down side from mounting side) GT25 Color GT9 GT15 127 For Network, High speed communication Part No. GT17-8DS-HU GT17A-8DS-HU GT11 ● Housing GT36 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No.4 PO5G 14.6 12 GT16 16.1 27 8 Pos. Straight Connectors 7.3 13.3 GT19 13.3 Contact No.1 Contact No.8 38.5 GT7 GT3 GT32 GT17 GT11 GT36 GT26 GT21 Contact No.5 BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, retainer, and center terminal) ● Housing Part No. GT17S-8DS-HU GT17SA-8DS-HU HRS No. 767-0108-2 767-0109-5 Material / Plating or Color PBT / Light Gray PBT / Black Packaging RoHS 1 YES HRS No. 767-0005-0 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES HRS No. 767-0106-7 Material / Plating or Color Copper alloy / Tin plating HRS No. 767-0107-0 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. 767-0110-4 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES ● Insulator Part No. GT17-8DS-2C ● Outer terminal Part No. GT17S-8DS-7CF Outer Diameter φ6.8 to 7.2 Packaging 1 ● Shield plate Part No. GT17S-8DS-SC GT10 ● Retainer Part No. GT17S-8DS-R GT25 GT18W ● Center terminal Used with 6,8, and 10 pos. cable BMating Table GT9 GT8E Color GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. PO5G Contact No.4 16.1 18 BBy using two key codings for different purposes, incorrect insertion can be prevented. GT16 GT13 GT5 GT17 Series ● For Network, High speed communication 128 Cable side connector Gray GT17S- 8DS-HU Black GT17SA- 8DS-HU Board connector GT17V- 8DP- DS GT17VB - 8DP- DS GT17VB - 8DP- DS-SB GT17VA - 8DP- DS GT17VC - 8DP- DS GT17VC - 8DP- DS-SB RoHS YES GT17 Series ● For Network, High speed communication GT5 8 Pos. Printed Circuit Board Connectors 16.5 GT13 ● Cable extraction facing up 15 13.1 3 2 GT16 GT17-8DS-R 23.2 12.2 15.7 PO5G 22 GT17V-8DP-DS T=1.6 GT17-8DS-HU PC BOARD PANEL 16.5 GT21 26.5 13.1 2 14.5 12.2 T=1.6 PANEL Material / Plating or Color Packaging RoHS 767-0139-6 Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating 1 YES GT32 HRS No. GT3 ● Cable extraction facing down PANEL GT7 GT17-8DS-HU 16.5 13.1 GT17VB-8DP-DS 2 GT25 3 15.7 12.2 PC BOARD GT17-8DS-R T=1.6 22 GT17VB-8DP-DS-SB (with enhanced shielding type) GT18W 23.2 GT10 GT17VB-8DP-DS 15 HRS No. Material / Plating or Color GT17VB- 8DP-DS-SB 767- 0123-6 Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Shield case: Brass /Tin plating RoHS 1 YES GT15 767-0185-3 Packaging GT9 GT17VB- 8DP-DS Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating GT8E Part No. 129 For Network, High speed communication GT17S-8DS-HU PC BOARD GT17 GT17V-8DP-DS GT11 Part No. GT17S-8DS-R GT36 15.7 GT17V-8DP-DS GT26 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 GT17V-8DP-DS 8 Pos. Printed Circuit Board Connectors ●Cable extraction facing up 16.5 GT16 GT17V-6DS-R T=1.6 GT17VA-8DP-DS 12.2 15.7 22 2 GT17VA-6DS-HU PC BOARD PANEL GT21 GT19 PO5G GT17VA-6DP-DS(70) 3 16.5 26.5 GT26 13.1 GT17VA-6DP-DS 2 GT17 GT17VA-8DP-DS 14.5 GT17VSA-6DS-HU PC BOARD PANEL HRS No. Material / Plating or Color Packaging RoHS 767-0200-5 Housing: PBT/Black Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating 1 YES GT3 GT32 12.2 T=1.6 GT11 15.7 GT36 GT17VS-6DS-R Part No. GT7 ●Cable extraction facing down GT17A-8DS-HU PANEL 16.5 13.1 GT17-8DS-R 3 15 Part No. GT17VC- 8DP-DS GT17VC- 8DP-DS-SB HRS No. Material / Plating or Color 767-0199-8 Housing: PBT/Black Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating 767-0124-9 Housing: PBT/Black Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Shield Case: Brass /Tin plating 15.7 12.2 GT17VC-8DP-DS-SB GT25 GT8E GT9 130 T=1.6 GT17VC-8DP-DS 22 23.2 GT18W GT10 GT17VC-8DP-DS (with enhanced shielding type) GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. 