RJ45 Modular Jack Connectors with Pulse Transformers
TM11RD - 5TANA Series
Pulse Transformer Circuit Diagram
Insulated transformer
Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Choke coil
TD+ 1
CT 3
TX- 2
RD+ 7
CT 6
RD- 8
1 TX+
2 TX3 RX+
4
5
6 RX7
8
4
GRAND 5
Circuit
PCB
■Features
RJ45
RJ11 (6 position) plug insertion prevention
1. Pulse Transformers Support FastEthernet
Equipped with built-in insulation transformers and
common mode choke coils, withstanding voltage of 1.5
kV and supporting 100Base-Tx and 10Base-T.
Outline of mating plug
2. Incorrect Plug Insertion Prevention Key
A built-in key offers protection against insertion of 6conductor type modular plug.
3. Built-in optical indicators
Optical indicators are integral part of the connectors,
saving space on the board.
There is no emission of any electrical noise.
4. EMI protection
Metal shield covers the outer surfaces of the connectors
assuring complete protection against electromagnetic
interference.
5. FCC standards
Meets requirements of FCC Title 47, Part 68, Subpart F.
6. Environmental considerations
Plating compounds are lead-free.
■Applications
Light pipe
Notebook PC's, telecommunication hubs, routers, bridges
and ATM transmission equipment, Ethernet switches and
networking equipment, office equipment, test and
measurement equipment.
* Light colors are determined by the color of LED's used.
2006.8
1
■Product Specifications
Connector
Pulse transformer
Item
1.Insertion resistance
2.Insulation resistance
Specification
-2dB min.
100M ohms min.
3.Withstanding voltage
No flashover or insulation breakdown.
4.Insertion resistance
-1dB min.
-20 dB max.
-16 dB max.
-12 dB max.
-10 dB max.
350μH min.
-40 dB max.
-35 dB max.
-30 dB max.
-30 dB max.
-20 dB max.
5.Return loss
Operating temperature range: -25ç to +80ç (Note)
Voltage rating 125V AC
Ratings
6.Inductance
7.Cross talk
(Reference)
8.Common mode rejection ratio
(Reference)
Conditions
1 to 65MHz
100V DC
Basic terminal between 123-45-768
500V AC / one minute
Primary (RJ45 side) to secondary (PCB side) 1500V AC / one minute
Terminal to shield
1 to 65MHz
1 to 10 MHz
10 to 30 MHz
30 to 60 MHz
60 to 80 MHz
0.1V, 100KHz, 8mADC
1 to 30 MHz
30 to 60 MHz
60 to 100 MHz
1 to 50 MHz
50 to 150 MHz
Note: Includes temperature rise caused by current flow.
■Materials
Material
Finish/Color
Remarks
Insulator
Component
PBT
Black
UL94V-0
Contacts
Copper alloy
Shield
Copper alloy
Contact area
: Gold plated
Termination area: Tin plated
Tin plated
Stainless
Incorrect insertion prevention key
Pulse transformer
Optical pipe
Polycarbonate
Clear
■Ordering information
1 Series name
2 Connector type
3 Direction of locking lever
TM11 R D - 5 T A NA - A - 8 8 - LP
1
2
2
3
4 5 6
7
8 9
10
4
5
6
7
8
9
10
(mating plug)
Jack suffix number
Transformer
Transformer type
Jack opening code
Number of inserted contacts
Optical pipe
UL94V--0
: TM11
R: Jack
D: Down
:5
T: With transformer
A: Transformer circuit type
NA-A: With built-in key
8: 8 contacts
8: 8 contacts
LP: With optical pipe inserted
Blank: Without optical pipe
■Modular Jack Connectors (With built-in optical pipe)
Contact No.1
21.3
3.18
3.56
Contact No.8
1.6
16
13.6
Contact No.1
Contact No.8
10.8
0.48
Part Number
CL No.
RoHS
TM11RD-5TANA-A-88-LP
CL222-2936-3
YES
BRecommended PCB mounting pattern
0.3
24.2
4 Suggested dimensions of LEDs
20.75MIN
11.43
10.75MAX
LED light emitting center
Printed board edge
7.4
Ø3.25
12.7
6.2
2.7MAX
7 5 3 1
8 6 4 2
3.2MAX
No conductive traces
1.5MAX
Ø1.63
5.55MIN
3.05
2.54
8-Ø0.9
1.27
LED center position
8.89
5
11.6
15.75
BPulse Transformer Circuit Diagram
1 TX+
TD+ 1
CT
3
TD-
2
2 TX-
1CT:1CT
RD+ 7
CT
3 RX+
6
RD- 8
4
CHS GROUND 5
1CT:1CT
75ø
75ø 75ø
0.001μF
75ø
Cable side
Board side
15.75
17.5
6 RX4
5
7
8
●Precautions
1
2
3
4
5
6
7
Hirose Electric did not check the compatibility with the PHY chip. When replacing other manufacturers jack it is recommended to verify the
compatibility with the actual equipment.
This connector is mounted on the board using wave or manual soldering. Do not use reflow soldering.
Recommended board thickness: 1.6mm
To assure correct operation of the indicator light pipes LED's must be installed directly on the PCB, within recommended dimensions and with light emitting
center in upward direction.
