The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
CL 222 TM
Plug for copper foil, stranded wire flat type cable
●Material・Finish
●Electrical Performance
Condition
Specification
Plug case
Polycarbonate
Clear
Current rating
Per pin
0.5A
Terminal
Phosphor Bronze
Gold plated
Voltage rating
Per pin
125V AC
Insulation Resistance
100V DC
100 M Ω Min.
Withstanding Voltage
1 minute
500V r.m.s AC
Part name
Material
Finish
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Applicable Cable
Conductor diameter
Copper foil or AWG # 26
Insulator diameter
φ0.9-φ1.0
Item
●TM3P-44P
CL No.
222-0207-2
Part No.
TM3P-44P
RoHS
YES
Insulator
Applicable cable section
(Packing unit: 100 Pcs.)
CL No.
222-0278-0
222-0208-5
222-0209-8
●TM3P-62P, 64P & 66P
Part No.
TM3P-62P
TM3P-64P
TM3P-66P
RoHS
YES
Insulator
Note: Shown TM3P-64P.
−31−
CL 222 TM
●TM8P-88P
CL No.
222-1817-9
Part No.
TM8P-88P
RoHS
YES
Insulator
−32−
CL 222 TM
Plug for copper foil, stranded wire circular type cable
●Material・Finish
Condition
Specification
Plug case
Polycarbonate
Material
Clear
Current rating
Per pin
0.5A
Terminal
Phosphor Bronze
Gold plated
Voltage rating
Per pin
125V AC
100V DC
100 M Ω Min.
1 minute
500V r.m.s AC
Part name
Finish
Applicable Cable
Conductor diameter
Insulator diameter
φ0.9-φ1.0
Item
●TM4P-44P
CL No.
222-0279-3
Part No.
TM4P-44P
RoHS
YES
Insulator
●TM4P-64P & 66P
CL No.
222-0280-2
222-0281-5
Part No.
TM4P-64P
TM4P-66P
RoHS
YES
TM4P-64P
TM4P-66P
Insulator
Note: Shown TM4P-64P.
−33−
CL 222 TM
●TM10P-88P
CL No.
222-1818-1
Part No.
TM10P-88P
RoHS
YES
Insulator
−34−
Plug Connector Cable Assembly Tool
Hand Tool
CL902-2205-0
HT601-TM3/4P-44P
CL902-2206-3
HT601-TM3/4P-64P
CL902-2207-6
HT601-TM3/4P-66P
HT601-TM3/4P-66P
CL 222 TM
Plug for Solid Wire Cable
●Material・Finish
Condition
Specification
Plug case
Polycarbonate
Material
Clear
Current rating
Per pin
0.5A
Terminal
Phosphor Bronze
Gold plated
Voltage rating
Per pin
30V AC
100V DC
100 M Ω Min.
1 minute
500V r.m.s AC
Part name
Finish
Item
Applicable Cable
Conductor diameter
φ0.4∼φ0.65 *
Insulator diameter
φ0.96 max.
* In case of use φ0.65, not to be connected fully for 6 pins
and 8 pins depend on size of insulator diameter.
●TM20P-66P
CL No.
222-2275-3
Mating Condifiton Figure
Part No.
TM20P-66P
RoHS
YES
●TM20P-88P
CL No.
222-2217-7
Part No.
TM20P-88P
RoHS
YES
Exclusive Hand Tool for Connection
CL No.
250-0240-7
250-0241-0
−36−
Part No.
TC2-TM20P-66P
TC2-TM20P/30P-88P
Applicable Connector
TM20P-66P
TM20P-88P
CL 222 TM
Plug for Thin Wire Cable
●Material・Finish
Part name
Plug case
Terminal
Condition
Specification
Polycarbonate
Material
6 Pins
Clear blue
Finish
Current rating
Per pin
0.5A
8 Pins
Clear
Voltage rating
Per pin
125V AC
Gold plated
100V DC
100 M Ω Min.
1 minute
500V r.m.s AC
Phosphor Bronze
Item
*UL94V-0
Applicable Cable
Conductor diameter
AWG # 28(7/0.127)
Insulator diameter
φ0.787 max.
●TM30P-66P
CL No.
222-2684-2
Part No.
TM30P-66P
RoHS
YES
Vinyl Sheath
Drain wire
Insulator
●TM30P-88P
CL No.
222-2685-5
Part No.
TM30P-88P
RoHS
YES
Vinyl Sheath
Drain wire
Insulator
CL No.
250-0145-6
250-0241-0
−37−
Part No.
TC1-TM30P-66P
TC2-TM20P/30P-88P
TM30P-66P
TM30P-88P
很抱歉,暂时无法提供与“TM10P-88P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.62969
- 10+8.14767
- 50+7.41737
- 100+6.03596
- 200+5.64882
- 800+5.63122
- 1600+4.86573