15 13.1 23.2 GT13 GT5 GT17 Series ● For Network, High speed communication Packaging RoHS 1 YES 2 PC BOARD GT17 Series ● For Network, High speed communication GT5 10 Pos. Right-angle Connectors GT13 BBy using two key codings for different purposes, incorrect insertion can be prevented. 27 20.6 18.7 8.6 GT16 17.2 Contact No.5 GT19 13.3 22 Contact No.1 Contact No.10 GT21 Contact No.6 GT26 BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, retainer, and center terminal) Material / Plating or Color PBT / Light Gray PBT / Black Packaging RoHS 1 YES HRS No. 767-0036-3 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES HRS No. 767-0037-6 Material / Plating or Color Copper alloy / Tin plating HRS No. 767-0038-9 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. 767-0041-3 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES GT17 HRS No. 767-0039-1 767-0040-0 ● Insulator Part No. GT17V-10DS-2C GT32 ● Outer terminal Outer Diameter φ7.5 to 8 Packaging 1 RoHS YES ● Shield plate GT7 Part No. GT17V-10DS-SC GT3 Part No. GT17V-10DS-8CF ● Retainer GT10 Part No. GT17V-10DS-R ● Center terminal GT18W Used with 6,8, and 10 pos. cable GT25 BMating Table Gray GT17V- 10DS-HU Black GT17VA- 10DS-HU Board connector GT17V- 10DP-DS(70)(Cable exit direction, up side from mounting side) GT17V- 10DP-DSA(70)(Straight type) GT17V- 10DP-DS-SB(70)(Cable exit direction, up side from mounting side) GT17V-10DP- DSA-SB(Straight type) GT17VA- 10DP-DS(70)(Cable exit direction, up side from mounting side) GT17VA- 10DP-DSA(70)(Straight type) GT17VA- 10DP-DS-SB(70)(Cable exit direction, up side from mounting side) GT17VA -10DP- DSA-SB(Straight type) GT9 Cable side connector GT8E Color GT15 131 For Network, High speed communication Part No. GT17V-10DS-HU GT17VA-10DS-HU GT11 ● Housing GT36 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12 PO5G 18.2 10 Pos. Straight Connectors BBy using two key codings for different purposes, incorrect insertion can be prevented. GT19 13.3 Contact No.1 Contact No.10 Contact No.6 GT17 GT11 GT36 GT26 GT21 38.5 BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, retainer, and center terminal) ● Housing Part No. GT17VS-10DS-HU GT17VSA-10DS-HU GT32 GT3 GT7 HRS No. 767-0061-0 767-0062-3 Material / Plating or Color PBT / Light Gray PBT / Black Packaging RoHS 1 YES HRS No. 767-0036-3 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES HRS No. 767-0059-9 Material / Plating or Color Copper alloy / Tin plating HRS No. 767-0060-8 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. 767-0063-6 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES ● Insulator Part No. GT17V-10DS-2C ● Outer terminal Part No. GT17VS-10DS-8CF Outer Diameter φ7.5 to 8 Packaging 1 ● Shield plate Part No. GT17VS-10DS-SC GT10 ● Retainer Part No. GT17VS-10DS-R GT18W Used with 6,8, and 10 pos. cable GT25 BMating Table Color Cable side connector GT8E Gray GT17VS- 10DS-HU GT9 ● Center terminal Black GT17VSA- 10DS-HU GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. PO5G Contact No.5 18.7 20.6 GT16 8.6 GT13 GT5 GT17 Series ● For Network, High speed communication 132 Board connector GT17V-10DP- DS(70) GT17V-10DP- DSA(70) GT17V-10DP- DS-SB(70) GT17V-10DP- DSA-SB GT17VA-10DP- DS(70) GT17VA-10DP- DSA(70) GT17VA-10DP- DS-SB(70) GT17VA-10DP- DSA-SB