APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
-40 C
TO
STORAGE
TEMPERATURE RANGE
105 C (NOTE1)
RATING
250 V
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
VOLTAGE
-40 C
CURRENT
AC
TO
1
105 C
A
SPECIFICATIONS
ITEM
CONSTRUCTION
TEST METHOD
GENERAL EXAMINATION
MARKING
REQUIREMENTS
QT AT
VISUALLY AND BY MEASURING INSTRUMENT. ACCORDING TO DRAWING.
CONFIRMED VISUALLY.
X
X
X
X
SIGNAL:30 mΩMAX, SHIELD:60mΩMAX.
X
X
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE
CONTACT RESISTANCE
MILLIVOLT LEVEL METHOD
INSULATION RESISTANCE
1A DC.
20 mV AC MAX,
500 V DC
100 MΩ MIN.
X
VOLTAGE PROOF
650 V AC FOR 1 min.
NO FLASHOVER OR BREAKDOWN.
X
INSERTION FORCE
- N MAX.
EXTRACTION FORCE
- N MIN.
① C0NTACT RESISTANCE: SIGNAL:30 mΩMAX, SHIELD:60mΩMAX.
② NO DAMAGE, CRACK AND LOOSENESS OF PARTS.
X
X
0.1 mA(DC OR 1000Hz)
MECHANICAL CHARACTERISTICS
CONTACT INSERTION AND
EXTRACTION FORCES
BY STEEL GAUGE, -.
MECHANICAL OPERATION
30 TIMES INSERTIONS AND EXTRACTIONS.
VIBRATION
FREQUENCY 20 TO 200 Hz,
2
43.1 m/s AT 3 h FOR 3 DIRECTIONS.
① NO ELECTRICAL DISCONTINUITY OF 10 s.
② C0NTACT RESISTANCE: SIGNAL:60 mΩMAX, SHIELD:120mΩMAX.
③ NO DAMAGE, CRACK AND LOOSENESS OF PARTS.
X
X
X
SHOCK
FREQUENCY 20 TO
2
66.6 m/s AT 1 h .
X
X
X
LOCK STRENGTH
APPLYING A PULL FORCE THE MATING
AXIALLY AT 98N MAX.
① DURING APPLYING,MATING COMPLETELY.
② AFTER APPLYING,NO DEFECT OF MATING PARTS.
X
X
50 Hz,
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT
(STEADY STATE)
EXPOSED AT
h.
① C0NTACT RESISTANCE: SIGNAL:60 mΩMAX, SHIELD:120mΩMAX.
② INSULATION RESISTANCE:100 M MIN.
X
X
X
RAPID CHANGE OF
TEMPERATURE
TEMPERATURE-40→5 TO 35→85→5 TO 35C
TIME
30 →
5 → 30 → 5 min
UNDER 1000 CYCLES.
X
X
X
DRY HEAT
EXPOSED AT 105C, 300 h.
X
X
COLD
EXPOSED AT -40C , 120 h.
RESISTANCE TO SO2 GAS
EXPOSED IN 500 PPM FOR 8h.
①
②
①
②
①
②
COUNT
60 C,
90 ~ 95 %,
DESCRIPTION OF REVISIONS
500
NO HEAVY CORROSION.
DESIGNED
REMARK
(NOTE1)
Note
INCLUDE THE TEMPERATURE RISING BY CURRENT.
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test
X:Applicable Test
CHECKED
PART NO.
CODE NO.
X
X
DATE
APPROVED
NH.NAKATA
14.12.24
CHECKED
NH.NAKATA
14.12.24
DESIGNED
TS.KUBOTA
14.12.23
DRAWN
TS.KUBOTA
14.12.23
DRAWING NO.
SPECIFICATION SHEET
X
X
ELC4-168691-00
GT17HNF-4DS-2C(A)
CL767-0259-8-00
0 1/1
很抱歉,暂时无法提供与“GT17HNF-4DS-2C(A)”相匹配的价格&库存,您可以联系我们找货
