PNP4WVJR-73-120R
PNP4WVJR-73-120R
    YAGEO(国巨)
    AXIAL-D6.2X17.5MM
    插件电阻 - 120Ω ±5% 4W -
PNP4WVJR-73-120R 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET WIREWOUND RESISTORS High Power PNP V Series ±1%, ±2%, ±5% 1W to 7W Product specification – August 16, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors WireWound Resistors Product Specification ORDERING INFORMATION Part number of the power wire wound resistor is identified by the series, power rating, tolerance, packing, temperature coefficient, forming and resistance value. PART NUMBER APPLICATIONS  Power applications PNP 3WV J T - 73- (1) (2) (3) (4) (5) (6) 100R (7) (1) SERIES PNP Series  Home appliance  Industry (2) POWER RATING FEATURES  Wide resistance range  High stable performance and high reliability 1WV = 1W 5WV = 5W 3WV = 3W 5SV = 5W 4WV = 4W 7WV = 7W (3) TOLERANCE F = ±1% J = ±5% G = ±2%  Flameproof coating equivalent to UL-94V-0  RoHS compliant & halogen free (4) PACKAGING R = Reel Pack B = Bulk T = Box Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE F=±100ppm/°C - = Based on spec. (6) FORMING 52- = 52.4mm 91- = 91mm 73- = 73mm (7) RESISTANCE VALUE E24 & E96 Series Example: 0R1= 0.1Ω, 100R= 100Ω, 1K = 1,000Ω www.yageo.com Aug. 16, 2021 V.0 2 12 PNP V Through Hole Resistors Product Specification WireWound Resistors PNP V DIMENSIONS Unit: mm Normal L ψD H ψd PNP1WV 10.0± 1.0 4.3 ± 0.5 26 ± 2.0 0.8 ± 0.05 PNP3WV 13.0± 1.0 5.5 ± 0.5 34 ± 2.0 0.8 ± 0.05 PNP4WV 17.5± 1.0 6.2 ± 0.5 32 ± 2.0 0.8 ± 0.05 PNP5SV 17.5± 1.0 6.2 ± 0.5 32 ± 2.0 0.8 ± 0.05 PNP5WV 17.0± 1.0 7.5 ± 0.5 32 ± 2.0 0.8 ± 0.05 PNP7WV 25.0± 1.0 7.5 ± 0.5 38 ± 2.0 0.8 ± 0.05 DERATING CURVE PNP1WV ~ PNP3WV Rated Power (%) 100 80 60 40 36 20 70 200 275 200 275 Ambient Temperature (°C) PNP4WV ~ PNP7WV Rated Power (%) 100 80 60 40 31 20 40 Ambient Temperature (°C) www.yageo.com Aug. 16, 2021 V.0 3 12 Through Hole Resistors WireWound Resistors Product Specification PNP V ELECTRICAL CHARACTERISTICS CHARACTERISTICS PNP1WV PNP3WV Power Rating at 40 °C PNP4WV PNP5SV PNP5WV PNP7WV 4W 5W 5W 7W Power Rating at 70 °C 1W 3W Resistance Range(±1%) 0.1Ω 1KΩ 0.1Ω 2.8KΩ 0.1Ω 4.3KΩ 0.1Ω 5.1KΩ 0.1Ω 8.2KΩ 0.1Ω 10KΩ Resistance Range(±2% & ±5%) 0.047Ω 1KΩ 0.047Ω 2.8KΩ 0.047Ω 4.3KΩ 0.047Ω 4.3KΩ 0.047Ω 6.8KΩ 0.1Ω 6KΩ Voltage Proof on Insulation 300V 300V 300V 300V 300V 300V Maximum working voltage √(P X R) Operating Temp. Range - 40°C to +200°C Temperature Coefficient ±100ppm/°C, ±300ppm/°C Note: For resistance value out of above range is by request. TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 10 times rated power for 5 sec. ±2%+0.05Ω Voltage Proof on IEC 60115-1 4.7 In V-Block for 60 sec. test voltage as No Breakdown Insulation PROCEDURE APPRAISE above table Temperature Coefficient IEC 60115-1 4.8 Between -40°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >100MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Damp Heat Steady State Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19  -55°C  Room Temp.  ±1.0%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat 260±3°C for 10±1 Sec., immersed to a ±1.0 %+0.05Ω point 3±0.5mm from the body Accidental Overload Test IEC 60115-1 4.26 4 times RCWV for 1 Min. No evidence of flaming or arcing www.yageo.com Aug. 16, 2021 V.0 4 12 Through Hole Resistors WireWound Resistors Product Specification PNP V Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) PULSE DIAGRAMS PNP3WV Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 16, 2021 V.0 5 12 Through Hole Resistors WireWound Resistors Product Specification PNP V PNP5WV Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time PNP7WV Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 16, 2021 V.0 6 12 Through Hole Resistors Product Specification WireWound Resistors PNP V AXIAL / REEL TAPE SPECIFICATION Unit: mm Normal a A B1-B2 (Max.) S (spacing) PNP1WV 6 ± 0.5 52.4 ± 1.5 1.2 10 73.0 ± 1.5 1.5 PNP3WV 6 ± 0.5 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 91.0 ± 1.5 1.5 PNP4WV 10 6 ± 0.5 PNP5WV 6 ± 0.5 1 mm per 10 spacing, 0.5 mm per 5 spacing 10 6 ± 0.5 PNP7WV T (max. deviation of spacing) 10 6 ± 0.5 PNP5SV 10 10 www.yageo.com Aug. 16, 2021 V.0 7 12 Through Hole Resistors WireWound Resistors Product Specification PNP V TAPE ON REEL PACKING TYPE Unit: mm/piece Normal Across Flange(A) B Quantity Per Reel PNP1WV 66.5 75.5 2,500 PNP3WV 66.5 75.5 1,000 PNP4WV 87 96 1,000 PNP5SV 87 96 1,000 PNP5WV 87 96 500 www.yageo.com Aug. 16, 2021 V.0 8 12 Through Hole Resistors WireWound Resistors Product Specification PNP V TAPE ON BOX PACKING TYPE DIMENTIONS Normal A B C Quantity Per Box PNP1WV 73 45 258 1,000 PNP3WV 103 94 260 1,000 PNP4WV 103 94 260 1,000 PNP5SV 103 78 260 500 PNP5WV 103 94 260 250 PNP7WV 115 70 263 250 Unit: mm/piece BULK PACKING Normal Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag PNP1WV 5,000 5 1,000 PNP3WV 1,000 2 500 PNP4WV 1,000 2 500 PNP5SV 1,000 2 500 PNP5WV 500 10 50 PNP7WV 500 10 50 www.yageo.com Aug. 16, 2021 V.0 9 12 Through Hole Resistors Product Specification WireWound Resistors 12 PNP V MARKING 5-BAND-CODE ±2%, ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 2nd BAND 3rd BAND MULTIPLIER 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω TOLERANCE SPECIAL CODE ± 1%(F) ± 2%(G) PNP V Series ± 5%(J) ±1% 6-BAND-CODE www.yageo.com Aug. 16, 2021 V.0 10 Through Hole Resistors WireWound Resistors Product Specification 12 PNP V REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 16, 2021 V.0 11 Through Hole Resistors WireWound Resistors Product Specification 12 PNP V LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 16, 2021 V.0 12
PNP4WVJR-73-120R 价格&库存
很抱歉,暂时无法提供与“PNP4WVJR-73-120R”相匹配的价格&库存,您可以联系我们找货
PNP4WVJR-73-120R
  • 5000+1.571555000+0.20342