RoHS YES GT17 Series ● For Network, High speed communication GT5 10 Pos. Printed Circuit Board Connectors ● Right-angle type In Combination with a Right-angle Connector 16.5 15 (Cable Side) 22 23.2 12.2 15.7 PO5G GT17V-10DP-DS-SB(70) T=1.6 (with enhanced shielding type) GT17V-10DS-HU Board Panel GT19 GT21 In Combination with a Straight Connector (Cable Side) 16.5 26.5 13.1 2 14.5 12.2 T=1.6 Material / Plating or Color RoHS 1 YES GT32 GT17V-10DP-DS-SB(70) 767-0069-2 70 Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Shield case: Brass /Tin plating GT17V-10DP-DS(70) Packaging GT17 767-0034-8 70 Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Panel GT3 ●Straight-type T=1.6 26.5 15.7 12.2 GT17V-10DP-DSA-SB (with enhanced shielding type) HRS No. Material / Plating or Color Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Shield case: Brass /Tin plating RoHS 1 YES GT15 GT17V-10DP-DSA-SB 767- 0154-0 Packaging GT9 GT17V-10DP-DSA(70) 767- 0067-7 70 Housing: PBT/Light Gray Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating GT8E Part No. GT25 GT17VS-10DS-HU Board Panel GT17V-10DP-DSA(70) GT18W GT17V-10DP-DSA(70) 14.5 GT17VS-10DS-R GT10 16.5 13.1 2 GT7 In Combination with a Straight Connector (Cable Side) 133 For Network, High speed communication HRS No. GT17VS-10DS-HU Board GT11 Part No. GT17VS-10DS-R GT36 15.7 GT17V-10DP-DS (70) GT26 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT17V-10DS-R GT16 GT17V-10DP-DS(70) 3 13.1 2 GT17V-10DP-DS(70) GT13 BBy using two key codings for different purposes, incorrect insertion can be prevented. 10 Pos. Printed Circuit Board Connectors BBy using two key codings for different purposes, incorrect insertion can be prevented. In Combination with a Right-angle Connector 16.5 15 (Cable Side) ●Right-angle type GT16 13.1 2 22 23.2 T=1.6 GT17VA-10DS-HU Board Panel GT21 In Combination with a Straight Connector (Cable Side) GT26 16.5 26.5 13.1 2 GT17VA-10DP-DS(70) 14.5 T=1.6 GT36 15.7 GT17VS-10DS-R GT11 GT17 12.2 15.7 PO5G GT19 GT17VA-10DP-DS-SB(70) (with enhanced shielding type) Part No. HRS No. Material / Plating or Color 767-0035-0 70 Housing: PBT/Black Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating GT17VA-10DP-DS-SB(70) 767-0070-1 70 Housing: PBT/Black Center terminale: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Shield case: Brass /Tin plating GT17VA-10DP-DS(70) GT17VSA-10DS-HU Board Panel Packaging RoHS 1 YES GT3 GT32 GT17V-10DS-R GT17VA-10DP-DS(70) GT17VA-10DP-DS(70) ●Straight-type GT7 In Combination with a Straight Connector (Cable Side) 16.5 13.1 2 14.5 15.7 GT17VA-10DP-DSA(70) GT17VA-10DP-DSA-SB (with enhanced shielding type) GT25 GT8E GT9 134 26.5 GT17VS-10DS-R 12.2 GT18W GT10 T=1.6 GT17VSA-10DS-HU Board GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. 3 12.2 GT13 GT5 GT17 Series ● For Network, High speed communication GT17VA-10DP-DSA(70) Part No. HRS No. Material / Plating or Color GT17VA-10DP-DSA(70) 767- 0068-0 70 Housing: PBT/Black Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating GT17VA-10DP-DSA-SB 767- 0174-7 Housing: PBT/Black Center terminal: Brass /Tin plating Outer terminal: Copper alloy /Tin plating Shield case: Brass /Tin plating Panel Packaging RoHS 1 YES GT17 Series ● For Network, High speed communication GT5 10 Pos. In-line Connectors GT13 40 GT16 24 9.8 21.6 Contact No.1 GT19 Contact No.10 Contact No.5 GT21 GT26 BThe product comprises 6 parts. (Housing, insulator case, outer terminal, shield plate, retainer, and center