TIC-L021-24
TIC-L021-24
    TAMURA
    CONN MAGJACK 8PORT 100 BASE-TX
TIC-L021-24 数据手册
3D Package View Features: 1. Meets IEEE 802.3 and ANSI X3.263 2. Operating Temperature: 0 °C to +85 °C 3. 1500Vrms Isolation 4. Enhanced Common Mode Attenuation for maximum EMI Suppression 5. Full Product Qualification Tests # P/N Row X Port Pack age Style 24S3 24S3L Product Selection Schematic Identification Auto Xfmr Output Pins -out Input Pins -out RTN Turn Ratio TX Only SCH # 1 TIC-L020 -24 2x4 24S3L X 7,6,8 3,5,4 3,7,8,6 1,4,5,2 S hd 1ct:1ct 13L 2 3 4 5 TIC-L021 -24 TIC-L022 -24 TIC-L023 -24 TIC-L024 -24 2x4 2x4 2x4 2x4 24S3 24S3 24S3 24S3 X X 7,6,8 3,7,6 1,4,2 3,7,6 1,3,2 1,4,2 3,7,6 1,4,2 3,7,8,6 3,7,8,6 1,4,5,2 3,7,8,6 1,4,5,2 1,4,5,2 3,7,8,6 1,4,5,2 Shd Shd Shd Shd 1ct:1ct 1ct:1ct 1ct:1ct 1.25ct:1ct 3 14 15 16 LED Or Gr 2,1 9,10 10,9 1,2 No No No No No No Package Identification Package # Package Style 24S3 24S3L Size LWH Package Identification 2 x 4 Port inches 2.330 x 1.118 x 0.981 mm 59.18 x 28.40 x 24.93 2 x 4 Port 2.330 x 1.118 x 0.981 59.18 x 28.40 x 24.93 10 Spring taps, Double stack, 8 pins each, no LED Shield Mounting GND tap - Plastic Mounting tap 10 Spring taps, Double stack, 10 pins each, LED's Shield Mounting GND tap - Plastic Mounting tap Electrical Specification @ 25 °C Insertion Loss (dB Max) 1-100 MHz 1 Return Loss (dB Min) 1-30 MHz -18 60 MHz -16 80 MHz -12 CMRR (dB Min) Crosstalk (dB Min) 1-100 MHz -35 1-100 MHz -35 Test # 1 Quantity weight /pcs weight / carton quantity / tray quantity / carton (g) ( kg ) ( pcs ) ( pcs ) 46.8 5.2 20 Hipot (Vrms) Impedance ( ) 8mA Dc Bias 350 1 minute 1500 100 Product Qualification Tests Package Information Weight OCL (m H Min) 80 1 Test Description Product Performance : Complete Electrical Test, Mechanical Measurements and Visual Inspection 2 Low Level Contact Resistance 3 Dielectric Strength 4 5 6 Insulation Resistance Vibration Mechanical Shock 7 8 Durability (Repeated mating / unmating) Solderability 9 10 Ther mal Shock Humidity Temperature Cycling Mechanical Material Specification Contact Shell Contact Finish Contact Material Phosphor Bronze 0.35 mm thick Contact Area Upper Contact Solder Tail Area Underpplating Contact Area Lower Contact Solder Tail Area Underplating Housing & Insert Front Gold Tin/Lead (9:1) Nickel Gold Tin/Lead (9:1) Nickel Thermoplastic Nylon 6T, Black Stainless SUS 304 30 µ” Min. 100 µ” Min. 50 µ” Min. 100 µ” Min. 100 µ” Min. 50 µ” Min. UL 94V-0 - 0.25 mm thick 2 Back Stainless SUS 304 0.20 mm thick 3 4
TIC-L021-24 价格&库存
很抱歉,暂时无法提供与“TIC-L021-24”相匹配的价格&库存,您可以联系我们找货
