TIC-L006-11
TIC-L006-11
    TAMURA
    CONN MAGJACK 1PORT 100 BASE-TX
TIC-L006-11 数据手册
Features: 1. Meets IEEE 802.3 and ANSI X3.263 2. Operating Temperature: 0 C ° to +85 C ° 3. 1500Vrms Isolation 4. Enhanced Common Mode Attenuation for maximum EMI Suppression 5. Full Product Qualification Tests 3D Package View S1 S2 S3 S4 Product Selection Schematic Identification # P/N 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Row X Port TIC-L003-11 TIC-L006-11 TIC-L007-11 TIC-L008-11 TIC-L002-11 TIC-L004-11 TIC-L009-11 TIC-L010-11 TIC-L011-11 TIC-L012-11 TIC-L001-11 TIC-L013-11 TIC-L014-11 TIC-L015-11 1x1 1x1 1x1 1x1 1x1 1x1 1x1 1x1 1x1 1x1 1X1 1x1 1x1 1x1 Package Style S1 S1 S1 S1 S1 S1 S2 S2 S3 S3 S3 S4 S4 S1 Auto Xfmr X X X X X X X X X Input Pins-out 1,3,2 1,2,3 1,3,2 7,6,8 1,4,2 1,3,2 1,2,3 1,4,2 1,3,2 1,4,2 7,6,8 1,3,2 1,4,2 1,3,2 7,8,6 4,5,6 7,6,8 1,3,2 3,5,6 7,6,8 4,5,6 3,7,6 7,6,8 3,7,6 3,2,4 7,6,8 3,7,6 7,6,8 Output Pins-out 1,4,5,2 1,4,5,2 1,4,5,2 3,7,8,6 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 3,4,5,6 1,4,5,2 1,4,5,2 1,2 3,7,8,6 3,7,8,6 3,7,8,6 1,4,5,2 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 1,7,8,2 3,7,8,6 3,7,8,6 3,6 RTN Turn Ratio TX Only SCH # Applications Base-TX Shd Shd Shd Shd 8 4,5 Shd Shd Shd Shd 1 Shd Shd No 1ct:1ct 1ct:1ct 1.25ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:2.5 1 2 1 3 5 6 2 4 1 4 7 1 4 8 10/100 10/100 10/100 10/100 10/100 10/100 10/100 10/100 10/100 10/100 10/100 10/100 10/100 10 base -T Package Identification Package # Package Style S1 S2 S3 S4 Size LWH Package Identification inches mm Single Port Single Port 0.850 x 0.625 x 0.530 0.850 x 0.625 x 0.530 21.60 x 15.88 x 13.45 21.60 x 15.88 x 13.45 Single Port Single Port 0.850 x 0.625 x 0.530 0.850 x 0.625 x 0.530 21.60 x 15.88 x 13.45 21.60 x 15.88 x 13.45 Plastic Mounting tap - Shield Mounting GND tap No Spring taps Plastic Mounting tap - Shield Mounting GND tap Shield Mounting GND tap - Plastic Mounting tap No Spring taps Shield Mounting GND tap - Plastic Mounting tap Package Information Weight Quantity weight /pcs (g) weight / carton ( kg ) quantity / tray ( pcs ) quantity / carton ( pcs ) 6.3 7.5 100 1000 1 Electrical Specification @ 25 °C Insertion Loss (dB Max) 1-100 MHz 1 Return Loss (dB Min) 1-30 MHz -18 60 MHz -16 80 MHz -12 CMRR (dB Min) Crosstalk (dB Min) OCL (µH Min) Hipot (Vrms) Impedance ( Ω) 1-100 MHz -35 1-100 MHz -35 8mA Dc Bias 350 1 minute 1500 100 Mechanical Material Specification Contact Shell Contact Finish Contact Material Phosphor Bronze 0.35 mm thick Contact Area Upper Contact Solder Tail Area Underpplating Contact Area Lower Contact Solder Tail Area Underplating Housing & Insert Gold Tin/Lead (9:1) Nickel Gold Tin/Lead (9:1) Nickel Thermoplastic Nylon 6T, Black 30 µ” Min. 100 µ” Min. 50 µ” Min. 100 µ” Min. 100 µ” Min. 50 µ” Min. UL 94V-0 - Front Stainless SUS 304 0.25 mm thick Product Qualification Tests Test # 1 Test Description Product Performanc e: Complete Electrical Test, Mechanical Measurements and Visual Inspection 2 Low Level Contact Resistance 3 Dielectric Strength 4 Insulation Resistance 5 6 Vibration Mechanical Shock 7 Durability (Repeated mating / unmating) 8 Solderability 9 Thermal Shock 10 Humidity Temperature Cycling Schematic 1 Schematic 2 TIC-L007-11 has turn ratio 1.25ct:1 ct on TX. 2 Back Stainless SUS 304 0.20 mm thick Schematic 3 Schematic 4 Schematic 5 Schematic 6 Schematic 7 Schematic 8 3 Package S1 Package S2 4 Package S3 Package S4 5
TIC-L006-11 价格&库存
很抱歉,暂时无法提供与“TIC-L006-11”相匹配的价格&库存,您可以联系我们找货
