SPRM12JA1M00
SPRM12JA1M00
    SEI
    AXIAL_D3X9MM_TM
    插件电阻 - 1MΩ ±5% 1/2W -
SPRM12JA1M00 数据手册
SPR / SPRM Series Stackpole Electronics, Inc. Discharge Path Resistor Resistive Product Solutions Features: • • • • • • • • Excellent anti-surge characteristics Stable characteristics through the resistance range Applications include power supplies, CRT’s and anti-surge circuits Good alternative to carbon composition resistors Cut and formed product is available on select sizes; contact Stackpole for details 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Type / Code Power Rating (W) @ 70ºC Maximum Working Voltage SPRM12 SPR1 0.5 1 E=√ P*R Maximum Overload Voltage (V) 2500 5000 Surge Withstanding Voltage (KV) Ohmic Range (Ω) and Tolerance 5% 10 1M - 12M Mechanical Specifications A Body Length 0.354 ± 0.039 9.00 ± 1.00 0.591 ± 0.039 15.00 ± 1.00 Type / Code SPRM12 SPR1 B Body Diameter 0.118 ± 0.020 3.00 ± 0.50 0.197 ± 0.020 5.00 ± 0.50 C Lead Length (Bulk) 1.102 ± 0.079 28.00 ± 2.00 1.378 ± 0.118 35.00 ± 3.00 D Lead Diameter 0.028 ± 0.002 0.70 ± 0.05 0.031 ± 0.002 0.80 ± 0.05 Unit inches mm inches mm Performance Characteristics (JIS C 5201-1) Test Test Results Moisture Resistance Temperature Cycling Load Life Resistance to Soldering Heat Short Time Overload Discharge ± 5% ± 1% ± 5% ± 1% ± 2% ± 10% Operating Temperature Range: -55ºC to +155ºC Rev Date: 10/22/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com SPR / SPRM Series Stackpole Electronics, Inc. Discharge Path Resistor Resistive Product Solutions Repetitive Pulse Information: If repetitive pulses are applied to resistors, pulse wave form must be less than “pulse limiting voltage”, “pulse limiting current” or “pulse limiting wattage” calculated by the formula below. Vp = K√P x R x T/t lp = K√P/R x T/t Pp = K2 x P x T/t Where: Vp: lp: Pp: P: R: T: t: K: [Vr: Note 1: Note 2: Note 3: Note 4: Note 5: Note 6: Pulse limiting voltage (V) Pulse limiting current (A) Pulse limiting wattage (W) Power rating (W) Nominal resistance (ohm) Repetitive period (sec) Pulse duration (sec) Coefficient: 1 Rated Voltage (V), Ir: Rated Current (A)] If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000 If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp) Pulse limiting voltage (current, wattage) is applied at less than rated ambient temperature. If ambient temperature is more than the rated temperature (70 °C), decrease power rating according to “Power Derating Curve” Assure sufficient margin for use period and conditions for “pulse limiting voltage” If the pulse waveform is not square wave, judge after transform the waveform into square wave according to the “Waveform Transformation to Square Wave”. Rev Date: 10/22/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com SPR / SPRM Series Stackpole Electronics, Inc. Discharge Path Resistor Resistive Product Solutions Waveform Transformation to Square Wave 1. Discharge curve wave with time constant “t” → Square wave 2. Damping oscillation wave with time constant of envelope “t” → Square wave 3. Half-wave rectification wave → Square wave 4. Triangular wave → Square wave 5. Special wave → Square wave Rev Date: 10/22/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com SPR / SPRM Series Stackpole Electronics, Inc. Discharge Path Resistor Resistive Product Solutions Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 10/22/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com SPR / SPRM Series Stackpole Electronics, Inc. Discharge Path Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile Packaging Specifications Series SPRM12 SPR1 A max.(1) B max 2.618 66.50 3.917 99.50 13.504 343.00 13.504 343.00 D(2) C 0.197 5.00 0.394 10.00 ± ± ± ± 0.020 0.50 0.020 0.50 2.063 52.40 2.063 52.40 ± ± ± ± 0.079 2.00 0.079 2.00 Tape Unit 0.250 6.35 0.250 6.35 inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. Rev Date: 10/22/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com SPR / SPRM Series Stackpole Electronics, Inc. Discharge Path Resistor Resistive Product Solutions RoHS Compliance Status Standard Product Series SPR Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Discharge Path Leaded Resistor Axial YES 99.3/0.7 Sn/Cu Apr-05 05/14 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 S P R 1 J B 1 0 M 0 Product Series SPR Standard SPRM Mini Power Size W 12 0.5 1 1 Code J Tolerance Tol Value 5% E24 Packaging Code Description Size B Bulk SPRM12; SPR1 SPRM12 A Ammo SPR1 Resistance Value Quantity 1000 2000 500 Four characters with the multiplier used as the decimal holder. 1 Mohm = 1M00 12 Mohm = 12M0 Rev Date: 10/22/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com
SPRM12JA1M00 价格&库存
很抱歉,暂时无法提供与“SPRM12JA1M00”相匹配的价格&库存,您可以联系我们找货
SPRM12JA1M00
  • 1+3.513041+0.42033
  • 10+1.9627410+0.23484
  • 25+1.5801425+0.18906
  • 50+1.3488450+0.16139
  • 100+1.15609100+0.13833
  • 250+0.95057250+0.11374
  • 500+0.82493500+0.09871
  • 1000+0.719881000+0.08614
库存:1435
SPRM12JA1M00
  • 2000+0.632032000+0.07562
  • 4000+0.558504000+0.06683
  • 6000+0.521176000+0.06236
  • 10000+0.4820610000+0.05768
库存:1435