Mount the LED so that the center of the light emitting center aligns with the center point as dimensioned on the Recommended PCB mounting pattern above.
Verify the actual LED's mounting pattern with it's manufacturer, then add it to the PCB mounting pattern, assuring the correct placement of the center point.
IPA cleaning at room temperature is recommended for the cleaning of this product.
When an aqueous cleaning agent is to be used, there is a concern that the light pipe (made of polycarbonate resin) may change color; therefore, please
make a selection based on a table showing the effects on the resin.These tables are issued by the various manufacturers of cleaning agents.
3
■Modular Jack Connectors (Without built-in optical pipe)
Contact No.1
21.3
3.18
3.56
Contact No.8
1.6
16
13.6
Contact No.1
Contact No.8
0.48
10.8
0.3
Part Number
CL No.
RoHS
TM11RD-5TANA-A-88
CL222-2932-2
YES
20.75MIN
11.43
10.75MAX
Printed board edge
6.2
7.4
Ø3.25
2.54
5.55MIN
3.05
7 5 3 1
8 6 4 2
Ø1.63
8-Ø0.9
1.27
8.89
15.75
1 TX+
TD+ 1
CT
3
TD-
2
2 TX-
1CT:1CT
RD+ 7
CT
3 RX+
6
RD- 8
4
1CT:1CT
75ø
75ø 75ø
0.001μF
75ø
CHS GROUND 5
Cable side
Board side
15.75
17.5
6 RX4
5
7
8
●Precautions
1
Hirose Electric did not check the compatibility with the PHY chip. When replacing other manufacturers jacks it is
recommended to verify the compatibility with the actual equipment.
2
This connector is mounted on the board using wave or manual soldering.Do not use reflow soldering.
3
4
change color; therefore, please make a selection based on a table showing the effects on the resin.These tables are
4
■Technical Data
Measurement results of electrical characteristics
●Insertion Loss
Insertion Loss
Network analyzer
MHz
40
50
60
70
80
50
60
70
80
-0.8
-1
-1.2
-1.4
-1.6
-1.8
-2
Pulse transformer section
●Reflection Loss
Reflection
Network analyzer
MHz
40
-10
dB
-20
-30
-40
-50
-60
-70
-80
●Crosstalk (Reference)
Cross Talk
Network analyzer
40
MHz
50
60
70
80
90
100
-10
-20
dB
-30
-40
-50
-60
-70
-80
-90
-100
●Common Mode Rejection Ratio (Reference Value)
CMRR
Network analyzer
MHz
20 30 40 50 60 70 80 90 100 110 120 130 140 150
-10
-20
dB
dB
-0.4
-0.6
10
-30
-40
-50
-60
-70
-80
5
NOTES :
Powered by TCPDF (www.tcpdf.org)
USA:
HIROSE ELECTRIC(U.S.A.), INC.
2688 Westhills Court, Simi Valley, CA 93065-6235
Phone : 1 805 522 7958
Fax : 1 805 522 3217
http://www.hiroseusa.com
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Beechavenue 46,1119 PV
Schiphol-Rijk
Phone : 31 20 6557490
Fax : 31 20 6557469
http://www.hiroseeurope.com
UNITED KINGDOM:
KOREA:
HIROSE ELECTRIC UK LTD.
HIROSE KOREA CO., LTD.
Crownhill Business Centre 22 Vincent Avenue (#2NA311,Shihwa Industrial Complex),
Crownhill, Milton Keynes MK8 OAB
1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do
Phone : 44 1908 305400
Phone : 82 31 496 7000,7124
Fax : 44 1908 305401
Fax : 82 31 496 7100
http://www.hirose.co.uk
http://www.hirose.co.kr
CHINA:
HIROSE ELECTRIC TRADING(SHANGHAI) CO., LTD.
3705-6,Bund Center,222 Yan An Road(E),Shanghai 200002
Phone : 86 21 6335 2538
Fax : 86 21 6335 0767
http://www.hirose-china.com.cn
HONG KONG:
Unit 506, Energy Plaza. 92 Granville Road, Tsim Sha
Tsui East, Kowloon
Phone : 852 2803 5338
Fax : 852 2591 6560
http://www.hirose-hongkong.com.hk
SINGAPORE:
10 Anson Road #34-13 International Plaza 079903
Phone : 65 6324 6113
Fax : 65 6324 6123
http://www.hirose-singapore.com.sg
6
GERMANY:
HIROSE ELECTRIC GmbH
Herzog-Carl-Strasse 4 D-73760 Ostfildern
(Scharnhauser Park)
Phone : 49 711 4560 02 1
Fax : 49 711 4560 02 299
http://www.hirose.de
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
No.28 Lane 247 Sec. 2 Yen Ping N,Rd.Taipei
Phone : 886 2 2557 7351,7352
Fax : 886 2 2552 9851
http://www.hirose-taiwan.com.tw
5-23,OSAKI 5-CHOME,SHINAGAWA-KU,TOKYO 141-8587,JAPAN
PHONE: 81-3-3491-9741, FAX: 81-3-3493-2933
http://www.hirose.com
http://www.hirose-connectors.com
The contents of this catalog are current as of date of publication. Contents are subject to change without notice for the purpose of improvements.
