RSF / RSMF Series
Stackpole Electronics, Inc.
General Purpose Metal Oxide Resistor
Resistive Product Solutions
Features:
Lower-cost alternative to carbon comps and wirewounds
Coating meets UL 94V-0
Meets solvent test of Mil Standard 202, Method 215
Cut and formed product is available on select sizes - contact Stackpole for details
Higher or lower resistance values may be possible - contact Stackpole
Flameproof
RoHS compliant, lead free and halogen free
Electrical Specifications
Maximum
Maximum
Power Rating
Type / Code
Working
Overload
(W) @ 70ºC
Voltage (V)(1) Voltage (V)
RSF12
0.5
250
400
RSF1
1
350
600
RSF2
2
350
600
RSF3
3
800
1000
RSF5
5
1000
1000
RSMF12
0.5
250
400
RSMF1
1
350
600
RSMF2
2
350
600
RSMF3
3
500
800
RSMF5
5
1000
1000
(1) Lesser of √ P*R or maximum working voltage
Dielectric
Withstanding
Voltage (V)
350
600
600
750
750
350
500
500
600
750
TCR (ppm/ºC)
± 200
± 200
± 200
± 200
± 200
± 200
± 200
± 200
± 200
± 200
Ohmic Range (Ω) and Tolerance
1%
2%
0.1 - 150K
0.1 - 75K
0.1 - 100K
0.1 - 120K
0.1 - 470K
0.1 - 560K
0.1 - 470K
0.1 - 560K
0.1 - 46.4K
0.1 - 47K
0.1 - 75K
0.1 - 100K
0.1 - 118K
0.1 - 120K
0.1 - 470K
0.1 - 560K
5%
0.1 - 1M
0.1 - 1M
0.1 - 1M
0.1 - 1M
0.1 - 1M
0.1 - 470K
0.1 - 470K
0.1 - 470K
0.1 - 470K
0.1 - 1M
Mechanical Specifications
Type / Code
RSF12
RSF1
RSF2
RSF3
RSF5
RSMF12
RSMF1
RSMF2
RSMF3
RSMF5
A
Body Length
0.35 ± 0.04
9.00 ± 1.00
0.43 ± 0.06
11.00 ± 1.50
0.59 ± 0.06
15.00 ± 1.50
0.69 ± 0.04
17.50 ± 1.00
0.96 ± 0.04
24.50 ± 1.00
0.24 ± 0.03
6.00 ± 0.80
0.35 ± 0.04
9.00 ± 1.00
0.43 ± 0.06
11.00 ± 1.50
0.59 ± 0.06
15.00 ± 1.50
0.69 ± 0.04
17.50 ± 1.00
B
Body Diameter
0.13 ± 0.03
3.20 ± 0.80
0.18 ± 0.04
4.50 ± 1.00
0.22 ± 0.04
5.50 ± 1.00
0.24 ± 0.02
6.00 ± 0.50
0.31 ± 0.02
8.00 ± 0.50
0.09 ± 0.01
2.30 ± 0.30
0.13 ± 0.03
3.20 ± 0.80
0.18 ± 0.04
4.50 ± 1.00
0.22 ± 0.04
5.50 ± 1.00
0.24 ± 0.02
6.00 ± 0.50
Rev Date: 10/22/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
C
Lead Length (Bulk)
1.10 ± 0.12
28.00 ± 3.00
1.10 ± 0.20
28.00 ± 5.00
1.18 ± 0.20
30.00 ± 5.00
1.38 ± 0.12
35.00 ± 3.00
1.38 ± 0.12
35.00 ± 3.00
1.10 ± 0.12
28.00 ± 3.00
1.10 ± 0.12
28.00 ± 3.00
1.18 ± 0.20
30.00 ± 5.00
1.18 ± 0.20
30.00 ± 5.00
1.38 ± 0.08
35.00 ± 2.00
D
Lead Diameter
0.03 ± 0.003
0.70 ± 0.08
0.03 ± 0.002
0.80 ± 0.05
0.03 ± 0.004
0.75 ± 0.10
0.03 ± 0.002
0.80 ± 0.05
0.03 ± 0.002
0.80 ± 0.05
0.02 ± 0.003
0.55 ± 0.07
0.03 ± 0.003
0.70 ± 0.08
0.03 ± 0.002
0.80 ± 0.05
0.03 ± 0.004
0.75 ± 0.10
0.03 ± 0.002
0.80 ± 0.05
Lead-Tape
Specification
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
marketing@seielect.com
RSF / RSMF Series
Performance Characteristics
Test
Test Method
Test Specification
Typical Results
Insulation Resistance
JIS C5201-1, IEC60115-1, 4.6
≥ 1G Ω
≥ 1G Ω
Voltage Proof
JIS C5201-1, IEC60115-1, 4.7
≤ ± (0.5% + 0.05 Ω)
No mechanical damage
< ± 0.25%
Short Time Overload
JIS C5201-1, IEC60115-1, 4.13
≤ ± (0.75% + 0.05 Ω)
< ± 0.1%
Resistance to Solder Heat
JIS C5201-1, IEC60115-1, 4.18
≤ ± (2.0% + 0.05 Ω)
< ± 1.0%
Endurance at 70°C
JIS C5201-1, IEC60115-1, 4.25.1
≤± (5.0% + 0.05 Ω)
< ± 2.0%
Robustness of Terminations
JIS C5201-1, IEC60115-1, 4.16
≤ ± (1.0% + 0.05 Ω)
< ± 0.10%
≤± (5% + 0.05 Ω)
Damp Heat (Steady state)
JIS C5201-1, IEC60115-1, 4.24
< ± 1.5%
≤± (1% + 0.05 Ω)
Rapid Change of Temperature
JIS C5201-1, IEC60115-1, 4.19
< ± 0.2%
Resistance to Solvents
JIS C5201-1, IEC60115-1, 4.29
No damage to component or removal of marking
Pass
