SMJ001-S88N-DS-11
SMJ001-S88N-DS-11
    SULLINS
    1 Port RJ45 Magjack Connector Through Hole 10/100/1000 Base-T, AutoMDIX
SMJ001-S88N-DS-11 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2406 INITIAL RELEASE 07/27/2011 GC F F 17.24±0.30 [.678 .012] E E 4.46 [.175] 1.27 .050 0.70 .028 2.54 .100 13.68 [.538] 0.75 [.029] D 12.91±0.20 [.507 .008] D 19.70 [.774] +.004 +0.10 24.16 [.949 - .008 ] - 0.20 +.024 +0.60 21.34 [.839 .000 ] 0.00 17.30±0.10 [.680 .004] 7.112 [.2800] 12.46 [.490] 1.016 .0400 JACK 8 7 6 5 4 3 2 1 SIDE 14.95 [.588] R0.40 .016 2.40 .094 24.70 [.971] 10.60±0.20 .417±.008 C C +.016 +0.40 13.0 [.51 .000 ] 0.00 3.23 .127 3.25 [.128] 3.25 [.128] 11 5.85 .230 11.30±0.10 [.444 .004] 9 7 5 3 1 10 8 6 4 2 3.35 [.132] 0.508 .0200 1.27 .050 8.07 [.317] 0.40 .016 2.92 [.115] 1.20 .047 6.35 .250 16.21 [.637] 13.74±0.20 [.540 .008] RECOMMENDED PCB LAYOUT PCB TOLERANCE:±0.05 [.002] DRAWN Pb A UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] TOLERANCES: .X= 0.25 [.01] .XX= 0.15 [.006] .XXX= 0.10 [.0040] RoHS COMPLIANT 7 B 17.24 [.678] 15.01±0.20 [.590 .008] 8 3.65 [.143] 6.68 .263 12.20 [.479] 7.03±0.20 [.276 .008] 5.85 .230 5.00 .197 6.35 .250 2.30±0.20 [.090 .008] 2.60 [.102] B 3.25 .128 6 5 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 DATE NAME 07/27/2011 GC THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE GIGABIT MODULAR JACK DIP TYPE PART NUMBER SIZE C CAGE CODE 54453 SCALE: 2:1 3 2 SMJ001-S88N-DS-11 DWG. NO. REV A 11817 SHEET 1 OF 2 1 FILE NAME: D:\Gina Work Fold\ECO2406_20110720\ECO 2406 gina to fix per markup 8-9-2011\11817, SMJ001-S88N-DS-11 PRINT: 8/9/2011 A 8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2406 INITIAL RELEASE 07/27/2011 GC F F NOTES: 1. MATERIAL: HOUSING: PA46 TS250F6D 9B0040 UL94V-0 OVERMOLD: LIQUID CRYSTAL POLYMER GLASS FILLED UL94V-0 COIL BOX: LIQUID CRYSTAL POLYMER GLASS FILLED UL94V-0 TERMINAL: COPPER ALLOY, .000039" MIN NICKEL UNDERPLATE, .000050" MIN GOLD ON CONTACT SURFACE, .000039" MIN TIN ON TERMINATION. TAIL: C2680 R-H, .000039" MIN NICKEL UNDERPLATE, .000039" MIN TIN ON TERMINATION. SHELL: C2680 R-H, .000039" MIN NICKEL UNDERPLATE, .000039" MIN TIN ON TERMINATION. 2. MAGNETICS: IMPEDANCE: 100 OHMS TRANSMIT OPEN CIRCUIT INDUCTANCE: 350uH MINIMUM @100kHz TURNS RATIO(BOARD:CABLE): TX 1:1 RX 1:1 TRANSMIT BIDIRECTIONAL ALL 4 PAIRS RECIEVE BIDIRECTIONAL ALL 4 PAIRS. E E PCB SIDE DIELECTRIC:CUT OFF CURRENT 1mA MAXIMUM IN 2250 VDC or 1500 VAC/ 1 MINUTE TEST ITEM D 1 Insertion Loss FREQUENCY 1~125MHz 0.1~30MHz 2 3 4 C 5 Return Loss Common Mode to Common Mode Rejection Common Mode to Differential Mode Conversion Near End Cross-Talk 1 Vcc +1.9V SPECIFICATION REQUIREMENT 30~60MHz 60~100MHz 2~20MHz 20~200MHz 2~15MHz 16~200MHz 10-20*LOG10(f MHz/60) dB MINIMUM 35 dB MINIMUN 15-20*LOG10(f MHz/200) dB MINIMUM 24 dB MINIMUM 2 DATA1- R=75Ω C=0.1μF C=0.1μF 7 DATA3+ 4 DATA3+ R=75Ω 8 DATA3- 40 dB MINIMUN 15-20*LOG10(f MHz/200) dB MINIMUM D 3 DATA2+ 5 DATA26 GND 10 dB MINIMUM 16~100MHz R=75Ω 4 DATA2+ 16 dB MINIMUM 35 dB MINIMUM 1 DATA1+ 3 DATA1- 0.2+0.002*(f MHz)^1.4 dB MAXIMUM 1~15MHz C=0.01μF 2 DATA1+ 1.2 dB MAXIMUM 100KHz JACK SIDE 5 DATA36 DATA27 DATA4+ 9 DATA4+ R=75Ω 10 DATA4- C=0.01μF C 8 DATA4- C=1000pF (2kV) 11 Vcc +1.9V B B DRAWN Pb A UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] TOLERANCES: .X= 0.25 [.01] .XX= 0.15 [.006] .XXX= 0.10 [.0040] RoHS COMPLIANT 8 7 6 5 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 DATE NAME 07/27/2011 GC THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE GIGABIT MODULAR JACK DIP TYPE PART NUMBER SIZE C 3 CAGE CODE 54453 SMJ001-S88N-DS-11 DWG. NO. 11817 SCALE: 2:1 SHEET 2 OF 2 2 1 REV A FILE NAME: D:\Gina Work Fold\ECO2406_20110720\ECO 2406 gina to fix per markup 8-9-2011\11817, SMJ001-S88N-DS-11 PRINT: 8/9/2011 A
SMJ001-S88N-DS-11 价格&库存
很抱歉,暂时无法提供与“SMJ001-S88N-DS-11”相匹配的价格&库存,您可以联系我们找货
