TIC-L026-11
TIC-L026-11
    TAMURA
    CONN MAGJACK 2PORT 100 BASE-TX
TIC-L026-11 数据手册
3D Package View S3L2U Features: 1. Meets IEEE 802.3 and ANSI X3.263 2. Operating Temperature: 0 °C to +85 °C 3. 1500Vrms Isolation 4. Enhanced Common Mode Attenuation for maximum EMI Suppression 5. Full Product Qualification Tests 3D Package View S3U P/N # 1** 2** 3 4 5 6 7 TIC-L025 -11 TIC-L026 -11 TIC-L027 -11 TIC-L028 -11 TIC-L029 -11 TIC-L030 -11 TIC-L031 -11 S4U Row Pack age Style X Port 1x1 1x1 1x1 1x1 1x1 1x1 1x1 S3LU S3LU S3LU S4LU S3L2U S3U S4U S3LU S4LU Product Selection Schematic Identification Input Pins -out Auto Xfmr X X X X X X X 2,1,3 2,1,3 2,1,3 2,1,3 2,1,3 2,1,3 2,1,3 4,6,5 4,6,5 4,6,5 4,6,5 4,6,5 4,6,5 4,6,5 Output Pins -out 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 RTN Turn Ratio SCH # LED Yellow LED Green and/or Orange S hd Shd Shd Shd Shd Shd Shd 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 9L 9L 9L1 9L 9L1 10 10 7,8 7,8 7,8*** 7,8 7,8*** No No 9,10* 9,10* 9,10 9,10* 9,10 No No * Bi-directional LED's, green and orange. The single LED is green. **The difference between these parts is breakdown voltage capacitor. 2KV for TIC-L025-11 3KV for TIC-L026-11 ***LED on pins 7-8 is orange, on pins 9-10 is green. Package Identification Package # Package Style Size LWH Package Identification S3U Single Port inches 1.005 x 0.662 x 1.138 mm 25.53 x 16.81 x 28.91 S4U Single Port 1.005 x 0.662 x 1.138 25.53 x 16.81 x 28.91 S3L2U Single Port 1.005 x 0.662 x 1.138 25.53 x 16.81 x 28.91 S3LU Single Port 1.005 x 0.662 x 1.138 25.53 x 16.81 x 28.91 S4LU Single Port 1.005 x 0.662 x 1.138 25.53 x 16.81 x 28.91 1 6 Spring taps, 3 Pin-Rows, No LED Shield Mounting GND tap - USB Shell tap No Spring taps, 3 Pin-Rows, No LED Shield Mounting GND tap - USB Shell tap 2 Spring taps, 4 Pin-Rows, LED's Shield Mounting GND tap - USB Shell tap 6 Spring taps, 4 Pin-Rows, LED's Shield Mounting GND tap - USB Shell tap No Spring taps, 4 Pin-Rows, LED's Shield Mounting GND tap - USB Shell tap Package Information Weight weight /pcs (g) Quantity weight / carton ( kg ) 17.2 quantity / tray ( pcs ) 4.9 quantity / carton ( pcs ) 50 200 Electrical Specification @ 25 °C Return Loss (dB Min) Insertion Loss (dB Max) 1-100 MHz 1 1-30 MHz -18 60 MHz -16 80 MHz -12 CMRR (dB Min) Crosstalk (dB Min) OCL (m H Min) Hipot (Vrms) Impedance ( ) 1-100 MHz -35 1-100 MHz -35 8mA Dc Bias 350 1 minute 1500 100 Mechanical Material Specification Contact Shell Contact Finish Contact Material Contact Area Phosphor Bronze 0.35 mm thick Upper Contact Solder Tail Area Underpplating Contact Area Lower Contact Solder Tail Area Underplating Housing & Insert Gold Tin/Lead (9:1) Nickel Gold Tin/Lead (9:1) Nickel Thermoplastic Nylon 6T, Black Stainless SUS 304 30 µ” Min. 100 µ” Min. 50 µ” Min. 100 µ” Min. 100 µ” Min. 50 µ” Min. UL 94V-0 - 0.25 mm thick Product Qualification Tests Test # 1 Front Test Description Product Performance : Complete Electrical Test, Mechanical Measurements and Visual Inspection 2 Low Level Contact Resistance 3 Dielectric Strength 4 5 6 Insulation Resistance Vibration Mechanical Shock 7 8 Durability (Repeated mating / unmating) Solderability 9 10 Ther mal Shock Humidity Temperature Cycling 2 Back Stainless SUS 304 0.20 mm thick Schematic 9L Schematic 9L1 Schematic 10 3 Package S3U 4 Package S4U 5 Package S3L2U 6 Package S3LU 7 Package S4LU 8
TIC-L026-11 价格&库存
很抱歉,暂时无法提供与“TIC-L026-11”相匹配的价格&库存,您可以联系我们找货