≤± (2% + 0.05 Ω)
Intermittent Overload
JIS C5201-1, IEC60115-1, 4.39
< ± 0.3%
Accidental Overload (Flame resistance)
JIS C5201-1, IEC60115-1, 4.26
No flaming of gauze
Pass
Operating temperature range is -55ºC to +200ºC (RSF12, RSMF12, RSMF1)
-55ºC to +235ºC (all others)
Power Derating Curve:
Percent Rated Power (%)
100
-55ºC
70ºC
80
RSF1, RSF2, RSF3, RSF5
RSMF2, RSMF3, RSMF5
60
RSF12
RSMF12, RSMF1
40
235
60
80
100
120
140
160
180
200
220
240
Ambient Temperature (ºC)
Surface Temp. Rise (°C)
120
RSF2
100
RSF1
80
60
RSF12
40
60
Power Rating (%)
80
100
Surface Temperature Rise
200
180
160
140
120
100
80
60
40
RSMF3
RSMF2
RSMF1
RSMF12
60
Power Rating (%)
80
100
www.seielect.com
RSF / RSMF Series
Repetitive Pulse Information:
If repetitive pulses are applied to resistors, pulse wave form must be less than “pulse limiting voltage”, “pulse limiting
current” or “pulse limiting wattage” calculated by the formula below.
Vp = K√P x R x T/t
lp = K√P/R x T/t
Pp = K2 x P x T/t
Where: Vp:
lp:
Pp:
P:
R:
T:
t:
K:
[Vr:
Note 1:
Note 2:
Note 3:
Note 4:
Note 5:
Note 6:
Pulse limiting voltage (V)
Pulse limiting current (A)
Pulse limiting wattage (W)
Power rating (W)
Nominal resistance (ohm)
Repetitive period (sec)
Pulse duration (sec)
Coefficient: 0.8
Rated Voltage (V), Ir: Rated Current (A)]
If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000
If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied
If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp)
Pulse limiting voltage (current, wattage) is applied at less than rated ambient temperature.
If ambient temperature is more than the rated temperature (70 °C), decrease power rating according to
“Power Derating Curve”
Assure sufficient margin for use period and conditions for “pulse limiting voltage”
If the pulse waveform is not square wave, judge after transform the waveform into square
wave according to the “Waveform Transformation to Square Wave”.
3
www.seielect.com
RSF / RSMF Series
1.
Discharge curve wave with time constant “t” → Square wave
2.
Damping oscillation wave with time constant of envelope “t” → Square wave
3.
Half-wave rectification wave → Square wave
4.
Triangular wave → Square wave
5.
Special wave → Square wave
4
www.seielect.com
RSF / RSMF Series
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
5
www.seielect.com
RSF / RSMF Series
Packaging Specifications
Reeled in accordance with EIA-296-F
Type / Code
RSF12
RSF1
RSF2
RSF3
RSF5
Type / Code
RSMF12
RSMF1
RSMF2
RSMF3
RSMF5
A max.(1)
2.736
69.50
2.815
71.50
3.524
89.50
3.740
95.00
4.331
110.00
A max.(1)
2.618
66.50
2.736
69.50
2.815
71.50
3.524
89.50
3.740
95.00
B max
13.504
343.00
13.504
343.00
13.504
343.00
12.008
305.00
12.008
305.00
B max
13.504
343.00
13.504
343.00
13.504
343.00
13.504
343.00
12.008
305.00
0.197
5.00
0.197
5.00
0.394
10.00
0.394
10.00
0.394
10.00
0.197
5.00
0.197
5.00
0.197
5.00
0.394
10.00
0.394
10.00
C
C
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
D(2)
2.063 ± 0.079
52.40 ± 2.00
2.063 ± 0.079
52.40 ± 2.00
2.500 ± 0.079
63.50 ± 2.00
2.874 ± 0.079
73.00 ± 2.00
3.465 ± 0.079
88.00 ± 2.00
D(2)
2.063 ± 0.079
52.40 ± 2.00
2.063 ± 0.079
52.40 ± 2.00
2.063 ± 0.079
52.40 ± 2.00
2.500 ± 0.079
63.50 ± 2.00
2.874 ± 0.079
73.00 ± 2.00
Tape
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
Tape
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Dimension "E":
This is a non-critical dimension that does not have a tolerance in the standard.
