APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
RATING
125 V AC
VOLTAGE
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
STORAGE
TEMPERATURE RANGE
-25C TO 60C
-25C TO 60C
100 mA
CURRENT
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
CONSTRUCTION
GENERAL EXAMINATION
VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ACCORDING TO DRAWING.
ELECTRIC CHARACTERISTICS
100 mA (DC OR 1000 Hz AC).
MEASUREMENT POINTS SHALL BE AS FOLLOWS.
CONTACT RESISTANCE
230
m MAX.
TEST POINT
100 mm
PLUG
MODULAR CABLE
RECEPTACLE
(ONE EXAMPLE OF CONNECTOR CONFIGURTION
IS S H O W N . )
100 V DC.
INSULATION RESISTANCE
1
100
500 V AC FOR 1 min.
VOLTAGE PROOF
M MIN.
NO FLASHOVER OR BREAKDOWN.
MECHANICAL CHARACTERISTICS
200
MECHANICAL OPERATION
① CONTACT RESISTANCE: 250 m MAX.
② NO DAMAGE, CRACK AND LOOSENESS
TIMES INSERTIONS AND EXTRACTIONS.
OF PARTS.
VIBRATION
FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE
0.75 mm, ― m/s2 AT 2h, FOR 3 DIRECTIONS.
490
SHOCK
AT
m/s2 DURATION OF PULSE 11 ms
TIMES FOR 3 DIRECTIONS.
3
OF PARTS.
RUBBER PROBE Φ6.9 ± 0.5 mm, DIAMETER SHALL BE
INSERTED AND WITHDRAWN.
(TEST STANDARD:UL1863)
RUBBER PROBE
① NO ELECTRICAL DISCONTINUITY OF 5s.
② CONTACT RESISTANCE: 250 m MAX.
③ NO DAMAGE, CRACK AND LOOSENESS
NO DEFECT AT WITHDRAWING.
ENVIRONMENTAL CHARACTERISTICS
40C,
, 500 h
② INSULATION RESISTANCE:
1 M MIN. (AT HIGH HUMIDITY)
10 M MIN. (AT DRY)
DAMP HEAT
(STEADY STATE)
EXPOSED AT
RAPID CHANGE OF
TEMPERATURE
TEMPERATURE –55±3→5 TO 35→85±2→5 TO 35 ℃
TIME
30 TO 35→5 MAX→30 TO 35→5 MAX min
UNDER 5 CYCLES.
CORROSION SALT MIST
EXPOSED IN
48 h.
90 TO 95
OF PARTS.
② INSULATION RESISTANCE: 100 M MIN.
OF PARTS.
1
5 % SALT WATER SPRAY FOR
② NO HEAVY CORROSION.
COUNT
DESCRIPTION OF REVISIONS
DESIGNED
4
DIS-E-00002925
KIM JAEHYEON
REMARK
Unless otherwise specified, refer to IEC 60512.
Note
QT:Qualification Test
AT:Assurance Test X:Applicable Test
PART NO.
CODE NO.
FORM HD0011-2-1
m MAX.
CHECKED
DATE
TU.TANIGUCHI
20200326
APPROVED
HO.MIWA
20050105
CHECKED
TH.KAMEYA
20050105
DESIGNED
SS.SATOH
20050105
DRAWN
SS.SATOH
20050105
DRAWING NO.
SPECIFICATION SHEET
250
ELC-120679-03-06
TM11AP-88P(03)
CL222-2780-6-03
1
1/1
很抱歉,暂时无法提供与“TM11AP-88P(03)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+91.52611
- 5+52.09948
- 11+46.64311
- 100+33.53024
