TM21P-TM-88P(63)
TM21P-TM-88P(63)
    HRS(广濑)
    CONN MOD PLUG
TM21P-TM-88P(63) 数据手册
Modular Plug Connectors Compliant to Enhanced Category 5 Standards Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM21P Series (Shielded Type) TM22P-88P (Non-shielded Type) ■Features 1. Supports High-Speed LAN Transmission Conforms to requirements of TIA/EIA-568B data wiring standard, meeting transmission performance of Enhanced Category 5. Supports Gigabit Ethernet (1000BASE-T) and Fast Ethernet (100BASE-TX) high-speed LAN transmission. Protected latch tab 2. EMI protection (TM21*P-88P) 360° coverage of the engagement area with a metal shield assures protection against electromagnetic interference. When mated with corresponding connector the shield surfaces are securely connected to provide continuous circuit. 3. Protected latch tab (TM21P-88P) Flexible case extends over the release tab preventing the possibility of breaking-off during handling of the complete cable assembly. 4. Termination of conductors 1 Self located 24 AWG conductors (solid or stranded) are terminated against pre-inserted contacts using simple tooling. 5. Simplified termination (TM21*P-88P) 2 Removeable one piece cover allows easy access to the termination areas. 6. Conforms to the ISO 8877 Standard (ISDN Interface Connector) 1 1 ■Applications Telecom Hubs, Routers, Bridges and ATM Transmission Equipment, Ethernet Switches and Networking Equipment, Test and Measurement Equipment and other equipment requiring this type of simple and reliable connection. Cover Installation Procedure 2022.2⑤ 1 TM21P Series●Modular Plug Connectors Compliant to Enhanced Category 5 Standards ■Product Specification Current rating 1A Operating temperature range : -25 to +60ç (Note) Voltage rating 125V AC Storage temperature range : Rating Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item -25 to +60ç Specification Conditions 1. Insulation resistance 100Mø min. 100V DC 2. Withstanding voltage (between adjacent contacts) No flashover or insulation breakdown 500V AC / 1minute 3. Withstanding voltage (between contact and shield) No flashover or insulation breakdown 1500V AC / 1minute 4. Contact resistance 230mø max. 100mA DC 5. Vibration No electrical discontinuity of 5 μsec min. Contact resistance : 250mø max. Frequency : 10 to 55Hz, single amplitude of 0.75mm, 5 min/cycle, 10 times for 3 directions No electrical discontinuity of 5 μsec min. Contact resistance : 250mø max. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 7. Durability (mating/un-mating) Contact resistance : 250mø max. 200 8. Temperature cycle Contact resistance : 250mø max. 6. Shock Temperature : -55ç/+5ç to +35ç/+85ç/+5ç to +35ç Duration : 30/5/30/5(Minutes) 5 cycles Insulation resistance : 100Mø min. 9. Humidity 10. Salt Spray Contact resistance : 250mø max. Insulation resistance : 1Mø min. (High humidity) Insulation resistance : 10Mø min. (Dry state) 500 hours at temperature of 40ç and humidity of 90% to 95% Contact resistance : 250mø max. Exposed to density 5% salt water for 48 hours Note : Includes temperature rise caused by current flow. ■Materials / Finish Part Material Finish Remarks Polycarbonate Color : Clear UL94V-2 Contacts Copper alloy Contact area : Gold plating 1.27μm ------- Shield Copper alloy Tin plating ------- Polycarbonate Color : Clear UL94V-2 Polyamide Color : Light beige (Note) UL94V-2 Insulator Conductor holding tray Cover Note : Cover available in various colors. Refer to page 3. ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Plugs- Shielded ●Plugs - Non-shielded TM21 C P - 8 8P 1 1 Series name 2 2 1 3 TM22P - 8 8P 4 1 2 3 TM21P : Shielded 1 Series name TM22P : Non-shielded 2 Cover Type Blank : Protective latch cover 2 Size 8 : For 8 contacts C : Short cover 3 Inserted contacts 8P: 8 3 Size 8 : For 8 contacts 4 Inserted contacts 8P : 8 TM21P Series●Modular Plug Connectors Compliant to Enhanced Category 5 Standards ■Plug Connectors 6.7 Cover (34) 30.2 9 16.6 11.7 6.09 ) 3.5 (R Contact No. 1 29.5 Conductor holding tray 3.45 (0.6) 12.9 17.5 6.6 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Shielded Contact No.8 5.4 9.05 Part No. TM21P-88P TM21P-88P(11) TM21P-88P(12) TM21P-88P(13) TM21P-88P(14) TM21P-88P(15) TM21P-88P(16) TM21P-88P(17) TM21P-88P(18) TM21P-88P(19) HRS No. 222-2862-9 00 222-2862-9 11 222-2862-9 12 222-2862-9 13 222-2862-9 14 222-2862-9 15 222-2862-9 16 222-2862-9 17 222-2862-9 18 222-2862-9 19 BCover installed Cover Color Light beige Light beige Medium gray Black Natural light gray Red Green Blue Yellow Orange Remarks Plug unit and Cover Cover Cover Cover Cover Cover Cover Cover Cover Cover RoHS YES BMated with corresponding receptacle (shown for reference only) (34) (13.4) (44.65) 3 TM21P Series●Modular Plug Connectors Compliant to Enhanced Category 5 Standards ■Plug Connectors ●Shielded-Short Cover 6.7 17.2 TM21CP-8 TM21CP-8 9 (R 3. 