301666-8
301666-8
    WINCHESTER(温彻斯特)
    CONN MOD JACK 6P6C R/A UNSHLD
301666-8 数据手册
Multi-Port With Metal Board Locks 2 To 6 Contacts - 2 To Twelve Ports No. of Ports Dimensions 2 3 4 5 6 7 8 9 10 11 12 A 23.3 34.3 45.3 56.3 67.3 78.3 89.3 100.3 111.3 122.3 133.3 0.92 1.3 1.78 2.22 2.65 3.08 3.52 3.95 4.38 4.82 5.25 B 23.5 34.5 45.5 56.5 67.5 78.5 89.5 100.5 111.5 122.5 133.5 0.93 1.36 1.79 2.22 2.66 3.09 3.52 3.96 4.39 4.82 5.26 C 11.0 22.0 33.0 44.0 55.0 66.0 77.0 88.0 99.0 110.0 121.0 0.43 0.86 1.299 1.732 2.165 2.598 3.031 3.465 3.898 4.331 4.764 Materials Housing: Standard Material Glass filled Polyester UL94V-0 Standard Color Medium Gray Contact: 0.46mm Diameter Alloy C5210. Gold Plating Over Nickel. Gold Plating: As Per Customer Request Ordering Information Positions/ Contacts 4P2C 4P4C 6P2C 6P4C 6P6C Description Multi-Port Solderable Board Lock Jack Multi-Port Solderable Board Lock Jack Multi-Port Solderable Board Lock Jack Multi-Port Solderable Board Lock Jack Multi-Port Solderable Board Lock Jack RoHS compliant wave solder only Part Number 301542B-* 301544B-* 301562B-* 301564B-* 301566B-* Standard contact plating is 15 micro inches of gold. For optional platings add dash number as follows: -6 = 6 Micro inches -30 = 30 Micro inches * Add -02 for 2 port, -03 for 3 port, etc. Two to twelve ports available. FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111 Back to Index Multi-Port Press Fit 2 To 6 Contacts - 2 To Twelve Ports Dimensions A B C 2 28.2 1.11 23.0 0.90 11.0 0.433 3 34.3 1.35 34.0 1.34 22.0 0.866 4 45.3 1.78 45.0 1.77 33.0 1.299 5 56.3 2.22 56.0 2.20 44.0 1.732 6 67.3 2.65 67.0 2.64 55.0 2.165 No. of Ports 7 8 78.3 89.3 3.08 3.52 78.0 89.0 3.07 3.50 66.0 77.0 2.598 3.031 9 100.3 3.95 100.0 3.94 88.0 3.465 10 111.3 4.38 111.0 4.37 99.0 3.898 11 122.3 4.82 122.0 4.80 110.0 4.331 12 133.3 5.25 133.0 5.24 121.0 4.764 Materials Housing: Standard Material Glass Filled Polyester UL 94V-0 Standard Color Medium Gray Contact: 0.46mm Diameter Alloy C5210. Gold Plating Over Nickel. Gold Plating: As Per Customer Request Ordering Information Positions/ Contacts 4P2C 4P4C 6P2C 6P4C 6P6C Description Part Number Multi-Port Press-Fit Jack Multi-Port Press-Fit Jack Multi-Port Press-Fit Jack Multi-Port Press-Fit Jack Multi-Port Press-Fit Jack 301642-* 301644-* 301662-* 301664-* 301666-* Standard contact plating is 15 micro inches of gold. For optional platings add the dash numbers as follows: -6 = 6 Micro inches -30 = 30 Micro inches 13 -50 = 50 Micro inches s RoHS compliant wave solder only * Add -02 for 2 port, -03 for 3 port, etc. Two to twelve ports available FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111 Back to Index 14 Single and Multi Port Jacks Non-Shielded, Shielded and Shielded with Grounding Tabs are available. Single position and up to twelve positions are standard as listed below in these moderate profile RJ45 jacks. Materials Shielded: Housing: 0.35mm Thickness Alloy C5210. Tin Plating Over Nickel in Solder Area Standard Material: Glass Filled Polyester UL 94V-O Standard Color Black Contact: 0.35mm (0.014”) Thickness Alloy C5210. Gold Plating Over Nickel in Contact Area Gold Plating: 0.76 um / 30 u inch Ordering Information Click Part Numbers Listed Below For Detailed Drawings Ports Unshielded Shielded 1 2 4 5 6 8 10 12 301201 301202 301204 301205 301206 301208 301210 301212 301201S 301202S 301204S 301205S 301206S 301208S 3012010S 3012012S Shielded W/ Ground Tabs 301201ST 301202ST 301204ST N/A 301206ST 301208ST 301210ST N/A s s s RoHS compliant wave solder only FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111 Back to Index 15 Multi Port RJ11 &RJ12 Jacks 4 Contact and 6 Contac Non-Shielded S Materials Housing: Standard Material ZYTEL FR-550 UL 94V-0 Standard Color Black Contact: 0.35mm (0.014”) Thickness Alloy C5210. Gold Plating Over Nickel Over Tin Gold Plating: 0.76u m / 30 u inch Ordering Information Contacts Description Non-Shielded Shielded 6P4C 6P6C 2 Port RJ11, 6 Position, 4 Contact Each Port 2 Port RJ12, 6 Position, 6 Contact Each Port 306504 306506 306504S 306506S RoHS compliant wave solder only FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347- Dual Row Multi Port Right Angle s s s Standard contact plating is 15 micro inches of gold. For optional platings add dash number as follows: -30 = 30 Micro inches -50 = 50 Micro inches s s Materials Shielded: Housing: 0.25mm Thickness Copper Alloy with Tin Plated Standard Material Glass Filled Polyester UL 94V-0 Standard Color Black Contact: 0.35mm (0.014”) Diameter Alloy C5210. Gold Plating Over Nickel Over Tin. Gold Plating: As Per Customer Request Ordering Information Ports/ 2 High by Wide 1 (2) 2 (4) 4 (8) 5 (10) 6 (12) 8 (16) s Non-Shielded Shielded 302201 302202 302204 302205 302206 302208 302201S 302202S 302204S N/A 302206S 302208S Shielded W/ Tabs 302201ST 302202ST 302204ST N/A 302206ST 302208ST s Click Part Number for Drawing s RoHS compliant wave solder onlyRoHS compliant wave solder onl FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111 Back to Index 17
301666-8 价格&库存
很抱歉,暂时无法提供与“301666-8”相匹配的价格&库存,您可以联系我们找货
