GT17HL-26DS-HU
GT17HL-26DS-HU
    HRS(广濑)
    CONN HOUSING 26COND
GT17HL-26DS-HU 数据手册
0.3mm Pitch 1.1mm Height Top and Bottom Contact Back-Flip actuator Flexible Printed Circuit Connectors FH39 Series ●3.45mm Depth 1.1mm 13. 9m m(3 9p os.) m m 45 3. Fig.1 ■Features ●Easy FPC insertion 1. Low-profile 0.3mm pitch connector with top and bottom contact Usable via either its top or bottom contact point, this connector achieves enhanced freedom in terms of the product design. Actuator 2. High contact reliability thanks to the spring terminal structure Because both top and bottom contact points are spring-loaded, the contact point adapts to the FPC motion, and high contact reliability is ensured. FPC 3. Delivered with the actuator open FPC can be immediately inserted without the need for the opening of the actuator. (Fig.2) 4. Easy FPC insertion Entry chamfers at all sides of the FPC insertion slot assure correct insertion and positioning of the FPC. Fig.2 ●Completely locked 5. Accepts standard FPC thickness 0.2mm thick standard Flexible Printed Circuit (FPC) can be used. This is the only ultra-low profile ZIF connector using standard FPC. 6. Conductive traces on the PCB can run under the connector No exposed contacts on the bottom of the connector. 7. Board placement with automatic equipment Flat upper surface and tape and reel packaging facilitate vacuum pick-up and placement. Standard reel packaging contains 5000 connectors. Fig.3 * 8. Halogen-free (FH39J Series) *As defined by IEC61249-2-21 Br-900ppm maximum, Cl-900ppm maximum, Cl + Br combined-1,500ppm maximum 2015.8③ 1 FH39 Series●0.3mm Pitch 1.1mm Height Top and Bottom Contact Back-Flip actuator Flexible Printed Circuit Connectors ■Product Specifications Current rating 0.2A Ratings Voltage rating 30Vrms AC Operating temperature range -55 to +85°C (Note 1) Relative humidity 90% max. Operating (No condensation) humidity range Recommended FPC Item Storage -10 to +50°C (Note 2) temperature range Storage Relative humidity 90% max. humidity range (No condensation) Thickness: 0.2 ± 0.03mm, Gold plated contact pads Specification 1.Insulation resistance Conditions 50Mø min. 100V DC 2.Withstanding voltage No flashover or insulation breakdown 3.Contact resistance 4.Durability 5.Vibration 6.Shock 7.Humidity (Steady state) 8.Temperature cycle 9.Resistance to soldering heat 90Vrms AC / 1 minute 100mø max. * Including FPC and FFC conductor resistance Contact resistance : 100mø max. No damage, cracks, or parts dislocation No electrical discontinuity of 1µs or longer Contact resistance : 100mø max. No damage, cracks, or parts dislocation No electrical discontinuity of 1µs or longer Contact resistance : 100mø max. No damage, cracks, or parts dislocation Contact resistance : 100mø max. Insulation resistance : 50Mø min. No damage, cracks, or parts dislocation Contact resistance : 100mø max. Insulation resistance : 50Mø min. No damage, cracks, or parts dislocation 1mA, AC max (AC: 1kHz) 10 cycles Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 axis Acceleration of 981m/s2, 6ms duration, sine half-wave, 3 cycles in each of the 3 axis 96 hours at 40ç and humidity of 90 to 95% Temperature : -55ç➝+15ç to +35ç➝+85ç➝+15ç to +35ç Time : 30➝ 2 to 3 ➝ 30➝ 2 to 3 minutes 5 cycles No deformation of components affecting Reflow : At the recommended temperature profile performance Manual soldering : 350ç ± 5ç for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage, shipment or during transportation after board mounting. ■Materials / Finish Part Insulator Contacts Material Finish LCP Color : Beige PA Color : Black Gold plated ----------------- Pure tin reflow plated ----------------- Phosphor bronze Metal fittings Remarks