5) 30.2 10.4 (22.4) 11.7 6.09 Cover Conductor holding tray 3.45 12.9 (0.6) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6.6 17.5 Contact No.8 Contact No.1 5.4 9.05 Part No. HRS No. Cover color RoHS TM21CP-88P(03) 222-2884-1 03 Black YES Note : For other colors contact Hirose sales representative. BCover installed BMated with corresponding receptacle (shown for reference only) (21.7) TM21CP-8 TM21CP-8 (32.35) (13.4 ) BApplicable Shielded Cable Specifications Specifications Solid copper conductor : 0.5mm dia. Jacket Conductor Shield Stranded copper conductor : 24 AWG (Dia. 0.2mm x 7 pcs) Insulation Conductor Individual conductor insulation dia. (0.9mm to 1.0mm) Drain wire 26 AWG (tin coated) Overall jacket dia. (dia. 6.6mm) Drain wire Note : For cable termination procedures refer to: [TM21P-88P Cable Termination Procedure Manual] (ETA-E2349) and [TM21CP-88P Cable termination Procedure Manual] (ETA-E2353). Some cables may not meet the required service ratings. Contact Hirose sales representative for specific cable applications recommendations. 4 TM21P Series●Modular Plug Connectors Compliant to Enhanced Category 5 Standards ■Plug Connectors ●Non-shielded Conductor holding tray 6.6 9.05 (0.6) 7.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 14.2 5.4 3.45 6.09 11.7 22.5 Contact No.1 Part No. HRS No. RoHS TM22P-88P 222-2899-9 YES Contact No.8 BMated with corresponding receptacle (shown for reference only) (11.85) BApplicable Non-shielded Cable Specifications Specifications Solid copper conductor : 0.5mm dia. Jacket Conductor Stranded copper conductor : 24 AWG (Dia. 0.2mm x 7 pcs) Individual conductor insulation dia. (0.9mm to 1.0mm) Overall jacket dia. (dia. 5.4mm to 5.7mm) Conductor Insulation Note : For cable termination procedures refer to : [TM22P-88P Cable Termination Procedure Manual] (ETA-E2381). Some cables may not meet the required service ratings. Contact Hirose sales representative for specific cable applications recommendations. 5 TM21P Series●Modular Plug Connectors Compliant to Enhanced Category 5 Standards BHand termination tools Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●For contact/conductor termination (For cable and shield crimping) Part No. HRS No. HT603/TM21P-88P 902-2532-0 ●For contact/conductor termination (Non-shielded connectors) HRS marking side (For contact/conductor termination) A Reverse side (For cable strain relief clamp crimping) 6 Part No. HRS No. HT601-TM23/22P-88P 902-2128-1 Applicable connector TM22P-88P TM23P-88P Applicable connector TM21P-88P TM21CP-88P TM21P Series●Modular Plug Connectors Compliant to Enhanced Category 5 Standards BTechnical Documentation ●CAT5e Transmission Characteristics Data These are the representative values of the various transmission characteristics data for connector assemblies TM21P-88P and TM21R-5C-88-LP when fully mated. • Signal Attenuation 0.4 0.3 0.2 0.1 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2 3,6 4,5 7,8 CAT5e Spec (Each two numbers are for the pair of individual contact position.) • Near-End Crosstalk Attenuation (NEXT) 120 NEXT(dB) 100 80 60 40 20 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2-3,6 1,2-4,5 1,2-7,8 3,6-4,5 3,6-7,8 4,5-7,8 CAT5e Spec • Return Loss 80 Return Loss(dB) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Attenuation(dB) 0.5 60 40 20 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2 3,6 4,5 7,8 CAT5e Spec 7 TM21P Series●Modular Plug Connectors Compliant to Enhanced Category 5 Standards • Far-End Crosstalk Attenuation (FEXT) 120 FEXT(dB) 100 80 60 40 20 0 0 10 20 30 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1,2-3,6 3,6-4,5 4,5-7,8 CAT-5e Spec 40 50 60 Frequency(MHz) 1,2-4,5 3,6-7,8 7,8-1,2 70 80 1,2-7,8 4,5-1,2 7,8-3,6 90 100 3,6-1,2 4,5-3,6 7,8-4,5 (Each two numbers are for pair of individual contact position.) • Propagation Delay 3 Delay(ns) 2.5 2 1.5 1 0.5 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2 3,6 4,5 7,8 CAT5e Spec • Propagation Delay skew 1.4 Delay Skew(ns) 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) Measurement Value 8 CAT5e Spec The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 02/2022. Contents are subject to change without notice for the purpose of improvements.
TM21P-TM-88P(63)
文档中的物料型号是:SN74LS241N,SN74LS241DR,SN74LS241DBR,SN74LS241D,SN74LS241N。
器件简介为8位三态输出寄存器。
引脚分配如下:1引脚为Vcc,2引脚为A,3引脚为B,4引脚为C,5引脚为D,6引脚为E,7引脚为F,8引脚为G,9引脚为H,10引脚为I/O1至8,16引脚为GND。
参数特性包括电源电压范围2.0V至6.0V,工作温度范围-40℃至+85℃,封装类型为N,D,DB,PDIP,SOIC。
功能详解为8位移位寄存器,具有三态输出,用于数据存储和传输。
应用信息为用于数据存储、传输、计数器、移位寄存器等。
封装信息为N型、D型、DB型、PDIP型、SOIC型。
TM21P-TM-88P(63) 价格&库存
很抱歉,暂时无法提供与“TM21P-TM-88P(63)”相匹配的价格&库存,您可以联系我们找货
