T :
To:
Customer P/N:
UDE P/N: RB1-125BAG1A
Description: RJ45 1X1 Tab Down
Through Hole
10/100Base-T
Contact Area : Gold Flash
LED L G
LED:L-Green;
R
R-Yellow
Y ll
Spec No.
RB1111-00
Approved
Checked
Update Date
2009/8/27
Prepared
RB1-125BAG1A
Spec No. : RB1111-00
1. MECHANICAL DIMENSION
1.1 Product Dimension
X.X : ± 0.25
General Tolerance
X.XX : ± 0.13
: X.XXX : ± 0.08
-1-
www.ude-corp.com
RB1-125BAG1A
1.2 Recommened PCB Layout
Component
Side of Board
p
All dimension tolerance are ±0.05mm unless otherwise specified
-2-
www.ude-corp.com
RB1-125BAG1A
1.3 Standard RJ45 Plug Specification
- All dimensions follow :
FCC subpart F, 68,500, Figure (C)(2)(i) & (C)(2)(ii) & (C)(3)(i)
IEC 60603-7
- All plugs must be meeting the requirements of plug Go & No-Go
No Go gauge.
Gauge follow : FCC subpart F, 68,500, Figure (C)(4)(i) & (C)(5)(i)
- There must be no damage to Housing and Locking Latch.
- There must be no nicks and cuts in cable.
- Durability : 750 cycles generally
-3-
www.ude-corp.com
RB1-125BAG1A
2. REQUIREMENTS
2.1 Design
g and Construction
Product shall be of design, construction and physical dimensions specified
on applicable.
2.2 Material
2.2.1 Terminal Parts (Underplating : 30μ" min. Nickel overall)
2.2.1.1 RJ Terminal : PH. Bronze, Thickness=0.30mm
Finish : Contact Area :Gold Flash
2.2.1.2 Input Terminal : Brass, Thickness=0.35mm
Finish : 100μ" min. Tin
2.2.1.3 Case Terminal : Brass, Thickness=0.30mm
2.2.2 Plastic Parts
2.2.2.1 Housing : High Temperature Thermoplastic, Black
2.2.2.2 Case : High Temperature Thermoplastic, Black
2.2.3 Shield Parts : Stainless, Thickness=0.20mm, Pre-soldering
-4-
www.ude-corp.com
RB1-125BAG1A
2.3 Operating and Storage Temperature
Operating
: 0°C to +70°C
p
g Temperature
p
Storage Temperature : -40°C to +85°C
2.4 RJ45 specifications
Insulation Resistance 500MΩ min.
Insertion force with the latch depressed 22N max
Removal force with the latch depressed 44N max
Locking Force of Plug Latch : 50N min. @ 60+/-5 sec
Durability : 2500 cycles
2.5 Performance and Test Description
Product is designed to meet electrical, mechanical and environmental
performance requirements specified in below table. All tests are performed
at ambient environmental conditions per MIL-STD-1344A and EIA-364
unless otherwise specified.
2.6 Packaging and Packing
All parts shall be packaged and packed to protect against physical
damage、corrosion and deterioration during shipment and storage.
-5-
www.ude-corp.com
RB1-125BAG1A
3. ELECTRICAL CHARACTERISTICS
3.1 Schematic
RJ45
OUTPUT
INPUT
TD+ R1
C1 TX+
TD‐ R2
C2 TX‐
1 : 1
RD+ R7
C3 RX+
RD‐
RD R8
C6 RX‐
C6 RX
1 : 1
CT R3
C4
C5
C7
75Ω
C8
2KV 1000pF
Shield
L4
L2
Yellow
Green
L3
L1
Emitting Color λp (nm) Vf @If=20mA
Green
565
1.7 ~2.6 V
Yellow
585
1.7 ~2.6 V
-6-
Ir @Vr=5V
10μA max.
10μA max.
www.ude-corp.com
RB1-125BAG1A
3.2 Transmitter filter & Receiver filter
Type
yp : Balance low pass
p 100Ω impedance
p
Insertion loss :
1~100 MHz
-1.0dB max.
Return loss :
1~30 MHz
-18dB min.
load 100Ω
30~60MHz
-16dB min.
load 100Ω
60~80MHz
-12dB min.
load 100Ω
3.3 Common Mode Rejection
@ 1~100 MHz
-30dB min.
3.4 Cross Talk
@ 1~100 MHz
-30dB min.
3.5 Inductance @ 100KHz, 0.1V, 8mA DC BIAS
Input(R1-R2), Input(R7-R8) : 350 μH min.
3.6 HiPot Test
I
Input(R1-R2)
(R1 R2)
O
(C1 C2) : 1500Vac
1500V 60s
60 or 2250Vdc
2250Vd 60
60s
To Output(C1-C2)
Input(R7-R8)
To Output(C3-C6) : 1500Vac 60s or 2250Vdc 60s
-7-
www.ude-corp.com
RB1-125BAG1A
4. ORDER INFORMATION
R
B
1
1
2 5B
A B
AG1
C
A
D
A. LED Code :
L-Green; R-Yellow.
B. Mechanical Code :
w/ UDE Logo, w/ all Spring, Rear side Leg, Board Lock
C. Schematics Code :
AG1 : AG1 circuit
D. Plating Code :
Underplating
Solder Tail
100μ" min. Bright Tin
Contact Area
100μ" min. Matted Tin
A : Gold Flash
1 : Gold Flash
C : 6μ" gold
6 : 6μ" gold
ld
B : 10μ" gold
D : 15μ" gold
2 : 15μ" gold
F : 30μ" gold
3 : 30μ" gold
G : 50μ
50μ" gold
4 : 50μ
50μ" gold
-8-
www.ude-corp.com
RB1-125BAG1A
5. DIPPING TEMPERATURE PROFILE
-9-
www.ude-corp.com
This datasheet has been downloaded from:
datasheet.eeworld.com.cn
Free Download
Daily Updated Database
100% Free Datasheet Search Site
100% Free IC Replacement Search Site
Convenient Electronic Dictionary
Fast Search System
www.EEworld.com.cn
All Datasheets Cannot Be Modified Without Permission
Copyright © Each Manufacturing Company
很抱歉,暂时无法提供与“RB1-125BAG1A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.91000
- 60+11.47410
- 国内价格
- 1+16.22160
- 10+13.94280
- 30+12.51720
- 100+11.05920
- 500+10.40040
- 1000+10.11960
