A63-113-331P4D2
A63-113-331P4D2
    插件
    CONN MAGJACK 1PORT 100 BASE-T
A63-113-331P4D2 数据手册
MAGNETIC JACK CONNECTORS (A60 SERIES) Cross Talk Insertion Loss CMRR Isolation PHY 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 2250 VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) PHY Side to Line Side Cross Talk Insertion Loss CMRR Isolation PHY 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 2250 VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) PHY Side to Line Side Cross Talk Insertion Loss CMRR Isolation PHY 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 2250 VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) PHY Side to Line Side Cross Talk Insertion Loss CMRR Hi-Pot Test 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 1500VAC or 2250VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) (P2,P3):(J1,J2) (P4,P5):(J3,J6) (P6,P7):(J4,J5) (P8,P9):(J7,J8) Cross Talk Insertion Loss CMRR Isolation PHY 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 2250 VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) PHY Side to Line Side Cross Talk Insertion Loss 1MHz-100MHz 1MHz-100MHz -30dB (Min) -1dB (Max) Return Loss 1MHz-40MHz -16dB (Min) 60MHz-80MHz -10dB (Min) CMRR 1MHz-100MHz -30dB (Min) Hi-Pot Test 1200 VAC (P1,P2):(J1,J2) (P3,P4):(J3,J6) (P5,P6):(J4,J5) (P7,P8):(J7,J8) Cross Talk Insertion Loss CMRR Hi-Pot Test 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 1500VAC or 2250VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) (P2,P3):(J1,J2) (P4,P5):(J3,J6) (P6,P7):(J4,J5) (P8,P9):(J7,J8) Cross Talk Insertion Loss CMRR Hi-Pot Test 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 1500VAC or 2250VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) (P2,P3):(J1,J2) (P4,P7):(J3,J6) (P5,P6):(J4,J5) (P8,P9):(J7,J8) Cross Talk Insertion Loss CMRR Hi-Pot Test 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 1500VAC or 2250VDC -30dB (Min) -1dB (Max) -16dB (Max) -10dB (Max) -30dB (Min) (P2,P3):(J1,J2) (P4,P5):(J3,J6) (P6,P7):(J4,J5) (P8,P9):(J7,J8) Cross Talk Insertion Loss CMRR Hi-Pot Test 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 1500VAC or 2250VDC -30dB (Max) -1dB (Max) -16dB (Max) -10dB (Max) -30dB (Min) (P1,P2):(J1,J2) (P3,P4):(J3,J6) (P7,P8):(J4,J5) (P9,P10):(J7,J8) Cross Talk Insertion Loss 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 2250 VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) PHY Side to Line Side CMRR Isolation PHY Cross Talk Insertion Loss CMRR Hi-Pot Test 1MHz-100MHz 1MHz-100MHz 1MHz-40MHz Return Loss 60MHz-80MHz 1MHz-100MHz 1500VAC or 2250VDC -30dB (Min) -1dB (Max) -16dB (Min) -10dB (Min) -30dB (Min) (P11,P10):(J1,J2) (P4,P5):(J3,J6) (P3,P2):(J4,J5) (P8,P9):(J7,J8) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-100MHz 1MHz-30MHz Return Loss -35dB (Typ) -1.2dB (Max) -18dB (Min) CMRR 60MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC or 2250VDC (P1,P2): (J1,J2) (P3,P6): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-100MHz 1MHz-30MHz Return Loss -35dB (Typ) -1.2dB (Max) -18dB (Min) CMRR 60MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC or 2250VDC (P5,P4): (J1,J2) (P1,P2): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-100MHz 1MHz-30MHz Return Loss -35dB (Typ) -1.2dB (Max) -18dB (Min) CMRR 60MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC or 2250VDC (P4,P3): (J1,J2) (P8,P7): (J3,J6) Cross Talk Insertion Loss CMRR Hi-Pot Test 1MHz-100MHz 0.1MHz-100MHz 1MHz-30MHz Return Loss 60MHz-80MHz 1MHz-100MHz 1500VAC or 2250VDC -35dB (Typ) -1.2dB (Max) -18dB (Min) -12dB (Min) -30dB (Typ) (P1,P2): (J1,J2) (P7,P8): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-100MHz 1MHz-30MHz Return Loss -35dB (Typ) -1.2dB (Max) -18dB (Min) CMRR 60MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC or 2250VDC (P1,P2): (J1,J2) (P3,P6): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-100MHz 1MHz-30MHz Return Loss -35dB (Typ) -1.2dB (Max) -18dB (Min) CMRR 60MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC or 2250VDC (P1,P2): (J1,J2) (P7,P8): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-80MHz 1MHz-30MHz Return Loss 30MHz-80MHz 30MHz-100MHz -35dB (Typ) -1.2dB (Max) -18dB (Min) -12dB (Min) -30dB (Typ) CMRR Hi-Pot Test 1500VAC (P1,P2): (J1,J2) (P7,P8): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-100MHz 1MHz-30MHz Return Loss -35dB (Typ) -1.2dB (Max) -18dB (Min) CMRR 60MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC or 2250VDC (P1,P2): (J1,J2) (P7,P8): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-100MHz 1MHz-30MHz Return Loss -35dB (Typ) -1.2dB (Max) -18dB (Min) CMRR 60MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC or 2250VDC (P1,P2): (J1,J2) (P7,P8): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-80MHz -35dB (Typ) -1.2dB (Max) Return Loss 1MHz-30MHz -18dB (Min) CMRR 30MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC (P1,P3): (J1,J2) (P4,P6): (J3,J6) Cross Talk Insertion Loss CMRR Hi-Pot Test 1MHz-100MHz 1MHz-100MHz 1MHz-30MHz Return Loss 60MHz-80MHz 1MHz-100MHz 1500VAC (2sec) -35dB (Typ) -1.2dB (Max) -18dB (Min) -12dB (Min) -30dB (Min) (P2,P3): (J1,J2) (P4,P5): (J3,J6) Cross Talk Insertion Loss 1MHz-100MHz 0.1MHz-80MHz 1MHz-30MHz Return Loss -35dB (Typ) -1.1dB (Max) -18dB (Min) CMRR 30MHz-80MHz 30MHz-100MHz -12dB (Min) -30dB (Typ) Hi-Pot Test 1500VAC or 2250VDC (P1,P2): (J1,J2) (P7,P8): (J3,J6) AMERICAS Phone: (416) 754-3322 Fax: (416) 754-3299 Email: customerservice@edac.net EUROPE Phone: +44 (0) 1933 427 300 Fax: +44 (0) 1933 677 611 Email: eu.enquiries@eu.edac.net ASIA Phone: 02- 8809-1480 Fax: 02- 8809-1460 Email: info@edac-tw.com FOR MORE INFORMATION www.edac.net ISSUE: MARCH 2016
A63-113-331P4D2 价格&库存
很抱歉,暂时无法提供与“A63-113-331P4D2”相匹配的价格&库存,您可以联系我们找货
A63-113-331P4D2
    • 1+92.26440
    • 180+36.81720
    • 480+35.58600
    • 1020+34.98120
