TIC-L033-11
TIC-L033-11
    TAMURA
    CONN MAGJACK 1PORT 100 BASE-TX
TIC-L033-11 数据手册
Features: 3D Package View 1. Meets IEEE 802.3 and ANSI X3.263 2. Operating Temperature: 0 °C to +85 °C S3L2 3. 1500Vrms Isolation 4. Enhanced Common Mode Attenuation for maximum EMI Suppression 5. Full Product Qualification Tests 3D Package View S1L S2L S3L S4L Product Selection Schematic Identification # P/N Row X Port Package Style 1 TIC-L033-11 1x1 S3L X 2,1,3 4,6,5 1,4,5,2 3,7,8,6 Shd 1ct:1ct 9L 7,8 LED Green and/or Orange 9,10* 2 3 4 5 TIC-L034-11 TIC-L035 -11 TIC- L036- 11 TIC-L037- 11 1x1 1x1 1x1 1x1 S4L S3L2 S2L S2L X X X X 2,1,3 2,1,3 1,3,2 1,3,2 4,6,5 4,6,5 7,6,8 7,6,8 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 9L 9L 6L 6L1 7,8 7,8 10,9 9,10 9,10* 9,10* 11,12* 11,12* 6 TIC-L040- 11 1x1 S2L X 1,3,2 7,6,8 1,4,5,2 3,7,8,6 Shd Shd 4,5 4,5, Shd 4,5, 1ct:1ct 6L3 11,12 7 8 TIC-L038-11 TIC-L039-11 1x1 1x1 S1L S1L X X 1,3,2 1,3,2 7,6,8 7,6,8 1,4,5,2 1,4,5,2 3,7,8,6 3,7,8,6 4,5 4,5, Shd 1ct:1ct 1ct:1ct 6L 3 6L4 11,12 11,12 Auto Xfmr Input Pins-out Output Pins-out RTN Turn Ratio TX Only SCH # LED Yellow 10,9 9,10 9,10 RCV turn ratio is 1ct:1ct * Bi-directional LEDs, green and orange. Single LED is green. Package Identification Package # Package Style Size LWH inches Package Identification mm S1L Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 6 Spring taps, 3 Pin -Rows Plastic Mounting tap - Shield Mounting GND tap S2L Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 No Spring taps, 3 P in-Rows Plastic Mounting tap - Shield Mounting GND tap S3L2 Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 2 Spring taps, 2 Pin -Rows Shield Mounting GND tap - Plastic Mounting tap S3L Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 6 Spring taps, 2 Pin -Rows Shield Mounting GND tap - Plastic Mounting tap S4L Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 No Spring taps, 2 Pin -Rows Shield Mounting GND tap - Plastic Mounting tap 1 of 8 5/19/03 Package Information qty/tray ( pcs ) 50 Quantity qty/box ( pcs ) 250 qty/carton ( pcs ) weight/pcs (g) Weight weight/box ( kg ) weight/carton ( kg ) box size ( cm ) Size carton size ( cm ) 1000 7.2 3.3 14.2 37.5x25.0x20.5 53.5x40.0x44.5 Electrical Specification @ 25 ° C Insertion Loss (dB Max) 1- 100 MHz 1 Return Loss (dB Min) 1-30 MHz -18 60 MHz -16 80 MHz -12 CMRR (dB Min) Crosstalk (dB Min) OCL (µH Min) Hipot (Vrms) Impedance ( Ω) 1-100 MHz -30 1-100 MHz -35 8mA Dc Bias 350 1 minute 1500 100 Mechanical Material Specification Contact RJ Contact Contact Material Phosphor Bronze 0.35 mm thick Plastic Part RJ Joint Contact and LED Contact Shell RJ Housing Set Housing & Insert Thermoplastic PA6T, Black Contact Area Solder Tail Area Underpplating Contact Material Solder Tail Area Underplating Gold Tin/Lead (9:1) Nickel Brass Tin/Lead (9:1) Nickel Thermoplastic PC Transparent 30 µ” Min. 100 µ” Min. 50 µ” Min. 0.35 mm thick 100 µ” Min. 50 µ” Min. UL 94V-0 UL 94V-0 E45587 E52579(M) General Electric Mitsui P.I. Grade: 940A Grade: CH230N Stainless SUS 304-1/2H 0.20 mm thick Product Qualification Tests Test # 1 Test Description Product Performanc e: Complete Electrical Test, Mechanical Measurements and Visual Inspection 2 Low Level Contact Resistance 3 Dielectric Strength 4 Insulation Resistance 5 6 Vibration Mechanical Shock 7 Durability (Repeated mating / unmating) 8 Solderability 9 Thermal Shock 10 Humidity Temperature Cycling 2 of 8 5/19/03 Schematic 6L Schematic 6L1 Schematic 6L4 Schematic 6L3 Schematic 9L 3 of 8 5/19/03 Package S1L 4 of 8 5/19/03 Package S2L 5 of 8 5/19/03 Package S3L 6 of 8 5/19/03 Package S3L2 7 of 8 5/19/03 Package S4L 8 of 8 5/19/03
TIC-L033-11
1. 物料型号:文档列出了多个型号,例如TIC-L033-11, TIC-L034-11, TIC-L035-11, TIC-L036-11, TIC-L037-11, TIC-L038-11, TIC-L039-11, 和 TIC-L040-11。
2. 器件简介:文档提到了符合IEEE 802.3和ANSI X3.263标准,工作温度范围为0°C至+85°C,具有1500Vrms隔离,增强的共模抑制以实现最大的电磁干扰抑制,以及完整的产品合格测试。
3. 引脚分配:文档提供了不同型号的引脚分配,例如S1L, S2L, S3L, S3L2, 和 S4L,每个型号都有其特定的输入输出引脚配置。
4. 参数特性:包括了电气规格,如差分增益和相位不平衡、共模抑制比、插入损耗、回波损耗、串扰等。
5. 功能详解:文档中提到了增强的共模抑制和电磁干扰抑制功能,以及产品通过的全面测试。
6. 应用信息:虽然没有直接提到应用信息,但从电气规格和特性可以推断这些器件可能用于高速通信或数据传输领域。
7. 封装信息:文档提供了不同封装的尺寸、重量、包装信息,以及材料规格,如塑料部件、接触材料、机械材料等。
TIC-L033-11 价格&库存
很抱歉,暂时无法提供与“TIC-L033-11”相匹配的价格&库存,您可以联系我们找货
TIC-L033-11
    • 50+24.7151450+3.19757
