EHRJ45P6IDC
EHRJ45P6IDC
    SWITCHCRAFT
EHRJ45P6IDC 数据手册
8 7 6 0.748 19.00 5 4 3 2 1 RJ45 SHIELDED IDC CONNECTOR 0.374 9.50 SWITCHCRAFT HOUSING 0.945 24.00 F F RJ45 IDC CONNECTOR FRONT VIEW CAT 5e SHIELDED OR UNSHIELDED 0.945 24.00 FRONT VIEW CAT 6 SHIELDED OR UNSHIELDED 0.473 12.00 WIRING LABEL SEE NOTE 5 2X FIGURE 1 RECOMMENDED PANEL CUT-OUT E WIRING LABEL SEE NOTE 5 SHIELD COVER 1.25 31.8 0.76 19.2 0.71 18.0 FIGURE 2 RECOMMENDED CABLE STRIPPING DETAIL TYPICAL FOR ALL BREAKOUTS SEE NOTE 4 D IDC CAPS (2) ASSEMBLY INSTRUCTIONS: C 1.72 43.8 A. INSTALL THE CABLE CONDUCTORS INTO THE RJ45 IDC CONNECTOR. SEE NOTE 5 AND FIGURE 2. B. TERMINATE THE CABLE USING A KRONE/110 PUNCHDOWN TOOL. C. (FOR SHIELDED VERSION) WRAP THE DRAIN WIRE AROUND THE CABLE DRAIN TIE BAR. USE THE CABLE TIE (NOT SHOWN) TO SECURE THE CABLE TO THE BAR. D. SNAP THE IDC CAPS OVER THE IDC BLOCK. E. (FOR SHIELDED VERSION) SLIDE THE SHIELDED COVER INTO PLACE. F. ASSEMBLE THE SWITCHCRAFT HOUSING ONTO THE FRONT OF THE PANEL USING THE RECOMMENDED PANEL CUT-OUT. SEE FIGURE 1. G. SNAP THE RJ45 IDC CONNECTOR INTO THE SWITCHCRAFT HOUSING FROM THE BACK OF THE PANEL. 1.13 28.8 CAT5e SHIELDED EHRJ45P5EIDC CAT5e UNSHIELDED EHRJ45P6SIDC CAT6 SHIELDED EHRJ45P6IDC CAT6 UNSHIELDED 0.083 2.11 1.02 26.0 0.083 2.11 C 0.94 24.0 RJ45 IDC CONNECTOR EHRJ45P5ESIDC D 1.17 29.8 1.02 26.0 PART NUMBER E IDC CAPS (2) DRAIN WIRE (ONLY NEEDED FOR SHIELDED VERSION) RJ45 CABLE SWITCHCRAFT HOUSING 0.138 3.51 CABLE DRAIN TIE BAR SEE NOTE 3 0.945 24.00 0.945 24.00 1.22 31.0 1.22 31.0 0.88 22.4 PIN 8 PIN 1 B B NOTES: PIN 1 PIN 8 1. THE RJ45 CAT 5e AND CAT 6 IDC CONNECTORS MEET TIA/EIA 568 B.2 STANDARD. 2. MATERIALS: SWITCHCRAFT HOUSING - THERMOPLASTIC, BLACK RJ45 IDC CONNECTOR INSULATOR BODY- THERMOPLASTIC, BLACK CONTACTS- COPPER ALLOY, GOLD PLATED (CONTACT AREA) IDC TERMINALS- COPPER ALLOY, TIN PLATED IDC CAPS- THERMOPLASTIC, WHITE (SHIELEDED VERSION ONLY) SHIELD- COPPER ALLOY, NICKEL PLATED DRAIN WIRE TIE BAR - COPPER ALLOY, NICKEL PLATED A 0.748 19.00 2X 0.138 3.51 SHEILDED RJ45 UNLESS OTHERWISE SPECIFIED 5. THE RJ45 CONNECTOR CONTAINS A WIRING LABEL FOR T568A & T568B WIRING. A REV RELEASE TO PROD. 10/23/14 27394 ECO NUMBER DATE REVISIONS 6 5 4 PC BY SIZE - TWO PLACE DECIMALS 0.02 MULT - THREE PLACE DECIMALS 0.005 [0.13] DATE DRAWN BY 10/03/14 AB DO NOT SCALE DRAWING SolidWorks CAD File NAME LBS/M TEMPER MATERIAL SPEC No. FIRST USED ON [0.5] TJK APVD WIDTH FINISH 1. ALL DIMENSIONS IN INCHES [mm] 6. THIS ASSEMBLY IS RoHS COMPLIANT. CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. 4. 22-26 AWG STRANDED OR SOLID WIRE IS RECOMMENDED. 7 0.138 3.51 UNSHEILDED RJ45 3. (SHIELDED VERSION ONLY) FOR SHIELDING, TIE SHIELD/DRAIN WIRE TO THE TIE BAR AND SECURE WITH CABLE TIE PROVIDED (NOT SHOWN). 8 2X 0.748 19.00 A SPEC No. SCALE CHKD AB 10/03/14 2:1 APVD TJK 09/21/15 SHEET PART No. 1 OF 1 EH SERIES RJ45 RA IDC, RoHS EHRJ45P__IDC_SERIES C REV A
EHRJ45P6IDC 价格&库存
很抱歉,暂时无法提供与“EHRJ45P6IDC”相匹配的价格&库存,您可以联系我们找货