UL94V-0 ■Product Number Structure FH 39 J - 51S - 0.3 SHW (10) q w e q Series name : FH w Series No. : 39 e Blank : Standard A : Long actuator type J : Halogen-free (Flame retardance UL94V-0). r t y u r No. of Contacts FH39 : 25 to 61 FH39A : 67 FH39J : 25 to 51 t Contact pitch : 0.3mm y Termination type SHW...SMT horizontal staggered row mount type u Plating specifications (10)...Standard 5,000 pcs/reel (99)...500 pcs/reel 2 FH39 Series●0.3mm Pitch 1.1mm Height Top and Bottom Contact Back-Flip actuator Flexible Printed Circuit Connectors ■Connector Dimensions A±0.15 0.3±0.1 B±0.1 (1.85) 3.55±0.2 (0.12) 0.6±0.1 Production LOT No. (0.12) 0.6±0.1 C±0.1 B (0.15) (D) (0.6) (3.3) E±0.1 B Detailed drawing [FH39 Series] 0.1 1.1±0.1 (1.89) (0.42) (FPC : t 0.2mm) (0.42) (FPC : t 0.2mm) 1.1±0.1 (1.54) 1 1 ) 0.1 0.47±0.1 0.1±0.15 0˚ 0.3±0.1 0.1±0.15 3.25±0.15 (4.15) (2.1) (1.55) (0.85) (9 ˚) Note 1 2 3 4 (90 (3.85) (2.1) (1.55) (0.85) 0.47±0.1 0.1±0.15 1 B Detailed drawing [FH39A Series] 0.3±0.1 0.1±0.15 3.25±0.15 0.1 1 0.1 : The coplanarity of each terminal lead within specified dimension is 0.1 mm Max. : Packaged on tape and reel only. Check packaging specification. : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. : After reflow, the terminal plating may change color, however this does not represent a quality issue. All dimensions : mm Part No. FH39-25S-0.3SHW(10) FH39-27S-0.3SHW(10) FH39-29S-0.3SHW(10) FH39-33S-0.3SHW(10) FH39-39S-0.3SHW(10) FH39-45S-0.3SHW(10) FH39-51S-0.3SHW(10) FH39-61S-0.3SHW(10) FH39A-67S-0.3SHW(10) FH39J-25S-0.3SHW(10) FH39J-33S-0.3SHW(10) FH39J-39S-0.3SHW(10) FH39J-45S-0.3SHW(10) FH39J-51S-0.3SHW(10) HRS No. 580-1806-8 10 580-1805-5 10 580-1807-0 10 580-1803-0 10 580-1800-1 10 580-1802-7 10 580-1801-4 10 580-1808-3 10 580-1809-6 10 580-1815-9 10 580-1814-6 10 580-1813-3 10 580-1811-8 10 580-1812-0 10 No. of Contacts 25 27 29 33 39 45 51 61 67 25 33 39 45 51 A 9.7 10.3 10.9 12.1 13.9 15.7 17.5 20.5 22.3 9.7 12.1 13.9 15.7 17.5 B 6.6 7.2 7.8 9 10.8 12.6 14.4 17.4 19.2 6.6 9 10.8 12.6 14.4 C 7.2 7.8 8.4 9.6 11.4 13.2 15 18 19.8 7.2 9.6 11.4 13.2 15 D 7.83 8.43 9.03 10.23 12.03 13.83 15.63 18.63 20.43 7.83 10.23 12.03 13.83 15.63 E 9.15 9.75 10.35 11.55 13.35 15.15 16.95 19.95 21.75 9.15 11.55 13.35 15.15 16.95 Note 1 : Tape and reel packaging (5,000 pcs/reel, 500 pcs/reel). Note 2 : Order by number of reels. 3 FH39 Series●0.3mm Pitch 1.1mm Height Top and Bottom Contact Back-Flip actuator Flexible Printed Circuit Connectors 0.3±0.03 (0.2) 1±0.05 0.35±0.05 (Metal mask:0.35) 0.6±0.05 (Metal mask:0.25) C±0.05 (Metal mask:1) 0.3±0.05 (Metal mask:0.57) 0.67±0.05 (3.65) (0.1) 0.3±0.03 (Metal mask:0.25) Recommended metal mask thickness : t=0.1 0.6±0.05 0.1±0.05 (Metal mask:0.42) B±0.05 2.48±0.05 0.5±0.05 BRecommended PCB mounting pattern and metal mask dimensions 0.8±0.05 BRecommended FPC Dimensions F±0.05 3.65MIN (Stiffner) 0.1 0.2 0.3 +0.04 -0.03 2.65±0.3 *∞(1) 2.1±0.1 .2 (Uncovered area) R0 0.2±0.03 2.25±0.1 0.3±0.02 1.15±0.1 0.6±0.02 0.3±0.1 0.3 +0.04 -0.03 2- 0.3±0.07 C±0.03 1.05±0.1 0.3±0.07 0.1±0.02 0.6±0.07 B±0.03 0.6±0.07 Note : Stiffener dimension should be 3.65mm min., however if it is not satisfied, X dimension should be 0.5mm or more. All dimensions : mm Part No. FH39-25S-0.3SHW(10) FH39-27S-0.3SHW(10) FH39-29S-0.3SHW(10) FH39-33S-0.3SHW(10) FH39-39S-0.3SHW(10) FH39-45S-0.3SHW(10) FH39-51S-0.3SHW(10) FH39-61S-0.3SHW(10) FH39A-67S-0.3SHW(10) FH39J-25S-0.3SHW(10) FH39J-33S-0.3SHW(10) FH39J-39S-0.3SHW(10) FH39J-45S-0.3SHW(10) FH39J-51S-0.3SHW(10) 4 HRS No. 580-1806-8 10 580-1805-5 10 580-1807-0 10 580-1803-0 10 580-1800-1 10 580-1802-7 10 580-1801-4 10 580-1808-3 10 580-1809-6 10 580-1815-9 10 580-1814-6 10 580-1813-3 10 