TM3RA1X-44(50)
TM3RA1X-44(50)
    HRS(广濑)
    Jack Modular Connector 4p4c (RJ9, RJ10, RJ22) Vertical Unshielded
TM3RA1X-44(50) 数据手册
FLYER Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM-DSA Series FCC Standard, Straight THT Type Modular Jack Connector Features 1 Complies with US FCC Standard requirements 2 Solder mounted perpendicular to PCB 3 Gold plated contact has excellent environmental durability. The insulation is made of flame retardant (UL-94V-0) material. 4 Port types available in 6 pins and 1 to 4 ports Application Examples ●Industrial PC, LAN, HUB, Interphone, Computer, etc. Specifications Mating Port Size and Contact Count (6pos. Size) The relationship between the jack connector mating port size and the number of contacts is shown below. Model 66 Model 64 Model 62 Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66. Please check the drawing for details. Rated Current 0.5A Rated Voltage 125V AC Operating Temperature -55 to +85°C* Contact Resistance 230mΩ Max. (100 mA DC) Withstanding Voltage 500V AC for 1 min. Insulation Resistance 100MΩ Min. (100V DC) Mating Durability 200 times *Includes the temperature rise due to current flow. - RoHS compliant MKT-E-21072F Issued: Jun. 16, 2022 © 2022 HIROSE ELECTRIC CO., LTD. All rights reserved. Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings, or availabilities.
TM3RA1X-44(50)
- 物料型号:TM-DSA系列 - 器件简介:该系列连接器符合美国FCC标准要求,垂直于PCB焊接安装,接触点为镀金,具有出色的环境耐久性,绝缘材料为阻燃材料(UL-94V-0)。 - 引脚分配:提供6针和1到4个端口的型号,具体型号66、64和62分别通过从型号66的两侧移除1针和2针来获得。 - 参数特性: - 额定电流:0.5A - 额定电压:125V AC - 工作温度:-55至+85°C(包括电流流动引起的温度升高) - 接触电阻:最大230mΩ(100mA DC) - 耐电压:500V AC,持续1分钟 - 绝缘电阻:最小100MΩ(100V DC) - 插拔耐久性:200次 - 功能详解:适用于工业PC、局域网、集线器、对讲机、计算机等。 - 应用信息:文档提供了应用示例,展示了不同型号的插座连接器的配合端口大小和接触点数量。 - 封装信息:文档中包含了详细的规格说明和图纸,但未提供封装的详细信息。
TM3RA1X-44(50) 价格&库存
很抱歉,暂时无法提供与“TM3RA1X-44(50)”相匹配的价格&库存,您可以联系我们找货
