APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
TIA/EIA-568-A CAT5
1
RATING VOLTAGE
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
STORAGE TEMPERATURE
RANGE
-55 C TO 85 C
2
OPERATING HUMIDITY
RANGE
APPLICABLE
CABLE
125 V AC
CURRENT
-25 C TO 60 C
3
1A
95 % MAX
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT AT
CONSTRUCTION
GENERAL EXAMINATION
VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ACCORDING TO DRAWING.
X
X
X
X
50 mΩ MAX.
X
X
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE
100 mA MAX (DC OR 1000 Hz AC).
(AN EXAMPLE CONNECTOR CONFIGURATION IS S H O W N . )
INSULATION RESISTANCE
100 V DC.
100 MΩ MIN.
VOLTAGE PROOF
(CONTACT TO CONTACT)
500 V AC FOR 1 min.
NO FLASHOVER OR BREAKDOWN.
X
X
X
X
VOLTAGE PROOF
(CONTACT TO SHIELD)
1500 V AC FOR 1 min.
X
NEAR END CROSSTALK
(NEXT)LOSS
MEASURED MINIMUM NEXT LOSS FOR EACH
PAIR COMBINATION (1,2-3,6) AT 100 MHz.
40 dB MIN.
X
1) CONTACT RESISTANCE
: 70 mΩ MAX.
2) NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
1) NO ELECTRICAL DISCONTINUITY OF 5 s.
X
X
X
: 70 mΩ MAX.
2) INSULATION RESISTANCE :
1 M MIN. (AT HIGH HUMIDITY)
10 M MIN. (AT DRY)
3) NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
X
1) CONTACT RESISTANCE : 70 mΩ MAX.
2) INSULATION RESISTANCE : 100 MΩ MIN.
OF PARTS.
1)CONTACT RESISTANCE : 70 m MAX.
2)NO HEAVY CORROSION.
X
X
NO DEFORMATION OF CASE AND EXCESSIVE
LOOSENESS OF THE TERMINALS.
X
MIN. 95 % OF SOLDER IMMERSED AREA
SHALL BE COVERED NEW SOLDER COATING.
X
MECHANICAL CHARACTERISTICS
MECHANICAL OPERATION
200 TIMES INSERTIONS AND EXTRACTIONS.
VIBRATION
FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE 0.75 mm,
1 OCTABE / min, 3 AXIAL DIRECTIONS, 10 CYCLES EACH.
SHOCK
490 m/s2 DURATION OF PULSE 11 ms
AT 3 TIMES FOR 6 DIRECTIONS.
OF PARTS.
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT,CYCLIC
EXPOSED AT 40 C, 90 TO 95 , 500 h
RAPID CHANGE OF
TEMPERATURE
TEMPERATURE -55±3 → 15 TO 35 → 85±2 → 15 TO 35 ℃
TIME
30
2 TO 3 →
30 →
2 TO 3 min
UNDER 5 CYCLES.
CORROSION SALT MIST
EXPOSED IN
RESISTANCE TO SOLDERING
HEAT
SOLDER TEMPERATURE,
DURATION 5 ± 1 S.
SOLDERABILITY
SOLDERED AT SOLDER TEMPERATURE, 245 ±5 ℃
FOR IMMERSION, DURATION MAX 3 S.
COUNT
REMARK
1
2
1
2
3
5 % SALT WATER SPRAY FOR 48 h.
260 ± 5 ℃ FOR IMMERSION,
DESCRIPTION OF REVISIONS
DESIGNED
CHECKED
DATE
DIS-E-00002932
KIM JAEHYEON
TU.TANIGUCHI
20200403
APPLICABLE PLUG CONNECTOR:TM21P-88P.
THE OPERATION TEMPERATURE INCLUDES THE TEMPERATURE RISE BY CURRENT CARRYING.
STORAGE TEMPERATURE RANGE SHOWS STORAGE CONDITION FOR UNUSED PRODUCTS
INCLUDING PACKING MATERIALS.
FOLLOW THE OPERATING TEMPERATURE RANGE FOR STORAGE CONDITION AFTER MOUNTING.
Unless otherwise specified, refer to IEC 60512.
5402. QT:Qualification Test AT:Assurance Test X:Applicable Test
Note
FORM HD0011-2-1
APPROVED
EJ.WAKATSUKI
20131028
CHECKED
EJ.WAKATSUKI
20131028
DESIGNED
MT.ITANO
20131025
DRAWN
MT.ITANO
20131025
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-123343-01-03
TM11R-5M2-88(01)
CL222-2906-2-01
1
1/1
很抱歉,暂时无法提供与“TM11R-5M2-88(01)”相匹配的价格&库存,您可以联系我们找货