terminal) GT36 Part No. GT17VSN-10DP-HU Material / Plating or Color PBT / Light Gray Packaging 1 RoHS YES HRS No. 767-0112-0 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES HRS No. 767- 0114-5 767- 0130-1 Material / Plating or Color HRS No. 767-0113-2 Material / Plating or Color Copper alloy / Tin plating Packaging 1,224 pcs/pack RoHS YES HRS No. 767-0111-7 767-0131-4 Material / Plating or Color Packaging RoHS 1 YES Part No. GT17V-10DP-2C GT17 ● Insulator ● Outer terminal Part No. GT17VS- 10DP-5.2CF GT17VS- 10DP-8CF Copper alloy / Tin plating Outer Diameter Ø5.0 to 5.4 Ø7.5 to 8.0 Packaging RoHS 1,224 pcs/pack YES GT32 HRS No. 767-0115-8 GT3 ● Shield plate Part No. GT17VS-10DP-SC GT7 ● Retainer PBT / Dark Gray GT10 Part No. GT17VS-10DP-5.2R GT17VS-10DP-8R ● Center terminal GT18W Used with 6, and 10 pos. cable BMated condition GT17VS-10DP-5.2R or GT17VS-10DP-8R GT17VS-10DS-HU GT17VSN-10DP-HU GT25 GT17VS-10DS-R or GT17VS-10DS-4.6R GT8E GT9 66.5 GT15 135 For Network, High speed communication ● Housing GT11 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 15.7 PO5G Contact No.6 GT13 GT5 GT17 Series ● For Network, High speed communication BWiring Method GT17V-10DS-HU Harness Finish 1 Strip the Jacket. Jacket 8 Insert the insulator into the Outer terminal. GT16 Outside shield PO5G Outer terminal 2 Cut the shield and intermediate material to expose the wire and braid. GT19 9 Insert the Shield Cover. Shield Cover GT21 Signal wires GT26 3 Bend back the drain wire over the Jacket. GT36 10 Fold back the Outer terminal. Drain wire GT11 4 Wrap with conductive tape. 11 Crimp the Outer terminal. GT32 GT17 Conductive tape 5 Strip the wire leads. 12 Insert the Outer terminal into the housing. Wire GT7 GT3 Housing 6 Crimp the center terminals. 13 Insert the retainer. GT10 Center terminal GT25 GT18W Retainer 7 Insert the center terminals into the insulator. 14 Completion Insulator GT8E GT9 GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. Drain wire 136 *Crimp height setting tables are available for each cable type. Please contact your nearest Hirose Electric account representative. Different cables will require different crimp height settings. GT17 Series ● For Network, High speed communication GT5 8 Insert the insulator into the Outer terminal. 11 Insert the Outer terminal into the housing. GT16 Housing GT13 GT17VS-10DS-HU Harness Finish Outer terminal PO5G 9 Crimp the Outer terminal. Retainer GT21 10 Insert the Shield Cover. GT19 Shield Cover 13 Completion GT26 GT36 GT17 GT32 GT3 GT7 GT10 GT18W GT25 GT8E GT9 GT15 137 For Network, High speed communication GT11 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12 Insert the retainer. 6 pos. In-line Type (Waterproof Type) F Connectors GT16 GT13 GT5 GT17 Series ● For Network, High speed communication 24.05 PO5G GT19 GT36 GT11 ● Insulator GT3 GT32 ● Housing GT17 GT26 GT21 GT17W BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, and center terminal) Part No. GT17W-6S-HU Part No. GT17V-6DS-2C Part No. GT17VS-6DS-5CF GT7 Material / Plating or Color PBT / Light Gray Packaging 1 RoHS YES HRS No. 767-0026-0 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES HRS No. 767-0050-4 Material / Plating or Color Copper alloy / Tin plating HRS No. 767-0049-5 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. Material / Plating or Color PBT / Dark Gray Silicon/White Packaging RoHS 1 YES GT18W GT25 GT8E GT9 Packaging 1 ● Retainer GT17W-1P/S-R 767-0216-5 ● Center terminal 138 Outer Diameter