N237-001-SH
N237-001-SH
    TRIPPLITE
    CONNWRGBLOCKSCREWHOLES
N237-001-SH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e/6 Shielded Surface-Mount Junction Box, 110 IDC, TAA MODEL NUMBER: N237-001-SH Highlights ● Uses standard 110 punchdown termination ● Recommended for use with solid conductor cable ● Color-coded for 568A/B wiring ● Protects against EMI/RFI line noise ● Dedicated space on punchdown block for grounding Package Includes Fast, easy, cost-effective way to directly connect 2 Cat5e/6 cables without using couplers or connectors. Ideal for audio/video, voice and Ethernet applications. Description The N237-001-SH Cat5e/6 Shielded Surface-Mount Junction Box is a fast, easy, cost-effective method of directly connecting two Cat5e/6 cables without using couplers or connectors. Designed for completing audio/video, voice and Ethernet applications, this junction box comes with screws and double-sided adhesive tape for quick mounting, as well as cable ties for keeping the cables neat and secure. It’s made from ABS UL 94V-0 plastic and is recommended for use with solid conductor cable. The UL-listed box is color-coded for 568A/B wiring for easy 110 punchdown termination. The shielded N237-001-SH protects the signal against EMI/RFI line noise and has a dedicated space on the punchdown block for grounding. Features Completes A/V, Voice and Ethernet Applications ● Directly connects 2 Cat5e/6 cables without couplers or connectors ● Uses standard 110 punchdown termination ● Recommended for use with solid conductor cable ● Protects against EMI/RFI line noise ● Dedicated space on punchdown block for grounding ● Color-coded for 568A/B wiring ● Mounting hardware and cable ties included ● Durable ABS UL 94V-0 plastic housing TAA-Compliant ● Complies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW 1/2 ● N237-001-SH Cat5e/6 Shielded Surface-Mount Junction Box ● Mounting hardware ● (2) Nylon cable ties 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332197320 Technology Cat5/5e; Cat6 Country/Region Global PHYSICAL Color Silver Total Number of Ports 0 Shipping Dimensions (hwd / in.) 0.25 x 4.90 x 4.09 Shipping Dimensions (hwd / cm) 0.64 x 12.45 x 10.39 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 CONNECTIONS Side A - Connector 1 110 IDC Side B - Connector 1 110 IDC FEATURES & SPECIFICATIONS Antibacterial No STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N237-001-SH 价格&库存
很抱歉,暂时无法提供与“N237-001-SH”相匹配的价格&库存,您可以联系我们找货