580-1811-8 10 580-1812-0 10 No. of Contacts 25 27 29 33 39 45 51 61 67 25 33 39 45 51 B 6.6 7.2 7.8 9 10.8 12.6 14.4 17.4 19.2 6.6 9 10.8 12.6 14.4 C 7.2 7.8 8.4 9.6 11.4 13.2 15 18 19.8 7.2 9.6 11.4 13.2 15 F 7.8 8.4 9 10.2 12 13.8 15.6 18.6 20.4 7.8 10.2 12 13.8 15.6 FH39 Series●0.3mm Pitch 1.1mm Height Top and Bottom Contact Back-Flip actuator Flexible Printed Circuit Connectors BRecommended FPC construction 1. Using Single-sided FPC FPC : Flexible Printed Circuit Material Name Material Thickness(µm) Material Covering film layer Cover adhesive Polyimide (25) Surface treatment 0.2µm thick gold plated over 1 to 5µm nickel underplating Copper foil Cu 1oz 35 Base adhesive Thermosetting adhesive 25 Base film Polyimide 25 Reinforcement material adhesive Thermosetting adhesive Stiffener Polyimide 1 mil thick. (25) 3 1 mil thick 40 75 3 mil thick 203 Total 2. Using Double-sided FPC FPC : Flexible Printed Circuit Material Name Covering film layer Material Thickness (µm) Material Polyimide (25) 1 mil thick. (25) Cover adhesive Surface treatment 0.2µm thick gold plated over 1 to 5µm nickel underplating Through-hole copper Cu 15 Copper foil Cu 1/2oz 18 Base adhesive Thermosetting adhesive 18 Base film Polyimide 25 Base adhesive Thermosetting adhesive Copper foil Cu 1/2oz Cover adhesive Thermosetting adhesive 25 Covering film layer Polyimide 1 mil thick. 25 Reinforcement material adhesive Thermosetting adhesive 25 Stiffener Polyimide 1 mil thick 3 18 (18) 25 3 mil thick 197 Total * To prevent release of the FPC due to its bending, use of the double sided FPC with copper foil on the back side is not recommended. 3. Precautions 1 : This specification is a recommendation for the construction of the FH39 Series FPC (t=0.2±0.03). 2 : For details about the construction, please contact the FPC manufacturers. BPackaging Specification ●Embossed Carrier Tape Dimensions (Tape width to 24mm max.) 4±0.1 2±0.15 8±0.1 (0.3) 1.5 1.75±0.1 .1 +0 0 (K) J±0.1 Ø G±0.3 (2.1 : FH39 series) (2.4 : FH39A series) Flat surface, for placement with automatic equipment. (4.65) Unreeling direction (1.85) 5 FH39 Series●0.3mm Pitch 1.1mm Height Top and Bottom Contact Back-Flip actuator Flexible Printed Circuit Connectors 1.5 1.75±0.1 ●Embossed Carrier Tape Dimensions (Tape width 32mm min.) .1 +0 0 H±0.1 +0.15 0 1.7 1.5 +0.1 0 G±0.3 (K) J±0.1 Ø 3) ●Reel Dimensions (Ø80) (Ø380) (Ø1 (L : INSIDE) (M : OUTSIDE) All dimensions : mm 6 Part No. FH39-25S-0.3SHW(10) HRS No. 580-1806-8 10 No. of Contacts 25 FH39-27S-0.3SHW(10) 580-1805-5 10 27 FH39-29S-0.3SHW(10) 580-1807-0 10 29 FH39-33S-0.3SHW(10) 580-1803-0 10 33 --- 13.4 FH39-39S-0.3SHW(10) 580-1800-1 10 39 --- 15.2 FH39-45S-0.3SHW(10) 580-1802-7 10 45 FH39-51S-0.3SHW(10) 580-1801-4 10 51 FH39-61S-0.3SHW(10) 580-1808-3 10 61 FH39A-67S-0.3SHW(10) 580-1809-6 10 67 FH39J-25S-0.3SHW(10) 580-1815-9 10 25 FH39J-33S-0.3SHW(10) 580-1814-6 10 33 FH39J-39S-0.3SHW(10) 580-1813-3 10 39 FH39J-45S-0.3SHW(10) 580-1811-8 10 45 FH39J-51S-0.3SHW(10) 580-1812-0 10 51 G H --- J --24 --- 11.5 28.4 14.2 44 40.4 20.2 ----- 28.4 M 12.2 25.4 29.4 17 18.8 33.4 37.4 21.8 23.6 45.4 49.4 25.4 29.4 33.4 37.4 11 11.5 --32 L 11.6 32 24 K 11 13.4 15.2 14.2 17 18.8 FH39 Series●0.3mm Pitch 1.1mm Height Top and Bottom Contact Back-Flip actuator Flexible Printed Circuit Connectors BConnector Operation and Precautions Operation Exercise care when handling connectors. Follow recommendations given below. 1. As delivered Delivered with the actuator open. There is no need to operate the actuator prior to the insertion of the FPC. The actuator is open when delivered in the embossed tape packaging [Note] •Do not close the actuator if the FPC has not been inserted yet. •If the actuator is closed without the FPC, it can narrow the contact gap and increases the insertion force. 