Ø4.8 to 5.2 ● Shield plate Part No. GT10 HRS No. 767-0214-0 ● Outer terminal Part No. GT17VS-6DS-SC GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. (49.3) 20.3 Used with 6,8 and 10 Pos. cable RoHS YES GT17 Series ● For Network, High speed communication GT5 M Connectors GT13 GT16 23.8 PO5G (50.4) 26.6 A GT17−6DP−2C A GT19 GT21 GT26 BThe product comprises 6 parts. (Housing, insulator, outer terminal, shield plate, and center terminal) GT36 Part No. GT17W-6PP-HU HRS No. Packaging RoHS 1 YES HRS No. 767-0078-3 Material / Plating or Color PBT / Dark Gray Packaging 1 RoHS YES HRS No. 767-0080-5 Material / Plating or Color Outer Diameter Ø4.8 to 5.2 Copper alloy / Tin plating HRS No. 767-0079-6 Material / Plating or Color Copper alloy / Tin plating Packaging 1 RoHS YES HRS No. Material / Plating or Color PBT / Dark Gray Silicon / White Packaging RoHS 1 YES 767-0215-2 GT17 Material / Plating or Color PBT / Light Gray Silicon / White ● Insulator Part No. GT17V-6DP-2C GT32 ● Outer terminal Packaging 1 ● Shield plate GT7 Part No. GT17VS-6DP-SC RoHS YES GT3 Part No. GT17VS-6DP-5CF ● Retainer 767-0216-5 Used with 6, and 10 Pos. cable GT18W ● Center terminal GT10 Part No. GT17W-1P/S-R GT25 GT8E GT9 GT15 139 For Network, High speed communication ● Housing GT11 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT17W 4 pos. Right-angle Connector (1 Row type) GT16 9.5 12.85 GT19 4 17.05 3 25 2 PO5G 20.95 1 GT21 8.1 GT26 Key Variation 0.5 1.5 0.5 0.5 1.5 0.5 1.5 GT11 GT36 1.5 1 BThe product comprises 5 parts. (Housing, insulator, outer terminal, retainer, center terminal) Part No. GT17H- 4S-HU GT17H2- 4S-HU GT7 GT10 ● Outer terminal GT18W ● Retainer ● Center terminal Part No. GT17H-4S-5CF Part No. GT17H-4S-R Part No. GT8-2428SCF(70) S ta n d a r d Key A Key B Key C Light Gray Brown Green Blue HRS No. 767- 0085-9 767- 0245-3 Material / Plating or Color HRS No. 767-0084-6 767-0167-1 767-0168-4 767-0169-7 Material / Plating or Color PBT / Light Gray PBT / Brown PBT / Green PBT / Blue HRS No. 767-0087-4 Material / Plating or Color Copper alloy / Tin plating HRS No. 767-0086-1 Material / Plating or Color PBT / Dark Gray PBT / Dark Gray Packaging Remarks ─── With lock guard 1 RoHS YES HRS No. Material / Plating or Color 758-0001-8 70 Phosphor Bronze / Tin plating Packaging RoHS 1 YES Outer Diameter Ø4.8 to 5.2 Packaging 1 Packaging 1 RoHS YES RoHS YES Conductor Size(AWG) 24 to 28 AWG Outer Diameter Ø0.8 to 1.5 Packaging 10,000 pcs/reel RoHS YES BMating Table Board connector GT9 GT8E 1 ● Insulator Part No. GT17H-4S-2C GT17H-4S-2C(A) GT17H-4S-2C(B) GT17H-4S-2C(C) Color Light Gray Brown Green Blue 140 1 ● Housing GT25 GT3 GT32 GT17 1 GT15 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. 5.2 PUSH GT13 GT5 GT17 Series ● For Network, High speed communication Cable side connector GT17H-4S-ASSY GT17H-4S-ASSY(Key typeA) GT17H-4S-ASSY(Key typeB) GT17H-4S-ASSY(Key typeC) SMT Type GT17H-4P-2H/GT17HR-4P-2H GT17H-4P-2H(A) GT17H-4P-2H(B) GT17H-4P-2H(C) DIP Type Angle Type Straight Type GT17H-4P-2DS GT17H-4P-2DSA GT17H-4P-2DS(A) GT17H-4P-2DSA(A) GT17H-4P-2DS(B) GT17H-4P-2DSA(B) GT17H-4P-2DS(C) GT17H-4P-2DSA(C) GT17 Series ● For Network, High speed communication GT5 B Wiring Method (4 Pos. Right-angle 1 Row Type) GT13 GT16 GT19 GT21 GT26 GT36 GT17 GT32 GT3 GT7 GT10 GT18W GT25 GT8E GT9 * Concerning the crimp height of terminals, crimp height settings have been prepared for each type of cable. Please contact a Hirose Electric account representative for further information. Please note that new crimp height settings will be made for new cables and that this might take several days. terminal insertion jig(GT17-4S/PR-MD) GT15 141 For Network, High speed communication GT11 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PO5G Insert center terminal to the insulator. 