Range of diameters is from 0.547 inches (13.90 mm) to 1.500 inches (38.10 mm).
(1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component.
The distance between flanges shall be 0.059 inches (1.50 mm) to 0.315 (8.00 mm) greater than the overall component.
(2) The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as option "N" packaging code.
6
www.seielect.com
RSF / RSMF Series
Packaging Specifications – Pana-Sert
Symbol
Description
ØD
Body diameter
A
Body length
A0
Mounting height
Ød
Lead diameter
P
Component pitch
P0
Feed hole pitch
P1
Feed hole center to lead
P2
Feed hole center to body
F
Lead-lead distance
Alpha
Performing angle
Δh
Component alignment
Δg
Component alignment
W
Tape width
W0
Hold down tape width
W1
Hole position
W2
Hold down tape position
PRSM12
0.157 max.
4.00 max.
0.394 max.
10.00 max.
0.571 max.
14.50 max.
0.028 ± 0.004
0.70 ± 0.10
PRSF1 / PRSM2
0.217 max.
5.50 max.
0.492 max.
12.50 max.
0.709 max.
18.00 max.
0.028 ± 0.004
0.70 ± 0.10
0.500
12.70
0.500
12.70
0.152
3.85
0.250
6.35
0.200
5.08
± 0.039
± 1.00
± 0.012
± 0.30
± 0.020
± 0.50
± 0.016
± 0.40
+0.24 / -0.008
+0.60 / -0.20
45° max
7
0.000
0.00
0.000
0.00
0.709
18.00
0.492
12.50
0.354
9.00
0.079
2.00
± 0.079
± 2.00
± 0.118
± 3.00
+0.039 / -0.031
+1.00 / -0.80
min.
min.
± 0.020
± 0.50
+0 / -0.059
+0 / -1.50
www.seielect.com
RSF / RSMF Series
Packaging Specifications – Pana-Sert (cont.)
Symbol
Description
PRSM12
H
Distance to tape center
H0
Lead wire clinch height
I
Lead wire portrait
ØD0
Feed hole diamenter
i
Total tape thickness
L
Length of shipped lead
PRSF1 / PRSM2
0.748
19.00
0.630
16.00
0.039
1.00
0.157
4.00
0.028
0.70
0.433
11.00
± 0.039
± 1.00
± 0.020
± 0.50
max.
max.
± 0.008
± 0.20
max.
max.
max.
max.
Pulse Limiting Power (one pulse) / RSMF Series ≤ 5Ω
10,000
Pulse Power (Watts)
1,000
1,300
1,300
1,300
560
440
215
560
440
215
560
440
215
560
270
190
100
95
250
135
84
42
110
66
37
48 RSMF3
32 RSMF2
16 RSMF1
18
10
8
RSMF12
1
1μ
10μ
100μ
1m
10m
100m
1
Pulse Width (sec.)
Pulse Limiting Power (one pulse) / RSMF Series ≥ 5Ω
Pulse Power (Watts)
10,000
1,500
1,000 1,000
700
400
1,500
1,000
700
400
1,500
1,000
700
400
800
420
300
150
100
300
180
115
56
130
76
43
21
48 RSMF3
32 RSMF2
16 RSMF1
10
8
RSMF12
1
1μ
10μ
100μ
1m
10m
100m
1
Pulse Width (sec.)
8
www.seielect.com
RSF / RSMF Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
RSF
Leaded Resistor
Axial
YES
RSMF
Mini-Metal Oxide Leaded Resistor
Axial
YES
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
99.3/0.7 Sn/Cu
100% Matte Sn
99.3/0.7 Sn/Cu
100% Matte Sn
Apr-05 (Japan)
Jan-04 (Taiwan, China)
Apr-05 (Japan)
Lead-Free
Effective Date
Code
(YY/WW)
05/14
04/01
05/14
04/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
R
S
F
1
2
J
T
R
4
7
Product Series
RSF
Metal Oxide
RSMF
Mini
(1)
Panasert
PRSF
PRSM(1) Panasert Mini
Power Rating
Size
W
12
0.5
1
1
2
2
3
3
5
5
Code
F
G
J
Tolerance
Tol
Value
1%
E96
2%
E24
5%
Code
Description
T
Tape and Reel
T
Tape and Reel
A
Ammo
B
Bulk
9
Packaging
Size
RSMF12, PRSM12
RSF12, RSF1
RSMF1, RSMF2
Resistance Value
Quantity
5000
2500
PRSF1, PRSM2
RSF2, RSMF3
RSF3, RSMF5
RSF5
RSMF12
RSF12; RSMF1, PRSM12
2000
1000
1000
500
5000
2000
RSF1, RSF2, RSMF2,
PRSF1, PRSM2, RSMF3
1000
RSF3, RSF5, RSMF5
All Sizes
500
1000
Four characters with
the multiplier used as
the decimal holder.
0.22 ohm = R220
33.2 ohm = 33R2
10.2 Kohm = 10K2
1 Mohm = 1M00
www.seielect.com