2. FPC insertion Align the FPC perpendicular with the connector and insert it firmly all the way. 3. Locking method q Operate the actuator in a rotational manner and press it down. Rotate and push down on the middle portion or the entire width of the actuator using the finger tip. Be sure to distribute the pressure evenly across the actuator, pressing down on only one side of the actuator may damage the actuator. Excessive force on the housing can also lead to damage or malfunction. Rotate Excessive force after the actuator is already closed Push at the center of the actuator. Do NOT close at the ends. 4. FPC removal (Lock release) qSlowly rotate the actuator in an upward motion. After it is Rotate (lift) unlocked, the FPC can be removed. Do not attempt to open more than 90° wWhen unlocking the actuator, always touch the middle portion of the actuator. Again, be sure to distribute the pressure evenly across the actuator, pressing down on only one side may damage the actuator. The actuator has a maximum opening of 90ç. Do not open (lift) at one end. Lift at the center Trying to open it more than that or applying any unnecessary force to the actuator will cause damage and possibly failure of the connector. * The actuator opens by rotating it in the direction opposite to the direction of the insertion of the FPC. do not attempt to open it from the same side as the insertion of the FPC. 7 FH39 Series●0.3mm Pitch 1.1mm Height Top and Bottom Contact Back-Flip actuator Flexible Printed Circuit Connectors Precautions when mounting connectors on the PCB ◆PC board warpage Minimize the warpage as much as possible. The connector is straight within 0.1 mm max. Make sure that the mounting area flatness can accept the connector terminals without causing any failure of the solder joints. ◆Handling before mounting on PCB Do not apply 0.5N or more external force to the connector before mounting. Insertion of the FPC or operation of the actuator prior to mounting on the PCB is not recommended. ◆Forces on the board When braking the large PC board into individual boards exercise care not to damage the installed connectors. When attaching the boards or other components with the screws make sure that any stresses will not cause board deflections affecting the mounting areas of the connector. Connector FPC (for mounting connectors) Other precautions ◆When hand soldering: • Do not perform hand soldering with the FPC inserted in the connector. • Do not apply excessive heat or touch the soldering iron anywhere other than the connector leads. • Do not use excessive amount of solder or flux compounds. Operation of the actuator or contacts may be affected by excessive amounts of solder or flux compounds. BTemperature Profile MAX 250ç 250 230ç Temperature (ç) 200 200ç 150 150ç 100 HRS test condition Solder method : Reflow, IR/hot air Environment : Room air Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry, Co., Ltd.'s Part No.:M705-221CM5-32-10.5) Test board : Glass epoxy 25mm∞50mm∞0.8mm thick Land dimensions : 0.3mm∞0.5mm, 0.3mm∞0.67mm Metal mask : 0.25∞0.42, 0.25∞0.57∞0.1mm thick 50 25ç (60 sec.) 90 sec. to 120 sec. Preheating 0 Soldering Start Time (Seconds) ® 8 (60 sec.) The temperature profiles shown are based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume / thickness and board size / thickness. Consult your solder paste and equipment manufacturer for specific recommendations. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2015. Contents are subject to change without notice for the purpose of improvements.
GT17HL-26DS-HU 价格&库存
很抱歉,暂时无法提供与“GT17HL-26DS-HU”相匹配的价格&库存,您可以联系我们找货
