SERIES A6X
STANDARD RJ45 MAGNETIC JACKS
FEATURES:
10/100 or 1000 Base T options – Full IEEE 802.3 compliance
Integrated Magnetics – Provides signal integrity, DC isolation and
protection for PHY chip
Integrated Design - Reduces component inventory and process
costs
Spring fingers on shells - Guaranteed advanced EMI/RFI
suppression
LED options available - Visual indication of port status and activity
information for user
Tab Up or Down options - Complete design for board and unit
compatibility
Available as Single or Stacked Multiport Options
Mate with Modular Plug Conforming to FCC Part 68, Subpart F
Applications: Telecommunications, Broadcast, Data Products
RoHS Compliant
Specifications:
Housing Material
Contact Material
Contact Plating
Shield
Storage Temperature
Wave Soldering Process
Performance:
CAT5
CAT5e
CAT6a
Thermoplastic, UL 94V-0
Copper Alloy
Gold Plating on contact area and Tin Plating on tails with Nickel underplating all over
Copper Alloy with Nickel Plating
-40°C to +85°C
260°C ± 5°C, 5~10 Seconds
10/100 BASE-T
10/100/1000 BASE-T or Gigabit Ethernet
10 Gigabit Ethernet
Example Part Number:
SERIES:
A60 - 10/100/1000 BASE T, 8 CORE
A62 - 10/100 BASE T, 2 CORE
A63 - 10/100 BASE T, 4 CORE
A64 - 10/100 BASE T, 5 CORE
A65 - 10 BASE T, 3 CORE
A66 - 10 BASE T, 4 CORE
A67 - 10/100 BASE T, POE
A68 - 10/100 BASE T WITH USB TYPE A
A69 - 100/1000 BASE T WITH USB TYPE A
A70 - 100/1000 BASE T, POE
A60-142-200P431
NO. OF PORTS: 1 4
STACK SIZE
PORT PER STACK
11 - 1X1: 1 PORT, 21 - 2X1: 2 PORTS
12 - 1X2: 2 PORTS, 22 - 2X2: 4 PORTS
14 - 1X4: 4 PORTS, 24 - 2X4: 8 PORTS
18 - 1X8: 8 PORTS, 28 - 2X8: 16 PORTS
1A - 1+2USB: 1 PORT + 2 USB PORTS
1B - 1+2USB3.0: 1 PORT + 2 USB3.0 PORTS
CONTACT PLATING:
2 - GOLD FLASH
3 - 15 MICROINCHES OF GOLD
4 - 30 MICROINCHES OF GOLD
5 - 50 MICROINCHES OF GOLD
CONNECTOR TYPE:
2 - RIGHT ANGLE WITH TAB-UP
3 - RIGHT ANGLE WITH TAB-DOWN
4 - VERTICAL WITH TAB-UP
5 - VERTICAL WITH TAB-DOWN
6 - SMT WITH TAB-UP
7 - SMT WITH TAB-DOWN
8 - RIGHT ANGLE WITH TAB-UP AND PANEL STOP
9 - RIGHT ANGLE WITH TAB-DOWN AND PANEL STOP
A - VERTICAL WITH TAB-UP AND PANEL STOP
ELECTRICAL CIRCUIT TYPE:
(SEE CIRCUIT TYPE PAGE FOR DETAILS)
SHIELD TYPE:
0 - NO SHIELD
1 - SHIELDED, NO EMI FINGER
2 - SHIELDED, WITH EMI FINGER ON TOP
3 - SHIELDED, WITH EMI FINGER BOTH SIDES
4 - SHIELDED, WITH EMI FINGER ON THREE SIDES
5 - SHIELDED, WITH EMI FINGER ON FOUR SIDES
6 - SHIELDED, WITH EMI FINGER ON THREE SIDES, LED TAIL STAGGERED
7 - SHIELDED, WITH EMI FINGER ON THREE SIDES, 3 LEG TAIL LED
HOUSING MATERIAL:
P - PBT POLYESTER
N - NYLON POLYESTER
L - LCP
RIGHT LED COLOR:
0 - NO LED
1 - YELLOW
2 - RED
3 - GREEN
4 - ORANGE
5 - GREEN/YELLOW BI-COLOR
LEFT LED COLOR:
0 - NO LED
1 - YELLOW
2 - RED
3 - GREEN
4 - ORANGE
6
7
8
9
RED/GREEN BI-COLOR
GREEN/ORANGE BI-COLOR
RED/YELLOW BI-COLOR
ORANGE/YELLOW BI-COLOR
6
7
8
9
RED/GREEN BI-COLOR
RED/YELLOW BI-COLOR
*Please consult EDAC for the availability of the modular or magnetic jack if
the part no is created using this ordering guide.
www.edac.net
SERIES A6X
CONTACT EDAC FOR FURTHER INFORMATION ON VARIOUS OTHER CIRCUITS
70 TYPE
16 TYPE
CONNECTOR SOLDER SIDE
RJ45 CONTACT SIDE
RJ45 CONTACT SIDE
1CT:1CT
P1
J1
J4
0.1uF
75
P7
J5
P2
J2
J7
P8
1CT:1CT
J8
1CT : 1CT
TRANSMIT
P1
P3
J3
0.1uF
75
J1
P6
J6
P2
75 OHM
1CT:1CT
P4
J4
0.1uF
J2
P3
1CT : 1CT
RECEIVE
P4
75
P5
J3
J5
1CT:1CT
P5
P7
J7
0.1uF
75 OHM
75
J6
P6
P8
J8
1000 pF
2 Kv
NOTE:
100 BASE-T MAGNETICS
P9
1000pF
2 Kv
Shield
P10
Shield
NOTE:
GIGABIT ETHERNET (1000 BASE-T) MAGNETICS
P1 TYPE: POWER OVER ETHERNET
13 TYPE: POWER OVER ETHERNET
1CT:1CT
P2
J1
P5
PW-
P3
J2
PW+
1CT:1CT
P4
J3
75?
P8
P10
J6
J4
J5
J7
J8
P9
P6
P10
1000pF/2KV
P9
P8
75?
P7
J8
P6
J7
P5
J6 RXRX
P4
P1
J5
P3
4*22nF
J4
TX
P2
J3 RX+
P1
4*75 OHM
J2 TX-
RJ45 FRONT VIEW
P7
J1 TX+
NOTE:
NOTE:
CAP 1000pF 2KV
SHIELD
32 TYPE
RJ45 CONTACT SIDE
30 TYPE
P10
P1
CAP 0.1uF
J1
P5
1CT:1CT
P2
J1
75
J2
P3
J2
P9
ICT : ICT
P4
J3
1CT:1CT
P4
J3
75
J6
P8
ICT : ICT
J6
P5
P3
J4
1CT:1CT
P6
J4
75
J5
P7
J5
P7
ICT : ICT
P2
J7
1CT:1CT
P8
J7
75
J8
P6
ICT : ICT
J8
P9
1000pF
2 KV
P1
SHIELD
CAP 1000pF 2KV
P10
NOTE:
www.edac.net
NOTE:
很抱歉,暂时无法提供与“A60-113-271N414”相匹配的价格&库存,您可以联系我们找货
