A00-432-662-450
A00-432-662-450
    插件
A00-432-662-450 数据手册
ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 2.327±.010(59.10±0.25) ORIGINAL 1 0.839±.010 0.550 (21.30±0.25) (13.98) 0.535 (13.60) 0.145 (3.68) 0.425 (10.80) 2.100±.010(53.34±0.25) A00-432-262-450 GOLD FLASH A00-432-362-450 15 MICROINCHES OF GOLD A00-432-662-450 30 MICROINCHES OF GOLD A00-432-962-450 50 MICROINCHES OF GOLD 0.100 (2.54) 0.250 (6.35) 0.145 (3.68) NOTES 0.400 ELECTRICAL CHARACTERISTICS: - CONTACT RESISTANCE: 30 MILLIOHMS MAX. - INSULATION RESISTANCE: 500 MEGOHMS MIN. - WITHSTANDING VOLTAGE : 500 VAC 1 MINUTE - CURRENT RATING: 1.5 AMP ( 0.126 3.20) ( 0.035 0.90) (13.98) (10.16) BODY: GLASS FILLED POLYESTER, UL94V-0 RATED CONTACTS: PHOSPHOR BRONZE(0.45mm DIA.) SELECTIVE GOLD ON CONTACTS AS PER PART NO. TABLE, TIN ON TERMINATION, ALL OVERNICKEL UNDERPLATE. SHIELD: 0.25mm THICK COPPER ALLOY PLATED WITH NICKEL 0.063 1.60) 2.100(53.34) 0.550 0.250 (6.35) MATERIAL AND FINISH: ( 2.318(58.90) 0.050 (1.27) 0.550 0.100 (2.54) 0.550 (13.98) (13.98) 0.550X3=1.651 (13.97X3=41.94) Ø0.063(1.60) PC BOARD LAYOUT COMPONENT SIDE SHOWN THIS SERIES FULLY CONFORMS TO THE EUROPEAN UNION DIRECTIVES 2002/95/EC COMPLIANT AND 2002/96/EC FOR RoHS COMPLIANCY. ACAD REF. DWG.: A00-432-262-450 4 PORTS, 8 POSITIONS DRAWN:F.BRIONES SHIELDED PCB JACK (GROUND AT FRONT) TOLERANCE UNLESS NOTED EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE .00 0.01 .000 .006 .0000 .003 ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. DATE: SEPT.16/02 CHECKED: DATE: SCALE: N.T.S SHEET 1 OF 1 DRAWING NUMBER A00-432-262-450 ISSUE 2
A00-432-662-450 价格&库存
很抱歉,暂时无法提供与“A00-432-662-450”相匹配的价格&库存,您可以联系我们找货
