Modular Plug Connectors Compliant to Enhanced Category 5 Standards
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
TM21P Series (Shielded Type)
TM22P-88P (Non-shielded Type)
■Features
1. Supports High-Speed LAN Transmission
Conforms to requirements of TIA/EIA-568B data
wiring standard, meeting transmission performance
of Enhanced Category 5.
Supports Gigabit Ethernet (1000BASE-T) and Fast
Ethernet (100BASE-TX) high-speed LAN
transmission.
Protected latch tab
2. EMI protection (TM21*P-88P)
360° coverage of the engagement area with a metal
shield assures protection against electromagnetic
interference. When mated with corresponding
connector the shield surfaces are securely
connected to provide continuous circuit.
3. Protected latch tab (TM21P-88P)
Flexible case extends over the release tab
preventing the possibility of breaking-off during
handling of the complete cable assembly.
4. Termination of conductors
1
Self located 24 AWG conductors (solid or stranded)
are terminated against pre-inserted contacts using
simple tooling.
5. Simplified termination (TM21*P-88P)
2
Removeable one piece cover allows easy access to
the termination areas.
6. Conforms to the ISO 8877 Standard
(ISDN Interface Connector)
1
1
■Applications
Telecom Hubs, Routers, Bridges and ATM
Transmission Equipment, Ethernet Switches and
Networking Equipment, Test and Measurement
Equipment and other equipment requiring this type of
simple and reliable connection.
Cover Installation Procedure
2022.2⑤
1
TM21P Series●Modular Plug Connectors Compliant to Enhanced Category 5 Standards
■Product Specification
Current rating
1A
Operating temperature range : -25 to +60ç (Note)
Voltage rating
125V AC
Storage temperature range :
Rating
Item
-25 to +60ç
Specification
Conditions
1. Insulation resistance
100Mø min.
100V DC
2. Withstanding voltage
(between adjacent contacts)
No flashover or insulation breakdown
500V AC / 1minute
3. Withstanding voltage
(between contact and shield)
1500V AC / 1minute
4. Contact resistance
230mø max.
100mA DC
5. Vibration
No electrical discontinuity of 5 μsec min.
Contact resistance : 250mø max.
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
5 min/cycle, 10 times for 3 directions
Acceleration of 490 m/s2, 11 ms duration,
sine half-wave waveform, 3 cycles in each of the 3 axis
7. Durability
(mating/un-mating)
200
8. Temperature cycle
6. Shock
Temperature : -55ç/+5ç to +35ç/+85ç/+5ç to +35ç
Duration : 30/5/30/5(Minutes)
5 cycles
Insulation resistance : 100Mø min.
9. Humidity
10. Salt Spray
Insulation resistance : 1Mø min. (High humidity)
Insulation resistance : 10Mø min. (Dry state)
500 hours at temperature of 40ç and humidity of 90% to 95%
Exposed to density 5% salt water for 48 hours
Note : Includes temperature rise caused by current flow.
■Materials / Finish
Part
Material
Finish
Remarks
Polycarbonate
Color : Clear
UL94V-2
Contacts
Copper alloy
Contact area : Gold plating 1.27μm
Shield
Copper alloy
Tin plating
Polycarbonate
Color : Clear
UL94V-2
Polyamide
Color : Light beige (Note)
UL94V-2
Insulator
Conductor holding tray
Cover
Note : Cover available in various colors. Refer to page 3.
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Plugs- Shielded
●Plugs - Non-shielded
TM21 C P - 8 8P
1
1 Series name
2
2
1
3
TM22P - 8 8P
4
1
2
3
TM21P : Shielded
1 Series name
TM22P : Non-shielded
2 Cover Type
Blank : Protective latch cover
2 Size
8 : For 8 contacts
C : Short cover
3 Inserted contacts
8P: 8
3 Size
8 : For 8 contacts
4 Inserted contacts
8P : 8
■Plug Connectors
6.7
Cover
(34)
30.2
9
16.6
11.7
6.09
3.5
(R
Contact No. 1
29.5
3.45
(0.6)
12.9
17.5
6.6
●Shielded
Contact No.8
5.4
9.05
Part No.
TM21P-88P
TM21P-88P(11)
TM21P-88P(12)
TM21P-88P(13)
TM21P-88P(14)
TM21P-88P(15)
TM21P-88P(16)
TM21P-88P(17)
TM21P-88P(18)
TM21P-88P(19)
HRS No.