4 Pos. Straight Connectors (1 Row type) 5.2 7.9 12.85 2 3 φ8.3 1 GT19 30.95 GT21 4 * GT26 Key Variation 0.5 1.5 0.5 0.5 1.5 0.5 1.5 GT17 GT32 GT3 GT7 GT10 GT18W GT25 4 GT8E 3 GT9 2 GT15 1 4 4 3 3 4 142 BThe product comprises 4 parts. (Housing, insulator, outer terminal, center terminal) 1 2 2 3 1 1 1 2 GT11 GT36 1.5 1 Network,HIROSE High speed communication Apr.1.2016 CopyrightFor2016 ELECTRIC CO., LTD. All Rights Reserved. PO5G 8.7 PUSH GT16 GT13 GT5 GT17 Series ● For Network, High speed communication 1 1 S ta n d a r d Key A Key B Key C Light Gray Brown Green Blue ● Housing Part No. GT17HS- 4S-HU GT17HSK- 4S-HU HRS No. 767- 0133-0 767-0244-0 Material / Plating or Color HRS No. 767-0084-6 767-0167-1 767-0168-4 767-0169-7 Material / Plating or Color PBT / Light Gray PBT / Brown PBT / Green PBT / Blue HRS No. 767- 0135-5 Material / Plating or Color Copper alloy / Tin plating PBT / Dark Gray Packaging Remarks ─── With lock guard 1 RoHS YES ● Insulator Part No. GT17H-4S-2C GT17H-4S-2C(A) GT17H-4S-2C(B) GT17H-4S-2C(C) Packaging RoHS 1 YES ● Outer terminal Part No. GT17HS- 4S-5CF Outer Diameter Ø4.8 to 5.2 Packaging 1 RoHS YES ● Center terminal Part No. GT8-2428SCF(70) HRS No. Material / Plating or Color Conductor Size(AWG) Outer Diameter 24 to 28 AWG 758-0001-8 70 Phosphor Bronze / Tin plating Ø0.8 to 1.5 Packaging 10,000 pcs/reel RoHS YES BMating Table Board connector Color Light Gray Brown Green Blue Cable side connector GT17H-4S-ASSY GT17H-4S-ASSY(Key typeA) GT17H-4S-ASSY(Key typeB) GT17H-4S-ASSY(Key typeC) SMT Type GT17H-4P-2H/GT17HR-4P-2H GT17H-4P-2H(A) GT17H-4P-2H(B) GT17H-4P-2H(C) DIP Type Angle Type Straight Type GT17H-4P-2DS GT17H-4P-2DSA GT17H-4P-2DS(A) GT17H-4P-2DSA(A) GT17H-4P-2DS(B) GT17H-4P-2DSA(B) GT17H-4P-2DS(C) GT17H-4P-2DSA(C) GT17 Series ● For Network, High speed communication GT5 B Wiring Method (4 Pos. Straight 1 RowType) GT13 GT16 PO5G GT21 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 GT26 GT36 GT17 GT32 GT3 GT7 GT10 GT18W GT25 GT8E GT9 GT15 * Concerning the crimp height of terminals, crimp height settings have been prepared for each type of cable. Please contact a Hirose Electric account representative for further information. Please note that new crimp height settings will be made for new cables and that this might take several days. terminal insertion jig(GT17-4S/PR-MD) 143 For Network, High speed communication GT11 Center Terminal 4 Pos. Board Connectors (1 Row type, Right-angle SMT Type, Right side key) 0.5 1 1.5 1 Key B Green 1 1 1.5 GT17H-4P-2H GT19 7.2 Standard Light Gray 0.5 PO5G 1 2 3 4 GT17H-4P-2H(B) 0.5 15.45 GT17H-4P-2H 12.2 >PPS GF40< GT17H-4P-2H(C) 0.5 Key A Brown GT17H-4P-2H Key C Blue Part No. GT17H- 4P-2H GT17H- 4P-2H(A) GT17H- 4P-2H(B) GT17H- 4P-2H(C) HRS No. 767-0083-3 767-0170-6 767-0171-9 767-0172-1 Color Light Gray Brown Green Blue Material / Plating Housing:PPS Center terminal:Brass/Tin plating Outer terminal:Copper alloy/Tin plating Packaging RoHS 400 pcs/reel YES 4 Pos. SMT Connector(1 Row type, Left side key) GT3 GT32 GT17 GT11 GT36 GT26 GT21 1.5 GT17H-4P-2H(A) GT7 &*#)* GT17H-4P-2H(S) Standard Light Gray ( ' &
GT17-2428SCF 价格&库存
很抱歉,暂时无法提供与“GT17-2428SCF”相匹配的价格&库存,您可以联系我们找货
