N238-025-WH
N238-025-WH
    TRIPPLITE
    不带LED
N238-025-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6/Cat5e 110 Style Punch Down Keystone Jack - White, 25-Pack, TAA Highlights ● 25-Pack ● Use in Cat6 or Cat5e installations ● Compliant with EIA/TIA CAT6 connecting hardware specifications. ● Dual-color coded labeling made for both 568A & 568B (258A) wiring schemes. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: N238-025-WH Package Includes Description Tripp Lite's Cat6/Cat5e 110 Style Punch Down Keystone Jacks provide maximum flexibility for any UTP Ethernet environment. Ideal for Cat5e cabling environments, the jack also meets UL-certified ANSI/TIA/EIA-568-B.2-1 Permanent Link/Channel Identification Test for Category 6 cabling installations. The uniquely patterned printed circuit board construction is designed to meet CAT6 250Mhz performance, and is fully compliant with EIA/TIA CAT6 connecting hardware specifications. With its compact casing, it fits into any conventional face plate, outlet box, or panel. It also features dual-color coded labeling made for both 568A & 568B (258A) wiring schemes. UTP Cat6 22-24 AWG solid cable Features ● 25-Pack ● Use in Cat6 or Cat5e installations ● Compliant with EIA/TIA Cat6 connecting hardware specifications ● Dual-color coded labeling made for both 568A & 568B (258A) wiring schemes ● Compact casing fits into any conventional face plate, outlet box, or panel ● UL-certified ANSI/TIA/EIA-568-B.2-1 Permanent Link/Channel Identification Test ● Uniquely patterned, printed circuit board designed to meet Cat6 performances ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332187864 Technology Cat5/5e PHYSICAL 1/2 ● Cat6/Cat5e 110 Punch Down Keystone Jack - White, 25-Pack ● Termination Caps (x25) 1000 Eaton Boulevard Cleveland, OH 44122 United States Color White Shipping Dimensions (hwd / in.) 7.01 x 7.87 x 0.50 Shipping Dimensions (hwd / cm) 17.81 x 19.99 x 1.27 Shipping Weight (lbs.) 0.48 Shipping Weight (kg) 0.22 CONNECTIONS Number of Ports 1 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 110 IDC STANDARDS & COMPLIANCE Product Certifications UL 1863; UL 2043 Product Compliance RoHS; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N238-025-WH 价格&库存
很抱歉,暂时无法提供与“N238-025-WH”相匹配的价格&库存,您可以联系我们找货