222-2862-9 00
222-2862-9 11
222-2862-9 12
222-2862-9 13
222-2862-9 14
222-2862-9 15
222-2862-9 16
222-2862-9 17
222-2862-9 18
222-2862-9 19
BCover installed
Cover Color
Light beige
Light beige
Medium gray
Black
Natural light gray
Red
Green
Blue
Yellow
Orange
Remarks
Plug unit and Cover
Cover
Cover
Cover
Cover
Cover
Cover
Cover
Cover
Cover
RoHS
YES
BMated with corresponding receptacle
(shown for reference only)
(34)
(13.4)
(44.65)
3
■Plug Connectors
●Shielded-Short Cover
6.7
17.2
TM21CP-8
TM21CP-8
9
(R
3.
5)
30.2
10.4
(22.4)
11.7
6.09
Cover
3.45
12.9
(0.6)
6.6
17.5
Contact No.8
Contact No.1
5.4
9.05
Part No.
HRS No.
Cover color
RoHS
TM21CP-88P(03)
222-2884-1 03
Black
YES
Note : For other colors contact Hirose sales representative.
BCover installed
(21.7)
TM21CP-8
TM21CP-8
(32.35)
(13.4 )
BApplicable Shielded Cable Specifications
Specifications
Solid copper conductor : 0.5mm dia.
Jacket
Conductor
Shield
Stranded copper conductor : 24 AWG
(Dia. 0.2mm x 7 pcs)
Insulation
Conductor
Individual conductor insulation dia.
(0.9mm to 1.0mm)
Drain wire
26 AWG (tin coated)
Overall jacket dia.
(dia. 6.6mm)
Drain wire
Note : For cable termination procedures refer to:
[TM21P-88P Cable Termination Procedure Manual] (ETA-E2349) and [TM21CP-88P Cable termination Procedure Manual]
(ETA-E2353).
Some cables may not meet the required service ratings. Contact Hirose sales representative for specific cable applications
recommendations.
4
■Plug Connectors
●Non-shielded
6.6
9.05
(0.6)
7.9
14.2
5.4
3.45
6.09
11.7
22.5
Contact No.1
Part No.
HRS No.
RoHS
TM22P-88P
222-2899-9
YES
Contact No.8
BMated with corresponding receptacle (shown for reference only)
(11.85)
BApplicable Non-shielded Cable Specifications
Specifications
Jacket
Conductor
(0.9mm to 1.0mm)
Overall jacket dia.
(dia. 5.4mm to 5.7mm)
Conductor
Insulation
Note : For cable termination procedures refer to :
[TM22P-88P Cable Termination Procedure Manual] (ETA-E2381).
recommendations.
5
BHand termination tools
●For contact/conductor termination (For cable and shield crimping)
Part No.
HRS No.
HT603/TM21P-88P
902-2532-0
●For contact/conductor termination (Non-shielded connectors)
HRS marking side
(For contact/conductor termination)
A
Reverse side
(For cable strain relief clamp crimping)
6
Part No.
HRS No.
HT601-TM23/22P-88P
902-2128-1
Applicable connector
TM22P-88P
TM23P-88P
TM21P-88P
TM21CP-88P
BTechnical Documentation
●CAT5e Transmission Characteristics Data
These are the representative values of the various transmission characteristics data for connector assemblies
TM21P-88P and TM21R-5C-88-LP when fully mated.
• Signal Attenuation
0.4
0.3
0.2
0.1
40
50
60
70
80
90
100
Frequency(MHz)
1,2
3,6
4,5
7,8
CAT5e Spec
(Each two numbers are for the pair of individual contact position.)
• Near-End Crosstalk Attenuation (NEXT)
120
NEXT(dB)
100
80
60
40
40
50
60
70
80
90
100
Frequency(MHz)
1,2-3,6
1,2-4,5
1,2-7,8
3,6-4,5
3,6-7,8
4,5-7,8
CAT5e Spec
• Return Loss
80
Return Loss(dB)
Attenuation(dB)
0.5
60
40
40
50
60
70
80
90
100
Frequency(MHz)
1,2
3,6
4,5
7,8
CAT5e Spec
7
• Far-End Crosstalk Attenuation (FEXT)
120
FEXT(dB)
100
80
60
40
1,2-3,6
3,6-4,5
4,5-7,8
CAT-5e Spec
40
50
60
Frequency(MHz)
1,2-4,5
3,6-7,8
7,8-1,2
70
80
1,2-7,8
4,5-1,2
7,8-3,6
90
100
3,6-1,2
4,5-3,6
7,8-4,5
(Each two numbers are for pair of individual contact position.)
• Propagation Delay
3
Delay(ns)
2.5
2
1.5
1
0.5
40
50
60
70
80
90
100
Frequency(MHz)
1,2
3,6
4,5
7,8
CAT5e Spec
• Propagation Delay skew
1.4
Delay Skew(ns)
1.2
1
0.8
0.6
0.4
0.2
40
50
60
70
80
90
100
Frequency(MHz)
Measurement Value
8
CAT5e Spec
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 02/2022. Contents are subject to change without notice for the purpose of improvements.
